[PATCH 3/3] tests: Use simple console driver
    Sebastian Huber
    Fri Nov  3 12:11:28 UTC 2017
Update #3170.
Update #3199.
 testsuites/ada/mptests/mp01/config_base.h          | 2 +-
 testsuites/ada/mptests/mp03/config_base.h          | 2 +-
 testsuites/ada/mptests/mp04/config_base.h          | 2 +-
 testsuites/ada/mptests/mp05/config_base.h          | 2 +-
 testsuites/ada/mptests/mp06/config_base.h          | 2 +-
 testsuites/ada/mptests/mp07/config_base.h          | 2 +-
 testsuites/ada/mptests/mp08/config_base.h          | 2 +-
 testsuites/ada/mptests/mp09/config_base.h          | 2 +-
 testsuites/ada/mptests/mp10/config_base.h          | 2 +-
 testsuites/ada/mptests/mp11/config_base.h          | 2 +-
 testsuites/ada/mptests/mp12/config_base.h          | 2 +-
 testsuites/ada/mptests/mp13/config_base.h          | 2 +-
 testsuites/ada/mptests/mp14/config_base.h          | 2 +-
 testsuites/ada/samples/base_mp/config.h            | 2 +-
 testsuites/ada/samples/base_sp/config.h            | 2 +-
 testsuites/ada/samples/hello/config.h              | 2 +-
 testsuites/ada/samples/nsecs/config.h              | 2 +-
 testsuites/ada/samples/ticker/config.h             | 2 +-
 testsuites/ada/sptests/sp01/config.h               | 2 +-
 testsuites/ada/sptests/sp02/config.h               | 2 +-
 testsuites/ada/sptests/sp03/config.h               | 2 +-
 testsuites/ada/sptests/sp04/config.h               | 2 +-
 testsuites/ada/sptests/sp05/config.h               | 2 +-
 testsuites/ada/sptests/sp06/config.h               | 2 +-
 testsuites/ada/sptests/sp07/config.h               | 2 +-
 testsuites/ada/sptests/sp08/config.h               | 2 +-
 testsuites/ada/sptests/sp09/config.h               | 2 +-
 testsuites/ada/sptests/sp11/config.h               | 2 +-
 testsuites/ada/sptests/sp12/config.h               | 2 +-
 testsuites/ada/sptests/sp13/config.h               | 2 +-
 testsuites/ada/sptests/sp14/config.h               | 2 +-
 testsuites/ada/sptests/sp15/config.h               | 2 +-
 testsuites/ada/sptests/sp16/config.h               | 2 +-
 testsuites/ada/sptests/sp17/config.h               | 2 +-
 testsuites/ada/sptests/sp19/config.h               | 2 +-
 testsuites/ada/sptests/sp20/config.h               | 2 +-
 testsuites/ada/sptests/sp22/config.h               | 2 +-
 testsuites/ada/sptests/sp23/config.h               | 2 +-
 testsuites/ada/sptests/sp24/config.h               | 2 +-
 testsuites/ada/sptests/sp25/config.h               | 2 +-
 testsuites/ada/sptests/spatcb01/config.h           | 2 +-
 testsuites/ada/sptests/spname01/config.h           | 2 +-
 testsuites/ada/tmtests/tm01/config.h               | 2 +-
 testsuites/ada/tmtests/tm02/config.h               | 2 +-
 testsuites/ada/tmtests/tm03/config.h               | 2 +-
 testsuites/ada/tmtests/tm04/config.h               | 2 +-
 testsuites/ada/tmtests/tm05/config.h               | 2 +-
 testsuites/ada/tmtests/tm06/config.h               | 2 +-
 testsuites/ada/tmtests/tm07/config.h               | 2 +-
 testsuites/ada/tmtests/tm08/config.h               | 2 +-
 testsuites/ada/tmtests/tm09/config.h               | 2 +-
 testsuites/ada/tmtests/tm10/config.h               | 2 +-
 testsuites/ada/tmtests/tm11/config.h               | 2 +-
 testsuites/ada/tmtests/tm12/config.h               | 2 +-
 testsuites/ada/tmtests/tm13/config.h               | 2 +-
 testsuites/ada/tmtests/tm14/config.h               | 2 +-
 testsuites/ada/tmtests/tm15/config.h               | 2 +-
 testsuites/ada/tmtests/tm16/config.h               | 2 +-
 testsuites/ada/tmtests/tm17/config.h               | 2 +-
 testsuites/ada/tmtests/tm18/config.h               | 2 +-
 testsuites/ada/tmtests/tm19/config.h               | 2 +-
 testsuites/ada/tmtests/tm20/config.h               | 2 +-
 testsuites/ada/tmtests/tm21/config.h               | 2 +-
 testsuites/ada/tmtests/tm22/config.h               | 2 +-
 testsuites/ada/tmtests/tm23/config.h               | 2 +-
 testsuites/ada/tmtests/tm24/config.h               | 2 +-
 testsuites/ada/tmtests/tm25/config.h               | 2 +-
 testsuites/ada/tmtests/tm28/config.h               | 2 +-
 testsuites/ada/tmtests/tm29/config.h               | 2 +-
 testsuites/ada/tmtests/tmck/config.h               | 2 +-
 testsuites/ada/tmtests/tmoverhd/config.h           | 2 +-
 testsuites/benchmarks/dhrystone/init.c             | 2 +-
 testsuites/benchmarks/linpack/init.c               | 2 +-
 testsuites/benchmarks/whetstone/init.c             | 2 +-
 testsuites/fstests/fsbdpart01/init.c               | 2 +-
 testsuites/fstests/fsclose01/init.c                | 2 +-
 testsuites/fstests/fsdosfsformat01/init.c          | 2 +-
 testsuites/fstests/fsdosfsname01/init.c            | 2 +-
 testsuites/fstests/fsdosfsname02/init.c            | 2 +-
 testsuites/fstests/fsdosfssync01/init.c            | 2 +-
 testsuites/fstests/fsdosfswrite01/init.c           | 2 +-
 testsuites/fstests/fsfseeko01/init.c               | 2 +-
 testsuites/fstests/fsimfsconfig02/init.c           | 2 +-
 testsuites/fstests/fsimfsgeneric01/init.c          | 2 +-
 testsuites/fstests/fsrofs01/init.c                 | 2 +-
 testsuites/fstests/imfs_support/fs_support.c       | 2 +-
 testsuites/fstests/jffs2_support/fs_support.c      | 2 +-
 testsuites/fstests/mdosfs_support/fs_support.c     | 2 +-
 testsuites/fstests/mimfs_support/fs_support.c      | 2 +-
 testsuites/fstests/mrfs_support/fs_support.c       | 2 +-
 testsuites/libtests/block01/init.c                 | 2 +-
 testsuites/libtests/block02/init.c                 | 2 +-
 testsuites/libtests/block03/init.c                 | 2 +-
 testsuites/libtests/block04/init.c                 | 2 +-
 testsuites/libtests/block05/init.c                 | 2 +-
 testsuites/libtests/block06/init.c                 | 2 +-
 testsuites/libtests/block07/init.c                 | 2 +-
 testsuites/libtests/block08/system.h               | 2 +-
 testsuites/libtests/block09/init.c                 | 2 +-
 testsuites/libtests/block10/init.c                 | 2 +-
 testsuites/libtests/block11/init.c                 | 2 +-
 testsuites/libtests/block12/init.c                 | 2 +-
 testsuites/libtests/block13/init.c                 | 2 +-
 testsuites/libtests/block14/init.c                 | 2 +-
 testsuites/libtests/block15/init.c                 | 2 +-
 testsuites/libtests/block16/init.c                 | 2 +-
 testsuites/libtests/block17/init.c                 | 2 +-
 testsuites/libtests/bspcmdline01/init.c            | 2 +-
 testsuites/libtests/capture01/system.h             | 2 +-
 testsuites/libtests/complex/init.c                 | 2 +-
 testsuites/libtests/cpuuse/system.h                | 2 +-
 testsuites/libtests/crypt01/init.c                 | 2 +-
 testsuites/libtests/debugger01/system.h            | 2 +-
 testsuites/libtests/devfs03/init.c                 | 2 +-
 testsuites/libtests/deviceio01/init.c              | 2 +-
 testsuites/libtests/dl01/init.c                    | 2 +-
 testsuites/libtests/dl02/init.c                    | 2 +-
 testsuites/libtests/dl03/init.c                    | 2 +-
 testsuites/libtests/dl04/init.c                    | 2 +-
 testsuites/libtests/dl05/init.c                    | 2 +-
 testsuites/libtests/dumpbuf01/init.c               | 2 +-
 testsuites/libtests/exit01/init.c                  | 2 +-
 testsuites/libtests/exit02/init.c                  | 2 +-
 testsuites/libtests/flashdisk01/init.c             | 2 +-
 testsuites/libtests/ftp01/init.c                   | 2 +-
 testsuites/libtests/gxx01/init.c                   | 2 +-
 testsuites/libtests/heapwalk/system.h              | 2 +-
 testsuites/libtests/i2c01/init.c                   | 2 +-
 testsuites/libtests/libfdt01/init.c                | 2 +-
 testsuites/libtests/malloc02/init.c                | 2 +-
 testsuites/libtests/malloc03/init.c                | 2 +-
 testsuites/libtests/malloc04/init.c                | 2 +-
 testsuites/libtests/malloctest/system.h            | 2 +-
 testsuites/libtests/math/init.c                    | 2 +-
 testsuites/libtests/mathf/init.c                   | 2 +-
 testsuites/libtests/mathl/init.c                   | 2 +-
 testsuites/libtests/md501/init.c                   | 2 +-
 testsuites/libtests/mghttpd01/init.c               | 2 +-
 testsuites/libtests/monitor/system.h               | 2 +-
 testsuites/libtests/monitor02/system.h             | 2 +-
 testsuites/libtests/mouse01/init.c                 | 2 +-
 testsuites/libtests/networking01/init.c            | 2 +-
 testsuites/libtests/newlib01/init.c                | 2 +-
 testsuites/libtests/putenvtest/init.c              | 2 +-
 testsuites/libtests/pwdgrp01/init.c                | 2 +-
 testsuites/libtests/pwdgrp02/init.c                | 2 +-
 testsuites/libtests/rbheap01/init.c                | 2 +-
 testsuites/libtests/rtmonuse/system.h              | 2 +-
 testsuites/libtests/sha/init.c                     | 2 +-
 testsuites/libtests/shell01/init.c                 | 2 +-
 testsuites/libtests/sparsedisk01/init.c            | 2 +-
 testsuites/libtests/spi01/init.c                   | 2 +-
 testsuites/libtests/stackchk/system.h              | 2 +-
 testsuites/libtests/stackchk01/init.c              | 2 +-
 testsuites/libtests/stringto01/init.c              | 2 +-
 testsuites/libtests/syscall01/init.c               | 2 +-
 testsuites/libtests/tar01/init.c                   | 2 +-
 testsuites/libtests/tar02/init.c                   | 2 +-
 testsuites/libtests/tar03/init.c                   | 2 +-
 testsuites/libtests/termios/init.c                 | 2 +-
 testsuites/libtests/termios01/init.c               | 2 +-
 testsuites/libtests/termios03/init.c               | 2 +-
 testsuites/libtests/termios04/init.c               | 2 +-
 testsuites/libtests/termios05/init.c               | 2 +-
 testsuites/libtests/termios06/init.c               | 2 +-
 testsuites/libtests/termios07/init.c               | 2 +-
 testsuites/libtests/termios08/init.c               | 2 +-
 testsuites/libtests/termios09/init.c               | 2 +-
 testsuites/libtests/top/system.h                   | 2 +-
 testsuites/libtests/tztest/init.c                  | 2 +-
 testsuites/libtests/uid01/init.c                   | 2 +-
 testsuites/libtests/utf8proc01/init.c              | 2 +-
 testsuites/mptests/mp01/system.h                   | 2 +-
 testsuites/mptests/mp03/system.h                   | 2 +-
 testsuites/mptests/mp04/system.h                   | 2 +-
 testsuites/mptests/mp05/system.h                   | 2 +-
 testsuites/mptests/mp06/system.h                   | 2 +-
 testsuites/mptests/mp07/system.h                   | 2 +-
 testsuites/mptests/mp08/system.h                   | 2 +-
 testsuites/mptests/mp09/system.h                   | 2 +-
 testsuites/mptests/mp10/system.h                   | 2 +-
 testsuites/mptests/mp11/system.h                   | 2 +-
 testsuites/mptests/mp12/system.h                   | 2 +-
 testsuites/mptests/mp13/system.h                   | 2 +-
 testsuites/mptests/mp14/system.h                   | 2 +-
 testsuites/psxtests/psx01/system.h                 | 2 +-
 testsuites/psxtests/psx02/system.h                 | 2 +-
 testsuites/psxtests/psx03/system.h                 | 2 +-
 testsuites/psxtests/psx04/system.h                 | 2 +-
 testsuites/psxtests/psx05/system.h                 | 2 +-
 testsuites/psxtests/psx06/system.h                 | 2 +-
 testsuites/psxtests/psx07/system.h                 | 2 +-
 testsuites/psxtests/psx08/system.h                 | 2 +-
 testsuites/psxtests/psx09/system.h                 | 2 +-
 testsuites/psxtests/psx10/system.h                 | 2 +-
 testsuites/psxtests/psx11/system.h                 | 2 +-
 testsuites/psxtests/psx12/init.c                   | 2 +-
 testsuites/psxtests/psx13/main.c                   | 2 +-
 testsuites/psxtests/psx14/system.h                 | 2 +-
 testsuites/psxtests/psx15/init.c                   | 2 +-
 testsuites/psxtests/psx16/init.c                   | 2 +-
 testsuites/psxtests/psxaio01/system.h              | 2 +-
 testsuites/psxtests/psxaio02/system.h              | 2 +-
 testsuites/psxtests/psxaio03/system.h              | 2 +-
 testsuites/psxtests/psxalarm01/init.c              | 2 +-
 testsuites/psxtests/psxautoinit01/init.c           | 2 +-
 testsuites/psxtests/psxautoinit02/init.c           | 2 +-
 testsuites/psxtests/psxbarrier01/main.c            | 2 +-
 testsuites/psxtests/psxcancel/init.c               | 2 +-
 testsuites/psxtests/psxcancel01/init.c             | 2 +-
 testsuites/psxtests/psxchroot01/main.c             | 2 +-
 testsuites/psxtests/psxclassic01/init.c            | 2 +-
 testsuites/psxtests/psxcleanup/system.h            | 2 +-
 testsuites/psxtests/psxcleanup01/init.c            | 2 +-
 testsuites/psxtests/psxcleanup02/init.c            | 2 +-
 testsuites/psxtests/psxclock/init.c                | 2 +-
 testsuites/psxtests/psxclock01/init.c              | 2 +-
 testsuites/psxtests/psxclockrealtime01/init.c      | 2 +-
 testsuites/psxtests/psxconcurrency01/init.c        | 2 +-
 testsuites/psxtests/psxcond01/init.c               | 2 +-
 testsuites/psxtests/psxcond02/init.c               | 2 +-
 testsuites/psxtests/psxconfig01/init.c             | 2 +-
 testsuites/psxtests/psxeintr_join/init.c           | 2 +-
 testsuites/psxtests/psxenosys/system.h             | 2 +-
 testsuites/psxtests/psxfatal_support/system.h      | 2 +-
 testsuites/psxtests/psxfchx01/init.c               | 2 +-
 testsuites/psxtests/psxfile01/main.c               | 2 +-
 testsuites/psxtests/psxfile02/init.c               | 2 +-
 testsuites/psxtests/psxfilelock01/init.c           | 2 +-
 testsuites/psxtests/psxgetattrnp01/init.c          | 2 +-
 testsuites/psxtests/psxgetrusage01/init.c          | 2 +-
 testsuites/psxtests/psxglobalcon01/init.cc         | 2 +-
 testsuites/psxtests/psxglobalcon02/init.cc         | 2 +-
 testsuites/psxtests/psxid01/init.c                 | 2 +-
 testsuites/psxtests/psximfs01/init.c               | 2 +-
 testsuites/psxtests/psximfs02/init.c               | 2 +-
 testsuites/psxtests/psxintrcritical01/init.c       | 2 +-
 testsuites/psxtests/psxitimer/init.c               | 2 +-
 testsuites/psxtests/psxkey01/system.h              | 2 +-
 testsuites/psxtests/psxkey02/init.c                | 2 +-
 testsuites/psxtests/psxkey03/init.c                | 2 +-
 testsuites/psxtests/psxkey04/init.c                | 2 +-
 testsuites/psxtests/psxkey05/init.c                | 2 +-
 testsuites/psxtests/psxkey06/init.c                | 2 +-
 testsuites/psxtests/psxkey07/init.c                | 2 +-
 testsuites/psxtests/psxkey08/init.c                | 2 +-
 testsuites/psxtests/psxkey09/init.c                | 2 +-
 testsuites/psxtests/psxkey10/init.c                | 2 +-
 testsuites/psxtests/psxmmap01/system.h             | 2 +-
 testsuites/psxtests/psxmount/main.c                | 2 +-
 testsuites/psxtests/psxmsgq01/system.h             | 2 +-
 testsuites/psxtests/psxmsgq02/system.h             | 2 +-
 testsuites/psxtests/psxmsgq03/system.h             | 2 +-
 testsuites/psxtests/psxmsgq04/init.c               | 2 +-
 testsuites/psxtests/psxmutexattr01/init.c          | 2 +-
 testsuites/psxtests/psxobj01/init.c                | 2 +-
 testsuites/psxtests/psxonce01/system.h             | 2 +-
 testsuites/psxtests/psxpasswd01/init.c             | 2 +-
 testsuites/psxtests/psxpasswd02/init.c             | 2 +-
 testsuites/psxtests/psxpipe01/init.c               | 2 +-
 testsuites/psxtests/psxrdwrv/main.c                | 2 +-
 testsuites/psxtests/psxreaddir/main.c              | 2 +-
 testsuites/psxtests/psxrwlock01/main.c             | 2 +-
 testsuites/psxtests/psxsem01/init.c                | 2 +-
 testsuites/psxtests/psxshm01/system.h              | 2 +-
 testsuites/psxtests/psxshm02/system.h              | 2 +-
 testsuites/psxtests/psxsignal01/system.h           | 2 +-
 testsuites/psxtests/psxsignal02/init.c             | 2 +-
 testsuites/psxtests/psxsignal03/init.c             | 2 +-
 testsuites/psxtests/psxsignal05/init.c             | 2 +-
 testsuites/psxtests/psxsignal06/init.c             | 2 +-
 testsuites/psxtests/psxspin01/main.c               | 2 +-
 testsuites/psxtests/psxstack01/init.c              | 2 +-
 testsuites/psxtests/psxstack02/init.c              | 2 +-
 testsuites/psxtests/psxstat/main.c                 | 2 +-
 testsuites/psxtests/psxstrsignal01/init.c          | 2 +-
 testsuites/psxtests/psxsysconf/system.h            | 2 +-
 testsuites/psxtests/psxthreadname01/init.c         | 2 +-
 testsuites/psxtests/psxtime/main.c                 | 2 +-
 testsuites/psxtests/psxtimer01/system.h            | 2 +-
 testsuites/psxtests/psxtimer02/system.h            | 2 +-
 testsuites/psxtests/psxtimes01/init.c              | 2 +-
 testsuites/psxtests/psxualarm/system.h             | 2 +-
 testsuites/psxtests/psxusleep/init.c               | 2 +-
 testsuites/psxtmtests/psxtmbarrier01/init.c        | 2 +-
 testsuites/psxtmtests/psxtmbarrier02/init.c        | 2 +-
 testsuites/psxtmtests/psxtmbarrier03/init.c        | 2 +-
 testsuites/psxtmtests/psxtmbarrier04/init.c        | 2 +-
 testsuites/psxtmtests/psxtmclocknanosleep01/init.c | 2 +-
 testsuites/psxtmtests/psxtmclocknanosleep02/init.c | 2 +-
 testsuites/psxtmtests/psxtmclocknanosleep03/init.c | 2 +-
 testsuites/psxtmtests/psxtmcond01/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond02/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond03/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond04/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond05/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond06/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond07/init.c           | 2 +-
 testsuites/psxtmtests/psxtmcond08/init.c           | 2 +-
 testsuites/psxtmtests/psxtmkey01/init.c            | 2 +-
 testsuites/psxtmtests/psxtmkey02/init.c            | 2 +-
 testsuites/psxtmtests/psxtmmq01/init.c             | 2 +-
 testsuites/psxtmtests/psxtmmutex01/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex02/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex03/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex04/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex05/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex06/init.c          | 2 +-
 testsuites/psxtmtests/psxtmmutex07/init.c          | 2 +-
 testsuites/psxtmtests/psxtmnanosleep01/init.c      | 2 +-
 testsuites/psxtmtests/psxtmnanosleep02/init.c      | 2 +-
 testsuites/psxtmtests/psxtmrwlock01/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock02/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock03/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock04/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock05/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock06/init.c         | 2 +-
 testsuites/psxtmtests/psxtmrwlock07/init.c         | 2 +-
 testsuites/psxtmtests/psxtmsem01/init.c            | 2 +-
 testsuites/psxtmtests/psxtmsem02/init.c            | 2 +-
 testsuites/psxtmtests/psxtmsem03/init.c            | 2 +-
 testsuites/psxtmtests/psxtmsem04/init.c            | 2 +-
 testsuites/psxtmtests/psxtmsem05/init.c            | 2 +-
 testsuites/psxtmtests/psxtmsleep01/init.c          | 2 +-
 testsuites/psxtmtests/psxtmsleep02/init.c          | 2 +-
 testsuites/psxtmtests/psxtmthread01/init.c         | 2 +-
 testsuites/psxtmtests/psxtmthread02/init.c         | 2 +-
 testsuites/psxtmtests/psxtmthread03/init.c         | 2 +-
 testsuites/psxtmtests/psxtmthread04/init.c         | 2 +-
 testsuites/psxtmtests/psxtmthread05/init.c         | 2 +-
 testsuites/psxtmtests/psxtmthread06/init.c         | 2 +-
 testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c  | 2 +-
 testsuites/rhealstone/rhilatency/ilatency.c        | 2 +-
 testsuites/rhealstone/rhmlatency/mlatency.c        | 2 +-
 testsuites/rhealstone/rhsemshuffle/semshuffle.c    | 2 +-
 testsuites/rhealstone/rhtaskpreempt/taskpreempt.c  | 2 +-
 testsuites/rhealstone/rhtaskswitch/taskswitch.c    | 2 +-
 testsuites/samples/base_mp/system.h                | 2 +-
 testsuites/samples/base_sp/system.h                | 2 +-
 testsuites/samples/capture/system.h                | 2 +-
 testsuites/samples/cdtest/system.h                 | 2 +-
 testsuites/samples/fileio/system.h                 | 2 +-
 testsuites/samples/hello/init.c                    | 2 +-
 testsuites/samples/iostream/system.h               | 2 +-
 testsuites/samples/loopback/init.c                 | 2 +-
 testsuites/samples/nsecs/system.h                  | 2 +-
 testsuites/samples/paranoia/system.h               | 2 +-
 testsuites/samples/pppd/system.h                   | 2 +-
 testsuites/samples/ticker/system.h                 | 2 +-
 testsuites/samples/unlimited/system.h              | 2 +-
 testsuites/smptests/smp01/system.h                 | 2 +-
 testsuites/smptests/smp02/system.h                 | 2 +-
 testsuites/smptests/smp03/system.h                 | 2 +-
 testsuites/smptests/smp05/init.c                   | 2 +-
 testsuites/smptests/smp07/init.c                   | 2 +-
 testsuites/smptests/smp08/system.h                 | 2 +-
 testsuites/smptests/smp09/init.c                   | 2 +-
 testsuites/smptests/smpaffinity01/init.c           | 2 +-
 testsuites/smptests/smpatomic01/init.c             | 2 +-
 testsuites/smptests/smpcache01/init.c              | 2 +-
 testsuites/smptests/smpcapture01/init.c            | 2 +-
 testsuites/smptests/smpcapture02/init.c            | 2 +-
 testsuites/smptests/smpclock01/init.c              | 2 +-
 testsuites/smptests/smpfatal01/init.c              | 2 +-
 testsuites/smptests/smpfatal02/init.c              | 2 +-
 testsuites/smptests/smpfatal03/init.c              | 2 +-
 testsuites/smptests/smpfatal04/init.c              | 2 +-
 testsuites/smptests/smpfatal05/init.c              | 2 +-
 testsuites/smptests/smpfatal06/init.c              | 2 +-
 testsuites/smptests/smpfatal08/init.c              | 2 +-
 testsuites/smptests/smpipi01/init.c                | 2 +-
 testsuites/smptests/smpload01/init.c               | 2 +-
 testsuites/smptests/smplock01/init.c               | 2 +-
 testsuites/smptests/smpmigration01/init.c          | 2 +-
 testsuites/smptests/smpmigration02/init.c          | 2 +-
 testsuites/smptests/smpmrsp01/init.c               | 2 +-
 testsuites/smptests/smpmutex01/init.c              | 2 +-
 testsuites/smptests/smpmutex02/init.c              | 2 +-
 testsuites/smptests/smppsxaffinity01/init.c        | 2 +-
 testsuites/smptests/smppsxaffinity02/init.c        | 2 +-
 testsuites/smptests/smppsxmutex01/init.c           | 2 +-
 testsuites/smptests/smppsxsignal01/init.c          | 2 +-
 testsuites/smptests/smpschedaffinity01/init.c      | 2 +-
 testsuites/smptests/smpschedaffinity02/init.c      | 2 +-
 testsuites/smptests/smpschedaffinity03/init.c      | 2 +-
 testsuites/smptests/smpschedaffinity04/init.c      | 2 +-
 testsuites/smptests/smpschedaffinity05/init.c      | 2 +-
 testsuites/smptests/smpschededf01/init.c           | 2 +-
 testsuites/smptests/smpschededf02/init.c           | 2 +-
