[PATCH v2 2/4] Port wpa supplicant to RTEMS.
Christian Mauderer list at c-mauderer.de
Sat Oct 14 13:14:11 UTC 2017
Hello Sichen,
I was able to establish a WPA encrypted connection. Really great. A few
details:
- I noted that most of the time wpa_supplicant exits, an assert is hit
(for example on a "wpa_supplicant_fork --help"). That's not really a
killer because in normal case wpa_supplicant shouldn't quit. But it is
not ideal too.
- Please don't add blank lines outside of __rtems__ guards to BSD code
(see comment below in the patch).
- There is one change that might could be upstreamed to the
wpa_supplicant repo (see comment in the patch).
- It would be great if you could write some notes how to use this to
some documentation or at least to the mailing list. Otherwise it's hard
to figure out what to do.
- You used the getentropy() but the BBB currently only has the default
implementation which provides just zeroes. That might could lead to weak
crypto.
To the RTEMS community: Should we already add that code? It's not
thoroughly tested and still has some problems (like the assert) but it
adds everything that is necessary for continuing that work. If we don't
merge it, it might get out of date during the next update to a newer
FreeBSD version.
Maybe some 'doc/libbsd-wifi.txt' could be added which contains the
problematic points listed above as well as a short guide how to set up a
wifi connection with the current version? With that a user has some
information about the current progress?
Regards
Christian
Am 12.10.2017 um 14:16 schrieb Sichen Zhao:
> Add wpa_supplicant lib support and shell command support in RTEMS.
>  builder.py                                         |   1 +
>  freebsd/contrib/wpa/src/utils/os_unix.c            |  11 +-
>  freebsd/contrib/wpa/wpa_supplicant/config.h        |   3 +
>  freebsd/contrib/wpa/wpa_supplicant/main.c          |  21 ++
>  libbsd.py                                          | 286 +++++++++++++++++++++
>  libbsd_waf.py                                      | 115 ++++++++-
>  rtemsbsd/include/bsp/nexus-devices.h               |   2 +
>  rtemsbsd/include/machine/rtems-bsd-commands.h      |   2 +
>  .../include/machine/rtems-wpa_supplicant-mutex.h   |  41 +++
>  rtemsbsd/include/rtems/netcmds-config.h            |   2 +
>  rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c    |  36 +++
>  rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c        |  47 ++++
>  12 files changed, 562 insertions(+), 5 deletions(-)
>  create mode 100644 rtemsbsd/include/machine/rtems-wpa_supplicant-mutex.h
>  create mode 100644 rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c
>  create mode 100644 rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c
> diff --git a/builder.py b/builder.py
> index ae2e6ee..5124dc6 100755
> --- a/builder.py
> +++ b/builder.py
> @@ -173,6 +173,7 @@ def includes():
>      return ['-Irtemsbsd/include',
>              '-Ifreebsd/sys',
>              '-Ifreebsd/sys/contrib/pf',
> +            '-Ifreebsd/crypto',
>              '-Ifreebsd/sys/net',
>              '-Ifreebsd/include',
>              '-Ifreebsd/lib',
> diff --git a/freebsd/contrib/wpa/src/utils/os_unix.c b/freebsd/contrib/wpa/src/utils/os_unix.c
> index a3abce4..7f101d7 100644
> --- a/freebsd/contrib/wpa/src/utils/os_unix.c
> +++ b/freebsd/contrib/wpa/src/utils/os_unix.c
> @@ -25,6 +25,11 @@
>  #include <mach/mach_time.h>
>  #endif /* __MACH__ */
> +#ifdef __rtems__
> +#include <unistd.h>
> +#endif /* __rtems__ */
At this point: Please no blank lines outside of the "#ifdef __rtems__"
>  #include "os.h"
>  #include "common.h"
> @@ -225,7 +230,7 @@ static int os_daemon(int nochdir, int noclose)
>  int os_daemonize(const char *pid_file)
> -#if defined(__uClinux__) || defined(__sun__)
> +#if defined(__uClinux__) || defined(__sun__) || defined(__rtems__)
I think that one should be upstreamed.
