[PATCH 3/3] posix: Unconditional thread attribute support
Mon Oct 9 13:55:06 UTC 2017
Update #2514.
 cpukit/posix/Makefile.am                           | 29 +++++----
 cpukit/posix/include/rtems/posix/pthreadattrimpl.h | 71 ++++++++++++++++++++++
 cpukit/posix/include/rtems/posix/pthreadimpl.h     | 29 ---------
 cpukit/posix/preinstall.am                         |  4 ++
 cpukit/posix/src/pthread.c                         | 54 ----------------
 cpukit/posix/src/pthreadattrdefault.c              | 60 ++++++++++++++++++
 cpukit/posix/src/pthreadattrdestroy.c              |  3 +-
 cpukit/posix/src/pthreadattrinit.c                 |  6 +-
 cpukit/posix/src/pthreadattrsetguardsize.c         |  4 +-
 cpukit/posix/src/pthreadattrsetinheritsched.c      |  3 -
 cpukit/posix/src/pthreadattrsetschedpolicy.c       |  3 -
 cpukit/posix/src/pthreadattrsetscope.c             |  3 -
 cpukit/posix/src/pthreadattrsetstack.c             |  9 +--
 cpukit/posix/src/pthreadattrsetstacksize.c         |  8 +--
 14 files changed, 156 insertions(+), 130 deletions(-)
 create mode 100644 cpukit/posix/include/rtems/posix/pthreadattrimpl.h
 create mode 100644 cpukit/posix/src/pthreadattrdefault.c
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 7bd6869c3c..cbdd22bd3a 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -24,6 +24,7 @@ include_rtems_posix_HEADERS += include/rtems/posix/config.h
 include_rtems_posix_HEADERS += include/rtems/posix/muteximpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
 include_rtems_posix_HEADERS += include/rtems/posix/priorityimpl.h
+include_rtems_posix_HEADERS += include/rtems/posix/pthreadattrimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphore.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
@@ -89,14 +90,25 @@ libposix_a_SOURCES += src/mutexattrdestroy.c src/mutexattrgetprioceiling.c \
     src/mutexlocksupp.c src/mutexsetprioceiling.c src/mutextimedlock.c \
     src/mutextrylock.c src/mutexunlock.c
+## PTHREAD_ATTR_C_FILES
+libposix_a_SOURCES += src/pthreadattrdefault.c src/pthreadattrdestroy.c \
+   src/pthreadattrgetdetachstate.c src/pthreadattrgetguardsize.c \
+   src/pthreadattrgetinheritsched.c src/pthreadattrgetschedparam.c \
+   src/pthreadattrgetschedpolicy.c src/pthreadattrgetscope.c \
+   src/pthreadattrgetstackaddr.c src/pthreadattrgetstack.c \
+   src/pthreadattrgetstacksize.c src/pthreadattrinit.c \
+   src/pthreadattrsetdetachstate.c src/pthreadattrsetguardsize.c \
+   src/pthreadattrsetinheritsched.c src/pthreadattrsetschedparam.c \
+   src/pthreadattrsetschedpolicy.c src/pthreadattrsetscope.c \
+   src/pthreadattrsetstackaddr.c src/pthreadattrsetstack.c \
+   src/pthreadattrsetstacksize.c
 ## PTHREAD_AFFINITY_C_FILES
 libposix_a_SOURCES += src/pthreadattrsetaffinitynp.c \
     src/pthreadattrgetaffinitynp.c  src/pthreadgetaffinitynp.c   \
     src/pthreadsetaffinitynp.c
 if HAS_PTHREADS
-libposix_a_SOURCES +=  src/pthreadatfork.c
 ## CANCEL_C_FILES
 libposix_a_SOURCES += src/cancel.c \
     src/cleanuppush.c src/setcancelstate.c \
@@ -128,18 +140,9 @@ libposix_a_SOURCES += src/mqueue.c src/mqueueclose.c \
     src/mqueueunlink.c
 ## PTHREAD_C_FILES
-libposix_a_SOURCES += src/pthreadatfork.c src/pthreadattrdestroy.c \
-    src/pthreadattrgetdetachstate.c src/pthreadattrgetinheritsched.c \
-    src/pthreadattrgetschedparam.c src/pthreadattrgetschedpolicy.c \
-    src/pthreadattrgetscope.c src/pthreadattrgetstackaddr.c \
-    src/pthreadattrgetstack.c src/pthreadattrgetstacksize.c \
-    src/pthreadattrinit.c src/pthreadattrsetdetachstate.c \
-    src/pthreadattrsetguardsize.c src/pthreadattrsetinheritsched.c \
-    src/pthreadattrsetschedparam.c src/pthreadattrsetschedpolicy.c \
-    src/pthreadattrsetscope.c src/pthreadattrsetstackaddr.c \
-    src/pthreadattrsetstack.c src/pthreadattrsetstacksize.c \
+libposix_a_SOURCES += src/pthreadatfork.c \
     src/pthreadgetattrnp.c \
-    src/pthreadattrgetguardsize.c src/pthread.c \
+    src/pthread.c \
     src/pthreadconcurrency.c \
     src/pthreadcreate.c src/pthreaddetach.c src/pthreadequal.c \
     src/pthreadexit.c src/pthreadgetcpuclockid.c \
diff --git a/cpukit/posix/include/rtems/posix/pthreadattrimpl.h b/cpukit/posix/include/rtems/posix/pthreadattrimpl.h
new file mode 100644
index 0000000000..f1eaea98a4
--- /dev/null
+++ b/cpukit/posix/include/rtems/posix/pthreadattrimpl.h
@@ -0,0 +1,71 @@
+ * @file
+ * @brief POSIX Threads Private Support
+ * This include file contains all the private support information for
+ * POSIX threads.
