[PATCH 2/2] libdl: Fix warnings
Fri Oct 6 07:17:44 UTC 2017
Update #3155.
 cpukit/libdl/rtl-elf.c             | 26 +++++++++++---------
 cpukit/libdl/rtl-mdreloc-powerpc.c |  5 ++--
 cpukit/libdl/rtl-obj.c             |  3 ++-
 cpukit/libdl/rtl-rap.c             | 50 ++++++++++++++++++++------------------
 cpukit/libdl/rtl-shell.c           |  2 +-
 5 files changed, 47 insertions(+), 39 deletions(-)
diff --git a/cpukit/libdl/rtl-elf.c b/cpukit/libdl/rtl-elf.c
index be2f06a7ba..c2bac9f69d 100644
--- a/cpukit/libdl/rtl-elf.c
+++ b/cpukit/libdl/rtl-elf.c
@@ -84,7 +84,7 @@ rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
       return false;
-    *value = (Elf_Word) symbol->value;
+    *value = (Elf_Addr) symbol->value;
     return true;
@@ -95,7 +95,7 @@ rtems_rtl_elf_find_symbol (rtems_rtl_obj_t* obj,
     return false;
-  *value = sym->st_value + (Elf_Word) sect->base;
+  *value = sym->st_value + (Elf_Addr) sect->base;
   return true;
@@ -250,9 +250,10 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t*      obj,
       if (is_rela)
         if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
-          printf ("rtl: rela: sym:%s(%d)=%08lx type:%d off:%08lx addend:%d\n",
-                  symname, (int) ELF_R_SYM (rela->r_info), symvalue,
-                  (int) ELF_R_TYPE (rela->r_info), rela->r_offset, (int) rela->r_addend);
+          printf ("rtl: rela: sym:%s(%d)=%08jx type:%d off:%08jx addend:%d\n",
+                  symname, (int) ELF_R_SYM (rela->r_info),
+                  (uintmax_t) symvalue, (int) ELF_R_TYPE (rela->r_info),
+                  (uintmax_t) rela->r_offset, (int) rela->r_addend);
         if (!rtems_rtl_elf_relocate_rela (obj, rela, targetsect,
                                           symname, sym.st_info, symvalue))
           return false;
@@ -260,9 +261,10 @@ rtems_rtl_elf_relocator (rtems_rtl_obj_t*      obj,
       else
-          printf ("rtl: rel: sym:%s(%d)=%08lx type:%d off:%08lx\n",
-                  symname, (int) ELF_R_SYM (rel->r_info), symvalue,
-                  (int) ELF_R_TYPE (rel->r_info), rel->r_offset);
+          printf ("rtl: rel: sym:%s(%d)=%08jx type:%d off:%08jx\n",
+                  symname, (int) ELF_R_SYM (rel->r_info),
+                  (uintmax_t) symvalue, (int) ELF_R_TYPE (rel->r_info),
+                  (uintmax_t) rel->r_offset);
         if (!rtems_rtl_elf_relocate_rel (obj, rel, targetsect,
           return false;
@@ -304,9 +306,9 @@ rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
     rela.r_info = reloc->rel[REL_R_INFO];
     rela.r_addend = reloc->rel[REL_R_ADDEND];
-          printf ("rtl: rela: sym:%d type:%d off:%08lx addend:%d\n",
+          printf ("rtl: rela: sym:%d type:%d off:%08jx addend:%d\n",
                   (int) ELF_R_SYM (rela.r_info), (int) ELF_R_TYPE (rela.r_info),
-                  rela.r_offset, (int) rela.r_addend);
+                  (uintmax_t) rela.r_offset, (int) rela.r_addend);
     if (!rtems_rtl_elf_relocate_rela (reloc->obj, &rela, sect,
                                       sym->name, sym->data, symvalue))
       return false;
@@ -317,9 +319,9 @@ rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t* reloc,
     rel.r_offset = reloc->rel[REL_R_OFFSET];
     rel.r_info = reloc->rel[REL_R_INFO];
-      printf ("rtl: rel: sym:%d type:%d off:%08lx\n",
+      printf ("rtl: rel: sym:%d type:%d off:%08jx\n",
               (int) ELF_R_SYM (rel.r_info), (int) ELF_R_TYPE (rel.r_info),
-              rel.r_offset);
+              (uintmax_t) rel.r_offset);
     if (!rtems_rtl_elf_relocate_rel (reloc->obj, &rel, sect,
       return false;
diff --git a/cpukit/libdl/rtl-mdreloc-powerpc.c b/cpukit/libdl/rtl-mdreloc-powerpc.c
index 978a2e8999..a3cb6b333a 100644
--- a/cpukit/libdl/rtl-mdreloc-powerpc.c
+++ b/cpukit/libdl/rtl-mdreloc-powerpc.c
@@ -7,6 +7,7 @@
 #include <sys/cdefs.h>
+#include <inttypes.h>
 #include <sys/types.h>
 #include <sys/stat.h>
@@ -183,12 +184,12 @@ rtems_rtl_elf_relocate_rela (const rtems_rtl_obj_t*      obj,
       break;
     default:
-      printf ("rtl: reloc unknown: sym = %lu, type = %lu, offset = %p, "
