[PATCH v2 0/6] Remove References to bsp_specs
Tue Nov 21 23:07:00 UTC 2017
Hi
bsp_specs is a GCC specific file that is not only used when
interacting with GCC. It is also used by the build system
when identifying BSP directories.
This patch eliminates all references to bsp_specs of this type.
sb-bootstrap also does this and there will be a separate patch.
The remaining references to bsp_specs in the source tree are
related to invoking GCC and will have to be addressed
separately.
--joel
Joel Sherrill (6):
  libbsp/*/*/configure.ac: Remove references to bsp_specs in
    AC_CONFIG_SRCDIR
  powerpc/ss555/startup/linkcmds: Remove obsolete reference to bsp_specs
  ampolish3: Remove reference to bsp_specs in comment
  gumstix/bsp_specs: Correct permissions
  bootstrap: Remove reference to bsp_specs in determining BSP
    directories
  aclocal/check-bsps.m4: Do not rely on bsp_specs to find BSP families
 aclocal/check-bsps.m4                                  | 6 +++---
 ampolish3                                              | 2 +-
 bootstrap                                              | 2 +-
 c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac     | 2 +-
 c/src/lib/libbsp/arm/atsam/configure.ac                | 2 +-
 c/src/lib/libbsp/arm/beagle/configure.ac               | 2 +-
 c/src/lib/libbsp/arm/csb336/configure.ac               | 2 +-
 c/src/lib/libbsp/arm/csb337/configure.ac               | 2 +-
 c/src/lib/libbsp/arm/edb7312/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/gdbarmsim/configure.ac            | 2 +-
 c/src/lib/libbsp/arm/gumstix/bsp_specs                 | 0
 c/src/lib/libbsp/arm/gumstix/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/imx/configure.ac                  | 2 +-
 c/src/lib/libbsp/arm/lm3s69xx/configure.ac             | 2 +-
 c/src/lib/libbsp/arm/lpc176x/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/lpc24xx/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/lpc32xx/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/raspberrypi/configure.ac          | 2 +-
 c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac      | 2 +-
 c/src/lib/libbsp/arm/rtl22xx/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/smdk2410/configure.ac             | 2 +-
 c/src/lib/libbsp/arm/stm32f4/configure.ac              | 2 +-
 c/src/lib/libbsp/arm/tms570/configure.ac               | 2 +-
 c/src/lib/libbsp/arm/xilinx-zynq/configure.ac          | 2 +-
 c/src/lib/libbsp/bfin/TLL6527M/configure.ac            | 2 +-
 c/src/lib/libbsp/bfin/bf537Stamp/configure.ac          | 2 +-
 c/src/lib/libbsp/bfin/eZKit533/configure.ac            | 2 +-
 c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac    | 2 +-
 c/src/lib/libbsp/i386/pc386/configure.ac               | 2 +-
 c/src/lib/libbsp/lm32/lm32_evr/configure.ac            | 2 +-
 c/src/lib/libbsp/lm32/milkymist/configure.ac           | 2 +-
 c/src/lib/libbsp/m32c/m32cbsp/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/av5282/configure.ac              | 2 +-
 c/src/lib/libbsp/m68k/csb360/configure.ac              | 2 +-
 c/src/lib/libbsp/m68k/gen68340/configure.ac            | 2 +-
 c/src/lib/libbsp/m68k/gen68360/configure.ac            | 2 +-
 c/src/lib/libbsp/m68k/genmcf548x/configure.ac          | 2 +-
 c/src/lib/libbsp/m68k/mcf5206elite/configure.ac        | 2 +-
 c/src/lib/libbsp/m68k/mcf52235/configure.ac            | 2 +-
 c/src/lib/libbsp/m68k/mcf5225x/configure.ac            | 2 +-
 c/src/lib/libbsp/m68k/mcf5235/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/mcf5329/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/mrm332/configure.ac              | 2 +-
 c/src/lib/libbsp/m68k/mvme147/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/mvme147s/configure.ac            | 2 +-
 c/src/lib/libbsp/m68k/mvme162/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/mvme167/configure.ac             | 2 +-
 c/src/lib/libbsp/m68k/uC5282/configure.ac              | 2 +-
 c/src/lib/libbsp/mips/csb350/configure.ac              | 2 +-
 c/src/lib/libbsp/mips/hurricane/configure.ac           | 2 +-
 c/src/lib/libbsp/mips/jmr3904/configure.ac             | 2 +-
 c/src/lib/libbsp/mips/malta/configure.ac               | 2 +-
 c/src/lib/libbsp/mips/rbtx4925/configure.ac            | 2 +-
 c/src/lib/libbsp/mips/rbtx4938/configure.ac            | 2 +-
 c/src/lib/libbsp/moxie/moxiesim/configure.ac           | 2 +-
 c/src/lib/libbsp/nios2/nios2_iss/configure.ac          | 2 +-
 c/src/lib/libbsp/no_cpu/no_bsp/configure.ac            | 2 +-
 c/src/lib/libbsp/or1k/generic_or1k/configure.ac        | 2 +-
 c/src/lib/libbsp/powerpc/beatnik/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/gen5200/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/gen83xx/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/haleakala/configure.ac        | 2 +-
 c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac | 2 +-
 c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac       | 2 +-
 c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac       | 2 +-
 c/src/lib/libbsp/powerpc/mvme3100/configure.ac         | 2 +-
 c/src/lib/libbsp/powerpc/mvme5500/configure.ac         | 2 +-
 c/src/lib/libbsp/powerpc/psim/configure.ac             | 2 +-
 c/src/lib/libbsp/powerpc/qemuppc/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/qoriq/configure.ac            | 2 +-
 c/src/lib/libbsp/powerpc/ss555/configure.ac            | 2 +-
 c/src/lib/libbsp/powerpc/ss555/startup/linkcmds        | 4 ----
 c/src/lib/libbsp/powerpc/t32mppc/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/tqm8xx/configure.ac           | 2 +-
 c/src/lib/libbsp/powerpc/virtex/configure.ac           | 2 +-
 c/src/lib/libbsp/powerpc/virtex4/configure.ac          | 2 +-
 c/src/lib/libbsp/powerpc/virtex5/configure.ac          | 2 +-
 c/src/lib/libbsp/riscv/riscv_generic/configure.ac      | 2 +-
 c/src/lib/libbsp/sh/gensh1/configure.ac                | 2 +-
 c/src/lib/libbsp/sh/gensh2/configure.ac                | 2 +-
 c/src/lib/libbsp/sh/gensh4/configure.ac                | 2 +-
 c/src/lib/libbsp/sh/shsim/configure.ac                 | 2 +-
 c/src/lib/libbsp/sparc/erc32/configure.ac              | 2 +-
 c/src/lib/libbsp/sparc/leon2/configure.ac              | 2 +-
 c/src/lib/libbsp/sparc/leon3/configure.ac              | 2 +-
 c/src/lib/libbsp/sparc64/niagara/configure.ac          | 2 +-
 c/src/lib/libbsp/sparc64/usiii/configure.ac            | 2 +-
 c/src/lib/libbsp/v850/gdbv850sim/configure.ac          | 2 +-
 88 files changed, 88 insertions(+), 92 deletions(-)
 mode change 100755 => 100644 c/src/lib/libbsp/arm/gumstix/bsp_specs
1.8.3.1
