[PATCH] source-builder/sb/bootstrap.py: Do not reference bsp_specs to find BSPs
Joel Sherrill
joel at rtems.org
Wed Nov 22 21:45:18 UTC 2017
On Wed, Nov 22, 2017 at 3:38 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 23/11/2017 02:33, Joel Sherrill wrote:
> > Updates #3520.
> > source-builder/sb/bootstrap.py | 13 +++++++++++--
> > 1 file changed, 11 insertions(+), 2 deletions(-)
> > diff --git a/source-builder/sb/bootstrap.py
> b/source-builder/sb/bootstrap.py
> > index 9095f3c..8fda3b8 100644
> > --- a/source-builder/sb/bootstrap.py
> > +++ b/source-builder/sb/bootstrap.py
> > @@ -34,6 +34,14 @@ import options
> > import path
> > import version
> > +def _collect_dirs(path_, dir):
> > + confs = []
> > + for root, dirs, files in os.walk(path.host(path_), topdown = True):
> > + for f in dirs:
> > + if f == dir:
> > + confs += [path.shell(path.join(root, f))]
> > + return confs
> > def _collect(path_, file):
> > confs = []
> > @@ -130,7 +138,7 @@ class autoreconf:
> > def bspopts(self):
> > if _grep(self.configure, 'RTEMS_CHECK_BSPDIR'):
> > - bsp_specs = _collect(self.cwd, 'bsp_specs')
> > + bsps = _collect_dirs(self.cwd, 'custom')
> > try:
> > acinclude = path.join(self.cwd, 'acinclude.m4')
> > b = open(path.host(acinclude), 'w')
> > @@ -138,8 +146,9 @@ class autoreconf:
> > b.write('AC_DEFUN([RTEMS_CHECK_BSPDIR],' + os.linesep)
> > b.write('[' + os.linesep)
> > b.write(' case "$1" in' + os.linesep)
> > - for bs in sorted(bsp_specs):
> > + for bs in sorted(bsps):
> > dir = path.dirname(bs)[len(self.cwd) + 1:]
> > + dir = os.path.dirname(dir)
> I think this should be the wrapped `path` call `path.dirname()`.
OK. That works and is now pushed.
I am just glad I didn't get a complete failing grade on my first Python
patch. :)
Any comments on the patches to the autotools infrastructure? Nibbling on
bsp_specs
--joel
> Chris
> > b.write(' %s )%s' % (dir, os.linesep))
> > b.write(' AC_CONFIG_SUBDIRS([%s]);;%s' % (dir,
> os.linesep))
> > b.write(' *)' + os.linesep)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171122/f09d7983/attachment.html>