+      printf ("rtl: reloc unknown: sym = %lu, type = %" PRIu32 ", offset = %p, "
               "contents = %p\n",
               ELF_R_SYM(rela->r_info), (uint32_t) ELF_R_TYPE(rela->r_info),
               (void *)rela->r_offset, (void *)*where);
       rtems_rtl_set_error (EINVAL,
-                           "%s: Unsupported relocation type %ld "
+                           "%s: Unsupported relocation type %" PRId32
                            "in non-PLT relocations",
                            sect->name, (uint32_t) ELF_R_TYPE(rela->r_info));
       return false;
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index 8b2d2b83c0..3a220092b3 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -779,7 +779,8 @@ rtems_rtl_obj_sections_loader (uint32_t                     mask,
         sect->base = base + base_offset;
         if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
-          printf ("rtl: loading:%2d: %s -> %8p (s:%zi f:%04lx a:%lu l:%02d)\n",
+          printf ("rtl: loading:%2d: %s -> %8p (s:%zi f:%04" PRIx32
+                  " a:%" PRIu32 " l:%02d)\n",
                   order, sect->name, sect->base, sect->size,
                   sect->flags, sect->alignment, sect->link);
diff --git a/cpukit/libdl/rtl-rap.c b/cpukit/libdl/rtl-rap.c
index cb7b751cd0..a413e09619 100644
--- a/cpukit/libdl/rtl-rap.c
+++ b/cpukit/libdl/rtl-rap.c
@@ -21,6 +21,7 @@
 #include <fcntl.h>
@@ -211,7 +212,7 @@ rtems_rtl_rap_loader (rtems_rtl_obj_t*      obj,
   rtems_rtl_rap_t* rap = (rtems_rtl_rap_t*) data;
   if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD))
-    printf ("rtl: rap: input %s=%lu\n",
+    printf ("rtl: rap: input %s=%" PRIu32 "\n",
             sect->name, rtems_rtl_obj_comp_input (rap->decomp));
   return rtems_rtl_obj_comp_read (rap->decomp, sect->base, sect->size);
@@ -266,7 +267,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
     relocs = header & ~(1 << 31);
     if (relocs && rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
-      printf ("rtl: relocation: %s: header: %08lx relocs: %d %s\n",
+      printf ("rtl: relocation: %s: header: %08" PRIx32 " relocs: %d %s\n",
               rap_sections[section].name,
               header, relocs, is_rela ? "rela" : "rel");
@@ -315,7 +316,8 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
-        printf (" %2d: info=%08lx offset=%lu addend=%lu\n",
+        printf (" %2d: info=%08" PRIx32 " offset=%" PRIu32
+                " addend=%" PRIu32 "\n",
                 r, info, offset, addend);
       type = info & 0xff;
@@ -331,7 +333,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
           return false;
-        symvalue = (Elf_Word) symsect->base + addend;
+        symvalue = (Elf_Addr) symsect->base + addend;
       else if (rtems_rtl_elf_rel_resolve_sym (type))
@@ -371,7 +373,7 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
           return false;
-        symvalue = (Elf_Word) symbol->value;
+        symvalue = (Elf_Addr) symbol->value;
       if (is_rela)
@@ -386,10 +388,10 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
         else rela.r_addend = addend;
-          printf (" %2d: rela: type:%-2d off:%lu addend:%d" \
-                  " symname=%s symtype=%lu symvalue=0x%08lx\n",
+          printf (" %2d: rela: type:%-2d off:%" PRIu32 " addend:%d"
+                  " symname=%s symtype=%ju symvalue=0x%08jx\n",
                   r, (int) type, offset, (int) addend,
-                  symname, symtype, symvalue);
+                  symname, (uintmax_t) symtype, (uintmax_t) symvalue);
         if (!rtems_rtl_elf_relocate_rela (obj, &rela, targetsect,
                                           symname, symtype, symvalue))
@@ -406,10 +408,10 @@ rtems_rtl_rap_relocate (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
         rel.r_info = type;
-          printf (" %2d: rel: type:%-2d off:%lu" \
+          printf (" %2d: rel: type:%-2d off:%" PRIu32
         if (!rtems_rtl_elf_relocate_rel (obj, &rel, targetsect,
@@ -611,7 +613,8 @@ rtems_rtl_rap_load_symbols (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