 testsuites/smptests/smpschededf03/init.c           | 2 +-
 testsuites/smptests/smpschedsem01/init.c           | 2 +-
 testsuites/smptests/smpscheduler01/init.c          | 2 +-
 testsuites/smptests/smpscheduler02/init.c          | 2 +-
 testsuites/smptests/smpscheduler03/init.c          | 2 +-
 testsuites/smptests/smpscheduler04/init.c          | 2 +-
 testsuites/smptests/smpscheduler05/init.c          | 2 +-
 testsuites/smptests/smpscheduler06/init.c          | 2 +-
 testsuites/smptests/smpscheduler07/init.c          | 2 +-
 testsuites/smptests/smpsignal01/init.c             | 2 +-
 testsuites/smptests/smpstrongapa01/init.c          | 2 +-
 testsuites/smptests/smpswitchextension01/init.c    | 2 +-
 testsuites/smptests/smpthreadlife01/init.c         | 2 +-
 testsuites/smptests/smpunsupported01/init.c        | 2 +-
 testsuites/smptests/smpwakeafter01/init.c          | 2 +-
 testsuites/sptests/sp01/system.h                   | 2 +-
 testsuites/sptests/sp02/system.h                   | 2 +-
 testsuites/sptests/sp03/system.h                   | 2 +-
 testsuites/sptests/sp04/system.h                   | 2 +-
 testsuites/sptests/sp05/system.h                   | 2 +-
 testsuites/sptests/sp06/system.h                   | 2 +-
 testsuites/sptests/sp07/system.h                   | 2 +-
 testsuites/sptests/sp08/init.c                     | 2 +-
 testsuites/sptests/sp11/system.h                   | 2 +-
 testsuites/sptests/sp12/system.h                   | 2 +-
 testsuites/sptests/sp13/system.h                   | 2 +-
 testsuites/sptests/sp14/system.h                   | 2 +-
 testsuites/sptests/sp15/system.h                   | 2 +-
 testsuites/sptests/sp16/system.h                   | 2 +-
 testsuites/sptests/sp17/system.h                   | 2 +-
 testsuites/sptests/sp18/init.c                     | 2 +-
 testsuites/sptests/sp19/system.h                   | 2 +-
 testsuites/sptests/sp20/system.h                   | 2 +-
 testsuites/sptests/sp2038/init.c                   | 2 +-
 testsuites/sptests/sp22/system.h                   | 2 +-
 testsuites/sptests/sp23/system.h                   | 2 +-
 testsuites/sptests/sp24/system.h                   | 2 +-
 testsuites/sptests/sp25/system.h                   | 2 +-
 testsuites/sptests/sp26/system.h                   | 2 +-
 testsuites/sptests/sp27/init.c                     | 2 +-
 testsuites/sptests/sp29/init.c                     | 2 +-
 testsuites/sptests/sp30/system.h                   | 2 +-
 testsuites/sptests/sp31/system.h                   | 2 +-
 testsuites/sptests/sp32/init.c                     | 2 +-
 testsuites/sptests/sp33/init.c                     | 2 +-
 testsuites/sptests/sp34/changepri.c                | 2 +-
 testsuites/sptests/sp35/priinv.c                   | 2 +-
 testsuites/sptests/sp36/strict_order_mut.c         | 2 +-
 testsuites/sptests/sp37/system.h                   | 2 +-
 testsuites/sptests/sp38/system.h                   | 2 +-
 testsuites/sptests/sp40/init.c                     | 4 ++--
 testsuites/sptests/sp41/init.c                     | 2 +-
 testsuites/sptests/sp42/init.c                     | 2 +-
 testsuites/sptests/sp43/system.h                   | 2 +-
 testsuites/sptests/sp44/init.c                     | 2 +-
 testsuites/sptests/sp45/init.c                     | 2 +-
 testsuites/sptests/sp46/init.c                     | 2 +-
 testsuites/sptests/sp47/init.c                     | 2 +-
 testsuites/sptests/sp48/init.c                     | 2 +-
 testsuites/sptests/sp49/init.c                     | 2 +-
 testsuites/sptests/sp50/init.c                     | 2 +-
 testsuites/sptests/sp51/init.c                     | 2 +-
 testsuites/sptests/sp52/init.c                     | 2 +-
 testsuites/sptests/sp54/init.c                     | 2 +-
 testsuites/sptests/sp55/init.c                     | 2 +-
 testsuites/sptests/sp56/init.c                     | 2 +-
 testsuites/sptests/sp57/init.c                     | 2 +-
 testsuites/sptests/sp58/init.c                     | 2 +-
 testsuites/sptests/sp59/init.c                     | 2 +-
 testsuites/sptests/sp60/init.c                     | 2 +-
 testsuites/sptests/sp62/init.c                     | 2 +-
 testsuites/sptests/sp63/init.c                     | 2 +-
 testsuites/sptests/sp64/init.c                     | 2 +-
 testsuites/sptests/sp65/init.c                     | 2 +-
 testsuites/sptests/sp67/init.c                     | 2 +-
 testsuites/sptests/sp68/init.c                     | 2 +-
 testsuites/sptests/sp69/init.c                     | 2 +-
 testsuites/sptests/sp70/init.c                     | 2 +-
 testsuites/sptests/sp71/init.c                     | 2 +-
 testsuites/sptests/sp72/init.c                     | 2 +-
 testsuites/sptests/sp73/init.c                     | 2 +-
 testsuites/sptests/sp74/init.c                     | 2 +-
 testsuites/sptests/sp75/init.c                     | 2 +-
 testsuites/sptests/sp76/init.c                     | 2 +-
 testsuites/sptests/sp77/init.c                     | 2 +-
 testsuites/sptests/spassoc01/init.c                | 2 +-
 testsuites/sptests/spatomic01/init.c               | 2 +-
 testsuites/sptests/spcache01/init.c                | 2 +-
 testsuites/sptests/spcbssched01/system.h           | 2 +-
 testsuites/sptests/spcbssched02/system.h           | 2 +-
 testsuites/sptests/spcbssched03/system.h           | 2 +-
 testsuites/sptests/spchain/init.c                  | 2 +-
 testsuites/sptests/spclock_err01/system.h          | 2 +-
 testsuites/sptests/spclock_err02/init.c            | 2 +-
 testsuites/sptests/spcontext01/init.c              | 2 +-
 testsuites/sptests/spcoverage/init.c               | 2 +-
 testsuites/sptests/spcpucounter01/init.c           | 2 +-
 testsuites/sptests/spcpuset01/system.h             | 2 +-
 testsuites/sptests/spedfsched01/system.h           | 2 +-
 testsuites/sptests/spedfsched02/system.h           | 2 +-
 testsuites/sptests/spedfsched03/system.h           | 2 +-
 testsuites/sptests/spedfsched04/init.c             | 2 +-
 testsuites/sptests/sperror01/init.c                | 2 +-
 testsuites/sptests/sperror02/init.c                | 2 +-
 testsuites/sptests/sperror03/init.c                | 2 +-
 testsuites/sptests/spevent_err03/system.h          | 2 +-
 testsuites/sptests/speventsystem01/init.c          | 2 +-
 testsuites/sptests/speventtransient01/init.c       | 2 +-
 testsuites/sptests/spextensions01/init.c           | 2 +-
 testsuites/sptests/spfatal17/testcase.h            | 2 ++
 testsuites/sptests/spfatal18/testcase.h            | 2 ++
 testsuites/sptests/spfatal19/testcase.h            | 2 ++
 testsuites/sptests/spfatal20/testcase.h            | 2 ++
 testsuites/sptests/spfatal_support/system.h        | 4 ++++
 testsuites/sptests/spfifo01/init.c                 | 2 +-
 testsuites/sptests/spfifo02/init.c                 | 2 +-
 testsuites/sptests/spfifo03/init.c                 | 2 +-
 testsuites/sptests/spfifo04/init.c                 | 2 +-
 testsuites/sptests/spfifo05/init.c                 | 2 +-
 testsuites/sptests/spfreechain01/init.c            | 2 +-
 testsuites/sptests/spglobalcon01/init.cc           | 2 +-
 testsuites/sptests/spheapprot/init.c               | 2 +-
 testsuites/sptests/spinternalerror02/init.c        | 2 +-
 testsuites/sptests/spintr_err01/system.h           | 2 +-
 testsuites/sptests/spintrcritical01/init.c         | 2 +-
 testsuites/sptests/spintrcritical06/init.c         | 2 +-
 testsuites/sptests/spintrcritical08/init.c         | 2 +-
 testsuites/sptests/spintrcritical09/init.c         | 2 +-
 testsuites/sptests/spintrcritical10/init.c         | 2 +-
 testsuites/sptests/spintrcritical11/init.c         | 2 +-
 testsuites/sptests/spintrcritical13/init.c         | 2 +-
 testsuites/sptests/spintrcritical15/init.c         | 2 +-
 testsuites/sptests/spintrcritical16/init.c         | 2 +-
 testsuites/sptests/spintrcritical18/init.c         | 2 +-
 testsuites/sptests/spintrcritical20/init.c         | 2 +-
 testsuites/sptests/spintrcritical21/system.h       | 2 +-
 testsuites/sptests/spintrcritical22/init.c         | 2 +-
 testsuites/sptests/spintrcritical23/init.c         | 2 +-
 testsuites/sptests/spintrcritical24/init.c         | 2 +-
 testsuites/sptests/splinkersets01/init.c           | 2 +-
 testsuites/sptests/spmkdir/init.c                  | 2 +-
 testsuites/sptests/spmountmgr01/init.c             | 2 +-
 testsuites/sptests/spmrsp01/init.c                 | 2 +-
 testsuites/sptests/spmsgq_err01/system.h           | 2 +-
 testsuites/sptests/spmsgq_err02/system.h           | 2 +-
 testsuites/sptests/spmutex01/init.c                | 2 +-
 testsuites/sptests/spnsext01/init.c                | 2 +-
 testsuites/sptests/spobjgetnext/system.h           | 2 +-
 testsuites/sptests/sppagesize/init.c               | 2 +-
 testsuites/sptests/sppartition_err01/system.h      | 2 +-
 testsuites/sptests/spport_err01/system.h           | 2 +-
 testsuites/sptests/spprivenv01/init.c              | 2 +-
 testsuites/sptests/spprofiling01/init.c            | 2 +-
 testsuites/sptests/spqreslib/system.h              | 2 +-
 testsuites/sptests/spratemon_err01/system.h        | 2 +-
 testsuites/sptests/sprbtree01/init.c               | 2 +-
 testsuites/sptests/spregion_err01/system.h         | 2 +-
 testsuites/sptests/sprmsched01/init.c              | 2 +-
 testsuites/sptests/sprmsched02/init.c              | 2 +-
 testsuites/sptests/spscheduler01/init.c            | 2 +-
 testsuites/sptests/spsem01/init.c                  | 2 +-
 testsuites/sptests/spsem02/init.c                  | 2 +-
 testsuites/sptests/spsem03/init.c                  | 2 +-
 testsuites/sptests/spsem_err01/system.h            | 2 +-
 testsuites/sptests/spsem_err02/system.h            | 2 +-
 testsuites/sptests/spsignal_err01/system.h         | 2 +-
 testsuites/sptests/spsimplesched01/init.c          | 2 +-
 testsuites/sptests/spsimplesched02/init.c          | 2 +-
 testsuites/sptests/spsimplesched03/init.c          | 2 +-
 testsuites/sptests/spsize/system.h                 | 2 +-
 testsuites/sptests/spstdthreads01/init.c           | 2 +-
 testsuites/sptests/spstkalloc/init.c               | 2 +-
 testsuites/sptests/spstkalloc02/init.c             | 2 +-
 testsuites/sptests/spsysinit01/init.c              | 2 +-
 testsuites/sptests/spsyslock01/init.c              | 2 +-
 testsuites/sptests/sptask_err01/system.h           | 2 +-
 testsuites/sptests/sptask_err02/system.h           | 2 +-
 testsuites/sptests/sptask_err03/system.h           | 2 +-
 testsuites/sptests/sptask_err04/system.h           | 2 +-
 testsuites/sptests/sptasknopreempt01/init.c        | 2 +-
 testsuites/sptests/spthreadlife01/init.c           | 2 +-
 testsuites/sptests/spthreadq01/init.c              | 2 +-
 testsuites/sptests/sptimecounter02/init.c          | 2 +-
 testsuites/sptests/sptimecounter03/init.c          | 2 +-
 testsuites/sptests/sptimecounter04/init.c          | 2 +-
 testsuites/sptests/sptimer_err01/init.c            | 2 +-
 testsuites/sptests/sptimer_err02/init.c            | 2 +-
 testsuites/sptests/sptimerserver01/init.c          | 2 +-
 testsuites/sptests/sptimespec01/init.c             | 2 +-
 testsuites/sptests/sptls01/init.c                  | 2 +-
 testsuites/sptests/sptls02/init.cc                 | 2 +-
 testsuites/sptests/sptls03/init.c                  | 2 +-
 testsuites/sptests/spwatchdog/system.h             | 2 +-
 testsuites/sptests/spwkspace/init.c                | 2 +-
 testsuites/tmtests/tm01/system.h                   | 2 +-
 testsuites/tmtests/tm02/system.h                   | 2 +-
 testsuites/tmtests/tm03/system.h                   | 2 +-
 testsuites/tmtests/tm04/system.h                   | 2 +-
 testsuites/tmtests/tm05/system.h                   | 2 +-
 testsuites/tmtests/tm06/system.h                   | 2 +-
 testsuites/tmtests/tm07/system.h                   | 2 +-
 testsuites/tmtests/tm08/system.h                   | 2 +-
 testsuites/tmtests/tm09/system.h                   | 2 +-
 testsuites/tmtests/tm10/system.h                   | 2 +-
 testsuites/tmtests/tm11/system.h                   | 2 +-
 testsuites/tmtests/tm12/system.h                   | 2 +-
 testsuites/tmtests/tm13/system.h                   | 2 +-
 testsuites/tmtests/tm14/system.h                   | 2 +-
 testsuites/tmtests/tm15/system.h                   | 2 +-
 testsuites/tmtests/tm16/system.h                   | 2 +-
 testsuites/tmtests/tm17/system.h                   | 2 +-
 testsuites/tmtests/tm18/system.h                   | 2 +-
 testsuites/tmtests/tm19/system.h                   | 2 +-
 testsuites/tmtests/tm20/system.h                   | 2 +-
 testsuites/tmtests/tm21/system.h                   | 2 +-
 testsuites/tmtests/tm22/system.h                   | 2 +-
 testsuites/tmtests/tm23/system.h                   | 2 +-
 testsuites/tmtests/tm24/system.h                   | 2 +-
 testsuites/tmtests/tm25/system.h                   | 2 +-
 testsuites/tmtests/tm26/system.h                   | 2 +-
 testsuites/tmtests/tm27/system.h                   | 2 +-
 testsuites/tmtests/tm28/system.h                   | 2 +-
 testsuites/tmtests/tm29/system.h                   | 2 +-
 testsuites/tmtests/tm30/init.c                     | 2 +-
 testsuites/tmtests/tmck/system.h                   | 2 +-
 testsuites/tmtests/tmcontext01/init.c              | 2 +-
 testsuites/tmtests/tmfine01/init.c                 | 2 +-
 testsuites/tmtests/tmoverhd/system.h               | 2 +-
 testsuites/tmtests/tmtimer01/init.c                | 2 +-
 618 files changed, 626 insertions(+), 614 deletions(-)
diff --git a/testsuites/ada/mptests/mp01/config_base.h b/testsuites/ada/mptests/mp01/config_base.h
index c1b8f24e86..2559d1a9ae 100644
--- a/testsuites/ada/mptests/mp01/config_base.h
+++ b/testsuites/ada/mptests/mp01/config_base.h
@@ -13,7 +13,7 @@
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/ada/mptests/mp03/config_base.h b/testsuites/ada/mptests/mp03/config_base.h
--- a/testsuites/ada/mptests/mp03/config_base.h
+++ b/testsuites/ada/mptests/mp03/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp04/config_base.h b/testsuites/ada/mptests/mp04/config_base.h
--- a/testsuites/ada/mptests/mp04/config_base.h
+++ b/testsuites/ada/mptests/mp04/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp05/config_base.h b/testsuites/ada/mptests/mp05/config_base.h
--- a/testsuites/ada/mptests/mp05/config_base.h
+++ b/testsuites/ada/mptests/mp05/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp06/config_base.h b/testsuites/ada/mptests/mp06/config_base.h
--- a/testsuites/ada/mptests/mp06/config_base.h
+++ b/testsuites/ada/mptests/mp06/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp07/config_base.h b/testsuites/ada/mptests/mp07/config_base.h
--- a/testsuites/ada/mptests/mp07/config_base.h
+++ b/testsuites/ada/mptests/mp07/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp08/config_base.h b/testsuites/ada/mptests/mp08/config_base.h
--- a/testsuites/ada/mptests/mp08/config_base.h
+++ b/testsuites/ada/mptests/mp08/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp09/config_base.h b/testsuites/ada/mptests/mp09/config_base.h
--- a/testsuites/ada/mptests/mp09/config_base.h
+++ b/testsuites/ada/mptests/mp09/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp10/config_base.h b/testsuites/ada/mptests/mp10/config_base.h
--- a/testsuites/ada/mptests/mp10/config_base.h
+++ b/testsuites/ada/mptests/mp10/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp11/config_base.h b/testsuites/ada/mptests/mp11/config_base.h
--- a/testsuites/ada/mptests/mp11/config_base.h
+++ b/testsuites/ada/mptests/mp11/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp12/config_base.h b/testsuites/ada/mptests/mp12/config_base.h
--- a/testsuites/ada/mptests/mp12/config_base.h
+++ b/testsuites/ada/mptests/mp12/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp13/config_base.h b/testsuites/ada/mptests/mp13/config_base.h
--- a/testsuites/ada/mptests/mp13/config_base.h
+++ b/testsuites/ada/mptests/mp13/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/mptests/mp14/config_base.h b/testsuites/ada/mptests/mp14/config_base.h
--- a/testsuites/ada/mptests/mp14/config_base.h
+++ b/testsuites/ada/mptests/mp14/config_base.h
@@ -13,7 +13,7 @@
diff --git a/testsuites/ada/samples/base_mp/config.h b/testsuites/ada/samples/base_mp/config.h
index 33c9288f4c..1b73abc7a9 100644
--- a/testsuites/ada/samples/base_mp/config.h
+++ b/testsuites/ada/samples/base_mp/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MP_APPLICATION
 #define CONFIGURE_MAXIMUM_TASKS           2
diff --git a/testsuites/ada/samples/base_sp/config.h b/testsuites/ada/samples/base_sp/config.h
index 083d52515e..8f26c8e031 100644
--- a/testsuites/ada/samples/base_sp/config.h
+++ b/testsuites/ada/samples/base_sp/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_SPTEST
diff --git a/testsuites/ada/samples/hello/config.h b/testsuites/ada/samples/hello/config.h
index 2be186cc2a..bab1fc5232 100644
--- a/testsuites/ada/samples/hello/config.h
+++ b/testsuites/ada/samples/hello/config.h
@@ -17,7 +17,7 @@
 /* NOTICE: the clock driver is explicitly disabled */
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
diff --git a/testsuites/ada/samples/nsecs/config.h b/testsuites/ada/samples/nsecs/config.h
index 7703e721f0..9f3337801b 100644
--- a/testsuites/ada/samples/nsecs/config.h
+++ b/testsuites/ada/samples/nsecs/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/samples/ticker/config.h b/testsuites/ada/samples/ticker/config.h
index 17d957c94a..24242c6c5e 100644
--- a/testsuites/ada/samples/ticker/config.h
+++ b/testsuites/ada/samples/ticker/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp01/config.h b/testsuites/ada/sptests/sp01/config.h
index 3a11342306..0cd63fba29 100644
--- a/testsuites/ada/sptests/sp01/config.h
+++ b/testsuites/ada/sptests/sp01/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp02/config.h b/testsuites/ada/sptests/sp02/config.h
--- a/testsuites/ada/sptests/sp02/config.h
+++ b/testsuites/ada/sptests/sp02/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp03/config.h b/testsuites/ada/sptests/sp03/config.h
index 393afc4b28..5d19b616a4 100644
--- a/testsuites/ada/sptests/sp03/config.h
+++ b/testsuites/ada/sptests/sp03/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp04/config.h b/testsuites/ada/sptests/sp04/config.h
index 45fc324df8..1590712bb8 100644
--- a/testsuites/ada/sptests/sp04/config.h
+++ b/testsuites/ada/sptests/sp04/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS     1
diff --git a/testsuites/ada/sptests/sp05/config.h b/testsuites/ada/sptests/sp05/config.h
index d85c77e62b..9e8a780551 100644
--- a/testsuites/ada/sptests/sp05/config.h
+++ b/testsuites/ada/sptests/sp05/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_TICKS_PER_TIMESLICE       100
diff --git a/testsuites/ada/sptests/sp06/config.h b/testsuites/ada/sptests/sp06/config.h
--- a/testsuites/ada/sptests/sp06/config.h
+++ b/testsuites/ada/sptests/sp06/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp07/config.h b/testsuites/ada/sptests/sp07/config.h
index 2aa307a46c..4812e0f8c3 100644
--- a/testsuites/ada/sptests/sp07/config.h
+++ b/testsuites/ada/sptests/sp07/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp08/config.h b/testsuites/ada/sptests/sp08/config.h
index 6ada011600..3d395dd3f3 100644
--- a/testsuites/ada/sptests/sp08/config.h
+++ b/testsuites/ada/sptests/sp08/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp09/config.h b/testsuites/ada/sptests/sp09/config.h
index a94c222fa1..be6424b789 100644
--- a/testsuites/ada/sptests/sp09/config.h
+++ b/testsuites/ada/sptests/sp09/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS              10
diff --git a/testsuites/ada/sptests/sp11/config.h b/testsuites/ada/sptests/sp11/config.h
index 41506d08ee..84e6f3d79f 100644
--- a/testsuites/ada/sptests/sp11/config.h
+++ b/testsuites/ada/sptests/sp11/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS               3
diff --git a/testsuites/ada/sptests/sp12/config.h b/testsuites/ada/sptests/sp12/config.h
index cd574e737f..c176cbc835 100644
--- a/testsuites/ada/sptests/sp12/config.h
+++ b/testsuites/ada/sptests/sp12/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS               8
diff --git a/testsuites/ada/sptests/sp13/config.h b/testsuites/ada/sptests/sp13/config.h
index 8e7821e061..b330e5ef3f 100644
--- a/testsuites/ada/sptests/sp13/config.h
+++ b/testsuites/ada/sptests/sp13/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS               4
diff --git a/testsuites/ada/sptests/sp14/config.h b/testsuites/ada/sptests/sp14/config.h
index 2c046d6db3..75f5f5c22b 100644
--- a/testsuites/ada/sptests/sp14/config.h
+++ b/testsuites/ada/sptests/sp14/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp15/config.h b/testsuites/ada/sptests/sp15/config.h
index 7774f3563c..72875b1d02 100644
--- a/testsuites/ada/sptests/sp15/config.h
+++ b/testsuites/ada/sptests/sp15/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp16/config.h b/testsuites/ada/sptests/sp16/config.h
index 087a4c5a49..331000425f 100644
--- a/testsuites/ada/sptests/sp16/config.h
+++ b/testsuites/ada/sptests/sp16/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp17/config.h b/testsuites/ada/sptests/sp17/config.h
index 0ceab6f736..513a22b5f9 100644
--- a/testsuites/ada/sptests/sp17/config.h
+++ b/testsuites/ada/sptests/sp17/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp19/config.h b/testsuites/ada/sptests/sp19/config.h
index 278aaf69b0..13c4de8fa8 100644
--- a/testsuites/ada/sptests/sp19/config.h
+++ b/testsuites/ada/sptests/sp19/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp20/config.h b/testsuites/ada/sptests/sp20/config.h
index daf598bf4c..ba57dfae4d 100644
--- a/testsuites/ada/sptests/sp20/config.h
+++ b/testsuites/ada/sptests/sp20/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS               7
diff --git a/testsuites/ada/sptests/sp22/config.h b/testsuites/ada/sptests/sp22/config.h
index b8ed5c97d0..996aebcb64 100644
--- a/testsuites/ada/sptests/sp22/config.h
+++ b/testsuites/ada/sptests/sp22/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp23/config.h b/testsuites/ada/sptests/sp23/config.h
index 277e38b708..8fb27c6d46 100644
--- a/testsuites/ada/sptests/sp23/config.h
+++ b/testsuites/ada/sptests/sp23/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp24/config.h b/testsuites/ada/sptests/sp24/config.h
index a72dd35dac..f4239b5c25 100644
--- a/testsuites/ada/sptests/sp24/config.h
+++ b/testsuites/ada/sptests/sp24/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/sp25/config.h b/testsuites/ada/sptests/sp25/config.h
index aa74afdd45..7c6db12bec 100644
--- a/testsuites/ada/sptests/sp25/config.h
+++ b/testsuites/ada/sptests/sp25/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/sptests/spatcb01/config.h b/testsuites/ada/sptests/spatcb01/config.h
index 405b536c82..530f0dddf8 100644
--- a/testsuites/ada/sptests/spatcb01/config.h
+++ b/testsuites/ada/sptests/spatcb01/config.h
@@ -6,7 +6,7 @@
  *  http://www.rtems.org/license/LICENSE.
