Build Failure on All BSPs on Master
Fri Oct 6 18:03:29 UTC 2017
Sorry, I made a mistake to resolve a merge conflict.  It should work now.
----- Am 6. Okt 2017 um 19:00 schrieb joel joel at rtems.org:
> Hi
> Every BSP (> 100 so far) in my build sweep is failing when linking psx02
> with this:
> /home/joel/rtems-work/rtems-testing/rtems/build-arm-tms570ls3137_hdk-rtems/arm-rtems4.12/c/tms570ls3137_hdk/testsuites/psxtests/psx02/../../../../../../../rtems/c/src/../../testsuites/psxtests/psx02/init.c:92:
> undefined reference to `sigpending'
> /home/joel/rtems-work/rtems-testing/rtems/build-arm-tms570ls3137_hdk-rtems/arm-rtems4.12/c/tms570ls3137_hdk/testsuites/psxtests/psx02/../../../../../../../rtems/c/src/../../testsuites/psxtests/psx02/init.c:101:
> --joel
> devel mailing list
> devel at rtems.org