+ *  COPYRIGHT (c) 1989-2011.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifndef _RTEMS_POSIX_PTHREADATTRIMPL_H
+#define _RTEMS_POSIX_PTHREADATTRIMPL_H
+#include <errno.h>
+#include <pthread.h>
+#include <rtems/score/basedefs.h>
+#include <rtems/score/assert.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup POSIX_PTHREAD
+ * This variable contains the default POSIX Thread attributes.
+extern pthread_attr_t _POSIX_Threads_Default_attributes;
+RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes(
+  pthread_attr_t        *dst_attr,
+  const pthread_attr_t  *src_attr
+  *dst_attr = *src_attr;
+  _Assert(
+    dst_attr->affinitysetsize == sizeof(dst_attr->affinitysetpreallocated)
+  dst_attr->affinityset = &dst_attr->affinitysetpreallocated;
+RTEMS_INLINE_ROUTINE void _POSIX_Threads_Initialize_attributes(
+  pthread_attr_t  *attr
+  _POSIX_Threads_Copy_attributes(
+    attr,
+    &_POSIX_Threads_Default_attributes
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 9e5314b2c2..055043105b 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -48,11 +48,6 @@ extern "C" {
 extern Thread_Information _POSIX_Threads_Information;
- * This variable contains the default POSIX Thread attributes.
-extern pthread_attr_t _POSIX_Threads_Default_attributes;
 RTEMS_INLINE_ROUTINE void _POSIX_Threads_Sporadic_timer_insert(
   Thread_Control    *the_thread,
   POSIX_API_Control *api
@@ -113,20 +108,6 @@ RTEMS_INLINE_ROUTINE Thread_Control *_POSIX_Threads_Allocate(void)
     _Objects_Allocate_unprotected( &_POSIX_Threads_Information.Objects );
-RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes(
-  pthread_attr_t        *dst_attr,
-  const pthread_attr_t  *src_attr
-  *dst_attr = *src_attr;
-#if defined(RTEMS_SMP)
-  _Assert(
-    dst_attr->affinitysetsize == sizeof(dst_attr->affinitysetpreallocated)
-  dst_attr->affinityset = &dst_attr->affinitysetpreallocated;
-#endif
 RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free (
   Thread_Control *the_pthread
@@ -134,16 +115,6 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free (
   _Objects_Free( &_POSIX_Threads_Information.Objects, &the_pthread->Object );
-RTEMS_INLINE_ROUTINE void _POSIX_Threads_Initialize_attributes(
-  pthread_attr_t  *attr
-  _POSIX_Threads_Copy_attributes(
-    attr,
-    &_POSIX_Threads_Default_attributes
 #ifdef __cplusplus
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 157be567c2..d96cbf75a7 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -59,6 +59,10 @@ $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h: include/rtems/posix/priorityimpl.
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/priorityimpl.h
+$(PROJECT_INCLUDE)/rtems/posix/pthreadattrimpl.h: include/rtems/posix/pthreadattrimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/pthreadattrimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/pthreadattrimpl.h
 $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h: include/rtems/posix/rwlockimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/rwlockimpl.h
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 1d791df7eb..17f7fe3a82 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -43,45 +43,6 @@
- *  The default pthreads attributes structure.
- *  NOTE: Be careful .. if the default attribute set changes,
- *        _POSIX_Threads_Initialize_user_threads will need to be examined.
