[PATCH 1/3] posix: Simplify POSIX_API_Control
Sebastian Huber
Mon Oct 9 13:55:04 UTC 2017
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
cpukit/posix/Makefile.am | 12 ++---
cpukit/posix/include/rtems/posix/pthreadimpl.h | 4 +-
cpukit/posix/include/rtems/posix/threadsup.h | 10 +++-
cpukit/posix/preinstall.am | 2 -
cpukit/posix/src/pthread.c | 13 +++---
cpukit/posix/src/pthreadattrcompare.c | 5 +-
cpukit/posix/src/pthreadattrgetaffinitynp.c | 14 ++----
cpukit/posix/src/pthreadattrsetaffinitynp.c | 16 ++-----
cpukit/posix/src/pthreadcreate.c | 5 +-
cpukit/posix/src/pthreadgetaffinitynp.c | 2 -
cpukit/posix/src/pthreadgetattrnp.c | 31 ++++++++++++-
cpukit/posix/src/pthreadgetschedparam.c | 4 +-
cpukit/posix/src/pthreadsetaffinitynp.c | 9 ----
cpukit/posix/src/pthreadsetschedparam.c | 4 +-
testsuites/psxtests/psxgetattrnp01/init.c | 33 ++++++++++++++
.../psxtests/psxgetattrnp01/psxgetattrnp01.scn | 9 +++-
testsuites/smptests/smppsxaffinity01/init.c | 53 ++++++++++++----------
.../smptests/smppsxaffinity01/smppsxaffinity01.scn | 16 +++----
18 files changed, 151 insertions(+), 91 deletions(-)
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index a4ce099752..627030bcb4 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -89,6 +89,11 @@ libposix_a_SOURCES += src/mutexattrdestroy.c src/mutexattrgetprioceiling.c \
src/mutexlocksupp.c src/mutexsetprioceiling.c src/mutextimedlock.c \
src/mutextrylock.c src/mutexunlock.c
+## PTHREAD_AFFINITY_C_FILES
+libposix_a_SOURCES += src/pthreadattrsetaffinitynp.c \
+ src/pthreadattrgetaffinitynp.c src/pthreadgetaffinitynp.c \
+ src/pthreadsetaffinitynp.c
if HAS_PTHREADS
libposix_a_SOURCES += src/pthreadatfork.c
@@ -148,13 +153,6 @@ libposix_a_SOURCES += src/pthreadsetschedprio.c
## RTEMS specific support methods
libposix_a_SOURCES += src/pthreadattrcompare.c
-if HAS_SMP
-## PTHREAD_AFFINITY_C_FILES
-libposix_a_SOURCES += src/pthreadattrsetaffinitynp.c \
- src/pthreadattrgetaffinitynp.c src/pthreadgetaffinitynp.c \
- src/pthreadsetaffinitynp.c
-endif
## PSIGNAL_C_FILES
libposix_a_SOURCES += src/psignal.c src/alarm.c src/kill.c src/killinfo.c \
src/kill_r.c src/pause.c src/psignalclearprocesssignals.c \
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 90a60b6c4d..290fbad02e 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -59,12 +59,12 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Sporadic_timer_insert(
the_thread->cpu_time_budget =
- _Timespec_To_ticks( &api->Attributes.schedparam.sched_ss_init_budget );
+ _Timespec_To_ticks( &api->schedparam.sched_ss_init_budget );
_Watchdog_Per_CPU_insert_relative(
&api->Sporadic.Timer,
_Per_CPU_Get(),
- _Timespec_To_ticks( &api->Attributes.schedparam.sched_ss_repl_period )
+ _Timespec_To_ticks( &api->schedparam.sched_ss_repl_period )
diff --git a/cpukit/posix/include/rtems/posix/threadsup.h b/cpukit/posix/include/rtems/posix/threadsup.h
index 3bb2210d97..cc250f7464 100644
--- a/cpukit/posix/include/rtems/posix/threadsup.h
+++ b/cpukit/posix/include/rtems/posix/threadsup.h
@@ -43,8 +43,14 @@ typedef struct {
/** Back pointer to thread of this POSIX API control. */
Thread_Control *thread;
- /** This is the POSIX threads attribute set. */
- pthread_attr_t Attributes;
+ /** Created with explicit or inherited scheduler. */
+ bool created_with_explicit_scheduler;
+ /** The scheduler policy. */
+ int schedpolicy;
+ /** The scheduler parameters */
+ struct sched_param schedparam;
* @brief Control block for the sporadic server scheduling policy.