diff --git a/testsuites/ada/sptests/spname01/config.h b/testsuites/ada/sptests/spname01/config.h
--- a/testsuites/ada/sptests/spname01/config.h
+++ b/testsuites/ada/sptests/spname01/config.h
@@ -17,7 +17,7 @@
diff --git a/testsuites/ada/tmtests/tm01/config.h b/testsuites/ada/tmtests/tm01/config.h
index 7730385b3c..fac8bedb98 100644
--- a/testsuites/ada/tmtests/tm01/config.h
+++ b/testsuites/ada/tmtests/tm01/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_TMTEST
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
diff --git a/testsuites/ada/tmtests/tm02/config.h b/testsuites/ada/tmtests/tm02/config.h
index b03802dcc5..ffb8dc3723 100644
--- a/testsuites/ada/tmtests/tm02/config.h
+++ b/testsuites/ada/tmtests/tm02/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS              111
diff --git a/testsuites/ada/tmtests/tm03/config.h b/testsuites/ada/tmtests/tm03/config.h
--- a/testsuites/ada/tmtests/tm03/config.h
+++ b/testsuites/ada/tmtests/tm03/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm04/config.h b/testsuites/ada/tmtests/tm04/config.h
index 700438ceae..0a37e7f8e6 100644
--- a/testsuites/ada/tmtests/tm04/config.h
+++ b/testsuites/ada/tmtests/tm04/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm05/config.h b/testsuites/ada/tmtests/tm05/config.h
--- a/testsuites/ada/tmtests/tm05/config.h
+++ b/testsuites/ada/tmtests/tm05/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm06/config.h b/testsuites/ada/tmtests/tm06/config.h
--- a/testsuites/ada/tmtests/tm06/config.h
+++ b/testsuites/ada/tmtests/tm06/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm07/config.h b/testsuites/ada/tmtests/tm07/config.h
--- a/testsuites/ada/tmtests/tm07/config.h
+++ b/testsuites/ada/tmtests/tm07/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm08/config.h b/testsuites/ada/tmtests/tm08/config.h
--- a/testsuites/ada/tmtests/tm08/config.h
+++ b/testsuites/ada/tmtests/tm08/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm09/config.h b/testsuites/ada/tmtests/tm09/config.h
index 56b5b2848e..5b40e5c8da 100644
--- a/testsuites/ada/tmtests/tm09/config.h
+++ b/testsuites/ada/tmtests/tm09/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm10/config.h b/testsuites/ada/tmtests/tm10/config.h
index ee201258aa..7d4d661a2e 100644
--- a/testsuites/ada/tmtests/tm10/config.h
+++ b/testsuites/ada/tmtests/tm10/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS              110
diff --git a/testsuites/ada/tmtests/tm11/config.h b/testsuites/ada/tmtests/tm11/config.h
index a5064b6e92..f5412f0119 100644
--- a/testsuites/ada/tmtests/tm11/config.h
+++ b/testsuites/ada/tmtests/tm11/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm12/config.h b/testsuites/ada/tmtests/tm12/config.h
--- a/testsuites/ada/tmtests/tm12/config.h
+++ b/testsuites/ada/tmtests/tm12/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm13/config.h b/testsuites/ada/tmtests/tm13/config.h
--- a/testsuites/ada/tmtests/tm13/config.h
+++ b/testsuites/ada/tmtests/tm13/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm14/config.h b/testsuites/ada/tmtests/tm14/config.h
--- a/testsuites/ada/tmtests/tm14/config.h
+++ b/testsuites/ada/tmtests/tm14/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm15/config.h b/testsuites/ada/tmtests/tm15/config.h
--- a/testsuites/ada/tmtests/tm15/config.h
+++ b/testsuites/ada/tmtests/tm15/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm16/config.h b/testsuites/ada/tmtests/tm16/config.h
--- a/testsuites/ada/tmtests/tm16/config.h
+++ b/testsuites/ada/tmtests/tm16/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm17/config.h b/testsuites/ada/tmtests/tm17/config.h
--- a/testsuites/ada/tmtests/tm17/config.h
+++ b/testsuites/ada/tmtests/tm17/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm18/config.h b/testsuites/ada/tmtests/tm18/config.h
--- a/testsuites/ada/tmtests/tm18/config.h
+++ b/testsuites/ada/tmtests/tm18/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm19/config.h b/testsuites/ada/tmtests/tm19/config.h
--- a/testsuites/ada/tmtests/tm19/config.h
+++ b/testsuites/ada/tmtests/tm19/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm20/config.h b/testsuites/ada/tmtests/tm20/config.h
index 30b26944d9..5ba47ff16a 100644
--- a/testsuites/ada/tmtests/tm20/config.h
+++ b/testsuites/ada/tmtests/tm20/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_PARTITIONS         1
diff --git a/testsuites/ada/tmtests/tm21/config.h b/testsuites/ada/tmtests/tm21/config.h
index d4b8bc5054..92e63bd2e9 100644
--- a/testsuites/ada/tmtests/tm21/config.h
+++ b/testsuites/ada/tmtests/tm21/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS              102
diff --git a/testsuites/ada/tmtests/tm22/config.h b/testsuites/ada/tmtests/tm22/config.h
index c1585c7ef4..2bceeec20d 100644
--- a/testsuites/ada/tmtests/tm22/config.h
+++ b/testsuites/ada/tmtests/tm22/config.h
@@ -15,7 +15,7 @@
 #define CONFIGURE_MAXIMUM_TASKS              103
diff --git a/testsuites/ada/tmtests/tm23/config.h b/testsuites/ada/tmtests/tm23/config.h
index 15e3e1ccf6..1873730f52 100644
--- a/testsuites/ada/tmtests/tm23/config.h
+++ b/testsuites/ada/tmtests/tm23/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm24/config.h b/testsuites/ada/tmtests/tm24/config.h
index 85640d92a9..0e9cbf456d 100644
--- a/testsuites/ada/tmtests/tm24/config.h
+++ b/testsuites/ada/tmtests/tm24/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm25/config.h b/testsuites/ada/tmtests/tm25/config.h
--- a/testsuites/ada/tmtests/tm25/config.h
+++ b/testsuites/ada/tmtests/tm25/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm28/config.h b/testsuites/ada/tmtests/tm28/config.h
index 2f73cd5acb..d050077d01 100644
--- a/testsuites/ada/tmtests/tm28/config.h
+++ b/testsuites/ada/tmtests/tm28/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tm29/config.h b/testsuites/ada/tmtests/tm29/config.h
index e9165e59c8..85aa0d9efa 100644
--- a/testsuites/ada/tmtests/tm29/config.h
+++ b/testsuites/ada/tmtests/tm29/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tmck/config.h b/testsuites/ada/tmtests/tmck/config.h
--- a/testsuites/ada/tmtests/tmck/config.h
+++ b/testsuites/ada/tmtests/tmck/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/ada/tmtests/tmoverhd/config.h b/testsuites/ada/tmtests/tmoverhd/config.h
--- a/testsuites/ada/tmtests/tmoverhd/config.h
+++ b/testsuites/ada/tmtests/tmoverhd/config.h
@@ -15,7 +15,7 @@
diff --git a/testsuites/benchmarks/dhrystone/init.c b/testsuites/benchmarks/dhrystone/init.c
index 44c3f27683..9ff4662d16 100644
--- a/testsuites/benchmarks/dhrystone/init.c
+++ b/testsuites/benchmarks/dhrystone/init.c
@@ -40,7 +40,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/benchmarks/linpack/init.c b/testsuites/benchmarks/linpack/init.c
index de5a61489f..ce9e0e7448 100644
--- a/testsuites/benchmarks/linpack/init.c
+++ b/testsuites/benchmarks/linpack/init.c
diff --git a/testsuites/benchmarks/whetstone/init.c b/testsuites/benchmarks/whetstone/init.c
index 2f9a34067b..0e8f7a4893 100644
--- a/testsuites/benchmarks/whetstone/init.c
+++ b/testsuites/benchmarks/whetstone/init.c
diff --git a/testsuites/fstests/fsbdpart01/init.c b/testsuites/fstests/fsbdpart01/init.c
index f339255469..0ac42c5a1d 100644
--- a/testsuites/fstests/fsbdpart01/init.c
+++ b/testsuites/fstests/fsbdpart01/init.c
@@ -224,7 +224,7 @@ rtems_ramdisk_config rtems_ramdisk_configuration [] = {
 size_t rtems_ramdisk_configuration_size = 1;
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS RAMDISK_DRIVER_TABLE_ENTRY
 #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
diff --git a/testsuites/fstests/fsclose01/init.c b/testsuites/fstests/fsclose01/init.c
index 77df082036..3b65b3b432 100644
--- a/testsuites/fstests/fsclose01/init.c
+++ b/testsuites/fstests/fsclose01/init.c
@@ -516,7 +516,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index b7df74883a..fb5896dca4 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -510,7 +510,7 @@ static void Init( rtems_task_argument arg )
 /* one active file + stdin + stdout + stderr + device file when mounted */
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index f272945d89..b796dee40f 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -1355,7 +1355,7 @@ size_t rtems_ramdisk_configuration_size = RTEMS_ARRAY_SIZE(rtems_ramdisk_configu
 #define CONFIGURE_INIT_TASK_STACK_SIZE ( 1024 * 64 )
 #define CONFIGURE_MAXIMUM_DRIVERS 4
 #define CONFIGURE_MAXIMUM_SEMAPHORES (2 * RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE)
diff --git a/testsuites/fstests/fsdosfsname02/init.c b/testsuites/fstests/fsdosfsname02/init.c
index 0496ca00a4..929157b18b 100644
--- a/testsuites/fstests/fsdosfsname02/init.c
+++ b/testsuites/fstests/fsdosfsname02/init.c
@@ -93,7 +93,7 @@ rtems_ramdisk_config rtems_ramdisk_configuration[] = {
 size_t rtems_ramdisk_configuration_size = RTEMS_ARRAY_SIZE(rtems_ramdisk_configuration);
diff --git a/testsuites/fstests/fsdosfssync01/init.c b/testsuites/fstests/fsdosfssync01/init.c
index c53d2ccc7b..5aee87622c 100644
--- a/testsuites/fstests/fsdosfssync01/init.c
+++ b/testsuites/fstests/fsdosfssync01/init.c
@@ -156,7 +156,7 @@ rtems_ramdisk_config rtems_ramdisk_configuration [] = {
diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
index 525a882d48..91111cc7fe 100644
--- a/testsuites/fstests/fsdosfswrite01/init.c
+++ b/testsuites/fstests/fsdosfswrite01/init.c
@@ -287,7 +287,7 @@ static void Init( rtems_task_argument arg )
 #define CONFIGURE_FILESYSTEM_DOSFS
diff --git a/testsuites/fstests/fsfseeko01/init.c b/testsuites/fstests/fsfseeko01/init.c
index dd073ce86a..26aa9a7ea8 100644
--- a/testsuites/fstests/fsfseeko01/init.c
+++ b/testsuites/fstests/fsfseeko01/init.c
@@ -96,7 +96,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
diff --git a/testsuites/fstests/fsimfsconfig02/init.c b/testsuites/fstests/fsimfsconfig02/init.c
index 35f9c83b58..0e3febd18c 100644
--- a/testsuites/fstests/fsimfsconfig02/init.c
+++ b/testsuites/fstests/fsimfsconfig02/init.c
@@ -66,7 +66,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_FILESYSTEM_IMFS
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index 45d6d1cc2d..300bc01178 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -490,7 +490,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/fstests/fsrofs01/init.c b/testsuites/fstests/fsrofs01/init.c
index 45aae88df9..6173701a24 100644
--- a/testsuites/fstests/fsrofs01/init.c
+++ b/testsuites/fstests/fsrofs01/init.c
@@ -169,7 +169,7 @@ rtems_ramdisk_config rtems_ramdisk_configuration [] = {
diff --git a/testsuites/fstests/imfs_support/fs_support.c b/testsuites/fstests/imfs_support/fs_support.c
index 966b01f121..641d32fcf3 100644
--- a/testsuites/fstests/imfs_support/fs_support.c
+++ b/testsuites/fstests/imfs_support/fs_support.c
@@ -31,7 +31,7 @@ test_shutdown_filesystem (void)
 /* configuration information */
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/fstests/jffs2_support/fs_support.c b/testsuites/fstests/jffs2_support/fs_support.c
index da80de6304..666d023f99 100644
--- a/testsuites/fstests/jffs2_support/fs_support.c
+++ b/testsuites/fstests/jffs2_support/fs_support.c
@@ -144,7 +144,7 @@ void test_shutdown_filesystem(void)
 #define CONFIGURE_FILESYSTEM_JFFS2
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index 1a07edf46f..7b73c27b84 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -75,7 +75,7 @@ void test_shutdown_filesystem(void)
 /* drivers */
  * Configure base RTEMS resources.
diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
index 7760ff7426..8420499213 100644
--- a/testsuites/fstests/mimfs_support/fs_support.c
+++ b/testsuites/fstests/mimfs_support/fs_support.c
@@ -49,7 +49,7 @@ test_shutdown_filesystem (void)
 /* drivers */
diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
index 11053505e5..28b7be9a03 100644
--- a/testsuites/fstests/mrfs_support/fs_support.c
+++ b/testsuites/fstests/mrfs_support/fs_support.c
@@ -59,7 +59,7 @@ test_shutdown_filesystem (void)
diff --git a/testsuites/libtests/block01/init.c b/testsuites/libtests/block01/init.c
index b7eaa2b91f..92dbfc9aba 100644
--- a/testsuites/libtests/block01/init.c
+++ b/testsuites/libtests/block01/init.c
@@ -249,7 +249,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block02/init.c b/testsuites/libtests/block02/init.c
index 51a286e230..c550517e21 100644
--- a/testsuites/libtests/block02/init.c
+++ b/testsuites/libtests/block02/init.c
@@ -197,7 +197,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block03/init.c b/testsuites/libtests/block03/init.c
index 41f773067a..c66a52049f 100644
--- a/testsuites/libtests/block03/init.c
+++ b/testsuites/libtests/block03/init.c
@@ -184,7 +184,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block04/init.c b/testsuites/libtests/block04/init.c
index 372b62b503..1b5d114029 100644
--- a/testsuites/libtests/block04/init.c
+++ b/testsuites/libtests/block04/init.c
@@ -156,7 +156,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
index bbe2bf6a7d..c20ccbf20d 100644
--- a/testsuites/libtests/block05/init.c
+++ b/testsuites/libtests/block05/init.c
@@ -514,7 +514,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
index f564fb8440..94b7298eae 100644
--- a/testsuites/libtests/block06/init.c
+++ b/testsuites/libtests/block06/init.c
@@ -1830,7 +1830,7 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_BDBUF_TASK_STACK_SIZE BDBUF_TEST_STACK_SIZE
diff --git a/testsuites/libtests/block07/init.c b/testsuites/libtests/block07/init.c
index 2a94c5b241..914dd35a90 100644
--- a/testsuites/libtests/block07/init.c
+++ b/testsuites/libtests/block07/init.c
@@ -259,7 +259,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block08/system.h b/testsuites/libtests/block08/system.h
index f2ba2ec87d..8ceb17e929 100644
--- a/testsuites/libtests/block08/system.h
+++ b/testsuites/libtests/block08/system.h
@@ -21,7 +21,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS               28
diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
index 1a7b02a173..b25c4e4113 100644
--- a/testsuites/libtests/block09/init.c
+++ b/testsuites/libtests/block09/init.c
@@ -234,7 +234,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
index c8dba60f24..27c0bb5478 100644
--- a/testsuites/libtests/block10/init.c
+++ b/testsuites/libtests/block10/init.c
@@ -476,7 +476,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block11/init.c b/testsuites/libtests/block11/init.c
index 4d19d1917b..f607bf515e 100644
--- a/testsuites/libtests/block11/init.c
+++ b/testsuites/libtests/block11/init.c
@@ -423,7 +423,7 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
diff --git a/testsuites/libtests/block12/init.c b/testsuites/libtests/block12/init.c
index 5b749773dc..036a4e92e6 100644
--- a/testsuites/libtests/block12/init.c
+++ b/testsuites/libtests/block12/init.c
@@ -135,7 +135,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_BDBUF_BUFFER_MIN_SIZE 1
diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
index 82c9b3a4a9..afd7704026 100644
--- a/testsuites/libtests/block13/init.c
+++ b/testsuites/libtests/block13/init.c
@@ -221,7 +221,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
index ab5ba57703..879582f214 100644
--- a/testsuites/libtests/block14/init.c
+++ b/testsuites/libtests/block14/init.c
@@ -201,7 +201,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
index 19d30d17bf..cf9ec5fc0c 100644
--- a/testsuites/libtests/block15/init.c
+++ b/testsuites/libtests/block15/init.c
@@ -166,7 +166,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/block16/init.c b/testsuites/libtests/block16/init.c
index c7d41480a9..401a888925 100644
--- a/testsuites/libtests/block16/init.c
+++ b/testsuites/libtests/block16/init.c
diff --git a/testsuites/libtests/block17/init.c b/testsuites/libtests/block17/init.c
index 384cb95a48..d916c738d5 100644
--- a/testsuites/libtests/block17/init.c
+++ b/testsuites/libtests/block17/init.c
 #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS (64UL * 1024UL)
diff --git a/testsuites/libtests/bspcmdline01/init.c b/testsuites/libtests/bspcmdline01/init.c
index bea50211e2..243c7aad2a 100644
--- a/testsuites/libtests/bspcmdline01/init.c
+++ b/testsuites/libtests/bspcmdline01/init.c
@@ -174,7 +174,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/capture01/system.h b/testsuites/libtests/capture01/system.h
index 9c066bcbb9..5836e2d316 100644
--- a/testsuites/libtests/capture01/system.h
+++ b/testsuites/libtests/capture01/system.h
@@ -24,7 +24,7 @@ void capture_test_1(void);
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/libtests/complex/init.c b/testsuites/libtests/complex/init.c
index 5f8ba34799..58e2549bf2 100644
--- a/testsuites/libtests/complex/init.c
+++ b/testsuites/libtests/complex/init.c
@@ -39,7 +39,7 @@ extern void docomplexl(void);
 #if __rtems__
diff --git a/testsuites/libtests/cpuuse/system.h b/testsuites/libtests/cpuuse/system.h
index 562f2dbbff..ebf79e5005 100644
--- a/testsuites/libtests/cpuuse/system.h
+++ b/testsuites/libtests/cpuuse/system.h
@@ -39,7 +39,7 @@ void Task_switch(
diff --git a/testsuites/libtests/crypt01/init.c b/testsuites/libtests/crypt01/init.c
index 545c533feb..c48fe1171d 100644
--- a/testsuites/libtests/crypt01/init.c
+++ b/testsuites/libtests/crypt01/init.c
@@ -245,7 +245,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/debugger01/system.h b/testsuites/libtests/debugger01/system.h
index c38283c33f..5ec19652f3 100644
--- a/testsuites/libtests/debugger01/system.h
+++ b/testsuites/libtests/debugger01/system.h
@@ -23,7 +23,7 @@ void test_wake(void);
diff --git a/testsuites/libtests/devfs03/init.c b/testsuites/libtests/devfs03/init.c
index 147deeb424..b9917b84fb 100644
--- a/testsuites/libtests/devfs03/init.c
+++ b/testsuites/libtests/devfs03/init.c
@@ -83,7 +83,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/deviceio01/init.c b/testsuites/libtests/deviceio01/init.c
index 519719d546..ca176fbd34 100644
--- a/testsuites/libtests/deviceio01/init.c
+++ b/testsuites/libtests/deviceio01/init.c
@@ -66,7 +66,7 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS TEST_DRIVER_TABLE_ENTRY
diff --git a/testsuites/libtests/dl01/init.c b/testsuites/libtests/dl01/init.c
index ec7ae1a413..9b4a2ae687 100644
--- a/testsuites/libtests/dl01/init.c
+++ b/testsuites/libtests/dl01/init.c
@@ -63,7 +63,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl02/init.c b/testsuites/libtests/dl02/init.c
index bf2d1a9717..bab6b80045 100644
--- a/testsuites/libtests/dl02/init.c
+++ b/testsuites/libtests/dl02/init.c
diff --git a/testsuites/libtests/dl03/init.c b/testsuites/libtests/dl03/init.c
index ae8272294c..e1d3235d7c 100644
--- a/testsuites/libtests/dl03/init.c
+++ b/testsuites/libtests/dl03/init.c
@@ -45,7 +45,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl04/init.c b/testsuites/libtests/dl04/init.c
index eb3018e393..7b1bb1b35c 100644
--- a/testsuites/libtests/dl04/init.c
+++ b/testsuites/libtests/dl04/init.c
diff --git a/testsuites/libtests/dl05/init.c b/testsuites/libtests/dl05/init.c
index 0c58204139..cb19de13f2 100644
--- a/testsuites/libtests/dl05/init.c
+++ b/testsuites/libtests/dl05/init.c
diff --git a/testsuites/libtests/dumpbuf01/init.c b/testsuites/libtests/dumpbuf01/init.c
index e9671cd144..45cf0c2f5a 100644
--- a/testsuites/libtests/dumpbuf01/init.c
+++ b/testsuites/libtests/dumpbuf01/init.c
@@ -52,7 +52,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/exit01/init.c b/testsuites/libtests/exit01/init.c
index c73738db3b..82e59a6286 100644
--- a/testsuites/libtests/exit01/init.c
+++ b/testsuites/libtests/exit01/init.c
@@ -106,7 +106,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_INITIAL_EXTENSIONS \
   { .fatal = fatal_extension }, \
diff --git a/testsuites/libtests/exit02/init.c b/testsuites/libtests/exit02/init.c
index b9874a8196..19a1517d8e 100644
--- a/testsuites/libtests/exit02/init.c
+++ b/testsuites/libtests/exit02/init.c
@@ -84,7 +84,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/flashdisk01/init.c b/testsuites/libtests/flashdisk01/init.c
index ea1b583895..8aac454a52 100644
--- a/testsuites/libtests/flashdisk01/init.c
+++ b/testsuites/libtests/flashdisk01/init.c
@@ -335,7 +335,7 @@ uint32_t rtems_flashdisk_configuration_size = FLASHDISK_CONFIG_COUNT;
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS FLASHDISK_DRIVER
diff --git a/testsuites/libtests/ftp01/init.c b/testsuites/libtests/ftp01/init.c
index ad166c3f77..380c2829f7 100644
--- a/testsuites/libtests/ftp01/init.c
+++ b/testsuites/libtests/ftp01/init.c
@@ -230,7 +230,7 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_MICROSECONDS_PER_TICK 10000
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 14
diff --git a/testsuites/libtests/gxx01/init.c b/testsuites/libtests/gxx01/init.c
index a0debcdc91..306e4f1f0b 100644
--- a/testsuites/libtests/gxx01/init.c
+++ b/testsuites/libtests/gxx01/init.c
@@ -210,7 +210,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_POSIX_KEYS            1
diff --git a/testsuites/libtests/heapwalk/system.h b/testsuites/libtests/heapwalk/system.h
index 482cef2d43..53a13fc1d6 100644
--- a/testsuites/libtests/heapwalk/system.h
+++ b/testsuites/libtests/heapwalk/system.h
@@ -29,7 +29,7 @@ void blow_stack( void );
 #define TASK_STACK_SIZE (RTEMS_MINIMUM_STACK_SIZE*3)
diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
index 0d6fc839f3..f993fa0259 100644
--- a/testsuites/libtests/i2c01/init.c
+++ b/testsuites/libtests/i2c01/init.c
@@ -653,7 +653,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK 2000
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
diff --git a/testsuites/libtests/libfdt01/init.c b/testsuites/libtests/libfdt01/init.c
index a13fc82021..1918505ffe 100644
--- a/testsuites/libtests/libfdt01/init.c
+++ b/testsuites/libtests/libfdt01/init.c
@@ -132,7 +132,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/malloc02/init.c b/testsuites/libtests/malloc02/init.c
index c333b22862..6db32478e7 100644
--- a/testsuites/libtests/malloc02/init.c
+++ b/testsuites/libtests/malloc02/init.c
@@ -81,7 +81,7 @@ rtems_task Init(
 #define CONFIGURE_MALLOC_DIRTY
diff --git a/testsuites/libtests/malloc03/init.c b/testsuites/libtests/malloc03/init.c
index 3b23a07c79..9e2b04d2a0 100644
--- a/testsuites/libtests/malloc03/init.c
+++ b/testsuites/libtests/malloc03/init.c
@@ -38,7 +38,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/malloc04/init.c b/testsuites/libtests/malloc04/init.c
index dabbf98e61..632ea28fc4 100644
--- a/testsuites/libtests/malloc04/init.c
+++ b/testsuites/libtests/malloc04/init.c
@@ -22,7 +22,7 @@ const char rtems_test_name[] = "MALLOC 4";
 /* At top of file to have access to configuration variables */
diff --git a/testsuites/libtests/malloctest/system.h b/testsuites/libtests/malloctest/system.h
index f1b3cb4813..93495cf6c6 100644
--- a/testsuites/libtests/malloctest/system.h
+++ b/testsuites/libtests/malloctest/system.h
diff --git a/testsuites/libtests/math/init.c b/testsuites/libtests/math/init.c
index fc493e86e7..f8c9649e8e 100644
--- a/testsuites/libtests/math/init.c
+++ b/testsuites/libtests/math/init.c
@@ -41,7 +41,7 @@ extern void domath(void);
 #if __rtems__
 #define CONFIGURE_INIT_TASK_ATTRIBUTES    RTEMS_FLOATING_POINT
diff --git a/testsuites/libtests/mathf/init.c b/testsuites/libtests/mathf/init.c
index a553e25482..333c038221 100644
--- a/testsuites/libtests/mathf/init.c
+++ b/testsuites/libtests/mathf/init.c
@@ -37,7 +37,7 @@ extern void domathf(void);
 #if __rtems__
diff --git a/testsuites/libtests/mathl/init.c b/testsuites/libtests/mathl/init.c
index 7e239f3fbe..4bb3b08c7f 100644
--- a/testsuites/libtests/mathl/init.c
+++ b/testsuites/libtests/mathl/init.c
@@ -37,7 +37,7 @@ extern void domathl(void);
 #if __rtems__
diff --git a/testsuites/libtests/md501/init.c b/testsuites/libtests/md501/init.c
index 124c2d7b9b..678dc0bc0b 100644
--- a/testsuites/libtests/md501/init.c
+++ b/testsuites/libtests/md501/init.c
@@ -243,7 +243,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/mghttpd01/init.c b/testsuites/libtests/mghttpd01/init.c
