[PATCH 5/5] Move Ada includes
Fri Nov 24 12:52:24 UTC 2017
Update #3254.
 c/src/ada/Makefile.am                              |  28 ----
 c/src/configure.ac                                 |  13 --
 cpukit/Makefile.am                                 |  44 ++++++
 .../include/adainclude}/preinstall.am              |   0
 .../include/adainclude}/rtems-barrier.adb          |   0
 .../include/adainclude}/rtems-barrier.ads          |   0
 .../include/adainclude}/rtems-clock.adb            |   0
 .../include/adainclude}/rtems-clock.ads            |   0
 .../include/adainclude}/rtems-cpu_usage.ads        |   0
 .../include/adainclude}/rtems-event.adb            |   0
 .../include/adainclude}/rtems-event.ads            |   0
 .../include/adainclude}/rtems-extension.adb        |   0
 .../include/adainclude}/rtems-extension.ads        |   0
 .../include/adainclude}/rtems-fatal.adb            |   0
 .../include/adainclude}/rtems-fatal.ads            |   0
 .../include/adainclude}/rtems-interrupt.ads        |   0
 .../ada => cpukit/include/adainclude}/rtems-io.adb |   0
 .../ada => cpukit/include/adainclude}/rtems-io.ads |   0
 .../include/adainclude}/rtems-message_queue.adb    |   0
 .../include/adainclude}/rtems-message_queue.ads    |   0
 .../include/adainclude}/rtems-multiprocessing.adb  |   0
 .../include/adainclude}/rtems-multiprocessing.ads  |   0
 .../include/adainclude}/rtems-object.adb           |   0
 .../include/adainclude}/rtems-object.ads           |   0
 .../include/adainclude}/rtems-partition.adb        |   0
 .../include/adainclude}/rtems-partition.ads        |   0
 .../include/adainclude}/rtems-port.adb             |   0
 .../include/adainclude}/rtems-port.ads             |   0
 .../include/adainclude}/rtems-rate_monotonic.adb   |   0
 .../include/adainclude}/rtems-rate_monotonic.ads   |   0
 .../include/adainclude}/rtems-region.adb           |   0
 .../include/adainclude}/rtems-region.ads           |   0
 .../include/adainclude}/rtems-semaphore.adb        |   0
 .../include/adainclude}/rtems-semaphore.ads        |   0
 .../include/adainclude}/rtems-signal.adb           |   0
 .../include/adainclude}/rtems-signal.ads           |   0
 .../include/adainclude}/rtems-stack_checker.ads    |   0
 .../include/adainclude}/rtems-tasks.adb            |   0
 .../include/adainclude}/rtems-tasks.ads            |   0
 .../include/adainclude}/rtems-timer.adb            |   0
 .../include/adainclude}/rtems-timer.ads            |   0
 {c/src/ada => cpukit/include/adainclude}/rtems.adb |   0
 {c/src/ada => cpukit/include/adainclude}/rtems.ads |   0
 cpukit/preinstall.am                               | 162 +++++++++++++++++++++
 44 files changed, 206 insertions(+), 41 deletions(-)
 delete mode 100644 c/src/ada/Makefile.am
 rename {c/src/ada => cpukit/include/adainclude}/preinstall.am (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-barrier.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-barrier.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-clock.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-clock.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-cpu_usage.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-event.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-event.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-extension.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-extension.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-fatal.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-fatal.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-interrupt.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-io.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-io.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-message_queue.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-message_queue.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-multiprocessing.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-multiprocessing.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-object.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-object.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-partition.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-partition.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-port.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-port.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-rate_monotonic.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-rate_monotonic.