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index c3ce5e5aa9..157be567c2 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -140,5 +140,3 @@ $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h: include/rtems/posix/timerimpl.h $(PR
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/timerimpl.h
endif
-if HAS_PTHREADS
-endif
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index edbfa13121..1d791df7eb 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -75,9 +75,11 @@ pthread_attr_t _POSIX_Threads_Default_attributes = {
.cputime_clock_allowed = 1, /* cputime_clock_allowed */
#endif
.detachstate = PTHREAD_CREATE_JOINABLE, /* detachstate */
- .affinitysetsize = 0,
- .affinityset = NULL,
- .affinitysetpreallocated = {{0x0}}
+ .affinitysetsize =
+ sizeof( _POSIX_Threads_Default_attributes.affinitysetpreallocated ),
+ .affinityset =
+ &_POSIX_Threads_Default_attributes.affinitysetpreallocated,
+ .affinitysetpreallocated = {{0x1}}
void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog )
@@ -166,8 +168,7 @@ static bool _POSIX_Threads_Create_extension(
/* XXX check all fields are touched */
api->thread = created;
- _POSIX_Threads_Initialize_attributes( &api->Attributes );
- api->Attributes.schedparam.sched_priority = _POSIX_Priority_From_core(
+ api->schedparam.sched_priority = _POSIX_Priority_From_core(
_Thread_Scheduler_get_home( created ),
_Thread_Get_priority( created )
@@ -203,7 +204,7 @@ static void _POSIX_Threads_Terminate_extension( Thread_Control *executing )
_Thread_State_acquire( executing, &lock_context );
- if ( api->Attributes.schedpolicy == SCHED_SPORADIC ) {
+ if ( api->schedpolicy == SCHED_SPORADIC ) {
_Watchdog_Per_CPU_remove_relative( &api->Sporadic.Timer );
diff --git a/cpukit/posix/src/pthreadattrcompare.c b/cpukit/posix/src/pthreadattrcompare.c
index 6a3b625be1..26ab28db33 100644
--- a/cpukit/posix/src/pthreadattrcompare.c
+++ b/cpukit/posix/src/pthreadattrcompare.c
@@ -32,7 +32,10 @@ int rtems_pthread_attribute_compare(
if ( attr1->is_initialized != attr2->is_initialized )
return 1;
- if ( attr1->stackaddr != attr2->stackaddr )
+ if (
+ attr1->stackaddr != NULL &&
+ attr2->stackaddr != NULL &&
+ attr1->stackaddr != attr2->stackaddr )
return 1;
if ( attr1->stacksize != attr2->stacksize )
diff --git a/cpukit/posix/src/pthreadattrgetaffinitynp.c b/cpukit/posix/src/pthreadattrgetaffinitynp.c
index 6ed50507be..b281b11e5f 100644
--- a/cpukit/posix/src/pthreadattrgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadattrgetaffinitynp.c
@@ -24,23 +24,19 @@
#include <pthread.h>
-#include <rtems/posix/pthreadimpl.h>
-#include <rtems/posix/priorityimpl.h>
-#include <rtems/score/threadimpl.h>
int pthread_attr_getaffinity_np(
const pthread_attr_t *attr,
size_t cpusetsize,
cpu_set_t *cpuset
- if ( !cpuset )
- return EFAULT;
- if ( !attr )
- return EFAULT;
+ if ( attr == NULL || !attr->is_initialized ) {
+ return EINVAL;
- if ( cpusetsize != attr->affinitysetsize)
+ if ( cpuset == NULL || cpusetsize != attr->affinitysetsize ) {
return EINVAL;
CPU_COPY( attr->affinityset, cpuset );
return 0;
diff --git a/cpukit/posix/src/pthreadattrsetaffinitynp.c b/cpukit/posix/src/pthreadattrsetaffinitynp.c
index e5462ec5c4..0e3c828c38 100644
--- a/cpukit/posix/src/pthreadattrsetaffinitynp.c
+++ b/cpukit/posix/src/pthreadattrsetaffinitynp.c
@@ -24,27 +24,21 @@
-#include <rtems/score/cpusetimpl.h>
int pthread_attr_setaffinity_np(
size_t cpusetsize,
const cpu_set_t *cpuset
- if ( !cpuset )
- return EFAULT;
- if ( !attr )
- return EFAULT;
+ return EINVAL;
- if (! _CPU_set_Is_valid( cpuset, cpusetsize ) )