index 39071a8dfb..d3f18feb63 100644
--- a/testsuites/libtests/mghttpd01/init.c
+++ b/testsuites/libtests/mghttpd01/init.c
@@ -268,7 +268,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/monitor/system.h b/testsuites/libtests/monitor/system.h
index 7e23bd2d40..6d758ff00c 100644
--- a/testsuites/libtests/monitor/system.h
+++ b/testsuites/libtests/monitor/system.h
@@ -33,7 +33,7 @@ void Get_all_counters( void );
diff --git a/testsuites/libtests/monitor02/system.h b/testsuites/libtests/monitor02/system.h
index f863c9114a..3d05473c57 100644
--- a/testsuites/libtests/monitor02/system.h
+++ b/testsuites/libtests/monitor02/system.h
diff --git a/testsuites/libtests/mouse01/init.c b/testsuites/libtests/mouse01/init.c
index d0a127d423..f6efa4ed5b 100644
--- a/testsuites/libtests/mouse01/init.c
+++ b/testsuites/libtests/mouse01/init.c
@@ -155,7 +155,7 @@ rtems_task Init(
     TERMIOS_TEST_DRIVER_TABLE_ENTRY, \
     SERIAL_MOUSE_DRIVER_TABLE_ENTRY
diff --git a/testsuites/libtests/networking01/init.c b/testsuites/libtests/networking01/init.c
index f22b3328b1..02662345b2 100644
--- a/testsuites/libtests/networking01/init.c
+++ b/testsuites/libtests/networking01/init.c
@@ -148,7 +148,7 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_MAXIMUM_DRIVERS 2
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index 24dad1c4c5..e9cf4d1f22 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -300,7 +300,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/putenvtest/init.c b/testsuites/libtests/putenvtest/init.c
index 0c2ca664e5..74cd8de1a8 100644
--- a/testsuites/libtests/putenvtest/init.c
+++ b/testsuites/libtests/putenvtest/init.c
@@ -36,7 +36,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/pwdgrp01/init.c b/testsuites/libtests/pwdgrp01/init.c
index bc373672e5..7e9f77a379 100644
--- a/testsuites/libtests/pwdgrp01/init.c
+++ b/testsuites/libtests/pwdgrp01/init.c
@@ -158,7 +158,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/pwdgrp02/init.c b/testsuites/libtests/pwdgrp02/init.c
index ebc8d0b3fc..ec2bdf1c3e 100644
--- a/testsuites/libtests/pwdgrp02/init.c
+++ b/testsuites/libtests/pwdgrp02/init.c
@@ -163,7 +163,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/rbheap01/init.c b/testsuites/libtests/rbheap01/init.c
index a85d107510..35114df805 100644
--- a/testsuites/libtests/rbheap01/init.c
+++ b/testsuites/libtests/rbheap01/init.c
@@ -530,7 +530,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/rtmonuse/system.h b/testsuites/libtests/rtmonuse/system.h
index b7bb5f136f..468c28693d 100644
--- a/testsuites/libtests/rtmonuse/system.h
+++ b/testsuites/libtests/rtmonuse/system.h
 #define CONFIGURE_MAXIMUM_TASKS               6
diff --git a/testsuites/libtests/sha/init.c b/testsuites/libtests/sha/init.c
index 797eec7794..bc64edf5d1 100644
--- a/testsuites/libtests/sha/init.c
+++ b/testsuites/libtests/sha/init.c
@@ -176,7 +176,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/shell01/init.c b/testsuites/libtests/shell01/init.c
index b7ec2d1601..57b4461a93 100644
--- a/testsuites/libtests/shell01/init.c
+++ b/testsuites/libtests/shell01/init.c
@@ -171,7 +171,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/sparsedisk01/init.c b/testsuites/libtests/sparsedisk01/init.c
index 7c556cd4cf..dfb87ecdd5 100644
--- a/testsuites/libtests/sparsedisk01/init.c
+++ b/testsuites/libtests/sparsedisk01/init.c
@@ -427,7 +427,7 @@ static void Init( rtems_task_argument arg )
diff --git a/testsuites/libtests/spi01/init.c b/testsuites/libtests/spi01/init.c
index 990d3ec2b4..6f086d4ac6 100644
--- a/testsuites/libtests/spi01/init.c
+++ b/testsuites/libtests/spi01/init.c
@@ -271,7 +271,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/stackchk/system.h b/testsuites/libtests/stackchk/system.h
index 32e232a1c3..cdadb78c69 100644
--- a/testsuites/libtests/stackchk/system.h
+++ b/testsuites/libtests/stackchk/system.h
diff --git a/testsuites/libtests/stackchk01/init.c b/testsuites/libtests/stackchk01/init.c
index be0d494e08..8e907e6d48 100644
--- a/testsuites/libtests/stackchk01/init.c
+++ b/testsuites/libtests/stackchk01/init.c
@@ -37,7 +37,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/stringto01/init.c b/testsuites/libtests/stringto01/init.c
index d36a4e543f..eb2e79337a 100644
--- a/testsuites/libtests/stringto01/init.c
+++ b/testsuites/libtests/stringto01/init.c
@@ -163,7 +163,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/syscall01/init.c b/testsuites/libtests/syscall01/init.c
index 253b91fd47..e1c2369ca7 100644
--- a/testsuites/libtests/syscall01/init.c
+++ b/testsuites/libtests/syscall01/init.c
@@ -318,7 +318,7 @@ static rtems_device_driver open_driver_open(
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS OPEN_DRIVER
diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
index 858c94104f..73a5474940 100644
--- a/testsuites/libtests/tar01/init.c
+++ b/testsuites/libtests/tar01/init.c
@@ -304,7 +304,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/tar02/init.c b/testsuites/libtests/tar02/init.c
index 23c1187034..45dfa35a18 100644
--- a/testsuites/libtests/tar02/init.c
+++ b/testsuites/libtests/tar02/init.c
@@ -137,7 +137,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/tar03/init.c b/testsuites/libtests/tar03/init.c
index 72e95ecd2f..142cdecfdf 100644
--- a/testsuites/libtests/tar03/init.c
+++ b/testsuites/libtests/tar03/init.c
@@ -50,7 +50,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios/init.c b/testsuites/libtests/termios/init.c
index 558f095449..b1d62f7ff4 100644
--- a/testsuites/libtests/termios/init.c
+++ b/testsuites/libtests/termios/init.c
@@ -792,7 +792,7 @@ Init (rtems_task_argument ignored)
 /* application configuration */
diff --git a/testsuites/libtests/termios01/init.c b/testsuites/libtests/termios01/init.c
index a892762b03..6f5e4f657c 100644
--- a/testsuites/libtests/termios01/init.c
+++ b/testsuites/libtests/termios01/init.c
@@ -1006,7 +1006,7 @@ static rtems_task Init(
 #define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS \
   { .initialization_entry = test_early_device_install }
 /* include an extra slot for registering the termios one dynamically */
diff --git a/testsuites/libtests/termios03/init.c b/testsuites/libtests/termios03/init.c
index ab33ac82fd..70ed74d84d 100644
--- a/testsuites/libtests/termios03/init.c
+++ b/testsuites/libtests/termios03/init.c
@@ -157,7 +157,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios04/init.c b/testsuites/libtests/termios04/init.c
index dd9f653a7b..ad5bb1379d 100644
--- a/testsuites/libtests/termios04/init.c
+++ b/testsuites/libtests/termios04/init.c
@@ -136,7 +136,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index 72c9e81a37..c02b7a6194 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -147,7 +147,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios06/init.c b/testsuites/libtests/termios06/init.c
index acdcc33956..721643de99 100644
--- a/testsuites/libtests/termios06/init.c
+++ b/testsuites/libtests/termios06/init.c
@@ -207,7 +207,7 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS TERMIOS_TEST_DRIVER_TABLE_ENTRY
diff --git a/testsuites/libtests/termios07/init.c b/testsuites/libtests/termios07/init.c
index bda570d706..2da5290ae5 100644
--- a/testsuites/libtests/termios07/init.c
+++ b/testsuites/libtests/termios07/init.c
diff --git a/testsuites/libtests/termios08/init.c b/testsuites/libtests/termios08/init.c
index 317ce7203d..ee5a5c1269 100644
--- a/testsuites/libtests/termios08/init.c
+++ b/testsuites/libtests/termios08/init.c
@@ -150,7 +150,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/termios09/init.c b/testsuites/libtests/termios09/init.c
index 6feb521244..7509101682 100644
--- a/testsuites/libtests/termios09/init.c
+++ b/testsuites/libtests/termios09/init.c
@@ -1129,7 +1129,7 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
diff --git a/testsuites/libtests/top/system.h b/testsuites/libtests/top/system.h
index 945fbcabca..17c081cf45 100644
--- a/testsuites/libtests/top/system.h
+++ b/testsuites/libtests/top/system.h
@@ -41,7 +41,7 @@ void add_some(
 #define TASK_COUNT           30
diff --git a/testsuites/libtests/tztest/init.c b/testsuites/libtests/tztest/init.c
index 88799f5849..f3085078ed 100644
--- a/testsuites/libtests/tztest/init.c
+++ b/testsuites/libtests/tztest/init.c
@@ -73,7 +73,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/uid01/init.c b/testsuites/libtests/uid01/init.c
index aae4b4b442..99d11f0ed4 100644
--- a/testsuites/libtests/uid01/init.c
+++ b/testsuites/libtests/uid01/init.c
@@ -127,7 +127,7 @@ rtems_task Init(
diff --git a/testsuites/libtests/utf8proc01/init.c b/testsuites/libtests/utf8proc01/init.c
index fda1444a37..50d75c6338 100644
--- a/testsuites/libtests/utf8proc01/init.c
+++ b/testsuites/libtests/utf8proc01/init.c
@@ -260,7 +260,7 @@ static void Init ( rtems_task_argument arg )
diff --git a/testsuites/mptests/mp01/system.h b/testsuites/mptests/mp01/system.h
index 67bed5a12a..894771b9e5 100644
--- a/testsuites/mptests/mp01/system.h
+++ b/testsuites/mptests/mp01/system.h
@@ -27,7 +27,7 @@ rtems_task Test_task(
diff --git a/testsuites/mptests/mp03/system.h b/testsuites/mptests/mp03/system.h
index a73796fc45..91cedd810c 100644
--- a/testsuites/mptests/mp03/system.h
+++ b/testsuites/mptests/mp03/system.h
@@ -32,7 +32,7 @@ rtems_timer_service_routine Delayed_send_event(
diff --git a/testsuites/mptests/mp04/system.h b/testsuites/mptests/mp04/system.h
index f71ecc024a..88ae1bedc3 100644
--- a/testsuites/mptests/mp04/system.h
+++ b/testsuites/mptests/mp04/system.h
diff --git a/testsuites/mptests/mp05/system.h b/testsuites/mptests/mp05/system.h
index 7b8871334c..3c32c99387 100644
--- a/testsuites/mptests/mp05/system.h
+++ b/testsuites/mptests/mp05/system.h
@@ -29,7 +29,7 @@ rtems_asr Process_asr( rtems_signal_set );
diff --git a/testsuites/mptests/mp06/system.h b/testsuites/mptests/mp06/system.h
index c999087ef8..d281a48aa3 100644
--- a/testsuites/mptests/mp06/system.h
+++ b/testsuites/mptests/mp06/system.h
diff --git a/testsuites/mptests/mp07/system.h b/testsuites/mptests/mp07/system.h
--- a/testsuites/mptests/mp07/system.h
+++ b/testsuites/mptests/mp07/system.h
diff --git a/testsuites/mptests/mp08/system.h b/testsuites/mptests/mp08/system.h
index 798073434a..080297cb6d 100644
--- a/testsuites/mptests/mp08/system.h
+++ b/testsuites/mptests/mp08/system.h
diff --git a/testsuites/mptests/mp09/system.h b/testsuites/mptests/mp09/system.h
index 3cb5f6dbec..4fdddc4fc4 100644
--- a/testsuites/mptests/mp09/system.h
+++ b/testsuites/mptests/mp09/system.h
@@ -31,7 +31,7 @@ void Send_messages( void );
diff --git a/testsuites/mptests/mp10/system.h b/testsuites/mptests/mp10/system.h
index 2c367753b6..b1f105ec7d 100644
--- a/testsuites/mptests/mp10/system.h
+++ b/testsuites/mptests/mp10/system.h
@@ -35,7 +35,7 @@ rtems_task Test_task3(
 #if ( NODE_NUMBER == 1 )
diff --git a/testsuites/mptests/mp11/system.h b/testsuites/mptests/mp11/system.h
index c1e58584d8..a516c2f9a6 100644
--- a/testsuites/mptests/mp11/system.h
+++ b/testsuites/mptests/mp11/system.h
@@ -23,7 +23,7 @@ rtems_task Init(
 #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS     0
diff --git a/testsuites/mptests/mp12/system.h b/testsuites/mptests/mp12/system.h
index 32c93fd464..366544c6b8 100644
--- a/testsuites/mptests/mp12/system.h
+++ b/testsuites/mptests/mp12/system.h
@@ -25,7 +25,7 @@ rtems_task Init(
 #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS     1
diff --git a/testsuites/mptests/mp13/system.h b/testsuites/mptests/mp13/system.h
index e79c2534d4..9e8e850966 100644
--- a/testsuites/mptests/mp13/system.h
+++ b/testsuites/mptests/mp13/system.h
@@ -31,7 +31,7 @@ rtems_task Test_task2(
diff --git a/testsuites/mptests/mp14/system.h b/testsuites/mptests/mp14/system.h
index 202c469e69..ffe84d7fc0 100644
--- a/testsuites/mptests/mp14/system.h
+++ b/testsuites/mptests/mp14/system.h
@@ -50,7 +50,7 @@ void Exit_test( void );
diff --git a/testsuites/psxtests/psx01/system.h b/testsuites/psxtests/psx01/system.h
index 2addbb4348..d0507dfac4 100644
--- a/testsuites/psxtests/psx01/system.h
+++ b/testsuites/psxtests/psx01/system.h
@@ -28,7 +28,7 @@ void *Task_1_through_3(
diff --git a/testsuites/psxtests/psx02/system.h b/testsuites/psxtests/psx02/system.h
index cf0242d52d..22365ba76f 100644
--- a/testsuites/psxtests/psx02/system.h
+++ b/testsuites/psxtests/psx02/system.h
@@ -26,7 +26,7 @@ void *Task_1_through_3(
diff --git a/testsuites/psxtests/psx03/system.h b/testsuites/psxtests/psx03/system.h
index 1fb6483620..7949d4c3c0 100644
--- a/testsuites/psxtests/psx03/system.h
+++ b/testsuites/psxtests/psx03/system.h
@@ -29,7 +29,7 @@ void *Task_2(
diff --git a/testsuites/psxtests/psx04/system.h b/testsuites/psxtests/psx04/system.h
index ebd61607cd..630ac9178d 100644
--- a/testsuites/psxtests/psx04/system.h
+++ b/testsuites/psxtests/psx04/system.h
@@ -33,7 +33,7 @@ void *Task_3(
diff --git a/testsuites/psxtests/psx05/system.h b/testsuites/psxtests/psx05/system.h
index a4d128d6f6..52d6f4957e 100644
--- a/testsuites/psxtests/psx05/system.h
+++ b/testsuites/psxtests/psx05/system.h
diff --git a/testsuites/psxtests/psx06/system.h b/testsuites/psxtests/psx06/system.h
index dbb991d7f1..8bcaff7d38 100644
--- a/testsuites/psxtests/psx06/system.h
+++ b/testsuites/psxtests/psx06/system.h
diff --git a/testsuites/psxtests/psx07/system.h b/testsuites/psxtests/psx07/system.h
index 4c2d6a463e..ee297e019d 100644
--- a/testsuites/psxtests/psx07/system.h
+++ b/testsuites/psxtests/psx07/system.h
@@ -30,7 +30,7 @@ void *Task_2(
diff --git a/testsuites/psxtests/psx08/system.h b/testsuites/psxtests/psx08/system.h
index 1ae4483636..127febe449 100644
--- a/testsuites/psxtests/psx08/system.h
+++ b/testsuites/psxtests/psx08/system.h
diff --git a/testsuites/psxtests/psx09/system.h b/testsuites/psxtests/psx09/system.h
index 2a86aa25fd..aa03a1822d 100644
--- a/testsuites/psxtests/psx09/system.h
+++ b/testsuites/psxtests/psx09/system.h
diff --git a/testsuites/psxtests/psx10/system.h b/testsuites/psxtests/psx10/system.h
index 93ed9ff075..da720f1dd2 100644
--- a/testsuites/psxtests/psx10/system.h
+++ b/testsuites/psxtests/psx10/system.h
@@ -35,7 +35,7 @@ void *Task_3(
diff --git a/testsuites/psxtests/psx11/system.h b/testsuites/psxtests/psx11/system.h
index 19a9b165ba..f1995a989f 100644
--- a/testsuites/psxtests/psx11/system.h
+++ b/testsuites/psxtests/psx11/system.h
@@ -25,7 +25,7 @@ void *Task_1(
diff --git a/testsuites/psxtests/psx12/init.c b/testsuites/psxtests/psx12/init.c
index 471fe73500..be0b8d6412 100644
--- a/testsuites/psxtests/psx12/init.c
+++ b/testsuites/psxtests/psx12/init.c
@@ -230,7 +230,7 @@ static void *POSIX_Init( void *argument )
   return NULL; /* just so the compiler thinks we returned something */
diff --git a/testsuites/psxtests/psx13/main.c b/testsuites/psxtests/psx13/main.c
index 2045de3af3..aee8b780fd 100644
--- a/testsuites/psxtests/psx13/main.c
+++ b/testsuites/psxtests/psx13/main.c
@@ -32,7 +32,7 @@ rtems_task Init(
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
diff --git a/testsuites/psxtests/psx14/system.h b/testsuites/psxtests/psx14/system.h
index 4de216015a..f44b630c30 100644
--- a/testsuites/psxtests/psx14/system.h
+++ b/testsuites/psxtests/psx14/system.h
@@ -24,7 +24,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psx15/init.c b/testsuites/psxtests/psx15/init.c
index 654f0c87fb..74fbfb9a45 100644
--- a/testsuites/psxtests/psx15/init.c
+++ b/testsuites/psxtests/psx15/init.c
@@ -104,7 +104,7 @@ void Init(rtems_task_argument arg)
diff --git a/testsuites/psxtests/psx16/init.c b/testsuites/psxtests/psx16/init.c
index 55f652679f..8e20e6d376 100644
--- a/testsuites/psxtests/psx16/init.c
+++ b/testsuites/psxtests/psx16/init.c
@@ -72,7 +72,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxaio01/system.h b/testsuites/psxtests/psxaio01/system.h
index 1bedd7328a..3ffb398e48 100644
--- a/testsuites/psxtests/psxaio01/system.h
+++ b/testsuites/psxtests/psxaio01/system.h
@@ -17,7 +17,7 @@ void *POSIX_Init (void *argument);
 #define CONFIGURE_MAXIMUM_TASKS             20
diff --git a/testsuites/psxtests/psxaio02/system.h b/testsuites/psxtests/psxaio02/system.h
index 4f2f08a7b1..f3e348e12b 100644
--- a/testsuites/psxtests/psxaio02/system.h
+++ b/testsuites/psxtests/psxaio02/system.h
diff --git a/testsuites/psxtests/psxaio03/system.h b/testsuites/psxtests/psxaio03/system.h
index 68bf3046eb..1ba17d2d8a 100644
--- a/testsuites/psxtests/psxaio03/system.h
+++ b/testsuites/psxtests/psxaio03/system.h
@@ -18,7 +18,7 @@ void *POSIX_Init (void *argument);
diff --git a/testsuites/psxtests/psxalarm01/init.c b/testsuites/psxtests/psxalarm01/init.c
index e4ab9b4f4a..f9556faf07 100644
--- a/testsuites/psxtests/psxalarm01/init.c
+++ b/testsuites/psxtests/psxalarm01/init.c
@@ -105,7 +105,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxautoinit01/init.c b/testsuites/psxtests/psxautoinit01/init.c
index 9001de2306..f94879e60f 100644
--- a/testsuites/psxtests/psxautoinit01/init.c
+++ b/testsuites/psxtests/psxautoinit01/init.c
@@ -61,7 +61,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxautoinit02/init.c b/testsuites/psxtests/psxautoinit02/init.c
index 5d652f7467..d1a4d3a400 100644
--- a/testsuites/psxtests/psxautoinit02/init.c
+++ b/testsuites/psxtests/psxautoinit02/init.c
@@ -95,7 +95,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxbarrier01/main.c b/testsuites/psxtests/psxbarrier01/main.c
index 5788078631..93aa9f788b 100644
--- a/testsuites/psxtests/psxbarrier01/main.c
+++ b/testsuites/psxtests/psxbarrier01/main.c
@@ -31,7 +31,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxcancel/init.c b/testsuites/psxtests/psxcancel/init.c
index c4c442b668..afef141001 100644
--- a/testsuites/psxtests/psxcancel/init.c
+++ b/testsuites/psxtests/psxcancel/init.c
@@ -257,7 +257,7 @@ static void resourceSnapshotCheck( void )
 #if defined(__rtems__)
diff --git a/testsuites/psxtests/psxcancel01/init.c b/testsuites/psxtests/psxcancel01/init.c
index fce188ed39..d87295ccd1 100644
--- a/testsuites/psxtests/psxcancel01/init.c
+++ b/testsuites/psxtests/psxcancel01/init.c
@@ -130,7 +130,7 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_TIMERS        1
diff --git a/testsuites/psxtests/psxchroot01/main.c b/testsuites/psxtests/psxchroot01/main.c
index 5e8bedbc0b..946fbb6073 100644
--- a/testsuites/psxtests/psxchroot01/main.c
+++ b/testsuites/psxtests/psxchroot01/main.c
@@ -26,7 +26,7 @@ rtems_task Init(
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
diff --git a/testsuites/psxtests/psxclassic01/init.c b/testsuites/psxtests/psxclassic01/init.c
index 1acc14142a..946dcc7e92 100644
--- a/testsuites/psxtests/psxclassic01/init.c
+++ b/testsuites/psxtests/psxclassic01/init.c
@@ -175,7 +175,7 @@ rtems_task Init( rtems_task_argument arg )
diff --git a/testsuites/psxtests/psxcleanup/system.h b/testsuites/psxtests/psxcleanup/system.h
index 04ea60394a..fa331514f5 100644
--- a/testsuites/psxtests/psxcleanup/system.h
+++ b/testsuites/psxtests/psxcleanup/system.h
@@ -34,7 +34,7 @@ void *task_c(
diff --git a/testsuites/psxtests/psxcleanup01/init.c b/testsuites/psxtests/psxcleanup01/init.c
index f38b48ee93..b5e833b911 100644
--- a/testsuites/psxtests/psxcleanup01/init.c
+++ b/testsuites/psxtests/psxcleanup01/init.c
@@ -134,7 +134,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxcleanup02/init.c b/testsuites/psxtests/psxcleanup02/init.c
index 88ecfee47e..3c05fff99e 100644
--- a/testsuites/psxtests/psxcleanup02/init.c
+++ b/testsuites/psxtests/psxcleanup02/init.c
@@ -33,7 +33,7 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 2
diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
index 1e7dae7bde..40c224cec4 100644
--- a/testsuites/psxtests/psxclock/init.c
+++ b/testsuites/psxtests/psxclock/init.c
@@ -306,7 +306,7 @@ static rtems_task Init(
diff --git a/testsuites/psxtests/psxclock01/init.c b/testsuites/psxtests/psxclock01/init.c
index 6be85d2b70..123774e1c6 100644
--- a/testsuites/psxtests/psxclock01/init.c
+++ b/testsuites/psxtests/psxclock01/init.c
@@ -39,7 +39,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxclockrealtime01/init.c b/testsuites/psxtests/psxclockrealtime01/init.c
index 8deac3cf88..e8337068a2 100644
--- a/testsuites/psxtests/psxclockrealtime01/init.c
+++ b/testsuites/psxtests/psxclockrealtime01/init.c
@@ -582,7 +582,7 @@ static void *POSIX_Init(void *arg)
 #define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
diff --git a/testsuites/psxtests/psxconcurrency01/init.c b/testsuites/psxtests/psxconcurrency01/init.c
index 60aef9230d..44aeb5f606 100644
--- a/testsuites/psxtests/psxconcurrency01/init.c
+++ b/testsuites/psxtests/psxconcurrency01/init.c
@@ -46,7 +46,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxcond01/init.c b/testsuites/psxtests/psxcond01/init.c
index 574769659a..69dc5458ca 100644
--- a/testsuites/psxtests/psxcond01/init.c
+++ b/testsuites/psxtests/psxcond01/init.c
@@ -89,7 +89,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxcond02/init.c b/testsuites/psxtests/psxcond02/init.c
index 6314762285..aa6d973083 100644
--- a/testsuites/psxtests/psxcond02/init.c
+++ b/testsuites/psxtests/psxcond02/init.c
@@ -92,7 +92,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxconfig01/init.c b/testsuites/psxtests/psxconfig01/init.c
index a1dc4c618f..91d6a7a917 100644
--- a/testsuites/psxtests/psxconfig01/init.c
+++ b/testsuites/psxtests/psxconfig01/init.c
@@ -165,7 +165,7 @@ const char rtems_test_name[] = "PSXCONFIG 1";
 #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
   (MQ_BUFFER_MEMORY + POSIX_MQ_BUFFER_MEMORY)
diff --git a/testsuites/psxtests/psxeintr_join/init.c b/testsuites/psxtests/psxeintr_join/init.c
index f0810b50a5..725a198c95 100644
--- a/testsuites/psxtests/psxeintr_join/init.c
+++ b/testsuites/psxtests/psxeintr_join/init.c
@@ -124,7 +124,7 @@ void *POSIX_Init( void *arg )
diff --git a/testsuites/psxtests/psxenosys/system.h b/testsuites/psxtests/psxenosys/system.h
index ef42e0391f..d0eaed6ca3 100644
--- a/testsuites/psxtests/psxenosys/system.h
+++ b/testsuites/psxtests/psxenosys/system.h
@@ -23,7 +23,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxfatal_support/system.h b/testsuites/psxtests/psxfatal_support/system.h
index cb84ef11ea..21a60f6396 100644
--- a/testsuites/psxtests/psxfatal_support/system.h
+++ b/testsuites/psxtests/psxfatal_support/system.h
@@ -59,7 +59,7 @@ extern rtems_extensions_table initial_extensions;
 /* extra parameters may be in testcase.h */
 /* always need an Init task, some cases need more tasks */
diff --git a/testsuites/psxtests/psxfchx01/init.c b/testsuites/psxtests/psxfchx01/init.c
index 89a0d06033..82065ca9b2 100644
--- a/testsuites/psxtests/psxfchx01/init.c
+++ b/testsuites/psxtests/psxfchx01/init.c
@@ -217,7 +217,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxfile01/main.c b/testsuites/psxtests/psxfile01/main.c
index bba7a58b2c..b2f3cae63d 100644
--- a/testsuites/psxtests/psxfile01/main.c
+++ b/testsuites/psxtests/psxfile01/main.c
@@ -29,7 +29,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxfile02/init.c b/testsuites/psxtests/psxfile02/init.c
index d66815203a..7736185f35 100644
--- a/testsuites/psxtests/psxfile02/init.c
+++ b/testsuites/psxtests/psxfile02/init.c
@@ -148,7 +148,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxfilelock01/init.c b/testsuites/psxtests/psxfilelock01/init.c
index d64d1a185f..533e6f6488 100644
--- a/testsuites/psxtests/psxfilelock01/init.c
+++ b/testsuites/psxtests/psxfilelock01/init.c
@@ -54,7 +54,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxgetattrnp01/init.c b/testsuites/psxtests/psxgetattrnp01/init.c
index 19981573d1..3c7c886e8d 100644
--- a/testsuites/psxtests/psxgetattrnp01/init.c
+++ b/testsuites/psxtests/psxgetattrnp01/init.c
@@ -285,7 +285,7 @@ void *POSIX_Init(
 #endif
diff --git a/testsuites/psxtests/psxgetrusage01/init.c b/testsuites/psxtests/psxgetrusage01/init.c
index 590bc20e77..8cf4946879 100644
--- a/testsuites/psxtests/psxgetrusage01/init.c
