[PATCH 3/5] tmtests/tm27: Simplify
Fri Nov 24 12:52:22 UTC 2017
Update #3254.
 testsuites/tmtests/tm27/task1.c | 104 ++++++++++++++++++++++------------------
 1 file changed, 57 insertions(+), 47 deletions(-)
diff --git a/testsuites/tmtests/tm27/task1.c b/testsuites/tmtests/tm27/task1.c
index c89c0956f1..9655936c65 100644
--- a/testsuites/tmtests/tm27/task1.c
+++ b/testsuites/tmtests/tm27/task1.c
@@ -28,24 +28,37 @@
 const char rtems_test_name[] = "TIME TEST 27";
-rtems_task Task_1(
+typedef struct {
+  volatile bool interrupt_occurred;
+  uint32_t      interrupt_enter_time;
+  uint32_t      interrupt_enter_nested_time;
+  uint32_t      interrupt_return_time;
+  uint32_t      interrupt_return_nested_time;
+  uint32_t      interrupt_nest;
+  uint32_t      timer_overhead;
+} test_context;
+static test_context test_instance;
+static rtems_task Task_1(
   rtems_task_argument argument
-rtems_task Task_2(
+static rtems_task Task_2(
-volatile uint32_t   Interrupt_occurred;
-volatile uint32_t   Interrupt_enter_time, Interrupt_enter_nested_time;
-volatile uint32_t   Interrupt_return_time, Interrupt_return_nested_time;
-uint32_t   Interrupt_nest;
-uint32_t   timer_overhead;
-rtems_isr Isr_handler(
+static rtems_isr Isr_handler(
   rtems_vector_number vector
+static void wait_for_interrupt( test_context *ctx )
+  while ( !ctx->interrupt_occurred ) {
+    /* Wait */
 static void set_thread_executing( Thread_Control *thread )
   _Per_CPU_Get_snapshot()->executing = thread;
@@ -55,6 +68,7 @@ rtems_task Init(
+  test_context *ctx = &test_instance;
   rtems_status_code status;
   Print_Warning();
@@ -82,7 +96,7 @@ rtems_task Init(
   directive_failed( status, "rtems_task_create Task_1" );
-  status = rtems_task_start( Task_id[ 1 ], Task_1, 0 );
+  status = rtems_task_start( Task_id[ 1 ], Task_1, (rtems_task_argument) ctx );
   directive_failed( status, "rtems_task_start Task_1" );
   status = rtems_task_create(
@@ -95,13 +109,13 @@ rtems_task Init(
   directive_failed( status, "rtems_task_create of Task_2" );
-  status = rtems_task_start( Task_id[ 2 ], Task_2, 0 );
+  status = rtems_task_start( Task_id[ 2 ], Task_2, (rtems_task_argument) ctx );
   directive_failed( status, "rtems_task_start of Task_2" );
   benchmark_timer_initialize();
   benchmark_timer_read();
-  timer_overhead = benchmark_timer_read();
+  ctx->timer_overhead = benchmark_timer_read();
   status = rtems_task_delete( RTEMS_SELF );
   directive_failed( status, "rtems_task_delete of RTEMS_SELF" );
@@ -111,6 +125,7 @@ rtems_task Task_1(
+  test_context *ctx = (test_context *) argument;
   Scheduler_priority_Context *scheduler_context =
     _Scheduler_priority_Get_context( _Thread_Scheduler_get_home( _Thread_Get_executing() ) );
 #if defined(RTEMS_SMP)
@@ -123,33 +138,31 @@ rtems_task Task_1(
    *  No preempt .. no nesting
-  Interrupt_nest = 0;
+  ctx->interrupt_nest = 0;
-  Interrupt_occurred = 0;
+  ctx->interrupt_occurred = 0;
   Cause_tm27_intr();
   /* goes to Isr_handler */
-#if (MUST_WAIT_FOR_INTERRUPT == 1)
-  while ( Interrupt_occurred == 0 );
-#endif
-  Interrupt_return_time = benchmark_timer_read();
+  wait_for_interrupt( ctx );
+  ctx->interrupt_return_time = benchmark_timer_read();
   put_time(
     "rtems interrupt: entry overhead returns to interrupted task",
-    Interrupt_enter_time,
+    ctx->interrupt_enter_time,
     1,
     0,
-    timer_overhead
   put_time(
     "rtems interrupt: exit overhead returns to interrupted task",
-    Interrupt_return_time,
+    ctx->interrupt_return_time,
     1,
     0,
-    timer_overhead
@@ -158,23 +171,21 @@ rtems_task Task_1(
   _Thread_Dispatch_disable();
-  Interrupt_nest = 1;
+  ctx->interrupt_nest = 1;
   Cause_tm27_intr();
-#endif
   _Thread_Dispatch_enable( _Per_CPU_Get() );
   put_time(
     "rtems interrupt: entry overhead returns to nested interrupt",
-    Interrupt_enter_nested_time,
+    ctx->interrupt_enter_nested_time,
     1,
     0,
     0
@@ -182,7 +193,7 @@ rtems_task Task_1(
   put_time(
     "rtems interrupt: exit overhead returns to nested interrupt",
-    Interrupt_return_nested_time,
+    ctx->interrupt_return_nested_time,
     1,
     0,
     0
@@ -206,7 +217,7 @@ rtems_task Task_1(
   _ISR_Local_enable(level);
 #endif
   Cause_tm27_intr();
@@ -230,6 +241,7 @@ rtems_task Task_2(
   Thread_Control *executing = _Thread_Get_executing();
   const Scheduler_Control    *scheduler;
   Scheduler_priority_Context *scheduler_context;
@@ -241,17 +253,15 @@ rtems_task Task_2(
   scheduler_context = _Scheduler_priority_Get_context( scheduler );
   _Thread_State_release( executing, &state_lock_context );
-#endif
   end_time = benchmark_timer_read();
   put_time(
     "rtems interrupt: entry overhead returns to preempting task",
     1,
     0,
-    timer_overhead
   put_time(
@@ -295,36 +305,36 @@ rtems_isr Isr_handler(
-  Interrupt_occurred = 1;
+  ctx->interrupt_occurred = 1;
   Isr_handler_inner();
 void Isr_handler_inner( void )
   /*enable_tracing();*/
   Clear_tm27_intr();
-  switch ( Interrupt_nest ) {
+  switch ( ctx->interrupt_nest ) {
     case 0:
-      Interrupt_enter_time = end_time;
+      ctx->interrupt_enter_time = end_time;
       break;
     case 1:
-      Interrupt_nest = 2;
+      ctx->interrupt_nest = 2;
       Lower_tm27_intr();
       Cause_tm27_intr();
       /* goes to a nested copy of Isr_handler */
-#endif
-      Interrupt_return_nested_time = benchmark_timer_read();
+      ctx->interrupt_return_nested_time = benchmark_timer_read();
       break;
     case 2:
-      Interrupt_enter_nested_time = end_time;
+      ctx->interrupt_enter_nested_time = end_time;
       break;
2.12.3