return EINVAL;
CPU_COPY( cpuset, attr->affinityset );
return 0;
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 5c5ea5f4de..ebb96bf8a4 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -242,7 +242,10 @@ int pthread_create(
api = the_thread->API_Extensions[ THREAD_API_POSIX ];
- _POSIX_Threads_Copy_attributes( &api->Attributes, the_attr );
+ api->created_with_explicit_scheduler =
+ ( the_attr->inheritsched == PTHREAD_EXPLICIT_SCHED );
+ api->schedpolicy = the_attr->schedpolicy;
+ api->schedparam = the_attr->schedparam;
_Priority_Node_initialize( &api->Sporadic.Low_priority, core_low_prio );
_Priority_Node_set_inactive( &api->Sporadic.Low_priority );
diff --git a/cpukit/posix/src/pthreadgetaffinitynp.c b/cpukit/posix/src/pthreadgetaffinitynp.c
index b843f931d4..dab6b63aa0 100644
--- a/cpukit/posix/src/pthreadgetaffinitynp.c
+++ b/cpukit/posix/src/pthreadgetaffinitynp.c
@@ -25,8 +25,6 @@
diff --git a/cpukit/posix/src/pthreadgetattrnp.c b/cpukit/posix/src/pthreadgetattrnp.c
index 63de97be4b..d815fc8c53 100644
--- a/cpukit/posix/src/pthreadgetattrnp.c
+++ b/cpukit/posix/src/pthreadgetattrnp.c
@@ -21,8 +21,10 @@
#define _GNU_SOURCE
+#include <string.h>
+#include <rtems/score/schedulerimpl.h>
int pthread_getattr_np(
@@ -33,11 +35,14 @@ int pthread_getattr_np(
Thread_Control *the_thread;
ISR_lock_Context lock_context;
POSIX_API_Control *api;
+ bool ok;
if ( attr == NULL ) {
return EINVAL;
+ attr = memset( attr, 0, sizeof( *attr ) );
the_thread = _Thread_Get( thread, &lock_context );
if ( the_thread == NULL ) {
@@ -47,7 +52,21 @@ int pthread_getattr_np(
_Thread_State_acquire_critical( the_thread, &lock_context );
- _POSIX_Threads_Copy_attributes( attr, &api->Attributes);
+ attr->is_initialized = true;
+ attr->stackaddr = the_thread->Start.Initial_stack.area;
+ attr->stacksize = the_thread->Start.Initial_stack.size;
+ attr->contentionscope = PTHREAD_SCOPE_PROCESS;
+ if ( api->created_with_explicit_scheduler ) {
+ attr->inheritsched = PTHREAD_EXPLICIT_SCHED;
+ } else {
+ attr->inheritsched = PTHREAD_INHERIT_SCHED;
+ attr->schedpolicy = api->schedpolicy;
+ attr->schedparam = api->schedparam;
+ attr->cputime_clock_allowed = 1;
if ( _Thread_Is_joinable( the_thread ) ) {
attr->detachstate = PTHREAD_CREATE_JOINABLE;
@@ -55,6 +74,14 @@ int pthread_getattr_np(
attr->detachstate = PTHREAD_CREATE_DETACHED;
+ attr->affinityset = &attr->affinitysetpreallocated;
+ attr->affinitysetsize = sizeof( attr->affinitysetpreallocated );
+ ok = _Scheduler_Get_affinity(
+ the_thread,
+ attr->affinitysetsize,
+ attr->affinityset
_Thread_State_release( the_thread, &lock_context );
- return 0;
+ return ok ? 0 : EINVAL;
diff --git a/cpukit/posix/src/pthreadgetschedparam.c b/cpukit/posix/src/pthreadgetschedparam.c
index b809db95dc..f172caecd4 100644
--- a/cpukit/posix/src/pthreadgetschedparam.c
+++ b/cpukit/posix/src/pthreadgetschedparam.c
@@ -56,8 +56,8 @@ int pthread_getschedparam(
_Thread_Wait_acquire_critical( the_thread, &queue_context );
- *policy = api->Attributes.schedpolicy;
- *param = api->Attributes.schedparam;
+ *policy = api->schedpolicy;
+ *param = api->schedparam;
scheduler = _Thread_Scheduler_get_home( the_thread );
priority = the_thread->Real_priority.priority;
diff --git a/cpukit/posix/src/pthreadsetaffinitynp.c b/cpukit/posix/src/pthreadsetaffinitynp.c
index 4ce51ec9ea..c504de5cd7 100644
--- a/cpukit/posix/src/pthreadsetaffinitynp.c
+++ b/cpukit/posix/src/pthreadsetaffinitynp.c
@@ -24,8 +24,6 @@
@@ -60,13 +58,6 @@ int pthread_setaffinity_np(
cpuset
- if ( ok ) {
- POSIX_API_Control *api;