+++ b/testsuites/psxtests/psxgetrusage01/init.c
@@ -26,7 +26,7 @@ const char rtems_test_name[] = "PSXGETRUSAGE 1";
diff --git a/testsuites/psxtests/psxglobalcon01/init.cc b/testsuites/psxtests/psxglobalcon01/init.cc
index d4855261be..154bf0d4fb 100644
--- a/testsuites/psxtests/psxglobalcon01/init.cc
+++ b/testsuites/psxtests/psxglobalcon01/init.cc
@@ -45,7 +45,7 @@ static void *POSIX_Init(void *argument)
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
diff --git a/testsuites/psxtests/psxglobalcon02/init.cc b/testsuites/psxtests/psxglobalcon02/init.cc
index c5f09b0d52..0ce5bdcea0 100644
--- a/testsuites/psxtests/psxglobalcon02/init.cc
+++ b/testsuites/psxtests/psxglobalcon02/init.cc
@@ -58,7 +58,7 @@ static void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxid01/init.c b/testsuites/psxtests/psxid01/init.c
index 5aa03999df..6935db7189 100644
--- a/testsuites/psxtests/psxid01/init.c
+++ b/testsuites/psxtests/psxid01/init.c
@@ -204,7 +204,7 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
diff --git a/testsuites/psxtests/psximfs01/init.c b/testsuites/psxtests/psximfs01/init.c
index 5c826fb381..5a8845f1c6 100644
--- a/testsuites/psxtests/psximfs01/init.c
+++ b/testsuites/psxtests/psximfs01/init.c
@@ -269,7 +269,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psximfs02/init.c b/testsuites/psxtests/psximfs02/init.c
index 047a4fcff5..0383762e5c 100644
--- a/testsuites/psxtests/psximfs02/init.c
+++ b/testsuites/psxtests/psximfs02/init.c
@@ -200,7 +200,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxintrcritical01/init.c b/testsuites/psxtests/psxintrcritical01/init.c
index a6a64bad60..9830c41b71 100644
--- a/testsuites/psxtests/psxintrcritical01/init.c
+++ b/testsuites/psxtests/psxintrcritical01/init.c
@@ -82,7 +82,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxitimer/init.c b/testsuites/psxtests/psxitimer/init.c
index dc32f34825..8292b6ebe7 100644
--- a/testsuites/psxtests/psxitimer/init.c
+++ b/testsuites/psxtests/psxitimer/init.c
@@ -82,7 +82,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxkey01/system.h b/testsuites/psxtests/psxkey01/system.h
index dafe5e552d..02d98b7623 100644
--- a/testsuites/psxtests/psxkey01/system.h
+++ b/testsuites/psxtests/psxkey01/system.h
@@ -20,7 +20,7 @@
diff --git a/testsuites/psxtests/psxkey02/init.c b/testsuites/psxtests/psxkey02/init.c
index 23a392b004..6c6a3a0be5 100644
--- a/testsuites/psxtests/psxkey02/init.c
+++ b/testsuites/psxtests/psxkey02/init.c
@@ -79,7 +79,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/psxtests/psxkey03/init.c b/testsuites/psxtests/psxkey03/init.c
index b133e50739..6d57b28b86 100644
--- a/testsuites/psxtests/psxkey03/init.c
+++ b/testsuites/psxtests/psxkey03/init.c
@@ -124,7 +124,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/psxtests/psxkey04/init.c b/testsuites/psxtests/psxkey04/init.c
index 4dcc342451..34e52c8aab 100644
--- a/testsuites/psxtests/psxkey04/init.c
+++ b/testsuites/psxtests/psxkey04/init.c
@@ -123,7 +123,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/psxtests/psxkey05/init.c b/testsuites/psxtests/psxkey05/init.c
index 6ebe49fe01..e849e7bae5 100644
--- a/testsuites/psxtests/psxkey05/init.c
+++ b/testsuites/psxtests/psxkey05/init.c
@@ -76,7 +76,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/psxtests/psxkey06/init.c b/testsuites/psxtests/psxkey06/init.c
index 28236c2adc..2b64c471c7 100644
--- a/testsuites/psxtests/psxkey06/init.c
+++ b/testsuites/psxtests/psxkey06/init.c
@@ -227,7 +227,7 @@ static rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/psxtests/psxkey07/init.c b/testsuites/psxtests/psxkey07/init.c
index 91cc7ea4ea..ffe4d5ada4 100644
--- a/testsuites/psxtests/psxkey07/init.c
+++ b/testsuites/psxtests/psxkey07/init.c
@@ -190,7 +190,7 @@ rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/psxtests/psxkey08/init.c b/testsuites/psxtests/psxkey08/init.c
index 1e6d53a34e..3b8bdae001 100644
--- a/testsuites/psxtests/psxkey08/init.c
+++ b/testsuites/psxtests/psxkey08/init.c
@@ -165,7 +165,7 @@ static rtems_task Init(rtems_task_argument arg)
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 #define CONFIGURE_MAXIMUM_TASKS 14
diff --git a/testsuites/psxtests/psxkey09/init.c b/testsuites/psxtests/psxkey09/init.c
index 2f7e92a741..472e90c907 100644
--- a/testsuites/psxtests/psxkey09/init.c
+++ b/testsuites/psxtests/psxkey09/init.c
@@ -93,7 +93,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/psxtests/psxkey10/init.c b/testsuites/psxtests/psxkey10/init.c
index 1c6ebd8c63..6273f1d899 100644
--- a/testsuites/psxtests/psxkey10/init.c
+++ b/testsuites/psxtests/psxkey10/init.c
@@ -98,7 +98,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/psxtests/psxmmap01/system.h b/testsuites/psxtests/psxmmap01/system.h
index 2241f881c4..055ad564d4 100644
--- a/testsuites/psxtests/psxmmap01/system.h
+++ b/testsuites/psxtests/psxmmap01/system.h
@@ -15,7 +15,7 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
index 74de986b20..e93ba339b3 100644
--- a/testsuites/psxtests/psxmount/main.c
+++ b/testsuites/psxtests/psxmount/main.c
@@ -28,7 +28,7 @@ rtems_task Init(
 /* NOTICE: the clock driver is explicitly disabled */
diff --git a/testsuites/psxtests/psxmsgq01/system.h b/testsuites/psxtests/psxmsgq01/system.h
index 764f733ff4..367b756b4b 100644
--- a/testsuites/psxtests/psxmsgq01/system.h
+++ b/testsuites/psxtests/psxmsgq01/system.h
@@ -29,7 +29,7 @@ void *Task_5(void *argument);
 #define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/psxtests/psxmsgq02/system.h b/testsuites/psxtests/psxmsgq02/system.h
index 180879e95a..5b87dab619 100644
--- a/testsuites/psxtests/psxmsgq02/system.h
+++ b/testsuites/psxtests/psxmsgq02/system.h
@@ -25,7 +25,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxmsgq03/system.h b/testsuites/psxtests/psxmsgq03/system.h
index 6be55ceb81..a2a3d73284 100644
--- a/testsuites/psxtests/psxmsgq03/system.h
+++ b/testsuites/psxtests/psxmsgq03/system.h
diff --git a/testsuites/psxtests/psxmsgq04/init.c b/testsuites/psxtests/psxmsgq04/init.c
index f1e1c968c0..07bd5ef87b 100644
--- a/testsuites/psxtests/psxmsgq04/init.c
+++ b/testsuites/psxtests/psxmsgq04/init.c
diff --git a/testsuites/psxtests/psxmutexattr01/init.c b/testsuites/psxtests/psxmutexattr01/init.c
index 1ea1ab58c0..b65eeefccd 100644
--- a/testsuites/psxtests/psxmutexattr01/init.c
+++ b/testsuites/psxtests/psxmutexattr01/init.c
@@ -111,7 +111,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxobj01/init.c b/testsuites/psxtests/psxobj01/init.c
index c3b3f49aa0..ca1fbc52ee 100644
--- a/testsuites/psxtests/psxobj01/init.c
+++ b/testsuites/psxtests/psxobj01/init.c
@@ -89,7 +89,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxonce01/system.h b/testsuites/psxtests/psxonce01/system.h
index 3205688822..10d611b86d 100644
--- a/testsuites/psxtests/psxonce01/system.h
+++ b/testsuites/psxtests/psxonce01/system.h
@@ -16,7 +16,7 @@
 #include <pmacros.h>
diff --git a/testsuites/psxtests/psxpasswd01/init.c b/testsuites/psxtests/psxpasswd01/init.c
index eb96e280c5..2845a47a2d 100644
--- a/testsuites/psxtests/psxpasswd01/init.c
+++ b/testsuites/psxtests/psxpasswd01/init.c
@@ -177,7 +177,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxpasswd02/init.c b/testsuites/psxtests/psxpasswd02/init.c
index 7090c9430f..dc2fa3c189 100644
--- a/testsuites/psxtests/psxpasswd02/init.c
+++ b/testsuites/psxtests/psxpasswd02/init.c
@@ -219,7 +219,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxpipe01/init.c b/testsuites/psxtests/psxpipe01/init.c
index 7066f6cf52..6ed4ee2390 100644
--- a/testsuites/psxtests/psxpipe01/init.c
+++ b/testsuites/psxtests/psxpipe01/init.c
@@ -99,7 +99,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxrdwrv/main.c b/testsuites/psxtests/psxrdwrv/main.c
index 67ee25e5b3..f6fa762218 100644
--- a/testsuites/psxtests/psxrdwrv/main.c
+++ b/testsuites/psxtests/psxrdwrv/main.c
diff --git a/testsuites/psxtests/psxreaddir/main.c b/testsuites/psxtests/psxreaddir/main.c
index 9ed55fc84d..11f372dda4 100644
--- a/testsuites/psxtests/psxreaddir/main.c
+++ b/testsuites/psxtests/psxreaddir/main.c
diff --git a/testsuites/psxtests/psxrwlock01/main.c b/testsuites/psxtests/psxrwlock01/main.c
index 7e2eda4806..2984ce965a 100644
--- a/testsuites/psxtests/psxrwlock01/main.c
+++ b/testsuites/psxtests/psxrwlock01/main.c
@@ -30,7 +30,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxsem01/init.c b/testsuites/psxtests/psxsem01/init.c
index ae0b390a7c..dfc2ed5670 100644
--- a/testsuites/psxtests/psxsem01/init.c
+++ b/testsuites/psxtests/psxsem01/init.c
@@ -618,7 +618,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxshm01/system.h b/testsuites/psxtests/psxshm01/system.h
index 531a9261ba..83e780aec6 100644
--- a/testsuites/psxtests/psxshm01/system.h
+++ b/testsuites/psxtests/psxshm01/system.h
diff --git a/testsuites/psxtests/psxshm02/system.h b/testsuites/psxtests/psxshm02/system.h
index 5ed0f0caf2..6b5a5a0bd9 100644
--- a/testsuites/psxtests/psxshm02/system.h
+++ b/testsuites/psxtests/psxshm02/system.h
diff --git a/testsuites/psxtests/psxsignal01/system.h b/testsuites/psxtests/psxsignal01/system.h
index fb88dd591e..418434bc80 100644
--- a/testsuites/psxtests/psxsignal01/system.h
+++ b/testsuites/psxtests/psxsignal01/system.h
@@ -34,7 +34,7 @@ void *Task_3(
diff --git a/testsuites/psxtests/psxsignal02/init.c b/testsuites/psxtests/psxsignal02/init.c
index 6ae68d6e5b..1f9afc9fca 100644
--- a/testsuites/psxtests/psxsignal02/init.c
+++ b/testsuites/psxtests/psxsignal02/init.c
@@ -192,7 +192,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxsignal03/init.c b/testsuites/psxtests/psxsignal03/init.c
index f3fc26672b..b51ff36313 100644
--- a/testsuites/psxtests/psxsignal03/init.c
+++ b/testsuites/psxtests/psxsignal03/init.c
@@ -222,7 +222,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxsignal05/init.c b/testsuites/psxtests/psxsignal05/init.c
index 0bc8d7f01f..40db63e4a1 100644
--- a/testsuites/psxtests/psxsignal05/init.c
+++ b/testsuites/psxtests/psxsignal05/init.c
@@ -94,7 +94,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxsignal06/init.c b/testsuites/psxtests/psxsignal06/init.c
index cb34bb6bc8..650a0fa6c5 100644
--- a/testsuites/psxtests/psxsignal06/init.c
+++ b/testsuites/psxtests/psxsignal06/init.c
@@ -120,7 +120,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxspin01/main.c b/testsuites/psxtests/psxspin01/main.c
index 5f7e7c0e1d..2c35d33b4e 100644
--- a/testsuites/psxtests/psxspin01/main.c
+++ b/testsuites/psxtests/psxspin01/main.c
@@ -35,7 +35,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxstack01/init.c b/testsuites/psxtests/psxstack01/init.c
index 7a010c8c6c..762e3950f9 100644
--- a/testsuites/psxtests/psxstack01/init.c
+++ b/testsuites/psxtests/psxstack01/init.c
diff --git a/testsuites/psxtests/psxstack02/init.c b/testsuites/psxtests/psxstack02/init.c
index df65ee3393..4fc1476812 100644
--- a/testsuites/psxtests/psxstack02/init.c
+++ b/testsuites/psxtests/psxstack02/init.c
@@ -94,7 +94,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtests/psxstat/main.c b/testsuites/psxtests/psxstat/main.c
index 5b788529b3..eb87b71f5d 100644
--- a/testsuites/psxtests/psxstat/main.c
+++ b/testsuites/psxtests/psxstat/main.c
diff --git a/testsuites/psxtests/psxstrsignal01/init.c b/testsuites/psxtests/psxstrsignal01/init.c
index 9614fb99aa..6c3a37cb52 100644
--- a/testsuites/psxtests/psxstrsignal01/init.c
+++ b/testsuites/psxtests/psxstrsignal01/init.c
@@ -106,7 +106,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtests/psxsysconf/system.h b/testsuites/psxtests/psxsysconf/system.h
--- a/testsuites/psxtests/psxsysconf/system.h
+++ b/testsuites/psxtests/psxsysconf/system.h
diff --git a/testsuites/psxtests/psxthreadname01/init.c b/testsuites/psxtests/psxthreadname01/init.c
index 16fdec6958..20bac2333d 100644
--- a/testsuites/psxtests/psxthreadname01/init.c
+++ b/testsuites/psxtests/psxthreadname01/init.c
@@ -86,7 +86,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/psxtests/psxtime/main.c b/testsuites/psxtests/psxtime/main.c
index 7f36c11546..c45efbb019 100644
--- a/testsuites/psxtests/psxtime/main.c
+++ b/testsuites/psxtests/psxtime/main.c
diff --git a/testsuites/psxtests/psxtimer01/system.h b/testsuites/psxtests/psxtimer01/system.h
index 3ca39e41bc..9cfd408d86 100644
--- a/testsuites/psxtests/psxtimer01/system.h
+++ b/testsuites/psxtests/psxtimer01/system.h
diff --git a/testsuites/psxtests/psxtimer02/system.h b/testsuites/psxtests/psxtimer02/system.h
index 917922d3cc..a173f3eb02 100644
--- a/testsuites/psxtests/psxtimer02/system.h
+++ b/testsuites/psxtests/psxtimer02/system.h
@@ -21,7 +21,7 @@ void *POSIX_Init (
diff --git a/testsuites/psxtests/psxtimes01/init.c b/testsuites/psxtests/psxtimes01/init.c
index 30cecd427a..7e191d0a15 100644
--- a/testsuites/psxtests/psxtimes01/init.c
+++ b/testsuites/psxtests/psxtimes01/init.c
@@ -78,7 +78,7 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxualarm/system.h b/testsuites/psxtests/psxualarm/system.h
--- a/testsuites/psxtests/psxualarm/system.h
+++ b/testsuites/psxtests/psxualarm/system.h
diff --git a/testsuites/psxtests/psxusleep/init.c b/testsuites/psxtests/psxusleep/init.c
index 383943e1fe..84eedd98dc 100644
--- a/testsuites/psxtests/psxusleep/init.c
+++ b/testsuites/psxtests/psxusleep/init.c
@@ -65,7 +65,7 @@ rtems_task Init(
diff --git a/testsuites/psxtmtests/psxtmbarrier01/init.c b/testsuites/psxtmtests/psxtmbarrier01/init.c
index cfbca8d975..06d61e3c98 100644
--- a/testsuites/psxtmtests/psxtmbarrier01/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier01/init.c
@@ -87,7 +87,7 @@ void *POSIX_Init(
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
diff --git a/testsuites/psxtmtests/psxtmbarrier02/init.c b/testsuites/psxtmtests/psxtmbarrier02/init.c
index 6705125ac6..22e9a56278 100644
--- a/testsuites/psxtmtests/psxtmbarrier02/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier02/init.c
@@ -129,7 +129,7 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS     OPERATION_COUNT + 2
diff --git a/testsuites/psxtmtests/psxtmbarrier03/init.c b/testsuites/psxtmtests/psxtmbarrier03/init.c
index 27feac1fe8..07df503311 100644
--- a/testsuites/psxtmtests/psxtmbarrier03/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier03/init.c
diff --git a/testsuites/psxtmtests/psxtmbarrier04/init.c b/testsuites/psxtmtests/psxtmbarrier04/init.c
index baf1bf1032..5d4885c193 100644
--- a/testsuites/psxtmtests/psxtmbarrier04/init.c
+++ b/testsuites/psxtmtests/psxtmbarrier04/init.c
@@ -86,7 +86,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep01/init.c b/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
index 5bc800f709..c0dab16b9d 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep01/init.c
@@ -47,7 +47,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep02/init.c b/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
index 3f458efb31..77d4dabc34 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep02/init.c
@@ -97,7 +97,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep03/init.c b/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
index 999cce24b4..12e2db96fc 100644
--- a/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
+++ b/testsuites/psxtmtests/psxtmclocknanosleep03/init.c
@@ -102,7 +102,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond01/init.c b/testsuites/psxtmtests/psxtmcond01/init.c
index 7ec876b9a0..35fdaed194 100644
--- a/testsuites/psxtmtests/psxtmcond01/init.c
+++ b/testsuites/psxtmtests/psxtmcond01/init.c
@@ -81,7 +81,7 @@ void *POSIX_Init(
 /* configure an instance of the condition variable created and destroyed */
diff --git a/testsuites/psxtmtests/psxtmcond02/init.c b/testsuites/psxtmtests/psxtmcond02/init.c
index 1e8e00ce94..ec5a2e9572 100644
--- a/testsuites/psxtmtests/psxtmcond02/init.c
+++ b/testsuites/psxtmtests/psxtmcond02/init.c
@@ -62,7 +62,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond03/init.c b/testsuites/psxtmtests/psxtmcond03/init.c
index 4a829bd55e..2f351ad372 100644
--- a/testsuites/psxtmtests/psxtmcond03/init.c
+++ b/testsuites/psxtmtests/psxtmcond03/init.c
diff --git a/testsuites/psxtmtests/psxtmcond04/init.c b/testsuites/psxtmtests/psxtmcond04/init.c
index 1a40f23e53..b45b24f697 100644
--- a/testsuites/psxtmtests/psxtmcond04/init.c
+++ b/testsuites/psxtmtests/psxtmcond04/init.c
diff --git a/testsuites/psxtmtests/psxtmcond05/init.c b/testsuites/psxtmtests/psxtmcond05/init.c
index fcfad14b5f..7791768fa2 100644
--- a/testsuites/psxtmtests/psxtmcond05/init.c
+++ b/testsuites/psxtmtests/psxtmcond05/init.c
diff --git a/testsuites/psxtmtests/psxtmcond06/init.c b/testsuites/psxtmtests/psxtmcond06/init.c
index ec87ccd45c..53d7e29ac9 100644
--- a/testsuites/psxtmtests/psxtmcond06/init.c
+++ b/testsuites/psxtmtests/psxtmcond06/init.c
@@ -119,7 +119,7 @@ void *POSIX_Init(
 #define CONFIGURE_MAXIMUM_POSIX_THREADS  2 + N
diff --git a/testsuites/psxtmtests/psxtmcond07/init.c b/testsuites/psxtmtests/psxtmcond07/init.c
index 218fccccd4..305082f371 100644
--- a/testsuites/psxtmtests/psxtmcond07/init.c
+++ b/testsuites/psxtmtests/psxtmcond07/init.c
@@ -115,7 +115,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmcond08/init.c b/testsuites/psxtmtests/psxtmcond08/init.c
index 377b09948d..6cce4545f7 100644
--- a/testsuites/psxtmtests/psxtmcond08/init.c
+++ b/testsuites/psxtmtests/psxtmcond08/init.c
@@ -165,7 +165,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmkey01/init.c b/testsuites/psxtmtests/psxtmkey01/init.c
index b58c8d571a..fc5b8174b0 100644
--- a/testsuites/psxtmtests/psxtmkey01/init.c
+++ b/testsuites/psxtmtests/psxtmkey01/init.c
@@ -82,7 +82,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtmtests/psxtmkey02/init.c b/testsuites/psxtmtests/psxtmkey02/init.c
index fafb8f62bf..268bbfe3a3 100644
--- a/testsuites/psxtmtests/psxtmkey02/init.c
+++ b/testsuites/psxtmtests/psxtmkey02/init.c
diff --git a/testsuites/psxtmtests/psxtmmq01/init.c b/testsuites/psxtmtests/psxtmmq01/init.c
index a5ed4fcf39..ac5ab402a8 100644
--- a/testsuites/psxtmtests/psxtmmq01/init.c
+++ b/testsuites/psxtmtests/psxtmmq01/init.c
@@ -295,7 +295,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmmutex01/init.c b/testsuites/psxtmtests/psxtmmutex01/init.c
index 7a020f917d..3356113014 100644
--- a/testsuites/psxtmtests/psxtmmutex01/init.c
+++ b/testsuites/psxtmtests/psxtmmutex01/init.c
@@ -79,7 +79,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmmutex02/init.c b/testsuites/psxtmtests/psxtmmutex02/init.c
index b71e21f35f..34d5713252 100644
--- a/testsuites/psxtmtests/psxtmmutex02/init.c
+++ b/testsuites/psxtmtests/psxtmmutex02/init.c
diff --git a/testsuites/psxtmtests/psxtmmutex03/init.c b/testsuites/psxtmtests/psxtmmutex03/init.c
index 13ad5fae83..bda72ac80e 100644
--- a/testsuites/psxtmtests/psxtmmutex03/init.c
+++ b/testsuites/psxtmtests/psxtmmutex03/init.c
@@ -169,7 +169,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmmutex04/init.c b/testsuites/psxtmtests/psxtmmutex04/init.c
index 6513c59223..ce439c5eb3 100644
--- a/testsuites/psxtmtests/psxtmmutex04/init.c
+++ b/testsuites/psxtmtests/psxtmmutex04/init.c
diff --git a/testsuites/psxtmtests/psxtmmutex05/init.c b/testsuites/psxtmtests/psxtmmutex05/init.c
index d274fc5257..64f1a5f9fd 100644
--- a/testsuites/psxtmtests/psxtmmutex05/init.c
+++ b/testsuites/psxtmtests/psxtmmutex05/init.c
diff --git a/testsuites/psxtmtests/psxtmmutex06/init.c b/testsuites/psxtmtests/psxtmmutex06/init.c
index c2bd0011c7..9314e2d56b 100644
--- a/testsuites/psxtmtests/psxtmmutex06/init.c
+++ b/testsuites/psxtmtests/psxtmmutex06/init.c
@@ -146,7 +146,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmmutex07/init.c b/testsuites/psxtmtests/psxtmmutex07/init.c
index de69fcca9c..b86fe419de 100644
--- a/testsuites/psxtmtests/psxtmmutex07/init.c
+++ b/testsuites/psxtmtests/psxtmmutex07/init.c
@@ -93,7 +93,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmnanosleep01/init.c b/testsuites/psxtmtests/psxtmnanosleep01/init.c
index f445af587c..24a34ee7fa 100644
--- a/testsuites/psxtmtests/psxtmnanosleep01/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep01/init.c
@@ -45,7 +45,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmnanosleep02/init.c b/testsuites/psxtmtests/psxtmnanosleep02/init.c
index 9e227e5291..97138f0426 100644
--- a/testsuites/psxtmtests/psxtmnanosleep02/init.c
+++ b/testsuites/psxtmtests/psxtmnanosleep02/init.c
diff --git a/testsuites/psxtmtests/psxtmrwlock01/init.c b/testsuites/psxtmtests/psxtmrwlock01/init.c
index 5bdfb5601c..4b791e4652 100644
--- a/testsuites/psxtmtests/psxtmrwlock01/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock01/init.c
@@ -268,7 +268,7 @@ void *POSIX_Init(
 /* configuration information */
diff --git a/testsuites/psxtmtests/psxtmrwlock02/init.c b/testsuites/psxtmtests/psxtmrwlock02/init.c
index f2462b235b..c284b06a95 100644
--- a/testsuites/psxtmtests/psxtmrwlock02/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock02/init.c
@@ -122,7 +122,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock03/init.c b/testsuites/psxtmtests/psxtmrwlock03/init.c
index 10c7aee4cc..da5a721565 100644
--- a/testsuites/psxtmtests/psxtmrwlock03/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock03/init.c
@@ -135,7 +135,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock04/init.c b/testsuites/psxtmtests/psxtmrwlock04/init.c
index dd2d7357f1..c707b00023 100644
--- a/testsuites/psxtmtests/psxtmrwlock04/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock04/init.c
@@ -123,7 +123,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmrwlock05/init.c b/testsuites/psxtmtests/psxtmrwlock05/init.c
index f6668c370d..d42ad8f5a0 100644
--- a/testsuites/psxtmtests/psxtmrwlock05/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock05/init.c
diff --git a/testsuites/psxtmtests/psxtmrwlock06/init.c b/testsuites/psxtmtests/psxtmrwlock06/init.c
index 93a49be1f5..818f2a0e40 100644
--- a/testsuites/psxtmtests/psxtmrwlock06/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock06/init.c
diff --git a/testsuites/psxtmtests/psxtmrwlock07/init.c b/testsuites/psxtmtests/psxtmrwlock07/init.c
index 303c3015c5..17634e8c26 100644
--- a/testsuites/psxtmtests/psxtmrwlock07/init.c
+++ b/testsuites/psxtmtests/psxtmrwlock07/init.c
@@ -154,7 +154,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmsem01/init.c b/testsuites/psxtmtests/psxtmsem01/init.c
index 4223a02b3b..4409b89b81 100644
--- a/testsuites/psxtmtests/psxtmsem01/init.c
+++ b/testsuites/psxtmtests/psxtmsem01/init.c
@@ -196,7 +196,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtmtests/psxtmsem02/init.c b/testsuites/psxtmtests/psxtmsem02/init.c
index 3c2f34a20b..4f1f4026d9 100644
--- a/testsuites/psxtmtests/psxtmsem02/init.c
+++ b/testsuites/psxtmtests/psxtmsem02/init.c
@@ -155,7 +155,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtmtests/psxtmsem03/init.c b/testsuites/psxtmtests/psxtmsem03/init.c
index 687c8c6343..5696145008 100644
--- a/testsuites/psxtmtests/psxtmsem03/init.c
+++ b/testsuites/psxtmtests/psxtmsem03/init.c
diff --git a/testsuites/psxtmtests/psxtmsem04/init.c b/testsuites/psxtmtests/psxtmsem04/init.c
index 540f0a3b97..7f9f46ea05 100644
--- a/testsuites/psxtmtests/psxtmsem04/init.c
+++ b/testsuites/psxtmtests/psxtmsem04/init.c
@@ -95,7 +95,7 @@ void *POSIX_Init(void *argument)
diff --git a/testsuites/psxtmtests/psxtmsem05/init.c b/testsuites/psxtmtests/psxtmsem05/init.c
index 07b96b2024..0d02d5491b 100644
--- a/testsuites/psxtmtests/psxtmsem05/init.c
+++ b/testsuites/psxtmtests/psxtmsem05/init.c
diff --git a/testsuites/psxtmtests/psxtmsleep01/init.c b/testsuites/psxtmtests/psxtmsleep01/init.c
index f2ee0af231..3ce4e58aa6 100644
--- a/testsuites/psxtmtests/psxtmsleep01/init.c
+++ b/testsuites/psxtmtests/psxtmsleep01/init.c
@@ -49,7 +49,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmsleep02/init.c b/testsuites/psxtmtests/psxtmsleep02/init.c
index 1e909a2633..ffc87e2070 100644
--- a/testsuites/psxtmtests/psxtmsleep02/init.c
