Version Info for RTEMS libbsd
Joel Sherrill
joel at rtems.org
Wed Nov 29 20:24:37 UTC 2017
Hi
Checking the version of FreeBSD that we were using with rtems-libbsd, I
poked at the top level files which left me pretty sure these are not quite
up to date.
+ CONTRIBUTING.md - has trunk, 2017-04-04
+ libbsd.txt - says FreeBSD 9.2
+ libbsd.txt - also uses 4.12 not 5 on target names and minimum version
+ libbsd.py - has a 4.12 reference
+ README.waf is full of 4.12 and says you need an RSB from at least April
2016
I was trying to note the FreeBSD version we are at and it seems that
it is not as easy to pin down as I hoped. git log didn't give me much of
a hint either.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171129/c7f220e5/attachment.html>