- api = the_thread->API_Extensions[ THREAD_API_POSIX ];
- CPU_COPY( cpuset, api->Attributes.affinityset );
_Thread_Dispatch_enable( cpu_self );
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 4da2ebf2a8..5d33f1d095 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -94,8 +94,8 @@ static int _POSIX_Set_sched_param(
- api->Attributes.schedpolicy = policy;
- api->Attributes.schedparam = *param;
+ api->schedpolicy = policy;
+ api->schedparam = *param;
the_thread->budget_algorithm = budget_algorithm;
the_thread->budget_callout = budget_callout;
diff --git a/testsuites/psxtests/psxgetattrnp01/init.c b/testsuites/psxtests/psxgetattrnp01/init.c
index df3e33541d..190e4f498e 100644
--- a/testsuites/psxtests/psxgetattrnp01/init.c
+++ b/testsuites/psxtests/psxgetattrnp01/init.c
@@ -41,6 +41,9 @@ void *Thread_1(
struct sched_param param;
int sc;
int value;
+ void *stackaddr;
+ size_t stacksize;
+ cpu_set_t set;
puts("Thread - pthread_getattr_np - Verify value");
sc = pthread_getattr_np( Thread_id, &attr );
@@ -61,6 +64,24 @@ void *Thread_1(
rtems_test_assert( !sc );
+ puts("Thread - Verify get stack");
+ stackaddr = NULL;
+ stacksize = 0;
+ sc = pthread_attr_getstack( &attr, &stackaddr, &stacksize );
+ rtems_test_assert( sc == 0 );
+ rtems_test_assert( stackaddr != NULL );
+ rtems_test_assert( stacksize != 0 );
+ puts("Thread - Verify contention scope");
+ sc = pthread_attr_getscope( &attr, &value );
+ rtems_test_assert( value == PTHREAD_SCOPE_PROCESS );
+ puts("Thread - Verify explicit scheduler");
+ sc = pthread_attr_getinheritsched( &attr, &value );
+ rtems_test_assert( value == PTHREAD_EXPLICIT_SCHED );
puts("Thread - Verify SCHED_FIFO policy");
sc = pthread_attr_getschedpolicy( &attr, &value );
@@ -73,8 +94,20 @@ void *Thread_1(
puts("Thread - Verify detached");
sc = pthread_attr_getdetachstate( &attr, &value );
rtems_test_assert( value == PTHREAD_CREATE_DETACHED );
+ puts("Thread - Verify affinity");
+ CPU_ZERO( &set );
+ sc = pthread_attr_getaffinity_np( &attr, sizeof( set ), &set );
+ rtems_test_assert( CPU_ISSET( 0, &set ) );
+ rtems_test_assert( !CPU_ISSET( 1, &set ) );
+ puts("Thread - Destroy");
+ sc = pthread_attr_destroy( &attr );
return NULL; /* just so the compiler thinks we returned something */
diff --git a/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.scn b/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.scn
index a3572e048c..ab09630f75 100644
--- a/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.scn
+++ b/testsuites/psxtests/psxgetattrnp01/psxgetattrnp01.scn
@@ -1,4 +1,4 @@
-*** POSIX ATTRIBUTE TEST 1 ***
+*** BEGIN OF TEST PSXGETATTRNP 1 ***
Init - pthread_getattr_np - attr NULL - EINVAL
Init - pthread_getattr_np - invalid id - ESRCH
Init - pthread_attr_init
@@ -16,7 +16,12 @@ Thread - pthread_getattr_np - Verify value
Thread - pthread_setschedparam: Setting highest priority SCHED_FIFO
Thread - Detach
+Thread - Verify get stack
+Thread - Verify contention scope
+Thread - Verify explicit scheduler
Thread - Verify max priority
-*** END OF POSIX ATTRIBUTE TEST 1 ***
+Thread - Verify affinity
+Thread - Destroy
+*** END OF TEST PSXGETATTRNP 1 ***
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index c4c4f4f7c3..58e1db5435 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -38,21 +38,30 @@ void Validate_attrgetaffinity_errors(void)
cpu_set_t cpuset;
pthread_attr_t attr;
+ sc = pthread_attr_init( &attr );
/* Verify pthread_attr_getaffinity_np validates attr */
- puts( "Init - pthread_attr_getaffinity_np - Invalid attr - EFAULT" );
