[PATCH 2/3] score: Use struct timespec for TOD
Fri Oct 6 13:45:37 UTC 2017
Use the timestamps only for uptime based values.  Use struct timespec
for the absolute time values (TOD).
Update #2740.
 cpukit/posix/src/clockgettime.c            |  2 +-
 cpukit/posix/src/clocksettime.c            |  7 +++-
 cpukit/posix/src/timersettime.c            |  4 +--
 cpukit/score/include/rtems/score/todimpl.h | 54 +++++-------------------------
 cpukit/score/src/coretodabsolutetimeout.c  |  2 +-
 cpukit/score/src/coretodadjust.c           |  8 ++---
 cpukit/score/src/coretodset.c              | 12 +++----
 7 files changed, 28 insertions(+), 61 deletions(-)
diff --git a/cpukit/posix/src/clockgettime.c b/cpukit/posix/src/clockgettime.c
index b3adbc4713..4f6c583ff1 100644
--- a/cpukit/posix/src/clockgettime.c
+++ b/cpukit/posix/src/clockgettime.c
@@ -37,7 +37,7 @@ int clock_gettime(
     rtems_set_errno_and_return_minus_one( EINVAL );
   if ( clock_id == CLOCK_REALTIME ) {
-    _TOD_Get_as_timespec(tp);
+    _TOD_Get(tp);
     return 0;
 #ifdef CLOCK_MONOTONIC
diff --git a/cpukit/posix/src/clocksettime.c b/cpukit/posix/src/clocksettime.c
index 8eb616c8b5..a0fdd9109f 100644
--- a/cpukit/posix/src/clocksettime.c
+++ b/cpukit/posix/src/clocksettime.c
@@ -36,10 +36,15 @@ int clock_settime(
+    ISR_lock_Context lock_context;
     if ( tp->tv_sec < TOD_SECONDS_1970_THROUGH_1988 )
-    _TOD_Set_with_timespec( tp );
+    _TOD_Lock();
+    _TOD_Acquire( &lock_context );
+    _TOD_Set( tp, &lock_context );
+    _TOD_Unlock();
 #ifdef _POSIX_CPUTIME
   else if ( clock_id == CLOCK_PROCESS_CPUTIME_ID )
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 698a47a6b7..1f98a7a08c 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -39,7 +39,7 @@ static void _POSIX_Timer_Insert(
   ptimer->state = POSIX_TIMER_STATE_CREATE_RUN;
   /* Store the time when the timer was started again */
-  _TOD_Get_as_timespec( &ptimer->time );
+  _TOD_Get( &ptimer->time );
   _Watchdog_Insert(
     &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ],
@@ -132,7 +132,7 @@ int timer_settime(
   /* Convert absolute to relative time */
   if (flags == TIMER_ABSTIME) {
     struct timespec now;
-    _TOD_Get_as_timespec( &now );
+    _TOD_Get( &now );
     /* Check for seconds in the past */
     if ( _Timespec_Greater_than( &now, &normalize.it_value ) )
diff --git a/cpukit/score/include/rtems/score/todimpl.h b/cpukit/score/include/rtems/score/todimpl.h
index 03f25b5ae0..f5dba85f8c 100644
--- a/cpukit/score/include/rtems/score/todimpl.h
+++ b/cpukit/score/include/rtems/score/todimpl.h
@@ -164,65 +164,27 @@ static inline void _TOD_Acquire( ISR_lock_Context *lock_context )
  * The caller must be the owner of the TOD lock.
- * @param tod_as_timestamp The new time of day in timestamp format representing
+ * @param tod The new time of day in timespec format representing
  *   the time since UNIX Epoch.
  * @param lock_context The ISR lock context used for the corresponding
  *   _TOD_Acquire().  The caller must be the owner of the TOD lock.  This
  *   function will release the TOD lock.
 void _TOD_Set(
-  const Timestamp_Control *tod_as_timestamp,
-  ISR_lock_Context        *lock_context
+  const struct timespec *tod,
+  ISR_lock_Context      *lock_context
- * @brief Sets the time of day with timespec format.