-pthread_attr_t _POSIX_Threads_Default_attributes = {
-  .is_initialized  = true,                       /* is_initialized */
-  .stackaddr       = NULL,                       /* stackaddr */
-  .stacksize       = 0,                          /* stacksize -- will be adjusted to minimum */
-  .contentionscope = PTHREAD_SCOPE_PROCESS,      /* contentionscope */
-  .inheritsched    = PTHREAD_INHERIT_SCHED,      /* inheritsched */
-  .schedpolicy     = SCHED_FIFO,                 /* schedpolicy */
-  .schedparam      =
-  {                           /* schedparam */
-    2,                        /* sched_priority */
-    #if defined(_POSIX_SPORADIC_SERVER) || \
-        defined(_POSIX_THREAD_SPORADIC_SERVER)
-      0,                        /* sched_ss_low_priority */
-      { 0L, 0 },                /* sched_ss_repl_period */
-      { 0L, 0 },                /* sched_ss_init_budget */
-      0                         /* sched_ss_max_repl */
-    #endif
-  #if HAVE_DECL_PTHREAD_ATTR_SETGUARDSIZE
-    .guardsize = 0,                            /* guardsize */
-  #endif
-  #if defined(_POSIX_THREAD_CPUTIME)
-    .cputime_clock_allowed = 1,                        /* cputime_clock_allowed */
-  #endif
-  .detachstate             = PTHREAD_CREATE_JOINABLE,    /* detachstate */
-  .affinitysetsize         =
-    sizeof( _POSIX_Threads_Default_attributes.affinitysetpreallocated ),
-  .affinityset             =
-    &_POSIX_Threads_Default_attributes.affinitysetpreallocated,
-  .affinitysetpreallocated = {{0x1}}
 void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog )
   POSIX_API_Control    *api;
@@ -243,21 +204,6 @@ User_extensions_Control _POSIX_Threads_User_extensions = {
 static void _POSIX_Threads_Manager_initialization(void)
-  #if defined(RTEMS_SMP)
-    const CPU_set_Control *affinity;
-    pthread_attr_t *attr;
-    /* Initialize default attribute. */
-    attr = &_POSIX_Threads_Default_attributes;
-    /*  Initialize the affinity to be the default cpu set for the system */
-    affinity = _CPU_set_Default();
-    _Assert( affinity->setsize == sizeof( attr->affinitysetpreallocated ) );
-    attr->affinityset             = &attr->affinitysetpreallocated;
-    attr->affinitysetsize         = affinity->setsize;
-    CPU_COPY( affinity->set, attr->affinityset );
-  #endif
   _Thread_Initialize_information(
     &_POSIX_Threads_Information, /* object information table */
     OBJECTS_POSIX_API,           /* object API */
diff --git a/cpukit/posix/src/pthreadattrdefault.c b/cpukit/posix/src/pthreadattrdefault.c
index 0000000000..15f0db1bf0
--- /dev/null
+++ b/cpukit/posix/src/pthreadattrdefault.c
@@ -0,0 +1,60 @@
+ * @file
+ * @brief Private Support Information for POSIX Threads
+ * @ingroup POSIX_PTHREADS Private Threads
+ *  COPYRIGHT (c) 1989-2014.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/posix/pthreadattrimpl.h>
+ *  The default pthreads attributes structure.
+ *  NOTE: Be careful .. if the default attribute set changes,
+ *        _POSIX_Threads_Initialize_user_threads will need to be examined.
+pthread_attr_t _POSIX_Threads_Default_attributes = {
+  .is_initialized  = true,                       /* is_initialized */
+  .stackaddr       = NULL,                       /* stackaddr */
+  .stacksize       = 0,                          /* stacksize -- will be adjusted to minimum */
+  .contentionscope = PTHREAD_SCOPE_PROCESS,      /* contentionscope */
+  .inheritsched    = PTHREAD_INHERIT_SCHED,      /* inheritsched */
+  .schedpolicy     = SCHED_FIFO,                 /* schedpolicy */
+  .schedparam      =
+  {                           /* schedparam */
+    2,                        /* sched_priority */
+    #if defined(_POSIX_SPORADIC_SERVER) || \
+        defined(_POSIX_THREAD_SPORADIC_SERVER)
+      0,                        /* sched_ss_low_priority */
