[PATCH 4/5] bsps: Remove empty tm27.h variants
Fri Nov 24 12:52:23 UTC 2017
Update #3254.
 c/src/lib/libbsp/arm/gumstix/Makefile.am           |  2 +-
 c/src/lib/libbsp/arm/gumstix/include/tm27.h        | 48 -----------------
 c/src/lib/libbsp/arm/gumstix/preinstall.am         |  2 +-
 c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am |  2 +-
 .../libbsp/epiphany/epiphany_sim/include/tm27.h    | 62 ----------------------
 .../lib/libbsp/epiphany/epiphany_sim/preinstall.am |  2 +-
 .../lib/libbsp/riscv/riscv_generic/include/tm27.h  | 53 ------------------
 c/src/lib/libbsp/sparc64/niagara/Makefile.am       |  2 +-
 c/src/lib/libbsp/sparc64/niagara/include/tm27.h    | 34 ------------
 c/src/lib/libbsp/sparc64/niagara/preinstall.am     |  2 +-
 c/src/lib/libbsp/sparc64/usiii/Makefile.am         |  2 +-
 c/src/lib/libbsp/sparc64/usiii/include/tm27.h      | 34 ------------
 c/src/lib/libbsp/sparc64/usiii/preinstall.am       |  2 +-
 13 files changed, 8 insertions(+), 239 deletions(-)
 delete mode 100644 c/src/lib/libbsp/arm/gumstix/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/riscv/riscv_generic/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/sparc64/niagara/include/tm27.h
 delete mode 100644 c/src/lib/libbsp/sparc64/usiii/include/tm27.h
diff --git a/c/src/lib/libbsp/arm/gumstix/Makefile.am b/c/src/lib/libbsp/arm/gumstix/Makefile.am
index 42104577ad..9c158f63f3 100644
--- a/c/src/lib/libbsp/arm/gumstix/Makefile.am
+++ b/c/src/lib/libbsp/arm/gumstix/Makefile.am
@@ -8,7 +8,7 @@ include_bspdir = $(includedir)/bsp
 dist_project_lib_DATA = bsp_specs
 include_HEADERS = include/bsp.h
-include_HEADERS += include/tm27.h
+include_HEADERS += ../../shared/include/tm27.h
 include_bsp_HEADERS =
diff --git a/c/src/lib/libbsp/arm/gumstix/include/tm27.h b/c/src/lib/libbsp/arm/gumstix/include/tm27.h
deleted file mode 100644
index ed8d73e113..0000000000
--- a/c/src/lib/libbsp/arm/gumstix/include/tm27.h
+++ /dev/null
@@ -1,48 +0,0 @@
- * @file
- * @ingroup gumstix_tm27
- * @brief tm27 timing test support
- *  tm27.h
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_TMTEST27
-#error "This is an RTEMS internal file you must not include directly."
-#endif
-#ifndef __tm27_h
-#define __tm27_h
- * @defgroup gumstix_tm27 tm27 Support
- * @ingroup arm_gumstix
- * @brief tm27 Timing Test Support
- * @name Interrupt mechanisms for Time Test 27
-#define MUST_WAIT_FOR_INTERRUPT 0
-#define Install_tm27_vector( handler ) /* empty */
-#define Cause_tm27_intr() /* empty */
-#define Clear_tm27_intr() /* empty */
-#define Lower_tm27_intr() /* empty */
-#endif
diff --git a/c/src/lib/libbsp/arm/gumstix/preinstall.am b/c/src/lib/libbsp/arm/gumstix/preinstall.am
index 23dbe2a207..5d7105b740 100644
--- a/c/src/lib/libbsp/arm/gumstix/preinstall.am
+++ b/c/src/lib/libbsp/arm/gumstix/preinstall.am
@@ -41,7 +41,7 @@ $(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
+$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
index 8517cee49a..dedc1f28a2 100644
--- a/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am
@@ -17,7 +17,7 @@ dist_project_lib_DATA = bsp_specs
 nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
 include_bsp_HEADERS = ../shared/include/linker-symbols.h
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h b/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
index 6e3d3055e4..0000000000
--- a/c/src/lib/libbsp/epiphany/epiphany_sim/include/tm27.h
+++ /dev/null
@@ -1,62 +0,0 @@
- * @ingroup bsp_epiphany
- * @brief Epiphany Time Test 27 Routines
- * Copyright (c) 2015 University of York.
