[PATCH 1/2] cpukit: Add the git hash to the version if built from git source.
    Chris Johns
    chrisj at rtems.org
    Mon Nov  6 21:49:29 UTC 2017
On 06/11/2017 17:23, Sebastian Huber wrote:
> How reliable is this Autoconf stuff?
Haha, that is a leading question! I suppose it depends on how you use it or
abuse it as we have in our case.
> Do I have to re-build everything after each
> Git checkout (cpuopts.h is included in nearly every header)?
The hash is only updated when configure is run. It is not 100% full proof,
something like a makefile check or the post-checkout would be needed if that
path is taken. What I did was a "good attempt" at best.
> Why can't we use a Git post-checkout hook (attached)?
I tend to get a little uneasy when a VC tool is touching code in a project
underneath another operation. It makes auditing more complicated. If you think
the autoconf change is still not suitable I suppose something in the makefiles
could perform the post-checkout functionality.
We need a way for the build and test records to show what was being tested. We
currently lack that information.