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-region.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-region.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-semaphore.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-semaphore.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-signal.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-signal.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-stack_checker.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-tasks.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-tasks.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-timer.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems-timer.ads (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems.adb (100%)
 rename {c/src/ada => cpukit/include/adainclude}/rtems.ads (100%)
diff --git a/c/src/ada/Makefile.am b/c/src/ada/Makefile.am
deleted file mode 100644
index 3f7c854afd..0000000000
--- a/c/src/ada/Makefile.am
+++ /dev/null
@@ -1,28 +0,0 @@
-if RTEMS_ADA
-include_adadir = $(includedir)/adainclude
-include_ada_HEADERS = rtems.adb rtems.ads
-include_ada_HEADERS +=  \
-    rtems-barrier.adb rtems-barrier.ads \
-    rtems-clock.adb rtems-clock.ads \
-    rtems-cpu_usage.ads \
-    rtems-event.adb rtems-event.ads \
-    rtems-extension.adb rtems-extension.ads \
-    rtems-fatal.adb rtems-fatal.ads \
-    rtems-interrupt.ads \
-    rtems-io.adb rtems-io.ads \
-    rtems-message_queue.adb rtems-message_queue.ads \
-    rtems-multiprocessing.adb rtems-multiprocessing.ads \
-    rtems-object.adb rtems-object.ads \
-    rtems-partition.adb rtems-partition.ads \
-    rtems-port.adb rtems-port.ads \
-    rtems-rate_monotonic.adb rtems-rate_monotonic.ads \
-    rtems-region.adb rtems-region.ads \
-    rtems-semaphore.adb rtems-semaphore.ads \
-    rtems-signal.adb rtems-signal.ads \
-    rtems-stack_checker.ads \
-    rtems-tasks.adb rtems-tasks.ads \
-    rtems-timer.adb rtems-timer.ads
-endif
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/automake/local.am
diff --git a/c/src/configure.ac b/c/src/configure.ac
index 0ef63ce80b..b55962cb65 100644
--- a/c/src/configure.ac
+++ b/c/src/configure.ac
@@ -142,17 +142,8 @@ AC_SUBST(libbsp_cpu_subdir,$RTEMS_CPU)
 BSP_SUBDIRS="$BSP_SUBDIRS lib"
 BSP_SUBDIRS="$BSP_SUBDIRS libchip"
 BSP_SUBDIRS="$BSP_SUBDIRS support"
-BSP_SUBDIRS="$BSP_SUBDIRS ada"
 BSP_SUBDIRS="$BSP_SUBDIRS wrapup"
-AC_ARG_ENABLE([ada],
-[AS_HELP_STRING(--enable-ada,enable ada support)],
-[case "${enable_ada}" in
-  yes) ;;
-  no) ;;
-  *)  AC_MSG_ERROR(bad value ${enable_ada} for --enable-ada) ;;
-esac],[enable_ada=no])
 # HACK ALERT!
 # FIXME: Assume multilib implies in-source-tree multilibs
@@ -191,9 +182,6 @@ AS_IF([test "$host_cpu" = sparc],[
 AM_CONDITIONAL([HAS_NETWORKING],[test "$HAS_NETWORKING" = "yes"])
 AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
-AM_CONDITIONAL(RTEMS_ADA,[test x"$enable_ada" = x"yes" \
-  && test x"$rtems_cv_HAS_POSIX_API" = x"yes"])
 RTEMS_PROJECT_ROOT
 # Explicitly list all Makefiles here
@@ -208,7 +196,6 @@ libchip/Makefile
 lib/Makefile
 lib/libcpu/Makefile
 lib/libbsp/Makefile
-ada/Makefile
 wrapup/Makefile
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 8ccc1d4e9a..d905f2b73a 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -278,6 +278,50 @@ include_drvmgr_HEADERS += libdrvmgr/drvmgr_confdefs.h
 include_drvmgr_HEADERS += libdrvmgr/drvmgr_list.h
 endif
+if LIBGNAT
+include_adaincludedir = $(includedir)/adainclude
+include_adainclude_HEADERS =
+include_adainclude_HEADERS += include/adainclude/rtems.adb
+include_adainclude_HEADERS += include/adainclude/rtems.ads
+include_adainclude_HEADERS += include/adainclude/rtems-barrier.adb
+include_adainclude_HEADERS += include/adainclude/rtems-barrier.ads
+include_adainclude_HEADERS += include/adainclude/rtems-clock.adb
+include_adainclude_HEADERS += include/adainclude/rtems-clock.ads
+include_adainclude_HEADERS += include/adainclude/rtems-cpu_usage.ads
+include_adainclude_HEADERS += include/adainclude/rtems-event.adb
+include_adainclude_HEADERS += include/adainclude/rtems-event.ads
+include_adainclude_HEADERS += include/adainclude/rtems-extension.adb
+include_adainclude_HEADERS += include/adainclude/rtems-extension.ads
+include_adainclude_HEADERS += include/adainclude/rtems-fatal.adb
+include_adainclude_HEADERS += include/adainclude/rtems-fatal.ads
+include_adainclude_HEADERS += include/adainclude/rtems-interrupt.ads