>  	return -1;
>  #else /* defined(__uClinux__) || defined(__sun__) */
>  #ifdef __FreeBSD__
> @@ -282,6 +287,9 @@ int os_get_random(unsigned char *buf, size_t len)
>  	if (TEST_FAIL())
>  		return -1;
> +#ifdef __rtems__
> +	return getentropy(buf, len);
> +#else /* __rtems__ */
>  	f = fopen("/dev/urandom", "rb");
>  	if (f == NULL) {
>  		printf("Could not open /dev/urandom.\n");
> @@ -292,6 +300,7 @@ int os_get_random(unsigned char *buf, size_t len)
>  	fclose(f);
>  	return rc != len ? -1 : 0;
> diff --git a/freebsd/contrib/wpa/wpa_supplicant/config.h b/freebsd/contrib/wpa/wpa_supplicant/config.h
> index 627f38b..9de7e70 100644
> --- a/freebsd/contrib/wpa/wpa_supplicant/config.h
> +++ b/freebsd/contrib/wpa/wpa_supplicant/config.h
> @@ -45,6 +45,9 @@
>  #include "common/ieee802_11_defs.h"
>  #include "common/ieee802_11_common.h"
> +#ifdef __rtems__
> +#include <machine/rtems-bsd-commands.h>
>  struct wpa_cred {
> diff --git a/freebsd/contrib/wpa/wpa_supplicant/main.c b/freebsd/contrib/wpa/wpa_supplicant/main.c
> index 0e86b93..40950d2 100644
> --- a/freebsd/contrib/wpa/wpa_supplicant/main.c
> +++ b/freebsd/contrib/wpa/wpa_supplicant/main.c
> @@ -19,6 +19,11 @@
>  #include "driver_i.h"
>  #include "p2p_supplicant.h"
> +#ifdef __rtems__
> +#include <assert.h>
> +#include <sys/mutex.h>
> +#include <machine/rtems-bsd-program.h>
>  static void usage(void)
> @@ -154,6 +159,22 @@ static void wpa_supplicant_fd_workaround(int start)
>  #endif /* __linux__ */
> +#ifdef __rtems__
> +#include <rtems/libio.h>
> +static int
> +main(int argc, char **argv);
> +int rtems_bsd_command_wpa_supplicant(int argc, char **argv)
> +	int exit_code;
> +	rtems_status_code sc;
> +	exit_code = rtems_bsd_program_call_main("wpa_supplicant", main, argc, argv);
> +	return exit_code;
>  int main(int argc, char *argv[])
> diff --git a/libbsd.py b/libbsd.py
> index 471fb65..6cf10bf 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -3959,6 +3959,291 @@ def usr_sbin_tcpdump(mm):
>      return mod
> +# /usr/sbin/wpa_supplicant
> +def usr_sbin_wpa_supplicant(mm):
> +    mod = builder.Module('usr_sbin_wpa_supplicant')
> +    mod.addUserSpaceHeaderFiles(
> +            'contrib/wpa/wpa_supplicant/ap.h',
> +            'contrib/wpa/wpa_supplicant/blacklist.h',
> +            'contrib/wpa/wpa_supplicant/bss.h',
> +            'contrib/wpa/wpa_supplicant/config.h',
> +            'contrib/wpa/wpa_supplicant/config_ssid.h',
> +            'contrib/wpa/wpa_supplicant/ctrl_iface.h',
> +            'contrib/wpa/wpa_supplicant/driver_i.h',
> +            'contrib/wpa/wpa_supplicant/gas_query.h',
> +            'contrib/wpa/wpa_supplicant/hs20_supplicant.h',
> +            'contrib/wpa/wpa_supplicant/interworking.h',
> +            'contrib/wpa/wpa_supplicant/mesh.h',
> +            'contrib/wpa/wpa_supplicant/mesh_mpm.h',
> +            'contrib/wpa/wpa_supplicant/mesh_rsn.h',
> +            'contrib/wpa/wpa_supplicant/notify.h',
> +            'contrib/wpa/wpa_supplicant/offchannel.h',
> +            'contrib/wpa/wpa_supplicant/scan.h',
> +            'contrib/wpa/wpa_supplicant/autoscan.h',
> +            'contrib/wpa/wpa_supplicant/wmm_ac.h',
> +            'contrib/wpa/wpa_supplicant/wnm_sta.h',
> +            'contrib/wpa/wpa_supplicant/wpas_glue.h',
