[rtems commit] bsp/atsam: Allow to change optimization settings.
Christian Mauderer list at c-mauderer.de
Thu Oct 12 16:36:26 UTC 2017
Am 12.10.2017 um 18:06 schrieb Chris Johns:
> On 12/10/17 12:00 am, Sebastian Huber wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    16fcd56a42dfdef514350ab6297137e2c863afa1
>> Changeset: http://git.rtems.org/rtems/commit/?id=16fcd56a42dfdef514350ab6297137e2c863afa1
>> Author:    Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>> Date:      Wed Oct 11 15:38:14 2017 +0200
>> Allow to overwrite the optimization settings during configuration.
>>  c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg | 3 +--
>>  1 file changed, 1 insertion(+), 2 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
>> index 06892f9..0a2437f 100644
>> --- a/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
>> +++ b/c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg
>> @@ -4,7 +4,6 @@ RTEMS_CPU = arm
>>  CPU_CFLAGS = -mthumb -mcpu=cortex-m7 -mfpu=fpv5-d16 -mfloat-abi=hard
>> -CFLAGS_OPTIMIZE_V = -O2 -g
>> -CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
>> +CFLAGS_OPTIMIZE_V ?= -O2 -g -ffunction-sections -fdata-sections
> This is a really nice change. Should all the BSP's be changed?
> I see a 104 instances in the code and the change could be scripted.
> Being inconsistent on something that could be consistent across all BSPs is
> confusing to all users.
> Chris
> devel mailing list
> devel at rtems.org
Hello Chris,
the change is just similar to some other BSPs (like or1k or realview).
If we want to offer something like that for all BSPs, it might would be
a better idea to split the flags up (what I haven't done here). I think
the -ffunction-sections -fdata-sections is allways necessary? Some BSPs
have some other options too like an additional -fomit-frame-pointer in
rbtx4925 or a -mmultiple in mcp750. So if a user would want to use that
environment variable to change optimization, the value wouldn't be
consistent across BSPs.
A consistent solution could be to split it up like in or1k:
  CFLAGS_OPTIMIZE_V ?= -O0 -g
The general optimization could be overwritten with CFLAGS_OPTIMIZE_V and
the BSP-specific parts would be added in the second line.
What do you think?
Kind regards
Christian Mauderer