+++ b/testsuites/psxtmtests/psxtmsleep02/init.c
@@ -80,7 +80,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmthread01/init.c b/testsuites/psxtmtests/psxtmthread01/init.c
index 60f94cfa56..8ed89862fc 100644
--- a/testsuites/psxtmtests/psxtmthread01/init.c
+++ b/testsuites/psxtmtests/psxtmthread01/init.c
@@ -67,7 +67,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmthread02/init.c b/testsuites/psxtmtests/psxtmthread02/init.c
index c468f0335e..e7cfd7d724 100644
--- a/testsuites/psxtmtests/psxtmthread02/init.c
+++ b/testsuites/psxtmtests/psxtmthread02/init.c
diff --git a/testsuites/psxtmtests/psxtmthread03/init.c b/testsuites/psxtmtests/psxtmthread03/init.c
index 938a8c62e0..76146b9c04 100644
--- a/testsuites/psxtmtests/psxtmthread03/init.c
+++ b/testsuites/psxtmtests/psxtmthread03/init.c
@@ -104,7 +104,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmthread04/init.c b/testsuites/psxtmtests/psxtmthread04/init.c
index 4ae0b574f1..ed8e4bb9b4 100644
--- a/testsuites/psxtmtests/psxtmthread04/init.c
+++ b/testsuites/psxtmtests/psxtmthread04/init.c
@@ -88,7 +88,7 @@ void *POSIX_Init(
diff --git a/testsuites/psxtmtests/psxtmthread05/init.c b/testsuites/psxtmtests/psxtmthread05/init.c
index 10d90369a4..4203e4b951 100644
--- a/testsuites/psxtmtests/psxtmthread05/init.c
+++ b/testsuites/psxtmtests/psxtmthread05/init.c
diff --git a/testsuites/psxtmtests/psxtmthread06/init.c b/testsuites/psxtmtests/psxtmthread06/init.c
index 603190932d..7499d98df1 100644
--- a/testsuites/psxtmtests/psxtmthread06/init.c
+++ b/testsuites/psxtmtests/psxtmthread06/init.c
diff --git a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
index a8977273c2..3538003a4a 100644
--- a/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
+++ b/testsuites/rhealstone/rhdeadlockbrk/deadlockbrk.c
@@ -203,7 +203,7 @@ rtems_task Task03( rtems_task_argument ignored )
 #define CONFIGURE_TICKS_PER_TIMESLICE        0
diff --git a/testsuites/rhealstone/rhilatency/ilatency.c b/testsuites/rhealstone/rhilatency/ilatency.c
index 0a7741bf28..27aa26eeaa 100644
--- a/testsuites/rhealstone/rhilatency/ilatency.c
+++ b/testsuites/rhealstone/rhilatency/ilatency.c
@@ -20,7 +20,7 @@
 #include <coverhd.h>
diff --git a/testsuites/rhealstone/rhmlatency/mlatency.c b/testsuites/rhealstone/rhmlatency/mlatency.c
index 11a29c0e2c..89d4d8d1ef 100644
--- a/testsuites/rhealstone/rhmlatency/mlatency.c
+++ b/testsuites/rhealstone/rhmlatency/mlatency.c
@@ -145,7 +145,7 @@ rtems_task Task02( rtems_task_argument ignored )
 #define CONFIGURE_MAXIMUM_TASKS              3
diff --git a/testsuites/rhealstone/rhsemshuffle/semshuffle.c b/testsuites/rhealstone/rhsemshuffle/semshuffle.c
index 6800926fec..0d1bf9c091 100644
--- a/testsuites/rhealstone/rhsemshuffle/semshuffle.c
+++ b/testsuites/rhealstone/rhsemshuffle/semshuffle.c
@@ -156,7 +156,7 @@ rtems_task Task02( rtems_task_argument ignored )
diff --git a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
index c396e742fe..490f4dcada 100644
--- a/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
+++ b/testsuites/rhealstone/rhtaskpreempt/taskpreempt.c
@@ -112,7 +112,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/rhealstone/rhtaskswitch/taskswitch.c b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
index 520de3374a..0806a67b9e 100644
--- a/testsuites/rhealstone/rhtaskswitch/taskswitch.c
+++ b/testsuites/rhealstone/rhtaskswitch/taskswitch.c
@@ -114,7 +114,7 @@ rtems_task Init( rtems_task_argument ignored )
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/samples/base_mp/system.h b/testsuites/samples/base_mp/system.h
index 359e5284c4..3c434397b5 100644
--- a/testsuites/samples/base_mp/system.h
+++ b/testsuites/samples/base_mp/system.h
@@ -30,7 +30,7 @@ rtems_task Application_task(
 #define CONFIGURE_MP_APPLICATION
diff --git a/testsuites/samples/base_sp/system.h b/testsuites/samples/base_sp/system.h
index 6e80fbbce3..174496ecbf 100644
--- a/testsuites/samples/base_sp/system.h
+++ b/testsuites/samples/base_sp/system.h
@@ -28,7 +28,7 @@ rtems_task Application_task(
 #include <bsp.h> /* for device driver prototypes */
diff --git a/testsuites/samples/capture/system.h b/testsuites/samples/capture/system.h
index d6d8b804a3..c187c75abd 100644
--- a/testsuites/samples/capture/system.h
+++ b/testsuites/samples/capture/system.h
@@ -39,7 +39,7 @@ extern void setup_tasks_to_watch(void);
diff --git a/testsuites/samples/cdtest/system.h b/testsuites/samples/cdtest/system.h
index f006552d56..5354a4c22a 100644
--- a/testsuites/samples/cdtest/system.h
+++ b/testsuites/samples/cdtest/system.h
@@ -24,7 +24,7 @@ rtems_task main_task(
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index 3a70ce850c..506c042a28 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
 #endif
 #define CONFIGURE_MAXIMUM_DRIVERS           4
 #ifdef RTEMS_BSP_HAS_IDE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 216a8b7e06..3f3dcd8d58 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
diff --git a/testsuites/samples/iostream/system.h b/testsuites/samples/iostream/system.h
index 62f7d535ec..0ae1d8f94f 100644
--- a/testsuites/samples/iostream/system.h
+++ b/testsuites/samples/iostream/system.h
@@ -20,7 +20,7 @@
 #define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY TRUE
diff --git a/testsuites/samples/loopback/init.c b/testsuites/samples/loopback/init.c
index 0532ef091b..0ba3e65a39 100644
--- a/testsuites/samples/loopback/init.c
+++ b/testsuites/samples/loopback/init.c
@@ -14,7 +14,7 @@
 const char rtems_test_name[] = "LOOPBACK";
diff --git a/testsuites/samples/nsecs/system.h b/testsuites/samples/nsecs/system.h
index 25f7d313b6..29627e49db 100644
--- a/testsuites/samples/nsecs/system.h
+++ b/testsuites/samples/nsecs/system.h
@@ -7,7 +7,7 @@
 extern void dummy_function_empty_body_to_force_call(void);
diff --git a/testsuites/samples/paranoia/system.h b/testsuites/samples/paranoia/system.h
index f6fce5655b..6726f81873 100644
--- a/testsuites/samples/paranoia/system.h
+++ b/testsuites/samples/paranoia/system.h
@@ -24,7 +24,7 @@ rtems_task Init(
diff --git a/testsuites/samples/pppd/system.h b/testsuites/samples/pppd/system.h
index f671cdbb83..52ce306918 100644
--- a/testsuites/samples/pppd/system.h
+++ b/testsuites/samples/pppd/system.h
@@ -12,7 +12,7 @@ extern int pppdapp_initialize(void);
 #include <bsp.h>
 #ifndef TTY1_DRIVER_TABLE_ENTRY
diff --git a/testsuites/samples/ticker/system.h b/testsuites/samples/ticker/system.h
index d4a54e082b..05261341f7 100644
--- a/testsuites/samples/ticker/system.h
+++ b/testsuites/samples/ticker/system.h
@@ -41,7 +41,7 @@ extern rtems_name Task_name[ 4 ];       /* array of task names */
 #define CONFIGURE_MAXIMUM_TASKS             4
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index 5da5d06aee..2624a696df 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -42,7 +42,7 @@ extern void test3(void);
 #define CONFIGURE_UNIFIED_WORK_AREAS
diff --git a/testsuites/smptests/smp01/system.h b/testsuites/smptests/smp01/system.h
index f3f08161aa..c1019b6858 100644
--- a/testsuites/smptests/smp01/system.h
+++ b/testsuites/smptests/smp01/system.h
@@ -23,7 +23,7 @@ rtems_task Test_task(
 #define CONFIGURE_MAXIMUM_PROCESSORS   4
diff --git a/testsuites/smptests/smp02/system.h b/testsuites/smptests/smp02/system.h
index 86d22958cf..da69df9568 100644
--- a/testsuites/smptests/smp02/system.h
+++ b/testsuites/smptests/smp02/system.h
diff --git a/testsuites/smptests/smp03/system.h b/testsuites/smptests/smp03/system.h
index 3d9b067381..2e9061c320 100644
--- a/testsuites/smptests/smp03/system.h
+++ b/testsuites/smptests/smp03/system.h
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index 7211e8ca88..6da5232780 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
 #define CONFIGURE_MAXIMUM_PROCESSORS   2
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 0dbf70b001..fe856c9d41 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -173,7 +173,7 @@ rtems_task Init(
diff --git a/testsuites/smptests/smp08/system.h b/testsuites/smptests/smp08/system.h
index 65209aace1..6d0fb97fed 100644
--- a/testsuites/smptests/smp08/system.h
+++ b/testsuites/smptests/smp08/system.h
@@ -25,7 +25,7 @@ rtems_task Test_task(
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index 66290641fd..5ebc855c9f 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -85,7 +85,7 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index eae6d708db..46b86eed17 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -225,7 +225,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 394cc3f865..593bd02d73 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -825,7 +825,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK (MS_PER_TICK * 1000)
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 73e30a13f2..c3e58685b2 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -303,7 +303,7 @@ static void fatal_extension(
 #define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index 2818b91cf1..259a8869bb 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -249,7 +249,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/smpcapture02/init.c
index 9926fbb493..9fc820ef6f 100644
--- a/testsuites/smptests/smpcapture02/init.c
+++ b/testsuites/smptests/smpcapture02/init.c
@@ -425,7 +425,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/smpclock01/init.c
index 5972959b66..8e0d93063c 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -172,7 +172,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index a49cb34bdf..f20d395697 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -116,7 +116,7 @@ static rtems_status_code test_driver_init(
 #define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
   { .initialization_entry = test_driver_init }
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index 94a9829529..a16261d1da 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -117,7 +117,7 @@ static rtems_status_code test_driver_init(
diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
index 3b83034261..26cc03482b 100644
--- a/testsuites/smptests/smpfatal03/init.c
+++ b/testsuites/smptests/smpfatal03/init.c
@@ -80,7 +80,7 @@ static void fatal_extension(
 #define CONFIGURE_INITIAL_EXTENSIONS \
   { .fatal = fatal_extension }, \
diff --git a/testsuites/smptests/smpfatal04/init.c b/testsuites/smptests/smpfatal04/init.c
index 939bf9f3a3..5599e790c4 100644
--- a/testsuites/smptests/smpfatal04/init.c
+++ b/testsuites/smptests/smpfatal04/init.c
@@ -55,7 +55,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpfatal05/init.c b/testsuites/smptests/smpfatal05/init.c
index 21c7a66aca..b850f922e4 100644
--- a/testsuites/smptests/smpfatal05/init.c
+++ b/testsuites/smptests/smpfatal05/init.c
@@ -49,7 +49,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpfatal06/init.c b/testsuites/smptests/smpfatal06/init.c
index 8c89bdb814..e18ed2ae74 100644
--- a/testsuites/smptests/smpfatal06/init.c
+++ b/testsuites/smptests/smpfatal06/init.c
diff --git a/testsuites/smptests/smpfatal08/init.c b/testsuites/smptests/smpfatal08/init.c
index 2b8fa1cf56..b4400136bb 100644
--- a/testsuites/smptests/smpfatal08/init.c
+++ b/testsuites/smptests/smpfatal08/init.c
@@ -106,7 +106,7 @@ static void fatal_extension(
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/smpipi01/init.c
index cc85388f7c..9a995c09bd 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -200,7 +200,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index 0e102354d4..da4c91d875 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -388,7 +388,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK 1000
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index c53da3bf79..796b0e02dc 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -758,7 +758,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index 8a25e65931..fffeff1871 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -235,7 +235,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index 4180f5387f..2a022d7dea 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -279,7 +279,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index aa974e29c9..b81877114f 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -1773,7 +1773,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (2 * CPU_COUNT + 2)
 #define CONFIGURE_MAXIMUM_SEMAPHORES (MRSP_COUNT + 1)
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index c7059e8e14..7f64415f89 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -941,7 +941,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_PROCESSORS PART_COUNT
diff --git a/testsuites/smptests/smpmutex02/init.c b/testsuites/smptests/smpmutex02/init.c
index 1604bb7cf8..7f8d331ef7 100644
--- a/testsuites/smptests/smpmutex02/init.c
+++ b/testsuites/smptests/smpmutex02/init.c
@@ -317,7 +317,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + WORKER_COUNT)
 #define CONFIGURE_MAXIMUM_SEMAPHORES (1 + MTX_COUNT)
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index 58e1db5435..0ae6ee9f8f 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
 #endif
diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
index 2d6dc10bc3..12f91124b3 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -231,7 +231,7 @@ void *POSIX_Init(
 #endif
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index aeed75c6d1..a85cc698d7 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -154,7 +154,7 @@ static void *POSIX_Init(void *arg)
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 367615838c..695eeb7b80 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -174,7 +174,7 @@ static void *POSIX_Init(void *arg)
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index 778fda7ba0..2d4585f3a4 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -153,7 +153,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity02/init.c b/testsuites/smptests/smpschedaffinity02/init.c
index 9a8cfed7dd..57fb0b8117 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -207,7 +207,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index a53b30caa7..629fa5d3f1 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -81,7 +81,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index 5dbd2eadae..9fb291f1f5 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -162,7 +162,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
index b89a6e29d8..4c8faaae1c 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -222,7 +222,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschededf01/init.c b/testsuites/smptests/smpschededf01/init.c
index 4613ebd61e..bf9b93c26d 100644
--- a/testsuites/smptests/smpschededf01/init.c
+++ b/testsuites/smptests/smpschededf01/init.c
@@ -132,7 +132,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_PERIODS 2
diff --git a/testsuites/smptests/smpschededf02/init.c b/testsuites/smptests/smpschededf02/init.c
index e0c5182f2e..03556bdd2b 100644
--- a/testsuites/smptests/smpschededf02/init.c
+++ b/testsuites/smptests/smpschededf02/init.c
@@ -365,7 +365,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + TASK_COUNT)
diff --git a/testsuites/smptests/smpschededf03/init.c b/testsuites/smptests/smpschededf03/init.c
index 33029532c6..2e46fdb333 100644
--- a/testsuites/smptests/smpschededf03/init.c
+++ b/testsuites/smptests/smpschededf03/init.c
@@ -143,7 +143,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpschedsem01/init.c b/testsuites/smptests/smpschedsem01/init.c
index cae5d6e84a..1aadc4704a 100644
--- a/testsuites/smptests/smpschedsem01/init.c
+++ b/testsuites/smptests/smpschedsem01/init.c
@@ -73,7 +73,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index 5df3281e25..a33805b72a 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -194,7 +194,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 831cff027e..c64e3d3b4c 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -423,7 +423,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_SEMAPHORES 2
diff --git a/testsuites/smptests/smpscheduler03/init.c b/testsuites/smptests/smpscheduler03/init.c
index 48ef87a82c..56fbd337fc 100644
--- a/testsuites/smptests/smpscheduler03/init.c
+++ b/testsuites/smptests/smpscheduler03/init.c
@@ -24,7 +24,7 @@ void Init(rtems_task_argument arg);
 const char rtems_test_name[] = "SMPSCHEDULER 3";
 #define CONFIGURE_MAXIMUM_PROCESSORS 1
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index a4e9da1289..f31925f1a2 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -176,7 +176,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpscheduler05/init.c b/testsuites/smptests/smpscheduler05/init.c
index 83a9786e58..b86ceea2cc 100644
--- a/testsuites/smptests/smpscheduler05/init.c
+++ b/testsuites/smptests/smpscheduler05/init.c
 const char rtems_test_name[] = "SMPSCHEDULER 5";
diff --git a/testsuites/smptests/smpscheduler06/init.c b/testsuites/smptests/smpscheduler06/init.c
index 96cae11200..44b45b7478 100644
--- a/testsuites/smptests/smpscheduler06/init.c
+++ b/testsuites/smptests/smpscheduler06/init.c
 const char rtems_test_name[] = "SMPSCHEDULER 6";
diff --git a/testsuites/smptests/smpscheduler07/init.c b/testsuites/smptests/smpscheduler07/init.c
index bb065b3844..70532aac94 100644
--- a/testsuites/smptests/smpscheduler07/init.c
+++ b/testsuites/smptests/smpscheduler07/init.c
 const char rtems_test_name[] = "SMPSCHEDULER 7";
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 52f2edbddd..966b68ff93 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -233,7 +233,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index 75ac79bc54..aae3ffa56e 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -327,7 +327,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpswitchextension01/init.c b/testsuites/smptests/smpswitchextension01/init.c
index 3fad1d927c..31c64dc49a 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -234,7 +234,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 5c2d106d0f..489dd954aa 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -504,7 +504,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index a5ccaae271..ef4ea9b71f 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -70,7 +70,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpwakeafter01/init.c b/testsuites/smptests/smpwakeafter01/init.c
index 3d091f59c0..b259e3b5fc 100644
--- a/testsuites/smptests/smpwakeafter01/init.c
+++ b/testsuites/smptests/smpwakeafter01/init.c
@@ -150,7 +150,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index 68f8277214..5acd17f83c 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -21,7 +21,7 @@ rtems_task Task_1_through_3(
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/sptests/sp02/system.h b/testsuites/sptests/sp02/system.h
index c9fcd3e30c..aea6dbc217 100644
--- a/testsuites/sptests/sp02/system.h
+++ b/testsuites/sptests/sp02/system.h
@@ -33,7 +33,7 @@ rtems_task Task_3(
diff --git a/testsuites/sptests/sp03/system.h b/testsuites/sptests/sp03/system.h
index 5db5cd576d..53e7b56323 100644
--- a/testsuites/sptests/sp03/system.h
+++ b/testsuites/sptests/sp03/system.h
@@ -25,7 +25,7 @@ rtems_task Task_2(
diff --git a/testsuites/sptests/sp04/system.h b/testsuites/sptests/sp04/system.h
index 9606368826..db7ba4999d 100644
--- a/testsuites/sptests/sp04/system.h
+++ b/testsuites/sptests/sp04/system.h
@@ -38,7 +38,7 @@ void Task_switch(
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS     1
diff --git a/testsuites/sptests/sp05/system.h b/testsuites/sptests/sp05/system.h
index 40491af3f8..d20217105e 100644
--- a/testsuites/sptests/sp05/system.h
+++ b/testsuites/sptests/sp05/system.h
 #define CONFIGURE_TICKS_PER_TIMESLICE       100
diff --git a/testsuites/sptests/sp06/system.h b/testsuites/sptests/sp06/system.h
index 7590d08473..272399ab6f 100644
--- a/testsuites/sptests/sp06/system.h
+++ b/testsuites/sptests/sp06/system.h
diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
index 3f8cb264c0..d171e85ebc 100644
--- a/testsuites/sptests/sp07/system.h
+++ b/testsuites/sptests/sp07/system.h
@@ -61,7 +61,7 @@ void Task_exit_extension(
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS     2
diff --git a/testsuites/sptests/sp08/init.c b/testsuites/sptests/sp08/init.c
index 2364c70287..52f16cf094 100644
--- a/testsuites/sptests/sp08/init.c
+++ b/testsuites/sptests/sp08/init.c
@@ -292,7 +292,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp11/system.h b/testsuites/sptests/sp11/system.h
index c76fa6bd81..a3ce85daea 100644
--- a/testsuites/sptests/sp11/system.h
+++ b/testsuites/sptests/sp11/system.h
@@ -64,7 +64,7 @@ rtems_timer_service_routine TA2_send_10_to_self(
diff --git a/testsuites/sptests/sp12/system.h b/testsuites/sptests/sp12/system.h
index 299169f350..7651b994b5 100644
--- a/testsuites/sptests/sp12/system.h
+++ b/testsuites/sptests/sp12/system.h
@@ -51,7 +51,7 @@ rtems_task Task5(
 #define CONFIGURE_INIT_TASK_STACK_SIZE      (RTEMS_MINIMUM_STACK_SIZE * 2)
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index e8632e45d4..21d769c82b 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -54,7 +54,7 @@ TEST_EXTERN rtems_name Queue_name[ 4 ];      /* array of queue names */
diff --git a/testsuites/sptests/sp14/system.h b/testsuites/sptests/sp14/system.h
index 3a63a8d119..38a84b369a 100644
--- a/testsuites/sptests/sp14/system.h
+++ b/testsuites/sptests/sp14/system.h
@@ -38,7 +38,7 @@ rtems_task Task_2(
diff --git a/testsuites/sptests/sp15/system.h b/testsuites/sptests/sp15/system.h
index 09a34fbfeb..68fd100a6a 100644
--- a/testsuites/sptests/sp15/system.h
+++ b/testsuites/sptests/sp15/system.h
@@ -25,7 +25,7 @@ rtems_task Task_1(
diff --git a/testsuites/sptests/sp16/system.h b/testsuites/sptests/sp16/system.h
index a8126631e0..38a44998fe 100644
--- a/testsuites/sptests/sp16/system.h
+++ b/testsuites/sptests/sp16/system.h
@@ -41,7 +41,7 @@ rtems_task Task5(
diff --git a/testsuites/sptests/sp17/system.h b/testsuites/sptests/sp17/system.h
index 9b84b2c6cd..52884269da 100644
--- a/testsuites/sptests/sp17/system.h
+++ b/testsuites/sptests/sp17/system.h
@@ -33,7 +33,7 @@ rtems_task Task_2(
diff --git a/testsuites/sptests/sp18/init.c b/testsuites/sptests/sp18/init.c
index 5f39794318..7a4bb14d26 100644
--- a/testsuites/sptests/sp18/init.c
+++ b/testsuites/sptests/sp18/init.c
diff --git a/testsuites/sptests/sp19/system.h b/testsuites/sptests/sp19/system.h
index 5c13c9ba75..f6e39c36b9 100644
--- a/testsuites/sptests/sp19/system.h
+++ b/testsuites/sptests/sp19/system.h
@@ -35,7 +35,7 @@ rtems_task Task_1(
 #define CONFIGURE_INIT_TASK_ATTRIBUTES    RTEMS_FLOATING_POINT
 #define CONFIGURE_MAXIMUM_TASKS             7
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index b7f1428919..6c5f679d72 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
@@ -33,7 +33,7 @@ void Get_all_counters( void );
 #define CONFIGURE_MICROSECONDS_PER_TICK 100000
diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
index da7c23ef5d..8d81cb1049 100644
--- a/testsuites/sptests/sp2038/init.c
+++ b/testsuites/sptests/sp2038/init.c
@@ -329,7 +329,7 @@ rtems_task Init(rtems_task_argument argument)
   rtems_test_exit(0);
diff --git a/testsuites/sptests/sp22/system.h b/testsuites/sptests/sp22/system.h
index 6ca7203984..9b5ba9f8e7 100644
--- a/testsuites/sptests/sp22/system.h
+++ b/testsuites/sptests/sp22/system.h
@@ -32,7 +32,7 @@ rtems_task Task_1(
 #define CONFIGURE_MAXIMUM_TASKS           2
diff --git a/testsuites/sptests/sp23/system.h b/testsuites/sptests/sp23/system.h
index 21e26f90e0..b7c1107008 100644
--- a/testsuites/sptests/sp23/system.h
+++ b/testsuites/sptests/sp23/system.h
diff --git a/testsuites/sptests/sp24/system.h b/testsuites/sptests/sp24/system.h
index 9da8005f2b..b0bcad44a1 100644
--- a/testsuites/sptests/sp24/system.h
+++ b/testsuites/sptests/sp24/system.h
@@ -30,7 +30,7 @@ rtems_task Task_1_through_3(
diff --git a/testsuites/sptests/sp25/system.h b/testsuites/sptests/sp25/system.h
index 7a32f26e9d..820fee0578 100644
--- a/testsuites/sptests/sp25/system.h
+++ b/testsuites/sptests/sp25/system.h
diff --git a/testsuites/sptests/sp26/system.h b/testsuites/sptests/sp26/system.h
index fdb22473e6..e1defb94e2 100644
