Many Warnings in Tests
Joel Sherrill
joel at rtems.org
Wed Nov 29 00:23:29 UTC 2017
Ok. I will fix this and commit it tomorrow.
Then look at other warnings.
Thanks.
--joel
On Nov 28, 2017 5:26 PM, "Chris Johns" <chrisj at rtems.org> wrote:
On 29/11/2017 10:23, Joel Sherrill wrote:
> Some recent change has introduced a lot of warnings like the following
where
> POSIX threads do not end with "return NULL;" or similar:
> og/arm-altcycv_devkit.log:../../../../../../../rtems/c/src/.
./../testsuites/psxtmtests/psxtmbarrier01/init.c:86:1:
> warning: control reaches end of non-void function [-Wreturn-type]
> My thought is that rtems_test_exit() should have been declared as
noreturn.
It should be the same as exit().
> Anyone disagree?
Not me.
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171128/382a9a07/attachment.html>