+      { 0L, 0 },                /* sched_ss_repl_period */
+      { 0L, 0 },                /* sched_ss_init_budget */
+      0                         /* sched_ss_max_repl */
+    #endif
+  #if HAVE_DECL_PTHREAD_ATTR_SETGUARDSIZE
+    .guardsize = 0,                            /* guardsize */
+  #endif
+  #if defined(_POSIX_THREAD_CPUTIME)
+    .cputime_clock_allowed = 1,                        /* cputime_clock_allowed */
+  #endif
+  .detachstate             = PTHREAD_CREATE_JOINABLE,    /* detachstate */
+  .affinitysetsize         =
+    sizeof( _POSIX_Threads_Default_attributes.affinitysetpreallocated ),
+  .affinityset             =
+    &_POSIX_Threads_Default_attributes.affinitysetpreallocated,
+  .affinitysetpreallocated = { { -1L } }
diff --git a/cpukit/posix/src/pthreadattrdestroy.c b/cpukit/posix/src/pthreadattrdestroy.c
index d36c1d6dfe..7d30be9ed5 100644
--- a/cpukit/posix/src/pthreadattrdestroy.c
+++ b/cpukit/posix/src/pthreadattrdestroy.c
@@ -20,8 +20,7 @@
-#include <rtems/system.h>
+#include <stdbool.h>
 int pthread_attr_destroy(
diff --git a/cpukit/posix/src/pthreadattrinit.c b/cpukit/posix/src/pthreadattrinit.c
index 311e42cc7a..d69cac497b 100644
--- a/cpukit/posix/src/pthreadattrinit.c
+++ b/cpukit/posix/src/pthreadattrinit.c
@@ -18,11 +18,7 @@
 #include "config.h"
 #endif
-#include <pthread.h>
-#include <errno.h>
-#include <rtems/posix/pthreadimpl.h>
  * 16.1.1 Thread Creation Attributes, P1003.1c/Draft 10, p, 140
diff --git a/cpukit/posix/src/pthreadattrsetguardsize.c b/cpukit/posix/src/pthreadattrsetguardsize.c
index 829a1b30c6..766066ce24 100644
--- a/cpukit/posix/src/pthreadattrsetguardsize.c
+++ b/cpukit/posix/src/pthreadattrsetguardsize.c
@@ -19,12 +19,10 @@
 #endif
 int pthread_attr_setguardsize(
   pthread_attr_t  *attr,
   size_t           guardsize
diff --git a/cpukit/posix/src/pthreadattrsetinheritsched.c b/cpukit/posix/src/pthreadattrsetinheritsched.c
index 8ce3a5db0e..c3b8a53053 100644
--- a/cpukit/posix/src/pthreadattrsetinheritsched.c
+++ b/cpukit/posix/src/pthreadattrsetinheritsched.c
@@ -23,9 +23,6 @@
 int pthread_attr_setinheritsched(
   int              inheritsched
diff --git a/cpukit/posix/src/pthreadattrsetschedpolicy.c b/cpukit/posix/src/pthreadattrsetschedpolicy.c
index 9adec1b8f9..235e7a8ad1 100644
--- a/cpukit/posix/src/pthreadattrsetschedpolicy.c
+++ b/cpukit/posix/src/pthreadattrsetschedpolicy.c
@@ -23,9 +23,6 @@
 int pthread_attr_setschedpolicy(
   int              policy
diff --git a/cpukit/posix/src/pthreadattrsetscope.c b/cpukit/posix/src/pthreadattrsetscope.c
index 78b0fde984..1d8bec0467 100644
--- a/cpukit/posix/src/pthreadattrsetscope.c
+++ b/cpukit/posix/src/pthreadattrsetscope.c
@@ -23,9 +23,6 @@
 int pthread_attr_setscope(
   int              contentionscope
diff --git a/cpukit/posix/src/pthreadattrsetstack.c b/cpukit/posix/src/pthreadattrsetstack.c
index 3f62247741..b335274d92 100644
--- a/cpukit/posix/src/pthreadattrsetstack.c
+++ b/cpukit/posix/src/pthreadattrsetstack.c
@@ -22,9 +22,6 @@
 #if HAVE_DECL_PTHREAD_ATTR_SETSTACK
-#include <rtems/score/stackimpl.h>
@@ -37,11 +34,7 @@ int pthread_attr_setstack(
   if ( !attr || !attr->is_initialized )
     return EINVAL;
-  if (stacksize < PTHREAD_MINIMUM_STACK_SIZE)
-    attr->stacksize = PTHREAD_MINIMUM_STACK_SIZE;
-  else
-    attr->stacksize = stacksize;
+  attr->stacksize = stacksize;
   attr->stackaddr = stackaddr;
   return 0;
diff --git a/cpukit/posix/src/pthreadattrsetstacksize.c b/cpukit/posix/src/pthreadattrsetstacksize.c
index 4dae0f359e..b54531daae 100644
--- a/cpukit/posix/src/pthreadattrsetstacksize.c
+++ b/cpukit/posix/src/pthreadattrsetstacksize.c
@@ -20,9 +20,6 @@
 #include "config.h"
 #endif
@@ -34,9 +31,6 @@ int pthread_attr_setstacksize(
     return EINVAL;
-  else
   return 0;
2.12.3
