parallel make failure?
    Sebastian Huber
    Tue Nov 28 06:27:09 UTC 2017
On 28/11/17 02:12, Chris Johns wrote:
> On 27/11/2017 18:07, Sebastian Huber wrote:
>> On 25/11/17 23:02, Chris Johns wrote:
>>> On 23/11/17 9:33 pm, Sebastian Huber wrote:
>>>> bsps/include
>>>> bsps/$arch/include
>>>> bsps/$arch/$bsp/include
>>>> cpukit/include
>>>> cpukit/libnetworking/include
>>>> cpukit/score/cpu/$arch/include
>> This generates a lot of header file moves that could be avoided with we use
> We are moving a lot of files. This specific change is around 140 moves and so
> not a big difference in the scale of things.
These header files contain the implementation details of the CPU ports.
I looked at the history of these files quite regularly.
>>> as an include directory.
> We need to handle libdl's headers as well as these arch specific score headers.
> I suggest:
> cpukit/include
> cpukit/@RTEMS_CPU@/include
> bsps/include
> bsps/@RTEMS_CPU@/include
> bsps/@RTEMS_CPU@/@RTEMS_BSP@/include
> I have used the automake defines values in the build system rather than $arch
> and $bsp. The `cpukit/@RTEMS_CPU@` may be misleading.
> The other solution is to move the libdl headers into the score.
I would move the CPU-specific headers of libdl to cpukit/score/cpu.
> Also we cannot use the actual BSP's name we have to use the base name and not an
> alias. I am not sure if @RTEMS_BSP@ is the aliased name or not.
With $bsp I mean the @RTEMS_BSP@, the BSP base directory, not the actual
BSP name.
>>> This is looking sensible but I am not sure how to handle the install phase.
>>> Do we have per ARCH and/or BSP makefile .in files that list the headers for that
>>> ARCH or BSP in that part of the tree and we have the Makefile.am subst to
>>> include the specific file, for example `include @RTEMS_CPU@/@RTEMS_BSP at .am? We
>>> cannot use .am files because the subst is during configure and not during
>>> bootstrap. If we did this would we have these file generated by the contents of
>>> the directory, that is all headers are installed?
>>> I just hope we do not fall into an Automake hole here.
>> I would one bsps/Makefile.am which includes
>> bsps/$arch/$arch.am
> I am not sure what you mean here with `$arch`. Do you mean we have a number of
> explicitly named files or some form of macro replacement?
arch is one of { arm, bfin, epiphany, i386, lm32, m32c, m68k, mips,
moxie, nios2, no_cpu, or1k, powerpc, riscv, sh, sparc, sparc64, v850 }.
For example:
bsps/lm32/lm32.am
>> to keep the file reasonably small. Then I would introduce
>> AM_CONDITIONAL(BSPS_$arch, ...)
>> AM_CONDITIONAL(BSPS_$arch_$bspdir)
> Where are the BSP headers listed?
In bsps/lm32/lm32.am:
if BSPS_LM32_MILKYMIST
include_HEADERS += bsps/lm32/milkymist/include/bsp.h
include_HEADERS += bsps/lm32/milkymist/include/tm27.h
endif
In Makefile.am or bsps/Makefile.am:
include $(srcdir)/lm32/lm32.am
I don't know if this AM_CONDITIONAL() stuff works well, but can we make
it worse than it is?
A general question, why do we need more than one configure.ac to build
RTEMS, the BSPs and the testsuites?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