> +            'contrib/wpa/wpa_supplicant/wpas_kay.h',
> +            'contrib/wpa/wpa_supplicant/wpa_supplicant_i.h',
> +            'contrib/wpa/wpa_supplicant/wps_supplicant.h',
> +            'contrib/wpa/wpa_supplicant/ibss_rsn.h',
> +            'contrib/wpa/wpa_supplicant/p2p_supplicant.h',
> +            'contrib/wpa/wpa_supplicant/wifi_display.h',
> +            'contrib/wpa/wpa_supplicant/sme.h',
> +            'contrib/wpa/wpa_supplicant/bgscan.h',
> +            'contrib/wpa/wpa_supplicant/dbus/dbus_common.h',
> +            'contrib/wpa/wpa_supplicant/dbus/dbus_old.h',
> +            'contrib/wpa/wpa_supplicant/dbus/dbus_new.h',
> +            'contrib/wpa/src/ap/ap_config.h',
> +            'contrib/wpa/src/ap/ap_drv_ops.h',
> +            'contrib/wpa/src/ap/hs20.h',
> +            'contrib/wpa/src/ap/hostapd.h',
> +            'contrib/wpa/src/ap/ieee802_11.h',
> +            'contrib/wpa/src/ap/ieee802_11_auth.h',
> +            'contrib/wpa/src/ap/p2p_hostapd.h',
> +            'contrib/wpa/src/ap/sta_info.h',
> +            'contrib/wpa/src/utils/includes.h',
> +            'contrib/wpa/src/utils/base64.h',
> +            'contrib/wpa/src/utils/build_config.h',
> +            'contrib/wpa/src/utils/common.h',
> +            'contrib/wpa/src/utils/eloop.h',
> +            'contrib/wpa/src/utils/ip_addr.h',
> +            'contrib/wpa/src/utils/list.h',
> +            'contrib/wpa/src/utils/os.h',
> +            'contrib/wpa/src/utils/platform.h',
> +            'contrib/wpa/src/utils/uuid.h',
> +            'contrib/wpa/src/utils/wpa_debug.h',
> +            'contrib/wpa/src/utils/wpabuf.h',
> +            'contrib/wpa/src/utils/trace.h',
> +            'contrib/wpa/src/utils/pcsc_funcs.h',
> +            'contrib/wpa/src/utils/ext_password.h',
> +            'contrib/wpa/src/utils/state_machine.h',
> +            'contrib/wpa/src/common/gas.h',
> +            'contrib/wpa/src/common/hw_features_common.h',
> +            'contrib/wpa/src/common/ieee802_11_common.h',
> +            'contrib/wpa/src/common/ieee802_11_defs.h',
> +            'contrib/wpa/src/common/wpa_common.h',
> +            'contrib/wpa/src/common/defs.h',
> +            'contrib/wpa/src/common/qca-vendor.h',
> +            'contrib/wpa/src/common/eapol_common.h',
> +            'contrib/wpa/src/common/sae.h',
> +            'contrib/wpa/src/common/wpa_ctrl.h',
> +            'contrib/wpa/src/common/version.h',
> +            'contrib/wpa/src/drivers/driver.h',
> +            'contrib/wpa/src/drivers/driver_ndis.h',
> +            'contrib/wpa/src/drivers/driver_nl80211.h',
> +            'contrib/wpa/src/drivers/linux_defines.h',
> +            'contrib/wpa/src/wps/http.h',
> +            'contrib/wpa/src/wps/http_client.h',
> +            'contrib/wpa/src/wps/http_server.h',
> +            'contrib/wpa/src/wps/httpread.h',
> +            'contrib/wpa/src/wps/wps.h',
> +            'contrib/wpa/src/wps/wps_i.h',
> +            'contrib/wpa/src/wps/wps_defs.h',
> +            'contrib/wpa/src/wps/upnp_xml.h',
> +            'contrib/wpa/src/wps/wps_attr_parse.h',
> +            'contrib/wpa/src/wps/wps_dev_attr.h',
> +            'contrib/wpa/src/wps/wps_er.h',