+include_adainclude_HEADERS += include/adainclude/rtems-io.adb
+include_adainclude_HEADERS += include/adainclude/rtems-io.ads
+include_adainclude_HEADERS += include/adainclude/rtems-message_queue.adb
+include_adainclude_HEADERS += include/adainclude/rtems-message_queue.ads
+include_adainclude_HEADERS += include/adainclude/rtems-multiprocessing.adb
+include_adainclude_HEADERS += include/adainclude/rtems-multiprocessing.ads
+include_adainclude_HEADERS += include/adainclude/rtems-object.adb
+include_adainclude_HEADERS += include/adainclude/rtems-object.ads
+include_adainclude_HEADERS += include/adainclude/rtems-partition.adb
+include_adainclude_HEADERS += include/adainclude/rtems-partition.ads
+include_adainclude_HEADERS += include/adainclude/rtems-port.adb
+include_adainclude_HEADERS += include/adainclude/rtems-port.ads
+include_adainclude_HEADERS += include/adainclude/rtems-rate_monotonic.adb
+include_adainclude_HEADERS += include/adainclude/rtems-rate_monotonic.ads
+include_adainclude_HEADERS += include/adainclude/rtems-region.adb
+include_adainclude_HEADERS += include/adainclude/rtems-region.ads
+include_adainclude_HEADERS += include/adainclude/rtems-semaphore.adb
+include_adainclude_HEADERS += include/adainclude/rtems-semaphore.ads
+include_adainclude_HEADERS += include/adainclude/rtems-signal.adb
+include_adainclude_HEADERS += include/adainclude/rtems-signal.ads
+include_adainclude_HEADERS += include/adainclude/rtems-stack_checker.ads
+include_adainclude_HEADERS += include/adainclude/rtems-tasks.adb
+include_adainclude_HEADERS += include/adainclude/rtems-tasks.ads
+include_adainclude_HEADERS += include/adainclude/rtems-timer.adb
+include_adainclude_HEADERS += include/adainclude/rtems-timer.ads
+endif
 ## HACK: doxygen filter.
 EXTRA_DIST = doxy-filter
diff --git a/c/src/ada/preinstall.am b/cpukit/include/adainclude/preinstall.am
similarity index 100%
rename from c/src/ada/preinstall.am
rename to cpukit/include/adainclude/preinstall.am
diff --git a/c/src/ada/rtems-barrier.adb b/cpukit/include/adainclude/rtems-barrier.adb
rename from c/src/ada/rtems-barrier.adb
rename to cpukit/include/adainclude/rtems-barrier.adb
diff --git a/c/src/ada/rtems-barrier.ads b/cpukit/include/adainclude/rtems-barrier.ads
rename from c/src/ada/rtems-barrier.ads
rename to cpukit/include/adainclude/rtems-barrier.ads
diff --git a/c/src/ada/rtems-clock.adb b/cpukit/include/adainclude/rtems-clock.adb
rename from c/src/ada/rtems-clock.adb
rename to cpukit/include/adainclude/rtems-clock.adb
diff --git a/c/src/ada/rtems-clock.ads b/cpukit/include/adainclude/rtems-clock.ads
rename from c/src/ada/rtems-clock.ads
rename to cpukit/include/adainclude/rtems-clock.ads
diff --git a/c/src/ada/rtems-cpu_usage.ads b/cpukit/include/adainclude/rtems-cpu_usage.ads
rename from c/src/ada/rtems-cpu_usage.ads
rename to cpukit/include/adainclude/rtems-cpu_usage.ads
diff --git a/c/src/ada/rtems-event.adb b/cpukit/include/adainclude/rtems-event.adb
rename from c/src/ada/rtems-event.adb
rename to cpukit/include/adainclude/rtems-event.adb
diff --git a/c/src/ada/rtems-event.ads b/cpukit/include/adainclude/rtems-event.ads
rename from c/src/ada/rtems-event.ads
rename to cpukit/include/adainclude/rtems-event.ads
diff --git a/c/src/ada/rtems-extension.adb b/cpukit/include/adainclude/rtems-extension.adb
rename from c/src/ada/rtems-extension.adb
rename to cpukit/include/adainclude/rtems-extension.adb
diff --git a/c/src/ada/rtems-extension.ads b/cpukit/include/adainclude/rtems-extension.ads
rename from c/src/ada/rtems-extension.ads
rename to cpukit/include/adainclude/rtems-extension.ads
diff --git a/c/src/ada/rtems-fatal.adb b/cpukit/include/adainclude/rtems-fatal.adb
rename from c/src/ada/rtems-fatal.adb
rename to cpukit/include/adainclude/rtems-fatal.adb
diff --git a/c/src/ada/rtems-fatal.ads b/cpukit/include/adainclude/rtems-fatal.ads
rename from c/src/ada/rtems-fatal.ads
rename to cpukit/include/adainclude/rtems-fatal.ads
diff --git a/c/src/ada/rtems-interrupt.ads b/cpukit/include/adainclude/rtems-interrupt.ads
rename from c/src/ada/rtems-interrupt.ads
rename to cpukit/include/adainclude/rtems-interrupt.ads
diff --git a/c/src/ada/rtems-io.adb b/cpukit/include/adainclude/rtems-io.adb
rename from c/src/ada/rtems-io.adb
rename to cpukit/include/adainclude/rtems-io.adb
diff --git a/c/src/ada/rtems-io.ads b/cpukit/include/adainclude/rtems-io.ads
rename from c/src/ada/rtems-io.ads