- * @param tod_as_timespec The new time of day in timespec format.
- * @see _TOD_Set().
-static inline void _TOD_Set_with_timespec(
-  const struct timespec *tod_as_timespec
-  Timestamp_Control tod_as_timestamp;
-  ISR_lock_Context  lock_context;
-  _Timestamp_Set(
-    &tod_as_timestamp,
-    tod_as_timespec->tv_sec,
-    tod_as_timespec->tv_nsec
-  _TOD_Lock();
-  _TOD_Acquire( &lock_context );
-  _TOD_Set( &tod_as_timestamp, &lock_context );
-  _TOD_Unlock();
- *  @brief Gets the current time in the bintime format.
- *  @param[out] time is the value gathered by the bintime request
-static inline void _TOD_Get(
-  Timestamp_Control *time
-  _Timecounter_Bintime(time);
  *  @brief Gets the current time in the timespec format.
- *  @param[out] time is the value gathered by the nanotime request
+ *  @param[out] time is the value gathered by the request
-static inline void _TOD_Get_as_timespec(
-  struct timespec *time
+static inline void _TOD_Get(
+  struct timespec *tod
-  _Timecounter_Nanotime(time);
+  _Timecounter_Nanotime( tod );
@@ -324,7 +286,7 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
  * @param[in] delta is the amount to adjust
 void _TOD_Adjust(
-  const Timestamp_Control *delta
+  const struct timespec *delta
diff --git a/cpukit/score/src/coretodabsolutetimeout.c b/cpukit/score/src/coretodabsolutetimeout.c
index fe74a6bbf2..d67b7c33c7 100644
--- a/cpukit/score/src/coretodabsolutetimeout.c
+++ b/cpukit/score/src/coretodabsolutetimeout.c
@@ -47,7 +47,7 @@ TOD_Absolute_timeout_conversion_results _TOD_Absolute_timeout_to_ticks(
    *  Is the absolute time in the past?
   if ( clock == CLOCK_REALTIME ) {
-    _TOD_Get_as_timespec( &current_time );
+    _TOD_Get( &current_time );
   } else {
     _Assert( clock == CLOCK_MONOTONIC );
     _TOD_Get_zero_based_uptime_as_timespec( &current_time );
diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
index 5996565e5c..f493a40b9d 100644
--- a/cpukit/score/src/coretodadjust.c
+++ b/cpukit/score/src/coretodadjust.c
@@ -21,11 +21,11 @@
 void _TOD_Adjust(
-  Timestamp_Control tod;
+  struct timespec  tod;
    * Currently, RTEMS does the adjustment in one movement.
@@ -38,7 +38,7 @@ void _TOD_Adjust(
   _TOD_Lock();
   _TOD_Get( &tod );
-  _Timestamp_Add_to( &tod, delta );
+  _Timespec_Add_to( &tod, delta );
   _TOD_Set( &tod, &lock_context );
   _TOD_Unlock();
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index f1d2e36eb0..80b0b762bd 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -23,21 +23,21 @@
 void _TOD_Set(
-  struct timespec tod_as_timespec;
+  struct bintime  tod_as_bintime;
   uint64_t        tod_as_ticks;
   uint32_t        cpu_count;
   uint32_t        cpu_index;
   _Assert( _API_Mutex_Is_owner( _Once_Mutex ) );
-  _Timecounter_Set_clock( tod_as_timestamp, lock_context );
+  timespec2bintime( tod, &tod_as_bintime );
+  _Timecounter_Set_clock( &tod_as_bintime, lock_context );
-  _Timestamp_To_timespec( tod_as_timestamp, &tod_as_timespec );
-  tod_as_ticks = _Watchdog_Ticks_from_timespec( &tod_as_timespec );
+  tod_as_ticks = _Watchdog_Ticks_from_timespec( tod );
   cpu_count = _SMP_Get_processor_count();
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
2.12.3
