RTEMS Tier Allocations.
Tue Nov 7 15:01:17 UTC 2017
On Nov 7, 2017 8:57 AM, "Chris Johns" <chrisj at rtems.org> wrote:
On 7/11/17 6:01 pm, Sebastian Huber wrote:
> On 06/11/17 23:03, Chris Johns wrote:
>> $ cat ~/.mailrc | grep chrisj
>> setfrom=chrisj at rtems.org
> With the sudo, I have to add this file to the root user.
Yes this is correct. There is the `MAILRC` environment var which can point
to a
.mailrc but this is also fragile.
I will fix the --mail-to bug and I will also add macro support so these
values
can be set in the user config file under a `global` section.
> Would it be possible to
> simply generate a raw mail file which can be sent later via an e-mail
client?
> Some test machines may be not connected to the internet for example.
Yes, this is a great idea. It should be is easy to add.
I mentioned earlier that GCC has a tool in contrib/ to send test results.
It has been around a long time and should be a good place to look for use
cases.
I recall the key behaviors are to run and get results, send email, and
resend email.
--joel
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171107/255ba614/attachment-0002.html>