rename to cpukit/include/adainclude/rtems-io.ads
diff --git a/c/src/ada/rtems-message_queue.adb b/cpukit/include/adainclude/rtems-message_queue.adb
rename from c/src/ada/rtems-message_queue.adb
rename to cpukit/include/adainclude/rtems-message_queue.adb
diff --git a/c/src/ada/rtems-message_queue.ads b/cpukit/include/adainclude/rtems-message_queue.ads
rename from c/src/ada/rtems-message_queue.ads
rename to cpukit/include/adainclude/rtems-message_queue.ads
diff --git a/c/src/ada/rtems-multiprocessing.adb b/cpukit/include/adainclude/rtems-multiprocessing.adb
rename from c/src/ada/rtems-multiprocessing.adb
rename to cpukit/include/adainclude/rtems-multiprocessing.adb
diff --git a/c/src/ada/rtems-multiprocessing.ads b/cpukit/include/adainclude/rtems-multiprocessing.ads
rename from c/src/ada/rtems-multiprocessing.ads
rename to cpukit/include/adainclude/rtems-multiprocessing.ads
diff --git a/c/src/ada/rtems-object.adb b/cpukit/include/adainclude/rtems-object.adb
rename from c/src/ada/rtems-object.adb
rename to cpukit/include/adainclude/rtems-object.adb
diff --git a/c/src/ada/rtems-object.ads b/cpukit/include/adainclude/rtems-object.ads
rename from c/src/ada/rtems-object.ads
rename to cpukit/include/adainclude/rtems-object.ads
diff --git a/c/src/ada/rtems-partition.adb b/cpukit/include/adainclude/rtems-partition.adb
rename from c/src/ada/rtems-partition.adb
rename to cpukit/include/adainclude/rtems-partition.adb
diff --git a/c/src/ada/rtems-partition.ads b/cpukit/include/adainclude/rtems-partition.ads
rename from c/src/ada/rtems-partition.ads
rename to cpukit/include/adainclude/rtems-partition.ads
diff --git a/c/src/ada/rtems-port.adb b/cpukit/include/adainclude/rtems-port.adb
rename from c/src/ada/rtems-port.adb
rename to cpukit/include/adainclude/rtems-port.adb
diff --git a/c/src/ada/rtems-port.ads b/cpukit/include/adainclude/rtems-port.ads
rename from c/src/ada/rtems-port.ads
rename to cpukit/include/adainclude/rtems-port.ads
diff --git a/c/src/ada/rtems-rate_monotonic.adb b/cpukit/include/adainclude/rtems-rate_monotonic.adb
rename from c/src/ada/rtems-rate_monotonic.adb
rename to cpukit/include/adainclude/rtems-rate_monotonic.adb
diff --git a/c/src/ada/rtems-rate_monotonic.ads b/cpukit/include/adainclude/rtems-rate_monotonic.ads
rename from c/src/ada/rtems-rate_monotonic.ads
rename to cpukit/include/adainclude/rtems-rate_monotonic.ads
diff --git a/c/src/ada/rtems-region.adb b/cpukit/include/adainclude/rtems-region.adb
rename from c/src/ada/rtems-region.adb
rename to cpukit/include/adainclude/rtems-region.adb
diff --git a/c/src/ada/rtems-region.ads b/cpukit/include/adainclude/rtems-region.ads
rename from c/src/ada/rtems-region.ads
rename to cpukit/include/adainclude/rtems-region.ads
diff --git a/c/src/ada/rtems-semaphore.adb b/cpukit/include/adainclude/rtems-semaphore.adb
rename from c/src/ada/rtems-semaphore.adb
rename to cpukit/include/adainclude/rtems-semaphore.adb
diff --git a/c/src/ada/rtems-semaphore.ads b/cpukit/include/adainclude/rtems-semaphore.ads
rename from c/src/ada/rtems-semaphore.ads
rename to cpukit/include/adainclude/rtems-semaphore.ads
diff --git a/c/src/ada/rtems-signal.adb b/cpukit/include/adainclude/rtems-signal.adb
rename from c/src/ada/rtems-signal.adb
rename to cpukit/include/adainclude/rtems-signal.adb
diff --git a/c/src/ada/rtems-signal.ads b/cpukit/include/adainclude/rtems-signal.ads
rename from c/src/ada/rtems-signal.ads
rename to cpukit/include/adainclude/rtems-signal.ads
diff --git a/c/src/ada/rtems-stack_checker.ads b/cpukit/include/adainclude/rtems-stack_checker.ads
rename from c/src/ada/rtems-stack_checker.ads
rename to cpukit/include/adainclude/rtems-stack_checker.ads
diff --git a/c/src/ada/rtems-tasks.adb b/cpukit/include/adainclude/rtems-tasks.adb
rename from c/src/ada/rtems-tasks.adb
rename to cpukit/include/adainclude/rtems-tasks.adb
diff --git a/c/src/ada/rtems-tasks.ads b/cpukit/include/adainclude/rtems-tasks.ads
rename from c/src/ada/rtems-tasks.ads
rename to cpukit/include/adainclude/rtems-tasks.ads
diff --git a/c/src/ada/rtems-timer.adb b/cpukit/include/adainclude/rtems-timer.adb
rename from c/src/ada/rtems-timer.adb
rename to cpukit/include/adainclude/rtems-timer.adb
diff --git a/c/src/ada/rtems-timer.ads b/cpukit/include/adainclude/rtems-timer.ads
rename from c/src/ada/rtems-timer.ads
rename to cpukit/include/adainclude/rtems-timer.ads
diff --git a/c/src/ada/rtems.adb b/cpukit/include/adainclude/rtems.adb
rename from c/src/ada/rtems.adb
