[PATCH] libdebugger: rtems_debugger_register_tcp_remote()
Wed Nov 29 06:30:36 UTC 2017
On 28/11/17 23:02, Chris Johns wrote:
> On 29/11/2017 00:59, Sebastian Huber wrote:
>> Always provide rtems_debugger_register_tcp_remote().  Header files are
>> supplied by Newlib and not libnetworking.
> Does this mean the version in libbsd can be removed?
Yes, but there is an issue with the library dependencies. The debugger
stuff is in librtemscpu.a which is present via bsp_specs. The socket()
stuff is in libbsd. I had to use:
-Wl,--start-group -lbsd -lrtemscpu -Wl,--end-group
libbsd.a defines strong _Watchdog_Ticks_since_boot alias. So, this
library must be first.
Maybe we should add a libdebugger.a.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
