[PATCH] c-user: Add obsolete configuration options section
Fri Oct 6 12:29:29 UTC 2017
Update #3112.
Update #3113.
Update #3114.
Update #3115.
Update #3116.
 c-user/configuring_a_system.rst | 257 +++++++++++++++-------------------------
 1 file changed, 93 insertions(+), 164 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index bed95cf..6f30912 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1182,62 +1182,6 @@ NOTES:
     All POSIX threads have floating point enabled.
-.. COMMENT: XXX - Add xref to CONFIGURE_MAXIMUM_TASKS.
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_MUTEXES ===
-.. _Specify Maximum POSIX API Mutexes:
-Specify Maximum POSIX API Mutexes
-.. index:: CONFIGURE_MAXIMUM_POSIX_MUTEXES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_MUTEXES``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-    The default value is 0.
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_MUTEXES`` is the maximum number of POSIX API
-    Mutexes that can be concurrently active.
-NOTES:
-    This object class can be configured in unlimited allocation mode.
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES ===
-.. _Specify Maximum POSIX API Condition Variables:
-Specify Maximum POSIX API Condition Variables
-.. index:: CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES`` is the maximum number of
-    POSIX API Condition Variables that can be concurrently active.
-NOTES:
 .. COMMENT: === CONFIGURE_MAXIMUM_POSIX_KEYS ===
 .. _Specify Maximum POSIX API Keys:
@@ -1348,114 +1292,6 @@ DESCRIPTION:
 NOTES:
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ===
-.. _Specify Maximum POSIX API Semaphores:
-Specify Maximum POSIX API Semaphores
-.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
-    Semaphores that can be concurrently active.
-NOTES:
-    None.
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_BARRIERS ===
-.. _Specify Maximum POSIX API Barriers:
-Specify Maximum POSIX API Barriers
-.. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_BARRIERS``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_BARRIERS`` is the maximum number of POSIX API
-    Barriers that can be concurrently active.
-NOTES:
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_SPINLOCKS ===
-.. _Specify Maximum POSIX API Spinlocks:
-Specify Maximum POSIX API Spinlocks
-.. index:: CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_SPINLOCKS``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_SPINLOCKS`` is the maximum number of POSIX API
-    Spinlocks that can be concurrently active.
-NOTES:
-.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_RWLOCKS ===
-.. _Specify Maximum POSIX API Read/Write Locks:
-Specify Maximum POSIX API Read/Write Locks
-.. index:: CONFIGURE_MAXIMUM_POSIX_RWLOCKS
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_POSIX_RWLOCKS``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_POSIX_RWLOCKS`` is the maximum number of POSIX API
-    Read/Write Locks that can be concurrently active.
-NOTES:
 .. COMMENT: === POSIX Initialization Threads Table Configuration ===
@@ -5087,3 +4923,96 @@ DESCRIPTION:
 NOTES:
     The Go language support is experimental
+Obsolete Configuration Options
+CONFIGURE_BDBUF_BUFFER_COUNT
+.. index:: CONFIGURE_BDBUF_BUFFER_COUNT
+This configuration option was introduced in RTEMS 4.7 and is obsolete since
+RTEMS 4.10.
+CONFIGURE_BDBUF_BUFFER_SIZE
+.. index:: CONFIGURE_BDBUF_BUFFER_SIZE
+RTEMS 4.10.
+CONFIGURE_HAS_OWN_BDBUF_TABLE
+.. index:: CONFIGURE_HAS_OWN_BDBUF_TABLE
+RTEMS 4.10.
+.. _Specify Maximum POSIX API Barriers:
+CONFIGURE_MAXIMUM_POSIX_BARRIERS
+.. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
+This configuration option is obsolete since RTEMS 4.12.
+.. _Specify Maximum POSIX API Condition Variables:
+CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+.. index:: CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
+CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
+This configuration option was introduced in RTEMS 4.10 and is obsolete since
+RTEMS 4.12.
+.. _Specify Maximum POSIX API Mutexes:
+CONFIGURE_MAXIMUM_POSIX_MUTEXES
+.. index:: CONFIGURE_MAXIMUM_POSIX_MUTEXES
+.. _Specify Maximum POSIX API Read/Write Locks:
+CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+.. index:: CONFIGURE_MAXIMUM_POSIX_RWLOCKS
+.. _Specify Maximum POSIX API Semaphores:
+CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+.. _Specify Maximum POSIX API Spinlocks:
+CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+.. index:: CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
+CONFIGURE_SMP_APPLICATION
+.. index:: CONFIGURE_SMP_APPLICATION
+This configuration option was introduced in RTEMS 4.11 and is obsolete since
+RTEMS 4.12.
+CONFIGURE_SMP_MAXIMUM_PROCESSORS
+.. index:: CONFIGURE_SMP_MAXIMUM_PROCESSORS
+RTEMS 4.12.
2.12.3
