[PATCH] c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
Sebastian Huber
Wed Oct 11 05:59:48 UTC 2017
This configuration is not obsolete since it is still used for named
semaphores.
Update #3116.
c-user/configuring_a_system.rst | 36 ++++++++++++++++++++++++++++++------
1 file changed, 30 insertions(+), 6 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 01904a1..c91c8b6 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -1292,6 +1292,36 @@ DESCRIPTION:
NOTES:
This object class can be configured in unlimited allocation mode.
+.. COMMENT: === CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ===
+.. _Specify Maximum POSIX API Semaphores:
+Specify Maximum POSIX API Named Semaphores
+.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
+DATA TYPE:
+ Unsigned integer (``uint32_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is 0.
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
+ Named Semaphores that can be concurrently active. Named semaphores are
+ created with ``sem_open()``. Semaphores initialized with ``sem_init()``
+ are not affected by this configuration option since the storage space for
+ these semaphores is user-provided.
+NOTES:
+ None.
.. COMMENT: === POSIX Initialization Threads Table Configuration ===
@@ -4986,12 +5016,6 @@ CONFIGURE_MAXIMUM_POSIX_RWLOCKS
This configuration option is obsolete since RTEMS 4.12.
-CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-This configuration option is obsolete since RTEMS 4.12.
CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
.. index:: CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
2.12.3