- * Hesham ALMatary <hmka501 at york.ac.uk>
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#endif
-#ifndef LIBBSP_EPIPHANY_EPIPHANY_SIM_TM27_H
-#define LIBBSP_EPIPHANY_EPIPHANY_SIM_TM27_H
-#endif /* LIBBSP_EPIPHANY_EPIPHANY_SIM_TM27_H */
diff --git a/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am b/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
index d79d62cd60..4ee8b02beb 100644
--- a/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
+++ b/c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am
@@ -46,7 +46,7 @@ $(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
diff --git a/c/src/lib/libbsp/riscv/riscv_generic/include/tm27.h b/c/src/lib/libbsp/riscv/riscv_generic/include/tm27.h
index 392f106da4..0000000000
--- a/c/src/lib/libbsp/riscv/riscv_generic/include/tm27.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * Hesham Almatary <hesham at alumni.york.ac.uk>
- * are met:
- * SUCH DAMAGE.
-#endif
-#ifndef __tm27_h
-#define __tm27_h
-#endif
diff --git a/c/src/lib/libbsp/sparc64/niagara/Makefile.am b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
index 129f9bc3e8..5f2d97e0d2 100644
--- a/c/src/lib/libbsp/sparc64/niagara/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/niagara/Makefile.am
 include_HEADERS += ../shared/include/asm.h
 include_bootdir = $(includedir)/boot
diff --git a/c/src/lib/libbsp/sparc64/niagara/include/tm27.h b/c/src/lib/libbsp/sparc64/niagara/include/tm27.h
index 9001b807ab..0000000000
--- a/c/src/lib/libbsp/sparc64/niagara/include/tm27.h
+++ /dev/null
@@ -1,34 +0,0 @@
- * @file
- * @ingroup sparc64_niagara
- * @brief Implementations for interrupt mechanisms for Time Test 27
-#endif
-#ifndef __tm27_h
-#define __tm27_h
- *  Define the interrupt mechanism for Time Test 27
-#define Install_tm27_vector( handler ) /* set_vector( (handler), 6, 1 ) */
-#define Cause_tm27_intr()  /* XXX */
-#define Clear_tm27_intr()  /* XXX */
-#endif
diff --git a/c/src/lib/libbsp/sparc64/niagara/preinstall.am b/c/src/lib/libbsp/sparc64/niagara/preinstall.am
index d2c8f3b3b8..d417b88f62 100644
--- a/c/src/lib/libbsp/sparc64/niagara/preinstall.am
+++ b/c/src/lib/libbsp/sparc64/niagara/preinstall.am
diff --git a/c/src/lib/libbsp/sparc64/usiii/Makefile.am b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
index 951afd2d09..8ce40238db 100644
--- a/c/src/lib/libbsp/sparc64/usiii/Makefile.am
+++ b/c/src/lib/libbsp/sparc64/usiii/Makefile.am
 include_HEADERS += ../shared/include/traptable.h
diff --git a/c/src/lib/libbsp/sparc64/usiii/include/tm27.h b/c/src/lib/libbsp/sparc64/usiii/include/tm27.h
index 14e07ca3a8..0000000000
--- a/c/src/lib/libbsp/sparc64/usiii/include/tm27.h
+++ /dev/null
@@ -1,34 +0,0 @@
- * @file
- * @ingroup sparc64_usiii
-#endif
-#ifndef __tm27_h
-#define __tm27_h
-#endif
diff --git a/c/src/lib/libbsp/sparc64/usiii/preinstall.am b/c/src/lib/libbsp/sparc64/usiii/preinstall.am
index fa403a3842..912959c807 100644
--- a/c/src/lib/libbsp/sparc64/usiii/preinstall.am
+++ b/c/src/lib/libbsp/sparc64/usiii/preinstall.am
2.12.3