rename to cpukit/include/adainclude/rtems.adb
diff --git a/c/src/ada/rtems.ads b/cpukit/include/adainclude/rtems.ads
rename from c/src/ada/rtems.ads
rename to cpukit/include/adainclude/rtems.ads
diff --git a/cpukit/preinstall.am b/cpukit/preinstall.am
index 7936de2ebb..d595085ebe 100644
--- a/cpukit/preinstall.am
+++ b/cpukit/preinstall.am
@@ -620,3 +620,165 @@ $(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h: libdrvmgr/drvmgr_list.h $(PROJECT_INCLU
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/drvmgr/drvmgr_list.h
 endif
+if LIBGNAT
+$(PROJECT_INCLUDE)/adainclude/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/adainclude
+	@: > $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+$(PROJECT_INCLUDE)/adainclude/rtems.adb: include/adainclude/rtems.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems.adb
+$(PROJECT_INCLUDE)/adainclude/rtems.ads: include/adainclude/rtems.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-barrier.adb: include/adainclude/rtems-barrier.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-barrier.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-barrier.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-barrier.ads: include/adainclude/rtems-barrier.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-barrier.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-barrier.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-clock.adb: include/adainclude/rtems-clock.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-clock.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-clock.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-clock.ads: include/adainclude/rtems-clock.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-clock.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-clock.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-cpu_usage.ads: include/adainclude/rtems-cpu_usage.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-cpu_usage.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-cpu_usage.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-event.adb: include/adainclude/rtems-event.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-event.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-event.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-event.ads: include/adainclude/rtems-event.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-event.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-event.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-extension.adb: include/adainclude/rtems-extension.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-extension.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-extension.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-extension.ads: include/adainclude/rtems-extension.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-extension.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-extension.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-fatal.adb: include/adainclude/rtems-fatal.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-fatal.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-fatal.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-fatal.ads: include/adainclude/rtems-fatal.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-fatal.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-fatal.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-interrupt.ads: include/adainclude/rtems-interrupt.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-interrupt.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-interrupt.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-io.adb: include/adainclude/rtems-io.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-io.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-io.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-io.ads: include/adainclude/rtems-io.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-io.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-io.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-message_queue.adb: include/adainclude/rtems-message_queue.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-message_queue.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-message_queue.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-message_queue.ads: include/adainclude/rtems-message_queue.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-message_queue.