[PATCH 3/4] freebsd/bus: Check return value of bus_accessor.
    Christian Mauderer
    christian.mauderer at embedded-brains.de
    Wed Nov  8 12:36:59 UTC 2017
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 freebsd/sys/sys/bus.h | 23 +++++++++++++++++++++++
 1 file changed, 23 insertions(+)
diff --git a/freebsd/sys/sys/bus.h b/freebsd/sys/sys/bus.h
index 61cb5b9cabf..e882823d402 100644
--- a/freebsd/sys/sys/bus.h
+++ b/freebsd/sys/sys/bus.h
@@ -781,6 +781,7 @@ DECLARE_MODULE(name##_##busname, name##_##busname##_mod,		\
  * Generic ivar accessor generation macros for bus drivers
+#ifndef __rtems__
 #define __BUS_ACCESSOR(varp, var, ivarp, ivar, type)			\
 static __inline type varp ## _get_ ## var(device_t dev)			\
@@ -797,6 +798,28 @@ static __inline void varp ## _set_ ## var(device_t dev, type t)		\
 	BUS_WRITE_IVAR(device_get_parent(dev), dev,			\
 	    ivarp ## _IVAR_ ## ivar, v);				\
+#else /* __rtems__ */
+#define __BUS_ACCESSOR(varp, var, ivarp, ivar, type)			\
+static __inline type varp ## _get_ ## var(device_t dev)			\
+	uintptr_t v;							\
+	int err;							\
+	err = BUS_READ_IVAR(device_get_parent(dev), dev,		\
+	    ivarp ## _IVAR_ ## ivar, &v);				\
+	BSD_ASSERT(err == 0);						\
+	return ((type) v);						\
+static __inline void varp ## _set_ ## var(device_t dev, type t)		\
+	uintptr_t v = (uintptr_t) t;					\
+	int err;							\
+	BUS_WRITE_IVAR(device_get_parent(dev), dev,			\
+	    ivarp ## _IVAR_ ## ivar, v);				\
+#endif /* __rtems__ */
  * Shorthand macros, taking resource argument
2.12.3
