parallel make failure?
Joel Sherrill
joel at rtems.org
Sat Nov 18 01:15:47 UTC 2017
The build log is on 64c. Can you get there? I can move it somewhere
accessible if you can. Once I get home.
It is large but I may be able to send it to dispatch
On Nov 17, 2017 6:30 PM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 18/11/17 1:45 am, Joel Sherrill wrote:
> > On Thu, Nov 16, 2017 at 6:32 PM, Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 17/11/2017 10:57, Joel Sherrill wrote:
> > > I started a build on rtbf64c which is Centos 7 (6 real cores, 12
> virtual). I
> > > I built "everything". It pretty quickly had the Altera BSP do this:
> > > /usr/bin/install -c -m 644
> > > /home/joel/rtems-work/rtems/c/src/libchip/i2c/spi-flash-m25p40.h
> > > ../../../altcycv_devkit_smp/lib/include/libchip/spi-flash-m25p40.h
> > This is wrong. There is no message like this in the build any more.
> It
> > should be:
> > Installing lib/include/rtems.h
> > OK. Not sure what happened. My overnight results are on the build@ log.
> > I just updated again and started another build.
> > Average BSP Build Time: 0:00:19.064294
> > Total Time 8:17:15.620426
> > Passes: 1502 Failures: 63
> > 205541.45user 44682.47system 8:17:27elapsed 838%CPU (0avgtext+0avgdata
> > 683108maxresident)k
> > 1224inputs+1712685408outputs (0major+30150341701minor)pagefaults 0swaps
> > More results in 8-12 hours, it looks like.
> I cannot tell anything from the bsp builder output, it is limited to avoid
> creating a huge email.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171117/2c43a16a/attachment-0002.html>
