[PATCH] Upgrade to 5.0.0
Thu Nov 9 16:45:45 UTC 2017
On Thu, Nov 9, 2017 at 8:01 AM, Sebastian Huber <sebastian.huber at embedded-
brains.de> wrote:
> On 09/11/17 14:58, Joel Sherrill wrote:
>>         5. Trac wiki. Medium(?). A wiki search of 4.12 gives 21 hits.
>>     This is probably the most important area to fix:
>>     https://devel.rtems.org/wiki/Release
>>     <https://devel.rtems.org/wiki/Release>
>>     I will do this today.
>>         6. rtems.org <http://rtems.org> website. That needs Joel.
>> I don't know of anything except the top paragraph that describes the
>> release branches. That should be easy to fix but we should make sure 4.12
>> is listed in the set of releases where ever they are to say it was renamed
>> to 5.0 before branching. multiple people will end up asking this question.
> I already added re-directs to:
> https://devel.rtems.org/wiki/Release/4.12
> https://devel.rtems.org/wiki/Release/4.12/4.12.0
> https://devel.rtems.org/wiki/Release/4.12/4.12.1
Just to be clear, we won't have a 5.0.0 release, will we?  Are we also
going to
the two digit release numbers?
The RSB change shows it is 5, which means the next branch will be 6.
Is this what we are doing?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171109/598f48b8/attachment-0002.html>
