Failures with rtems-bsp-builder
Wed Nov 1 11:32:35 UTC 2017
On Wed, Nov 1, 2017 at 6:28 AM, Joel Sherrill <joel at rtems.org> wrote:
> Looks like some variation of the %%s issue is still present:
> [   1/1565] arm/altcycv_devkit (debug)                         Start
> [   1/1565] arm/altcycv_devkit (debug)                         Creating:
> build/arm/altcycv_devkit.debug
> [   1/1565] arm/altcycv_devkit (debug)                         Configuring
> run: %s: arm/altcycv_devkit.debug\
>          /home/joel/rtems-work/rtems/configure --target=arm-rtems4.12\
>          --enable-rtemsbsp=altcycv_devkit --prefix=/home/joel/rtems-\
>          work/bsps --enable-debug
> [   1/1565] arm/altcycv_devkit (debug)                         Building
>          make -j 12
>  I will let it go and see if it picks up the build failures I know
> currently exist.
Well there are different failures:
/usr/bin/install -c -m 644
/home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
../../../altcycv_devkit/lib/include/libchip/spi-flash-m25p40.h
/usr/bin/install: cannot create regular file
‘../../../altcycv_devkit/lib/include/libchip/spi-memdrv.h’: File exists
/home/joel/rtems-work/rtems/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
../../../../.././altcycv_devkit/lib/linkcmds.base
gmake[4]: *** [../../../altcycv_devkit/lib/include/libchip/spi-memdrv.h]
Error 1
gmake[4]: Leaving directory
`/data/home/joel/rtems-work/build/arm/altcycv_devkit.no-posix/arm-rtems4.12/c/altcycv_devkit/libchip'
gmake[3]: *** [preinstall-libchip] Error 1
gmake[3]: *** Waiting for unfinished jobs....
Looks like something in the -j12 on rtbf64c.
> --joel
> On Tue, Oct 31, 2017 at 10:31 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 01/11/2017 10:06, Chris Johns wrote:
>> > I am seeing this as well and will fix it today.
>> Fixed. I have pushed a fix. I can build tier-1 BSPs.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171101/7f5a9150/attachment-0002.html>