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-message_queue.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.adb: include/adainclude/rtems-multiprocessing.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.ads: include/adainclude/rtems-multiprocessing.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-multiprocessing.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-object.adb: include/adainclude/rtems-object.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-object.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-object.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-object.ads: include/adainclude/rtems-object.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-object.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-object.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-partition.adb: include/adainclude/rtems-partition.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-partition.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-partition.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-partition.ads: include/adainclude/rtems-partition.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-partition.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-partition.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-port.adb: include/adainclude/rtems-port.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-port.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-port.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-port.ads: include/adainclude/rtems-port.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-port.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-port.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.adb: include/adainclude/rtems-rate_monotonic.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.ads: include/adainclude/rtems-rate_monotonic.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-rate_monotonic.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-region.adb: include/adainclude/rtems-region.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-region.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-region.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-region.ads: include/adainclude/rtems-region.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-region.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-region.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-semaphore.adb: include/adainclude/rtems-semaphore.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-semaphore.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-semaphore.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-semaphore.ads: include/adainclude/rtems-semaphore.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-semaphore.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-semaphore.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-signal.adb: include/adainclude/rtems-signal.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-signal.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-signal.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-signal.ads: include/adainclude/rtems-signal.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-signal.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-signal.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-stack_checker.ads: include/adainclude/rtems-stack_checker.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-stack_checker.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-stack_checker.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-tasks.adb: include/adainclude/rtems-tasks.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-tasks.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-tasks.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-tasks.ads: include/adainclude/rtems-tasks.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-tasks.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-tasks.ads
+$(PROJECT_INCLUDE)/adainclude/rtems-timer.adb: include/adainclude/rtems-timer.adb $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-timer.adb
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-timer.adb
+$(PROJECT_INCLUDE)/adainclude/rtems-timer.ads: include/adainclude/rtems-timer.ads $(PROJECT_INCLUDE)/adainclude/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/adainclude/rtems-timer.ads
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/adainclude/rtems-timer.ads
+endif
2.12.3
