[PATCH v2] dosfs: Fix files with same name as volume name.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Nov 28 15:42:00 UTC 2017
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
Take care that a file in the root directory with the same name as the
volume name can be found.
 cpukit/libfs/src/dosfs/msdos_misc.c     |  3 ++-
 testsuites/fstests/fsdosfsname01/init.c | 45 ++++++++++++++++++++++++++++++++-
 2 files changed, 46 insertions(+), 2 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/msdos_misc.c
index dec894f133..addfd7fa84 100644
--- a/cpukit/libfs/src/dosfs/msdos_misc.c
+++ b/cpukit/libfs/src/dosfs/msdos_misc.c
@@ -1562,7 +1562,8 @@ msdos_find_file_in_directory (
                         printf ("MSFS:[9.2] checksum, entry_matched:%i, lfn_entry:%i, lfn_checksum:%02x/%02x\n",
                                 entry_matched, lfn_entry, lfn_checksum, msdos_lfn_checksum(entry));
 #endif
-                    } else {
+                    } else if ((*MSDOS_DIR_ATTR(entry) & MSDOS_ATTR_VOLUME_ID)
+                               == 0) {
                         bytes_in_entry = MSDOS_SHORT_NAME_LEN + 1;
                         bytes_in_entry = msdos_short_entry_to_utf8_name (
                             converter,
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index f272945d89..d0c909877c 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -46,6 +46,7 @@ const char rtems_test_name[] = "FSDOSFSNAME 1";
 #define RAMDISK_PATH "/dev/rda"
 #define BLOCK_NUM 47
 #define BLOCK_SIZE 512
+#define VOLUME_LABEL "MyDisk"
 #define NUMBER_OF_DIRECTORIES 8
 #define NUMBER_OF_FILES 13
@@ -78,7 +79,7 @@ static rtems_resource_snapshot            before_mount;
 static const msdos_format_request_param_t rqdata = {
   .OEMName             = "RTEMS",
-  .VolLabel            = "RTEMSDisk",
+  .VolLabel            = VOLUME_LABEL,
   .sectors_per_cluster = 2,
   .fat_num             = 0,
   .files_per_root_dir  = 0,
@@ -1107,10 +1108,52 @@ static void test_full_8_3_name( void )
   rtems_test_assert( rc == 0 );
+static void test_dir_with_same_name_as_volume_label( void )
+  int  rc;
+  DIR *dirp;
+  rc = mkdir( MOUNT_DIR "/" VOLUME_LABEL, S_IRWXU | S_IRWXG | S_IRWXO );
+  rtems_test_assert( rc == 0 );
+  dirp = opendir( MOUNT_DIR "/" VOLUME_LABEL );
+  rtems_test_assert( NULL != dirp );
+  rc = closedir( dirp );
+  rc = unlink( MOUNT_DIR "/" VOLUME_LABEL );
+static void test_file_with_same_name_as_volume_label( void )
+  int rc;
+  int fd;
+  fd = open( MOUNT_DIR "/" VOLUME_LABEL, O_RDWR | O_CREAT,
+             S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH | S_IWOTH );
+  rtems_test_assert( fd >= 0 );
+  rc = close( fd );
+  fd = open( MOUNT_DIR "/" VOLUME_LABEL, O_RDWR );
+  rc = close( fd );
 static void test_special_cases( void )
   test_end_of_string_matches();
   test_full_8_3_name();
+  test_file_with_same_name_as_volume_label();
+  test_dir_with_same_name_as_volume_label();
2.12.3