- sc = pthread_attr_getaffinity_np( NULL, sizeof(cpu_set_t), &cpuset );
- rtems_test_assert( sc == EFAULT );
+ puts( "Init - pthread_attr_getaffinity_np - Invalid attr - EINVAL" );
+ sc = pthread_attr_getaffinity_np( NULL, sizeof( cpuset ), &cpuset );
+ rtems_test_assert( sc == EINVAL );
/* Verify pthread_attr_getaffinity_np validates cpuset */
- sc = pthread_attr_getaffinity_np( &attr, sizeof(cpu_set_t), NULL );
+ sc = pthread_attr_getaffinity_np( &attr, sizeof( cpuset ), NULL );
/* Verify pthread_attr_getaffinity_np validates cpusetsize */
puts( "Init - pthread_attr_getaffinity_np - Invalid cpusetsize - EINVAL" );
- sc = pthread_attr_getaffinity_np( &attr, sizeof(cpu_set_t) * 2 , &cpuset );
+ sc = pthread_attr_getaffinity_np( &attr, sizeof( cpuset ) * 2 , &cpuset );
+ puts( "Init - pthread_attr_getaffinity_np - Not initialized attr - EINVAL" );
+ sc = pthread_attr_getaffinity_np( &attr, sizeof( cpuset ), &cpuset );
void Validate_attrsetaffinity_errors(void)
@@ -61,31 +70,29 @@ void Validate_attrsetaffinity_errors(void)
cpu_set_t cpuset;
/* Verify pthread_attr_setaffinity_np validates attr. */
- puts( "Init - pthread_attr_setaffinity_np - Invalid attr - EFAULT" );
- sc = pthread_attr_setaffinity_np( NULL, sizeof(cpu_set_t), &cpuset );
+ puts( "Init - pthread_attr_setaffinity_np - Invalid attr - EINVAL" );
+ sc = pthread_attr_setaffinity_np( NULL, sizeof( cpuset ), &cpuset );
/* Verify pthread_attr_setaffinity_np validates cpuset */
- sc = pthread_attr_setaffinity_np( &attr, sizeof(cpu_set_t), NULL );
+ sc = pthread_attr_setaffinity_np( &attr, sizeof( cpuset ), NULL );
/* Verify pthread_attr_setaffinity_np validates cpusetsize */
puts( "Init - pthread_attr_setaffinity_np - Invalid cpusetsize - EINVAL" );
- sc = pthread_attr_setaffinity_np( &attr, sizeof(cpu_set_t) * 2 , &cpuset );
+ sc = pthread_attr_setaffinity_np( &attr, sizeof( cpuset ) * 2 , &cpuset );
- /* Verify pthread_attr_setaffinity_np validates cpuset greater than 0 */
- CPU_ZERO(&cpuset);
- puts( "Init - pthread_attr_setaffinity_np - No cpus in cpuset - EINVAL" );
- sc = pthread_attr_setaffinity_np( &attr, sizeof(cpu_set_t) , &cpuset );
- rtems_test_assert( sc == EINVAL );
- /* Verify pthread_attr_setaffinity_np validates invalid cpu in cpuset */
- CPU_FILL(&cpuset);
- puts( "Init - pthread_attr_setaffinity_np - Too many cpus in cpuset - EINVAL" );
+ puts( "Init - pthread_attr_setaffinity_np - Not initialized attr - EINVAL" );
+ sc = pthread_attr_setaffinity_np( &attr, sizeof( cpuset ), &cpuset );
diff --git a/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.scn b/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.scn
index 70bd6d31c8..15459e0c2c 100644
--- a/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.scn
+++ b/testsuites/smptests/smppsxaffinity01/smppsxaffinity01.scn
@@ -1,11 +1,11 @@
-*** SMP POSIX AFFINITY ATTRIBUTE TEST 1 ***
-Init - pthread_attr_setaffinity_np - Invalid attr - EFAULT
+*** BEGIN OF TEST SMPPSXAFFINITY 1 ***
+Init - pthread_attr_setaffinity_np - Invalid attr - EINVAL
-Init - pthread_attr_setaffinity_np - No cpus in cpuset - EINVAL
-Init - pthread_attr_setaffinity_np - Too many cpus in cpuset - EINVAL
-Init - pthread_attr_getaffinity_np - Invalid attr - EFAULT
+Init - pthread_attr_setaffinity_np - Not initialized attr - EINVAL
+Init - pthread_attr_getaffinity_np - Invalid attr - EINVAL
+Init - pthread_attr_getaffinity_np - Not initialized attr - EINVAL
Init - Validate pthread_attr_setaffinity_np and pthread_attr_getaffinity_np
-*** END OF SMP POSIX AFFINITY ATTRIBUTE TEST 1 ***
+*** END OF TEST SMPPSXAFFINITY 1 ***
2.12.3
