parallel make failure?
Fri Nov 17 14:45:14 UTC 2017
On Thu, Nov 16, 2017 at 6:32 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/11/2017 10:57, Joel Sherrill wrote:
> > I started a build on rtbf64c which is Centos 7 (6 real cores, 12
> virtual). I
> > I built "everything". It pretty quickly had the Altera BSP do this:
> > /usr/bin/install -c -m 644
> > /home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
> > ../../../altcycv_devkit_smp/lib/include/libchip/spi-flash-m25p40.h
> This is wrong. There is no message like this in the build any more. It
> should be:
> Installing lib/include/rtems.h
OK. Not sure what happened. My overnight results are on the build@ log.
I just updated again and started another build.
Average BSP Build Time: 0:00:19.064294
Total Time 8:17:15.620426
Passes: 1502   Failures: 63
205541.45user 44682.47system 8:17:27elapsed 838%CPU (0avgtext+0avgdata
683108maxresident)k
1224inputs+1712685408outputs (0major+30150341701minor)pagefaults 0swaps
More results in 8-12 hours, it looks like.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171117/0833b93d/attachment-0002.html>
