CXXFLAGS, SMP, and C++11
Thu Oct 12 01:48:51 UTC 2017
Hi
Is this still needed in prog-cxx.m4?
# If CXXFLAGS is not set, default to CFLAGS
if test x"$rtems_cv_HAS_SMP" = x"yes" ; then
  CXXFLAGS=${CXXFLAGS-${CFLAGS} -std=gnu++11}
else
  CXXFLAGS=${CXXFLAGS-${CFLAGS}}
fi
Aren't we up to a modern enough compiler that this isn't needed?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171011/80f30f38/attachment.html>