     if (rtems_rtl_trace (RTEMS_RTL_TRACE_SYMBOL))
-      printf ("rtl: sym:load: data=0x%08lx name=0x%08lx value=0x%08lx\n",
+      printf ("rtl: sym:load: data=0x%08" PRIx32 " name=0x%08" PRIx32
+              " value=0x%08" PRIx32 "\n",
               data, name, value);
@@ -640,7 +643,7 @@ rtems_rtl_rap_load_symbols (rtems_rtl_rap_t* rap, rtems_rtl_obj_t* obj)
       obj->global_table = NULL;
       obj->global_syms = 0;
       obj->global_size = 0;
-      rtems_rtl_set_error (EINVAL, "section index not found: %lu", data >> 16);
+      rtems_rtl_set_error (EINVAL, "section index not found: %" PRIu32, data >> 16);
       return false;
@@ -816,14 +819,14 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
-    printf ("rtl: rap: input machine=%lu\n",
+    printf ("rtl: rap: input machine=%" PRIu32 "\n",
             rtems_rtl_obj_comp_input (rap.decomp));
   if (!rtems_rtl_rap_read_uint32 (rap.decomp, &rap.machinetype))
     return false;
-    printf ("rtl: rap: machinetype=%lu\n", rap.machinetype);
+    printf ("rtl: rap: machinetype=%" PRIu32 "\n", rap.machinetype);
   if (!rtems_rtl_rap_machine_check (rap.machinetype))
@@ -835,7 +838,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
     return false;
-    printf ("rtl: rap: datatype=%lu\n", rap.datatype);
+    printf ("rtl: rap: datatype=%" PRIu32 "\n", rap.datatype);
   if (!rtems_rtl_rap_datatype_check (rap.datatype))
@@ -847,7 +850,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
     return false;
-    printf ("rtl: rap: class=%lu\n", rap.class);
+    printf ("rtl: rap: class=%" PRIu32 "\n", rap.class);
   if (!rtems_rtl_rap_class_check (rap.class))
@@ -864,7 +867,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
-    printf ("rtl: rap: input header=%lu\n",
+    printf ("rtl: rap: input header=%" PRIu32 "\n",
   if (!rtems_rtl_rap_read_uint32 (rap.decomp, &rap.init))
@@ -885,7 +888,8 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
   rap.symbols = rap.symtab_size / (3 * sizeof (uint32_t));
-    printf ("rtl: rap: load: symtab=%lu (%lu) strtab=%lu relocs=%lu\n",
+    printf ("rtl: rap: load: symtab=%" PRIu32 " (%" PRIu32
+            ") strtab=%" PRIu32 " relocs=%" PRIu32 "\n",
             rap.symtab_size, rap.symbols,
             rap.strtab_size, rap.relocs_size);
@@ -913,7 +917,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
       return false;
     if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
-      printf ("rtl: rap: details: obj_num=%lu\n", obj->obj_num);
+      printf ("rtl: rap: details: obj_num=%" PRIu32 "\n", obj->obj_num);
     if (!rtems_rtl_rap_load_linkmap (&rap, obj))
       return false;
@@ -943,7 +947,7 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
       return false;
-      printf ("rtl: rap: %s: size=%lu align=%lu\n",
+      printf ("rtl: rap: %s: size=%" PRIu32 " align=%" PRIu32 "\n",
               rap.secs[section].size,
               rap.secs[section].alignment);
@@ -965,14 +969,14 @@ rtems_rtl_rap_file_load (rtems_rtl_obj_t* obj, int fd)
     return false;
-    printf ("rtl: rap: input symbols=%lu\n",
+    printf ("rtl: rap: input symbols=%" PRIu32 "\n",
   if (!rtems_rtl_rap_load_symbols (&rap, obj))
     return false;
-    printf ("rtl: rap: input relocs=%lu\n",
+    printf ("rtl: rap: input relocs=%" PRIu32 "\n",
   if (!rtems_rtl_rap_relocate (&rap, obj))
diff --git a/cpukit/libdl/rtl-shell.c b/cpukit/libdl/rtl-shell.c
index 0bb3519555..612ed35902 100644
--- a/cpukit/libdl/rtl-shell.c
+++ b/cpukit/libdl/rtl-shell.c
@@ -214,7 +214,7 @@ rtems_rtl_obj_printer (rtems_rtl_obj_print_t* print, rtems_rtl_obj_t* obj)
     printf ("%-*cbss base      : %p (%zi)\n", print->indent, ' ',
             obj->bss_base, obj->bss_size);
-  printf ("%-*cunresolved    : %lu\n", print->indent, ' ', obj->unresolved);
+  printf ("%-*cunresolved    : %" PRIu32 "\n", print->indent, ' ', obj->unresolved);
   printf ("%-*csymbols       : %zi\n", print->indent, ' ', obj->global_syms);
   printf ("%-*csymbol memory : %zi\n", print->indent, ' ', obj->global_size);
   if (print->symbols)
2.12.3