--- a/testsuites/sptests/sp26/system.h
+++ b/testsuites/sptests/sp26/system.h
@@ -23,7 +23,7 @@ void task1(void);
 #define CONFIGURE_EXTRA_TASK_STACKS (5 * 3 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp27/init.c b/testsuites/sptests/sp27/init.c
index bb4630d2de..b9522fd364 100644
--- a/testsuites/sptests/sp27/init.c
+++ b/testsuites/sptests/sp27/init.c
@@ -131,7 +131,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS               6
diff --git a/testsuites/sptests/sp29/init.c b/testsuites/sptests/sp29/init.c
index e65fbe3d45..6b96ab8792 100644
--- a/testsuites/sptests/sp29/init.c
+++ b/testsuites/sptests/sp29/init.c
@@ -21,7 +21,7 @@ rtems_task Init (rtems_task_argument argument);
diff --git a/testsuites/sptests/sp30/system.h b/testsuites/sptests/sp30/system.h
index 2c716bdb23..0ec1ed9f57 100644
--- a/testsuites/sptests/sp30/system.h
+++ b/testsuites/sptests/sp30/system.h
 #define CONFIGURE_MAXIMUM_TASKS               5
diff --git a/testsuites/sptests/sp31/system.h b/testsuites/sptests/sp31/system.h
index b631949ca3..05c0009e5a 100644
--- a/testsuites/sptests/sp31/system.h
+++ b/testsuites/sptests/sp31/system.h
diff --git a/testsuites/sptests/sp32/init.c b/testsuites/sptests/sp32/init.c
index 71cd46c001..2432a14d2f 100644
--- a/testsuites/sptests/sp32/init.c
+++ b/testsuites/sptests/sp32/init.c
@@ -87,7 +87,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_PERIODS      1
diff --git a/testsuites/sptests/sp33/init.c b/testsuites/sptests/sp33/init.c
index d8e3c50ae3..5470a9974d 100644
--- a/testsuites/sptests/sp33/init.c
+++ b/testsuites/sptests/sp33/init.c
@@ -22,7 +22,7 @@ rtems_task Init (rtems_task_argument ignored);
 #define CONFIGURE_MAXIMUM_BARRIERS  1
diff --git a/testsuites/sptests/sp34/changepri.c b/testsuites/sptests/sp34/changepri.c
index 5000f693d3..c0e2dbf977 100644
--- a/testsuites/sptests/sp34/changepri.c
+++ b/testsuites/sptests/sp34/changepri.c
@@ -180,7 +180,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp35/priinv.c b/testsuites/sptests/sp35/priinv.c
index f604dbbddf..417462418a 100644
--- a/testsuites/sptests/sp35/priinv.c
+++ b/testsuites/sptests/sp35/priinv.c
@@ -432,7 +432,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp36/strict_order_mut.c b/testsuites/sptests/sp36/strict_order_mut.c
index db270caf41..f50b207116 100644
--- a/testsuites/sptests/sp36/strict_order_mut.c
+++ b/testsuites/sptests/sp36/strict_order_mut.c
@@ -22,7 +22,7 @@
diff --git a/testsuites/sptests/sp37/system.h b/testsuites/sptests/sp37/system.h
index 67a62d22a9..0b9d888164 100644
--- a/testsuites/sptests/sp37/system.h
+++ b/testsuites/sptests/sp37/system.h
@@ -25,7 +25,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp38/system.h b/testsuites/sptests/sp38/system.h
index b9965afd90..24fb0e6bf0 100644
--- a/testsuites/sptests/sp38/system.h
+++ b/testsuites/sptests/sp38/system.h
@@ -21,7 +21,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp40/init.c b/testsuites/sptests/sp40/init.c
index 44e8d45a03..37af04abd7 100644
--- a/testsuites/sptests/sp40/init.c
+++ b/testsuites/sptests/sp40/init.c
@@ -178,11 +178,11 @@ rtems_task Init(
 /* more one more driver slot than are statically configured */
-#define CONFIGURE_MAXIMUM_DRIVERS 3
+#define CONFIGURE_MAXIMUM_DRIVERS 2
diff --git a/testsuites/sptests/sp41/init.c b/testsuites/sptests/sp41/init.c
index 04b855b352..02fb5254d7 100644
--- a/testsuites/sptests/sp41/init.c
+++ b/testsuites/sptests/sp41/init.c
@@ -66,7 +66,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/sp42/init.c b/testsuites/sptests/sp42/init.c
index f4be2a5ca2..546cbebbf1 100644
--- a/testsuites/sptests/sp42/init.c
+++ b/testsuites/sptests/sp42/init.c
@@ -222,7 +222,7 @@ static rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS             MAX_TASKS+1
diff --git a/testsuites/sptests/sp43/system.h b/testsuites/sptests/sp43/system.h
index 991b51fe05..333ad972ab 100644
--- a/testsuites/sptests/sp43/system.h
+++ b/testsuites/sptests/sp43/system.h
diff --git a/testsuites/sptests/sp44/init.c b/testsuites/sptests/sp44/init.c
index 5b11eadda5..7354618a5f 100644
--- a/testsuites/sptests/sp44/init.c
+++ b/testsuites/sptests/sp44/init.c
@@ -121,7 +121,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp45/init.c b/testsuites/sptests/sp45/init.c
index b8b43b4df4..da9e740208 100644
--- a/testsuites/sptests/sp45/init.c
+++ b/testsuites/sptests/sp45/init.c
@@ -122,7 +122,7 @@ rtems_task Init(
 /* Two Tasks: Init and Timer Server */
diff --git a/testsuites/sptests/sp46/init.c b/testsuites/sptests/sp46/init.c
index 55653e0b3a..9d58a96fd9 100644
--- a/testsuites/sptests/sp46/init.c
+++ b/testsuites/sptests/sp46/init.c
@@ -110,7 +110,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp47/init.c b/testsuites/sptests/sp47/init.c
index 5d28303f19..dba7b7e87b 100644
--- a/testsuites/sptests/sp47/init.c
+++ b/testsuites/sptests/sp47/init.c
@@ -62,7 +62,7 @@ rtems_task Init(rtems_task_argument ignored)
 /* configuration stuff */
diff --git a/testsuites/sptests/sp48/init.c b/testsuites/sptests/sp48/init.c
index 53d8245c23..3af65f5f12 100644
--- a/testsuites/sptests/sp48/init.c
+++ b/testsuites/sptests/sp48/init.c
@@ -87,7 +87,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp49/init.c b/testsuites/sptests/sp49/init.c
index 64db98e11f..d1f6f05216 100644
--- a/testsuites/sptests/sp49/init.c
+++ b/testsuites/sptests/sp49/init.c
@@ -48,7 +48,7 @@ rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/sp50/init.c b/testsuites/sptests/sp50/init.c
index 58a7be7501..6852c4a28c 100644
--- a/testsuites/sptests/sp50/init.c
+++ b/testsuites/sptests/sp50/init.c
@@ -90,7 +90,7 @@ rtems_task Init(
 /**************** START OF CONFIGURATION INFORMATION ****************/
diff --git a/testsuites/sptests/sp51/init.c b/testsuites/sptests/sp51/init.c
index 1e8f9e5ceb..d1c16d1b6f 100644
--- a/testsuites/sptests/sp51/init.c
+++ b/testsuites/sptests/sp51/init.c
@@ -111,7 +111,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp52/init.c b/testsuites/sptests/sp52/init.c
index f7629a5d11..801a0b8754 100644
--- a/testsuites/sptests/sp52/init.c
+++ b/testsuites/sptests/sp52/init.c
@@ -120,7 +120,7 @@ static rtems_task Init(
 #define CONFIGURE_MICROSECONDS_PER_TICK 50000
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index 3b0d4589a9..cf7f4dbda4 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -56,7 +56,7 @@ static void *Init( uintptr_t ignored )
diff --git a/testsuites/sptests/sp55/init.c b/testsuites/sptests/sp55/init.c
index ee06e84d76..b89aecdad6 100644
--- a/testsuites/sptests/sp55/init.c
+++ b/testsuites/sptests/sp55/init.c
@@ -67,7 +67,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp56/init.c b/testsuites/sptests/sp56/init.c
index c0ce3c007c..5e0fde79ee 100644
--- a/testsuites/sptests/sp56/init.c
+++ b/testsuites/sptests/sp56/init.c
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
diff --git a/testsuites/sptests/sp57/init.c b/testsuites/sptests/sp57/init.c
index 3003c2fa9c..8d1573aede 100644
--- a/testsuites/sptests/sp57/init.c
+++ b/testsuites/sptests/sp57/init.c
@@ -77,7 +77,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp58/init.c b/testsuites/sptests/sp58/init.c
index b61120320e..f15a9229c4 100644
--- a/testsuites/sptests/sp58/init.c
+++ b/testsuites/sptests/sp58/init.c
diff --git a/testsuites/sptests/sp59/init.c b/testsuites/sptests/sp59/init.c
index 4120761acd..fc43a7c989 100644
--- a/testsuites/sptests/sp59/init.c
+++ b/testsuites/sptests/sp59/init.c
@@ -118,7 +118,7 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
diff --git a/testsuites/sptests/sp60/init.c b/testsuites/sptests/sp60/init.c
index b015ac1244..887747fd54 100644
--- a/testsuites/sptests/sp60/init.c
+++ b/testsuites/sptests/sp60/init.c
@@ -64,7 +64,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp62/init.c b/testsuites/sptests/sp62/init.c
index 7df64df0d6..e1ffc29747 100644
--- a/testsuites/sptests/sp62/init.c
+++ b/testsuites/sptests/sp62/init.c
@@ -144,7 +144,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp63/init.c b/testsuites/sptests/sp63/init.c
index 6f1c837d84..c63917ac1c 100644
--- a/testsuites/sptests/sp63/init.c
+++ b/testsuites/sptests/sp63/init.c
@@ -141,7 +141,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp64/init.c b/testsuites/sptests/sp64/init.c
index 153a9f25f4..0e1cdd131f 100644
--- a/testsuites/sptests/sp64/init.c
+++ b/testsuites/sptests/sp64/init.c
@@ -102,7 +102,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp65/init.c b/testsuites/sptests/sp65/init.c
index 09c64b9d0b..a557ede775 100644
--- a/testsuites/sptests/sp65/init.c
+++ b/testsuites/sptests/sp65/init.c
@@ -135,7 +135,7 @@ rtems_task Task_1(
diff --git a/testsuites/sptests/sp67/init.c b/testsuites/sptests/sp67/init.c
index 154e836f41..877f2d75d1 100644
--- a/testsuites/sptests/sp67/init.c
+++ b/testsuites/sptests/sp67/init.c
@@ -113,7 +113,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp68/init.c b/testsuites/sptests/sp68/init.c
index 5642203b74..66f456cea6 100644
--- a/testsuites/sptests/sp68/init.c
+++ b/testsuites/sptests/sp68/init.c
@@ -465,7 +465,7 @@ rtems_task Init(rtems_task_argument argument)
   rtems_test_exit(0);
diff --git a/testsuites/sptests/sp69/init.c b/testsuites/sptests/sp69/init.c
index c604c2de06..6a5e139d34 100644
--- a/testsuites/sptests/sp69/init.c
+++ b/testsuites/sptests/sp69/init.c
@@ -178,7 +178,7 @@ rtems_task Init(
 #define CONFIGURE_MILLISECONDS_PER_TICK 1
diff --git a/testsuites/sptests/sp70/init.c b/testsuites/sptests/sp70/init.c
index 721e3b91a1..becd7fb511 100644
--- a/testsuites/sptests/sp70/init.c
+++ b/testsuites/sptests/sp70/init.c
diff --git a/testsuites/sptests/sp71/init.c b/testsuites/sptests/sp71/init.c
index eff6ba72d0..7e6a7e591f 100644
--- a/testsuites/sptests/sp71/init.c
+++ b/testsuites/sptests/sp71/init.c
diff --git a/testsuites/sptests/sp72/init.c b/testsuites/sptests/sp72/init.c
index 5e2c8ab91d..188498f923 100644
--- a/testsuites/sptests/sp72/init.c
+++ b/testsuites/sptests/sp72/init.c
@@ -84,7 +84,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sp73/init.c b/testsuites/sptests/sp73/init.c
index 8db5024fc5..b798f8403b 100644
--- a/testsuites/sptests/sp73/init.c
+++ b/testsuites/sptests/sp73/init.c
@@ -116,7 +116,7 @@ rtems_task Init(
 #define CONFIGURE_SCHEDULER_SIMPLE
diff --git a/testsuites/sptests/sp74/init.c b/testsuites/sptests/sp74/init.c
index 346c67662c..2dd00861c7 100644
--- a/testsuites/sptests/sp74/init.c
+++ b/testsuites/sptests/sp74/init.c
@@ -63,7 +63,7 @@ rtems_task Init(
 #define CONFIGURE_INIT_TASK_PRIORITY      2
diff --git a/testsuites/sptests/sp75/init.c b/testsuites/sptests/sp75/init.c
index e699e766c6..dafa775339 100644
--- a/testsuites/sptests/sp75/init.c
+++ b/testsuites/sptests/sp75/init.c
@@ -55,7 +55,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS             1
diff --git a/testsuites/sptests/sp76/init.c b/testsuites/sptests/sp76/init.c
index daf55f1ede..c7e451c32a 100644
--- a/testsuites/sptests/sp76/init.c
+++ b/testsuites/sptests/sp76/init.c
@@ -96,7 +96,7 @@ static rtems_task Init(
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
diff --git a/testsuites/sptests/sp77/init.c b/testsuites/sptests/sp77/init.c
index c6ccacc3bc..2c4a71a73c 100644
--- a/testsuites/sptests/sp77/init.c
+++ b/testsuites/sptests/sp77/init.c
@@ -41,7 +41,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spassoc01/init.c b/testsuites/sptests/spassoc01/init.c
index ba3873ac0e..737cadb493 100644
--- a/testsuites/sptests/spassoc01/init.c
+++ b/testsuites/sptests/spassoc01/init.c
@@ -285,7 +285,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spatomic01/init.c b/testsuites/sptests/spatomic01/init.c
index b5fa6c4a7a..a37f3b3c32 100644
--- a/testsuites/sptests/spatomic01/init.c
+++ b/testsuites/sptests/spatomic01/init.c
@@ -342,7 +342,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
index 52fa860b93..09bb300ef3 100644
--- a/testsuites/sptests/spcache01/init.c
+++ b/testsuites/sptests/spcache01/init.c
@@ -504,7 +504,7 @@ static void fatal_extension(
diff --git a/testsuites/sptests/spcbssched01/system.h b/testsuites/sptests/spcbssched01/system.h
index 813a7a094e..1f75749a30 100644
--- a/testsuites/sptests/spcbssched01/system.h
+++ b/testsuites/sptests/spcbssched01/system.h
@@ -27,7 +27,7 @@ rtems_task Task_1_through_3(
 #define CONFIGURE_SCHEDULER_CBS
diff --git a/testsuites/sptests/spcbssched02/system.h b/testsuites/sptests/spcbssched02/system.h
index 302b9b54c2..007ca96810 100644
--- a/testsuites/sptests/spcbssched02/system.h
+++ b/testsuites/sptests/spcbssched02/system.h
@@ -25,7 +25,7 @@ rtems_task Task_Periodic(
 #define CONFIGURE_MICROSECONDS_PER_TICK 20000
diff --git a/testsuites/sptests/spcbssched03/system.h b/testsuites/sptests/spcbssched03/system.h
index 7ce4884eb7..1f864b5150 100644
--- a/testsuites/sptests/spcbssched03/system.h
+++ b/testsuites/sptests/spcbssched03/system.h
@@ -29,7 +29,7 @@ rtems_task Tasks_Aperiodic(
diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
index 8fa7ea087d..67bc3f53d0 100644
--- a/testsuites/sptests/spchain/init.c
+++ b/testsuites/sptests/spchain/init.c
@@ -518,7 +518,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spclock_err01/system.h b/testsuites/sptests/spclock_err01/system.h
index a1f3e95285..90238247d1 100644
--- a/testsuites/sptests/spclock_err01/system.h
+++ b/testsuites/sptests/spclock_err01/system.h
@@ -27,7 +27,7 @@ rtems_timer_service_routine Delayed_routine(
 #define CONFIGURE_MAXIMUM_TASKS              10
diff --git a/testsuites/sptests/spclock_err02/init.c b/testsuites/sptests/spclock_err02/init.c
index 7912ab8b21..c879c4ce1f 100644
--- a/testsuites/sptests/spclock_err02/init.c
+++ b/testsuites/sptests/spclock_err02/init.c
@@ -119,7 +119,7 @@ rtems_task Init(
   TEST_END();
diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
index e093c50618..7f874751f6 100644
--- a/testsuites/sptests/spcontext01/init.c
+++ b/testsuites/sptests/spcontext01/init.c
@@ -284,7 +284,7 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
 #define CONFIGURE_MAXIMUM_TIMERS 1
diff --git a/testsuites/sptests/spcoverage/init.c b/testsuites/sptests/spcoverage/init.c
index a80acec7fe..7c8e509d74 100644
--- a/testsuites/sptests/spcoverage/init.c
+++ b/testsuites/sptests/spcoverage/init.c
@@ -36,7 +36,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spcpucounter01/init.c b/testsuites/sptests/spcpucounter01/init.c
index 2fe197505e..a9caf3f545 100644
--- a/testsuites/sptests/spcpucounter01/init.c
+++ b/testsuites/sptests/spcpucounter01/init.c
@@ -242,7 +242,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK (NS_PER_TICK / 1000)
diff --git a/testsuites/sptests/spcpuset01/system.h b/testsuites/sptests/spcpuset01/system.h
index 85571c8e2d..37b56af1a8 100644
--- a/testsuites/sptests/spcpuset01/system.h
+++ b/testsuites/sptests/spcpuset01/system.h
@@ -34,7 +34,7 @@ void cpuset_logic_test(void);
 #define CONFIGURE_MAXIMUM_SEMAPHORES       1
diff --git a/testsuites/sptests/spedfsched01/system.h b/testsuites/sptests/spedfsched01/system.h
index e673b1f4d3..acf1a8317f 100644
--- a/testsuites/sptests/spedfsched01/system.h
+++ b/testsuites/sptests/spedfsched01/system.h
 #define CONFIGURE_SCHEDULER_EDF
diff --git a/testsuites/sptests/spedfsched02/system.h b/testsuites/sptests/spedfsched02/system.h
index cbdb7ad564..f3280e400c 100644
--- a/testsuites/sptests/spedfsched02/system.h
+++ b/testsuites/sptests/spedfsched02/system.h
diff --git a/testsuites/sptests/spedfsched03/system.h b/testsuites/sptests/spedfsched03/system.h
index ec5af826d1..71000be93d 100644
--- a/testsuites/sptests/spedfsched03/system.h
+++ b/testsuites/sptests/spedfsched03/system.h
diff --git a/testsuites/sptests/spedfsched04/init.c b/testsuites/sptests/spedfsched04/init.c
index bcaced994c..7efcd6809f 100644
--- a/testsuites/sptests/spedfsched04/init.c
+++ b/testsuites/sptests/spedfsched04/init.c
@@ -139,7 +139,7 @@ static rtems_task Init(
   directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
diff --git a/testsuites/sptests/sperror01/init.c b/testsuites/sptests/sperror01/init.c
index d2ccf0c9c7..b3b220bc66 100644
--- a/testsuites/sptests/sperror01/init.c
+++ b/testsuites/sptests/sperror01/init.c
diff --git a/testsuites/sptests/sperror02/init.c b/testsuites/sptests/sperror02/init.c
index abbe1c384f..324e38d43d 100644
--- a/testsuites/sptests/sperror02/init.c
+++ b/testsuites/sptests/sperror02/init.c
@@ -54,7 +54,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sperror03/init.c b/testsuites/sptests/sperror03/init.c
index e0369518e9..f4323a5001 100644
--- a/testsuites/sptests/sperror03/init.c
+++ b/testsuites/sptests/sperror03/init.c
@@ -49,7 +49,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spevent_err03/system.h b/testsuites/sptests/spevent_err03/system.h
index de3626be32..df7deb109d 100644
--- a/testsuites/sptests/spevent_err03/system.h
+++ b/testsuites/sptests/spevent_err03/system.h
@@ -22,7 +22,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/speventsystem01/init.c b/testsuites/sptests/speventsystem01/init.c
index 7fb2429bc2..d262023c69 100644
--- a/testsuites/sptests/speventsystem01/init.c
+++ b/testsuites/sptests/speventsystem01/init.c
@@ -126,7 +126,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/speventtransient01/init.c b/testsuites/sptests/speventtransient01/init.c
index 91d6ecfc18..e8e35f171f 100644
--- a/testsuites/sptests/speventtransient01/init.c
+++ b/testsuites/sptests/speventtransient01/init.c
@@ -119,7 +119,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spextensions01/init.c b/testsuites/sptests/spextensions01/init.c
index 58000839c4..35fce4878e 100644
--- a/testsuites/sptests/spextensions01/init.c
+++ b/testsuites/sptests/spextensions01/init.c
@@ -501,7 +501,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_USER_EXTENSIONS 4
diff --git a/testsuites/sptests/spfatal17/testcase.h b/testsuites/sptests/spfatal17/testcase.h
index 2f1046ab49..a82edca551 100644
--- a/testsuites/sptests/spfatal17/testcase.h
+++ b/testsuites/sptests/spfatal17/testcase.h
@@ -16,6 +16,8 @@
 #define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_RTEMS_API
 #define FATAL_ERROR_EXPECTED_ERROR       RTEMS_TOO_MANY
+#define FATAL_USE_TERMIOS_CONSOLE
 #define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS \
   CONSUME_SEMAPHORE_DRIVERS
diff --git a/testsuites/sptests/spfatal18/testcase.h b/testsuites/sptests/spfatal18/testcase.h
index eab617c1cf..ce1310ee35 100644
--- a/testsuites/sptests/spfatal18/testcase.h
+++ b/testsuites/sptests/spfatal18/testcase.h
@@ -16,6 +16,8 @@
diff --git a/testsuites/sptests/spfatal19/testcase.h b/testsuites/sptests/spfatal19/testcase.h
index 16ef09da3b..7b94ca4c9f 100644
--- a/testsuites/sptests/spfatal19/testcase.h
+++ b/testsuites/sptests/spfatal19/testcase.h
@@ -16,6 +16,8 @@
diff --git a/testsuites/sptests/spfatal20/testcase.h b/testsuites/sptests/spfatal20/testcase.h
index 863982aee0..715854c461 100644
--- a/testsuites/sptests/spfatal20/testcase.h
+++ b/testsuites/sptests/spfatal20/testcase.h
@@ -13,6 +13,8 @@
diff --git a/testsuites/sptests/spfatal_support/system.h b/testsuites/sptests/spfatal_support/system.h
index e0ffc7315f..8fe68ad716 100644
--- a/testsuites/sptests/spfatal_support/system.h
+++ b/testsuites/sptests/spfatal_support/system.h
@@ -71,7 +71,11 @@ extern rtems_extensions_table initial_extensions;
 /* extra parameters may be in testcase.h */
+#ifdef FATAL_USE_TERMIOS_CONSOLE
+#else
+#endif
 /* always need an Init task, some cases need more tasks */
diff --git a/testsuites/sptests/spfifo01/init.c b/testsuites/sptests/spfifo01/init.c
index 0e0f67815b..e38b23e039 100644
--- a/testsuites/sptests/spfifo01/init.c
+++ b/testsuites/sptests/spfifo01/init.c
@@ -59,7 +59,7 @@ rtems_task Init(rtems_task_argument not_used)
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
diff --git a/testsuites/sptests/spfifo02/init.c b/testsuites/sptests/spfifo02/init.c
index 64724016a3..a1cb2a3a55 100644
--- a/testsuites/sptests/spfifo02/init.c
+++ b/testsuites/sptests/spfifo02/init.c
@@ -205,7 +205,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spfifo03/init.c b/testsuites/sptests/spfifo03/init.c
index 5aa48004ec..4a2b7419d7 100644
--- a/testsuites/sptests/spfifo03/init.c
+++ b/testsuites/sptests/spfifo03/init.c
@@ -202,7 +202,7 @@ rtems_task Init(
   rtems_test_exit(0);
 #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
diff --git a/testsuites/sptests/spfifo04/init.c b/testsuites/sptests/spfifo04/init.c
index 157b45c786..01c84e4df6 100644
--- a/testsuites/sptests/spfifo04/init.c
+++ b/testsuites/sptests/spfifo04/init.c
@@ -97,7 +97,7 @@ rtems_task Init(
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spfifo05/init.c b/testsuites/sptests/spfifo05/init.c
index ab3ed66f96..dc331808f1 100644
--- a/testsuites/sptests/spfifo05/init.c
+++ b/testsuites/sptests/spfifo05/init.c
@@ -258,7 +258,7 @@ rtems_task Init(
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spfreechain01/init.c b/testsuites/sptests/spfreechain01/init.c
index 6efcd93762..60388101ea 100644
--- a/testsuites/sptests/spfreechain01/init.c
+++ b/testsuites/sptests/spfreechain01/init.c
@@ -59,7 +59,7 @@ static rtems_task Init(rtems_task_argument ignored)
diff --git a/testsuites/sptests/spglobalcon01/init.cc b/testsuites/sptests/spglobalcon01/init.cc
index 4ef3077b9f..aee9d0a141 100644
--- a/testsuites/sptests/spglobalcon01/init.cc
+++ b/testsuites/sptests/spglobalcon01/init.cc
@@ -47,7 +47,7 @@ static void *idle_body(uintptr_t ignored)
 #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
diff --git a/testsuites/sptests/spheapprot/init.c b/testsuites/sptests/spheapprot/init.c
index 114abebc20..261b7dcc76 100644
--- a/testsuites/sptests/spheapprot/init.c
+++ b/testsuites/sptests/spheapprot/init.c
@@ -138,7 +138,7 @@ static rtems_task Init(rtems_task_argument argument)
 #define CONFIGURE_MAXIMUM_DRIVERS 1
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 2ed4c955d8..f1ef8f3826 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -86,7 +86,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spintr_err01/system.h b/testsuites/sptests/spintr_err01/system.h
index b915dce53e..bfece39291 100644
--- a/testsuites/sptests/spintr_err01/system.h
+++ b/testsuites/sptests/spintr_err01/system.h
@@ -26,7 +26,7 @@ rtems_isr Service_routine(
diff --git a/testsuites/sptests/spintrcritical01/init.c b/testsuites/sptests/spintrcritical01/init.c
index b7cfee42f8..5c480b4bb3 100644
--- a/testsuites/sptests/spintrcritical01/init.c
+++ b/testsuites/sptests/spintrcritical01/init.c
@@ -133,7 +133,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical06/init.c b/testsuites/sptests/spintrcritical06/init.c
index 423e4b5fa7..161f0502de 100644
--- a/testsuites/sptests/spintrcritical06/init.c
+++ b/testsuites/sptests/spintrcritical06/init.c
@@ -125,7 +125,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 1a7ed2d2e5..559a1e421d 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -120,7 +120,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index 87c1c1aab3..dc5b985ce7 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -100,7 +100,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index f7e372a46b..bbdfb54f3f 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -349,7 +349,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical11/init.c b/testsuites/sptests/spintrcritical11/init.c
index 2a3f83a315..fb0d320dea 100644
--- a/testsuites/sptests/spintrcritical11/init.c
+++ b/testsuites/sptests/spintrcritical11/init.c
@@ -78,7 +78,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical13/init.c b/testsuites/sptests/spintrcritical13/init.c
index 7069938191..e284d3c33d 100644
--- a/testsuites/sptests/spintrcritical13/init.c
+++ b/testsuites/sptests/spintrcritical13/init.c
@@ -99,7 +99,7 @@ rtems_task Init(
 #if defined(SERVER_FIRE_AFTER)
diff --git a/testsuites/sptests/spintrcritical15/init.c b/testsuites/sptests/spintrcritical15/init.c
index 72e4832769..6f2548ff6f 100644
--- a/testsuites/sptests/spintrcritical15/init.c
+++ b/testsuites/sptests/spintrcritical15/init.c
@@ -98,7 +98,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical16/init.c b/testsuites/sptests/spintrcritical16/init.c
index 3657c0607f..1879cbd189 100644
--- a/testsuites/sptests/spintrcritical16/init.c
+++ b/testsuites/sptests/spintrcritical16/init.c
@@ -97,7 +97,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/spintrcritical18/init.c b/testsuites/sptests/spintrcritical18/init.c
index f621d21280..d15ab80f19 100644
--- a/testsuites/sptests/spintrcritical18/init.c
+++ b/testsuites/sptests/spintrcritical18/init.c
@@ -152,7 +152,7 @@ static void Init( rtems_task_argument ignored )
   rtems_test_exit( 0 );
diff --git a/testsuites/sptests/spintrcritical20/init.c b/testsuites/sptests/spintrcritical20/init.c
index 1697df426a..f9c52809a9 100644
--- a/testsuites/sptests/spintrcritical20/init.c
+++ b/testsuites/sptests/spintrcritical20/init.c
@@ -155,7 +155,7 @@ static void Init(rtems_task_argument ignored)
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spintrcritical21/system.h b/testsuites/sptests/spintrcritical21/system.h
index f9111c0412..04b9050598 100644
--- a/testsuites/sptests/spintrcritical21/system.h
+++ b/testsuites/sptests/spintrcritical21/system.h
diff --git a/testsuites/sptests/spintrcritical22/init.c b/testsuites/sptests/spintrcritical22/init.c
index 7412bdef7e..0ffb8cf89c 100644
--- a/testsuites/sptests/spintrcritical22/init.c
+++ b/testsuites/sptests/spintrcritical22/init.c
@@ -122,7 +122,7 @@ static void Init(rtems_task_argument ignored)
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spintrcritical23/init.c b/testsuites/sptests/spintrcritical23/init.c
index f71de71099..c0a159471c 100644
--- a/testsuites/sptests/spintrcritical23/init.c
+++ b/testsuites/sptests/spintrcritical23/init.c
diff --git a/testsuites/sptests/spintrcritical24/init.c b/testsuites/sptests/spintrcritical24/init.c
index 8f60c1ce70..4c74ee5929 100644
--- a/testsuites/sptests/spintrcritical24/init.c
+++ b/testsuites/sptests/spintrcritical24/init.c
@@ -131,7 +131,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/splinkersets01/init.c b/testsuites/sptests/splinkersets01/init.c
index 4e19c6e846..a567cb9449 100644
--- a/testsuites/sptests/splinkersets01/init.c
+++ b/testsuites/sptests/splinkersets01/init.c
@@ -264,7 +264,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spmkdir/init.c b/testsuites/sptests/spmkdir/init.c
index 6b016e3f1c..d2d12657f4 100644
--- a/testsuites/sptests/spmkdir/init.c
+++ b/testsuites/sptests/spmkdir/init.c
@@ -107,7 +107,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/sptests/spmountmgr01/init.c b/testsuites/sptests/spmountmgr01/init.c
index 2330ca82ba..a55beace39 100644
--- a/testsuites/sptests/spmountmgr01/init.c
+++ b/testsuites/sptests/spmountmgr01/init.c
diff --git a/testsuites/sptests/spmrsp01/init.c b/testsuites/sptests/spmrsp01/init.c
index bf144a9775..c7b2ae27c2 100644
--- a/testsuites/sptests/spmrsp01/init.c
+++ b/testsuites/sptests/spmrsp01/init.c
@@ -323,7 +323,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spmsgq_err01/system.h b/testsuites/sptests/spmsgq_err01/system.h
index f1f9f3bda9..9d1dd7e96e 100644
--- a/testsuites/sptests/spmsgq_err01/system.h
+++ b/testsuites/sptests/spmsgq_err01/system.h
 /* configuration information */
diff --git a/testsuites/sptests/spmsgq_err02/system.h b/testsuites/sptests/spmsgq_err02/system.h
index 572ff14b7f..32ee6cc7c4 100644
--- a/testsuites/sptests/spmsgq_err02/system.h
+++ b/testsuites/sptests/spmsgq_err02/system.h
@@ -26,7 +26,7 @@ rtems_task Task_3(
diff --git a/testsuites/sptests/spmutex01/init.c b/testsuites/sptests/spmutex01/init.c
index b9d4a05f73..8590dde00f 100644
--- a/testsuites/sptests/spmutex01/init.c
+++ b/testsuites/sptests/spmutex01/init.c
@@ -706,7 +706,7 @@ static void fatal_extension(
 #define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
diff --git a/testsuites/sptests/spnsext01/init.c b/testsuites/sptests/spnsext01/init.c
index 1a10736611..86e8225c6f 100644
--- a/testsuites/sptests/spnsext01/init.c
+++ b/testsuites/sptests/spnsext01/init.c
@@ -79,7 +79,7 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/sptests/spobjgetnext/system.h b/testsuites/sptests/spobjgetnext/system.h
index 3282f1c6f9..37941c3d0e 100644
--- a/testsuites/sptests/spobjgetnext/system.h
+++ b/testsuites/sptests/spobjgetnext/system.h
@@ -17,7 +17,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/sppagesize/init.c b/testsuites/sptests/sppagesize/init.c
index 04d735b84b..1f2f1f1432 100644
--- a/testsuites/sptests/sppagesize/init.c
+++ b/testsuites/sptests/sppagesize/init.c
@@ -35,7 +35,7 @@ rtems_task Init(
     rtems_test_exit(0);
diff --git a/testsuites/sptests/sppartition_err01/system.h b/testsuites/sptests/sppartition_err01/system.h
index 71a5f2a9b5..c57a85a844 100644
--- a/testsuites/sptests/sppartition_err01/system.h
+++ b/testsuites/sptests/sppartition_err01/system.h
@@ -11,7 +11,7 @@
diff --git a/testsuites/sptests/spport_err01/system.h b/testsuites/sptests/spport_err01/system.h
--- a/testsuites/sptests/spport_err01/system.h
+++ b/testsuites/sptests/spport_err01/system.h
diff --git a/testsuites/sptests/spprivenv01/init.c b/testsuites/sptests/spprivenv01/init.c
index 88cf5e07af..b6b6c14541 100644
--- a/testsuites/sptests/spprivenv01/init.c
+++ b/testsuites/sptests/spprivenv01/init.c
@@ -115,7 +115,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spprofiling01/init.c b/testsuites/sptests/spprofiling01/init.c
index 7a3b0e1736..a0e3188e09 100644
--- a/testsuites/sptests/spprofiling01/init.c
+++ b/testsuites/sptests/spprofiling01/init.c
@@ -138,7 +138,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spqreslib/system.h b/testsuites/sptests/spqreslib/system.h
index 2687153d71..80cb528e46 100644
--- a/testsuites/sptests/spqreslib/system.h
+++ b/testsuites/sptests/spqreslib/system.h
diff --git a/testsuites/sptests/spratemon_err01/system.h b/testsuites/sptests/spratemon_err01/system.h
index a7eb2ebb4c..7c1993cad5 100644
--- a/testsuites/sptests/spratemon_err01/system.h
+++ b/testsuites/sptests/spratemon_err01/system.h
@@ -33,7 +33,7 @@ void Screen10( void );
diff --git a/testsuites/sptests/sprbtree01/init.c b/testsuites/sptests/sprbtree01/init.c
index 746b36ee3a..cbd6c8f9e1 100644
--- a/testsuites/sptests/sprbtree01/init.c
+++ b/testsuites/sptests/sprbtree01/init.c
@@ -2306,7 +2306,7 @@ rtems_task Init( rtems_task_argument ignored )
diff --git a/testsuites/sptests/spregion_err01/system.h b/testsuites/sptests/spregion_err01/system.h
index 97d3e11897..865085fde7 100644
--- a/testsuites/sptests/spregion_err01/system.h
+++ b/testsuites/sptests/spregion_err01/system.h
@@ -11,7 +11,7 @@
diff --git a/testsuites/sptests/sprmsched01/init.c b/testsuites/sptests/sprmsched01/init.c
index f806605ec8..5efd9e2f6b 100644
--- a/testsuites/sptests/sprmsched01/init.c
+++ b/testsuites/sptests/sprmsched01/init.c
@@ -140,7 +140,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/sprmsched02/init.c b/testsuites/sptests/sprmsched02/init.c
index 4ee58ab5ec..3834542622 100644
--- a/testsuites/sptests/sprmsched02/init.c
+++ b/testsuites/sptests/sprmsched02/init.c
@@ -101,7 +101,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index c7e5518c57..fc03d0348d 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -612,7 +612,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spsem01/init.c b/testsuites/sptests/spsem01/init.c
index 924f4c052d..a84eead468 100644
--- a/testsuites/sptests/spsem01/init.c
+++ b/testsuites/sptests/spsem01/init.c
@@ -12,7 +12,7 @@
 #include "tmacros.h"
diff --git a/testsuites/sptests/spsem02/init.c b/testsuites/sptests/spsem02/init.c
index d5fb47b255..99def724f4 100644
--- a/testsuites/sptests/spsem02/init.c
+++ b/testsuites/sptests/spsem02/init.c
@@ -12,7 +12,7 @@
diff --git a/testsuites/sptests/spsem03/init.c b/testsuites/sptests/spsem03/init.c
index 859f996629..780219d06e 100644
--- a/testsuites/sptests/spsem03/init.c
+++ b/testsuites/sptests/spsem03/init.c
@@ -140,7 +140,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spsem_err01/system.h b/testsuites/sptests/spsem_err01/system.h
index 567427c5b7..2c023e52f3 100644
--- a/testsuites/sptests/spsem_err01/system.h
+++ b/testsuites/sptests/spsem_err01/system.h
diff --git a/testsuites/sptests/spsem_err02/system.h b/testsuites/sptests/spsem_err02/system.h
index 7a48a48ba8..72654922e2 100644
--- a/testsuites/sptests/spsem_err02/system.h
+++ b/testsuites/sptests/spsem_err02/system.h
@@ -26,7 +26,7 @@ rtems_task Task_2(
diff --git a/testsuites/sptests/spsignal_err01/system.h b/testsuites/sptests/spsignal_err01/system.h
--- a/testsuites/sptests/spsignal_err01/system.h
+++ b/testsuites/sptests/spsignal_err01/system.h
diff --git a/testsuites/sptests/spsimplesched01/init.c b/testsuites/sptests/spsimplesched01/init.c
index 6bac9c367a..90af5c4462 100644
--- a/testsuites/sptests/spsimplesched01/init.c
+++ b/testsuites/sptests/spsimplesched01/init.c
@@ -126,7 +126,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index 884a3abf6f..f683a7dd90 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
 #define CONFIGURE_MAXIMUM_TASKS             3
diff --git a/testsuites/sptests/spsimplesched03/init.c b/testsuites/sptests/spsimplesched03/init.c
index 2f352af88b..a5970ee8ab 100644
--- a/testsuites/sptests/spsimplesched03/init.c
+++ b/testsuites/sptests/spsimplesched03/init.c
@@ -42,7 +42,7 @@ rtems_task Init(
diff --git a/testsuites/sptests/spsize/system.h b/testsuites/sptests/spsize/system.h
index ab4c458929..3e80b1f43d 100644
--- a/testsuites/sptests/spsize/system.h
+++ b/testsuites/sptests/spsize/system.h
@@ -27,7 +27,7 @@ int getint( void );
diff --git a/testsuites/sptests/spstdthreads01/init.c b/testsuites/sptests/spstdthreads01/init.c
index 4a9953cf8a..72c4a153e9 100644
--- a/testsuites/sptests/spstdthreads01/init.c
+++ b/testsuites/sptests/spstdthreads01/init.c
@@ -411,7 +411,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MICROSECONDS_PER_TICK US_PER_TICK
diff --git a/testsuites/sptests/spstkalloc/init.c b/testsuites/sptests/spstkalloc/init.c
index 4a26fdb9a6..ab9612c94a 100644
--- a/testsuites/sptests/spstkalloc/init.c
+++ b/testsuites/sptests/spstkalloc/init.c
@@ -82,7 +82,7 @@ rtems_task Init(
 #define CONFIGURE_TASK_STACK_ALLOCATOR    StackAllocator
diff --git a/testsuites/sptests/spstkalloc02/init.c b/testsuites/sptests/spstkalloc02/init.c
index ae78b41480..d6812fb043 100644
--- a/testsuites/sptests/spstkalloc02/init.c
+++ b/testsuites/sptests/spstkalloc02/init.c
@@ -117,7 +117,7 @@ static rtems_task Init(rtems_task_argument argument)
   rtems_test_exit(0);
diff --git a/testsuites/sptests/spsysinit01/init.c b/testsuites/sptests/spsysinit01/init.c
index d0d3042a44..4b62302bd6 100644
--- a/testsuites/sptests/spsysinit01/init.c
+++ b/testsuites/sptests/spsysinit01/init.c
@@ -662,7 +662,7 @@ static void *POSIX_Init(void *arg)
 #endif /* RTEMS_POSIX_API */
diff --git a/testsuites/sptests/spsyslock01/init.c b/testsuites/sptests/spsyslock01/init.c
index 815579a0d9..1e3d16a675 100644
--- a/testsuites/sptests/spsyslock01/init.c
+++ b/testsuites/sptests/spsyslock01/init.c
@@ -705,7 +705,7 @@ static void fatal_extension(
diff --git a/testsuites/sptests/sptask_err01/system.h b/testsuites/sptests/sptask_err01/system.h
index e7965ddca8..4edc5aae04 100644
--- a/testsuites/sptests/sptask_err01/system.h
+++ b/testsuites/sptests/sptask_err01/system.h
diff --git a/testsuites/sptests/sptask_err02/system.h b/testsuites/sptests/sptask_err02/system.h
index 61209dad74..98fd96b6cf 100644
--- a/testsuites/sptests/sptask_err02/system.h
+++ b/testsuites/sptests/sptask_err02/system.h
diff --git a/testsuites/sptests/sptask_err03/system.h b/testsuites/sptests/sptask_err03/system.h
index 1e41c6ad01..eac27fc7a6 100644
--- a/testsuites/sptests/sptask_err03/system.h
+++ b/testsuites/sptests/sptask_err03/system.h
diff --git a/testsuites/sptests/sptask_err04/system.h b/testsuites/sptests/sptask_err04/system.h
index 60a7652444..91f16400c6 100644
--- a/testsuites/sptests/sptask_err04/system.h
+++ b/testsuites/sptests/sptask_err04/system.h
@@ -26,7 +26,7 @@ rtems_task Task_1(
diff --git a/testsuites/sptests/sptasknopreempt01/init.c b/testsuites/sptests/sptasknopreempt01/init.c
index 4bd49b1d82..2d698e0f18 100644
--- a/testsuites/sptests/sptasknopreempt01/init.c
+++ b/testsuites/sptests/sptasknopreempt01/init.c
@@ -80,7 +80,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spthreadlife01/init.c b/testsuites/sptests/spthreadlife01/init.c
index 8bf26b9b72..6cab1dd857 100644
--- a/testsuites/sptests/spthreadlife01/init.c
+++ b/testsuites/sptests/spthreadlife01/init.c
@@ -417,7 +417,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spthreadq01/init.c b/testsuites/sptests/spthreadq01/init.c
index 0b307542cf..64a51bcf18 100644
--- a/testsuites/sptests/spthreadq01/init.c
+++ b/testsuites/sptests/spthreadq01/init.c
@@ -291,7 +291,7 @@ static rtems_task Init(
diff --git a/testsuites/sptests/sptimecounter02/init.c b/testsuites/sptests/sptimecounter02/init.c
index 4f8de6a034..abd550f4f6 100644
--- a/testsuites/sptests/sptimecounter02/init.c
+++ b/testsuites/sptests/sptimecounter02/init.c
@@ -251,7 +251,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (2 + CPU_COUNT - 1)
 #define CONFIGURE_MAXIMUM_TIMERS 2
diff --git a/testsuites/sptests/sptimecounter03/init.c b/testsuites/sptests/sptimecounter03/init.c
index 3b57d95a12..a471a19781 100644
--- a/testsuites/sptests/sptimecounter03/init.c
+++ b/testsuites/sptests/sptimecounter03/init.c
@@ -92,7 +92,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
diff --git a/testsuites/sptests/sptimecounter04/init.c b/testsuites/sptests/sptimecounter04/init.c
index 72f2a138d5..f1304a3c5c 100644
--- a/testsuites/sptests/sptimecounter04/init.c
+++ b/testsuites/sptests/sptimecounter04/init.c
@@ -71,7 +71,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sptimer_err01/init.c b/testsuites/sptests/sptimer_err01/init.c
index 35a6d7a1dd..1faa2e27fa 100644
--- a/testsuites/sptests/sptimer_err01/init.c
+++ b/testsuites/sptests/sptimer_err01/init.c
@@ -258,7 +258,7 @@ rtems_timer_service_routine Delayed_routine(
diff --git a/testsuites/sptests/sptimer_err02/init.c b/testsuites/sptests/sptimer_err02/init.c
index ad25a16926..882f86be1a 100644
--- a/testsuites/sptests/sptimer_err02/init.c
+++ b/testsuites/sptests/sptimer_err02/init.c
@@ -215,7 +215,7 @@ rtems_timer_service_routine Delayed_routine(
diff --git a/testsuites/sptests/sptimerserver01/init.c b/testsuites/sptests/sptimerserver01/init.c
index 88f1fb3cf3..237f8b3699 100644
--- a/testsuites/sptests/sptimerserver01/init.c
+++ b/testsuites/sptests/sptimerserver01/init.c
@@ -115,7 +115,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TIMERS TIMER_COUNT
diff --git a/testsuites/sptests/sptimespec01/init.c b/testsuites/sptests/sptimespec01/init.c
index 945bd217ed..53aba88bf2 100644
--- a/testsuites/sptests/sptimespec01/init.c
+++ b/testsuites/sptests/sptimespec01/init.c
@@ -240,7 +240,7 @@ void test_convert(){
diff --git a/testsuites/sptests/sptls01/init.c b/testsuites/sptests/sptls01/init.c
index ba662aa832..7724f63af2 100644
--- a/testsuites/sptests/sptls01/init.c
+++ b/testsuites/sptests/sptls01/init.c
@@ -96,7 +96,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/sptls02/init.cc b/testsuites/sptests/sptls02/init.cc
index 86e3158dc9..1cbefc6fcc 100644
--- a/testsuites/sptests/sptls02/init.cc
+++ b/testsuites/sptests/sptls02/init.cc
@@ -273,7 +273,7 @@ extern "C" void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_SEMAPHORES 3
diff --git a/testsuites/sptests/sptls03/init.c b/testsuites/sptests/sptls03/init.c
index 1487595981..6690ec349c 100644
--- a/testsuites/sptests/sptls03/init.c
+++ b/testsuites/sptests/sptls03/init.c
@@ -48,7 +48,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spwatchdog/system.h b/testsuites/sptests/spwatchdog/system.h
index 887c8c8a42..40b7777faa 100644
--- a/testsuites/sptests/spwatchdog/system.h
+++ b/testsuites/sptests/spwatchdog/system.h
diff --git a/testsuites/sptests/spwkspace/init.c b/testsuites/sptests/spwkspace/init.c
index 5131ebc189..ab07e006c5 100644
--- a/testsuites/sptests/spwkspace/init.c
+++ b/testsuites/sptests/spwkspace/init.c
diff --git a/testsuites/tmtests/tm01/system.h b/testsuites/tmtests/tm01/system.h
index 5df14cd56b..a661b80824 100644
--- a/testsuites/tmtests/tm01/system.h
+++ b/testsuites/tmtests/tm01/system.h
@@ -27,7 +27,7 @@ rtems_id   Task_id[ OPERATION_COUNT+1 ];   /* array of task ids */
 #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
diff --git a/testsuites/tmtests/tm02/system.h b/testsuites/tmtests/tm02/system.h
index 2a32e3e340..2b070749ac 100644
--- a/testsuites/tmtests/tm02/system.h
+++ b/testsuites/tmtests/tm02/system.h
@@ -24,7 +24,7 @@ rtems_task Init(
 #define CONFIGURE_MAXIMUM_TASKS              (3 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm03/system.h b/testsuites/tmtests/tm03/system.h
--- a/testsuites/tmtests/tm03/system.h
+++ b/testsuites/tmtests/tm03/system.h
diff --git a/testsuites/tmtests/tm04/system.h b/testsuites/tmtests/tm04/system.h
index 9147efbed4..3da9bf8c0c 100644
--- a/testsuites/tmtests/tm04/system.h
+++ b/testsuites/tmtests/tm04/system.h
 #define CONFIGURE_MAXIMUM_TASKS              (4 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm05/system.h b/testsuites/tmtests/tm05/system.h
index 68e1fcd84d..29a25acd03 100644
--- a/testsuites/tmtests/tm05/system.h
+++ b/testsuites/tmtests/tm05/system.h
 #define CONFIGURE_MAXIMUM_TASKS              (2 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm06/system.h b/testsuites/tmtests/tm06/system.h
--- a/testsuites/tmtests/tm06/system.h
+++ b/testsuites/tmtests/tm06/system.h
diff --git a/testsuites/tmtests/tm07/system.h b/testsuites/tmtests/tm07/system.h
--- a/testsuites/tmtests/tm07/system.h
+++ b/testsuites/tmtests/tm07/system.h
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index e6af3c12af..5e83418f29 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
diff --git a/testsuites/tmtests/tm09/system.h b/testsuites/tmtests/tm09/system.h
index 2a6eba30fc..86a291b5a8 100644
--- a/testsuites/tmtests/tm09/system.h
+++ b/testsuites/tmtests/tm09/system.h
@@ -28,7 +28,7 @@ rtems_id   Task_id[ OPERATION_COUNT+1 ];   /* array of task ids */
diff --git a/testsuites/tmtests/tm10/system.h b/testsuites/tmtests/tm10/system.h
index ecefd4a2e1..8403656b52 100644
--- a/testsuites/tmtests/tm10/system.h
+++ b/testsuites/tmtests/tm10/system.h
diff --git a/testsuites/tmtests/tm11/system.h b/testsuites/tmtests/tm11/system.h
index 1e1d6eb14a..b36266b04b 100644
--- a/testsuites/tmtests/tm11/system.h
+++ b/testsuites/tmtests/tm11/system.h
diff --git a/testsuites/tmtests/tm12/system.h b/testsuites/tmtests/tm12/system.h
--- a/testsuites/tmtests/tm12/system.h
+++ b/testsuites/tmtests/tm12/system.h
diff --git a/testsuites/tmtests/tm13/system.h b/testsuites/tmtests/tm13/system.h
--- a/testsuites/tmtests/tm13/system.h
+++ b/testsuites/tmtests/tm13/system.h
diff --git a/testsuites/tmtests/tm14/system.h b/testsuites/tmtests/tm14/system.h
--- a/testsuites/tmtests/tm14/system.h
+++ b/testsuites/tmtests/tm14/system.h
diff --git a/testsuites/tmtests/tm15/system.h b/testsuites/tmtests/tm15/system.h
index 47d0121b72..067722db7c 100644
--- a/testsuites/tmtests/tm15/system.h
+++ b/testsuites/tmtests/tm15/system.h
@@ -26,7 +26,7 @@ rtems_id   Task_id[ OPERATION_COUNT+1 ];   /* array of task ids */
diff --git a/testsuites/tmtests/tm16/system.h b/testsuites/tmtests/tm16/system.h
index e35811839b..2ba66fc981 100644
--- a/testsuites/tmtests/tm16/system.h
+++ b/testsuites/tmtests/tm16/system.h
diff --git a/testsuites/tmtests/tm17/system.h b/testsuites/tmtests/tm17/system.h
index 1438c9a689..c96a653c85 100644
--- a/testsuites/tmtests/tm17/system.h
+++ b/testsuites/tmtests/tm17/system.h
diff --git a/testsuites/tmtests/tm18/system.h b/testsuites/tmtests/tm18/system.h
--- a/testsuites/tmtests/tm18/system.h
+++ b/testsuites/tmtests/tm18/system.h
diff --git a/testsuites/tmtests/tm19/system.h b/testsuites/tmtests/tm19/system.h
index 11f14ebf94..fcca4a6f1d 100644
--- a/testsuites/tmtests/tm19/system.h
+++ b/testsuites/tmtests/tm19/system.h
 #define CONFIGURE_MAXIMUM_TASKS              4
diff --git a/testsuites/tmtests/tm20/system.h b/testsuites/tmtests/tm20/system.h
index 4344d53d6f..940ec7f689 100644
--- a/testsuites/tmtests/tm20/system.h
+++ b/testsuites/tmtests/tm20/system.h
 #define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
diff --git a/testsuites/tmtests/tm21/system.h b/testsuites/tmtests/tm21/system.h
index 3c7a305ee3..dc232e89e9 100644
--- a/testsuites/tmtests/tm21/system.h
+++ b/testsuites/tmtests/tm21/system.h
@@ -26,7 +26,7 @@ rtems_task Init(
 #define MESSAGE_SIZE (sizeof(long) * 4)
diff --git a/testsuites/tmtests/tm22/system.h b/testsuites/tmtests/tm22/system.h
index 89c7138efc..355c229a45 100644
--- a/testsuites/tmtests/tm22/system.h
+++ b/testsuites/tmtests/tm22/system.h
diff --git a/testsuites/tmtests/tm23/system.h b/testsuites/tmtests/tm23/system.h
index 239f62d686..538bb8841c 100644
--- a/testsuites/tmtests/tm23/system.h
+++ b/testsuites/tmtests/tm23/system.h
 #define CONFIGURE_MAXIMUM_TASKS              (1 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm24/system.h b/testsuites/tmtests/tm24/system.h
index dc4fac4f94..ba8b6c6d98 100644
--- a/testsuites/tmtests/tm24/system.h
+++ b/testsuites/tmtests/tm24/system.h
diff --git a/testsuites/tmtests/tm25/system.h b/testsuites/tmtests/tm25/system.h
index 41f04c7975..dfaba09c4f 100644
--- a/testsuites/tmtests/tm25/system.h
+++ b/testsuites/tmtests/tm25/system.h
diff --git a/testsuites/tmtests/tm26/system.h b/testsuites/tmtests/tm26/system.h
index 2ba7979c8a..7978605349 100644
--- a/testsuites/tmtests/tm26/system.h
+++ b/testsuites/tmtests/tm26/system.h
 #define CONFIGURE_MAXIMUM_TASKS              (6 + OPERATION_COUNT)
diff --git a/testsuites/tmtests/tm27/system.h b/testsuites/tmtests/tm27/system.h
index 61f2ab8e7f..83963651ec 100644
--- a/testsuites/tmtests/tm27/system.h
+++ b/testsuites/tmtests/tm27/system.h
diff --git a/testsuites/tmtests/tm28/system.h b/testsuites/tmtests/tm28/system.h
index 2f76a81a6e..fb9e9eb768 100644
--- a/testsuites/tmtests/tm28/system.h
+++ b/testsuites/tmtests/tm28/system.h
diff --git a/testsuites/tmtests/tm29/system.h b/testsuites/tmtests/tm29/system.h
index 2aeda94809..c104966638 100644
--- a/testsuites/tmtests/tm29/system.h
+++ b/testsuites/tmtests/tm29/system.h
diff --git a/testsuites/tmtests/tm30/init.c b/testsuites/tmtests/tm30/init.c
index 022cdafb4f..309ed805c1 100644
--- a/testsuites/tmtests/tm30/init.c
+++ b/testsuites/tmtests/tm30/init.c
diff --git a/testsuites/tmtests/tmck/system.h b/testsuites/tmtests/tmck/system.h
index 20a26ac939..9d06647d17 100644
--- a/testsuites/tmtests/tmck/system.h
+++ b/testsuites/tmtests/tmck/system.h
@@ -26,7 +26,7 @@ rtems_name Task_name[ OPERATION_COUNT+1 ]; /* array of task names */
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index 2651847de4..4b3c9d8c8a 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -268,7 +268,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS (1 + CPU_COUNT)
diff --git a/testsuites/tmtests/tmfine01/init.c b/testsuites/tmtests/tmfine01/init.c
index 7a0cf8f486..21e6aff6f5 100644
--- a/testsuites/tmtests/tmfine01/init.c
+++ b/testsuites/tmtests/tmfine01/init.c
@@ -808,7 +808,7 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/tmtests/tmoverhd/system.h b/testsuites/tmtests/tmoverhd/system.h
index f2a63cd3bf..f726d2e9b0 100644
--- a/testsuites/tmtests/tmoverhd/system.h
+++ b/testsuites/tmtests/tmoverhd/system.h
@@ -42,7 +42,7 @@ extern rtems_status_code Empty_directive(void);
diff --git a/testsuites/tmtests/tmtimer01/init.c b/testsuites/tmtests/tmtimer01/init.c
index 6b9430481f..3d337e693b 100644
--- a/testsuites/tmtests/tmtimer01/init.c
+++ b/testsuites/tmtests/tmtimer01/init.c
@@ -197,7 +197,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_UNIFIED_WORK_AREAS
2.12.3