> +            'contrib/wpa/src/wps/wps_upnp.h',
> +            'contrib/wpa/src/wps/wps_upnp_i.h',
> +            'contrib/wpa/src/l2_packet/l2_packet.h',
> +            'contrib/wpa/src/rsn_supp/peerkey.h',
> +            'contrib/wpa/src/rsn_supp/pmksa_cache.h',
> +            'contrib/wpa/src/rsn_supp/preauth.h',
> +            'contrib/wpa/src/rsn_supp/wpa.h',
> +            'contrib/wpa/src/rsn_supp/wpa_i.h',
> +            'contrib/wpa/src/rsn_supp/wpa_ie.h',
> +            'contrib/wpa/src/p2p/p2p.h',
> +            'contrib/wpa/src/fst/fst.h',
> +            'contrib/wpa/src/fst/fst_ctrl_iface.h',
> +            'contrib/wpa/src/fst/fst_ctrl_aux.h',
> +            'contrib/wpa/src/crypto/md5.h',
> +            'contrib/wpa/src/crypto/sha256.h',
> +            'contrib/wpa/src/crypto/sha384.h',
> +            'contrib/wpa/src/crypto/aes_wrap.h',
> +            'contrib/wpa/src/crypto/crypto.h',
> +            'contrib/wpa/src/crypto/random.h',
> +            'contrib/wpa/src/crypto/dh_group5.h',
> +            'contrib/wpa/src/crypto/sha1.h',
> +            'contrib/wpa/src/crypto/tls.h',
> +            'contrib/wpa/src/crypto/ms_funcs.h',
> +            'contrib/wpa/src/crypto/aes.h',
> +            'contrib/wpa/src/crypto/sha256_i.h',
> +            'contrib/wpa/src/eapol_supp/eapol_supp_sm.h',
> +            'contrib/wpa/src/eap_peer/eap_config.h',
> +            'contrib/wpa/src/eap_peer/eap.h',
> +            'contrib/wpa/src/eap_peer/eap_i.h',
> +            'contrib/wpa/src/eap_peer/eap_methods.h',
> +            'contrib/wpa/src/eap_peer/eap_proxy.h',
> +            'contrib/wpa/src/eap_peer/mschapv2.h',
> +            'contrib/wpa/src/eap_peer/tncc.h',
> +            'contrib/wpa/src/eap_peer/eap_tls_common.h',
> +            'contrib/wpa/src/eap_common/eap_defs.h',
> +            'contrib/wpa/src/eap_common/eap_wsc_common.h',
> +            'contrib/wpa/src/eap_common/eap_peap_common.h',
> +            'contrib/wpa/src/eap_common/eap_psk_common.h',
> +            'contrib/wpa/src/eap_common/eap_tlv_common.h',
> +            'contrib/wpa/src/eap_common/eap_common.h',
> +            'contrib/wpa/src/eap_common/chap.h',
> +            'contrib/wpa/src/eap_common/eap_ttls.h',
> +            'contrib/wpa/src/eap_server/eap_methods.h',
> +            'contrib/wpa/src/tls/tlsv1_client.h',
> +            'contrib/wpa/src/tls/tlsv1_cred.h',
> +            'contrib/wpa/src/tls/tlsv1_server.h',
> +            'usr.sbin/wpa/wpa_supplicant/Packet32.h',
> +            'usr.sbin/wpa/wpa_supplicant/ntddndis.h',
> +    mod.addUserSpaceSourceFiles(
> +            'contrib/wpa/wpa_supplicant/blacklist.c',
> +            'contrib/wpa/wpa_supplicant/bss.c',
> +            'contrib/wpa/wpa_supplicant/config.c',
> +            'contrib/wpa/wpa_supplicant/config_file.c',
> +            'contrib/wpa/wpa_supplicant/ctrl_iface.c',
> +            'contrib/wpa/wpa_supplicant/ctrl_iface_unix.c',
> +            'contrib/wpa/wpa_supplicant/eap_register.c',
> +            'contrib/wpa/wpa_supplicant/events.c',
> +            'contrib/wpa/wpa_supplicant/gas_query.c',
> +            'contrib/wpa/wpa_supplicant/hs20_supplicant.c',
> +            'contrib/wpa/wpa_supplicant/interworking.c',
> +            'contrib/wpa/wpa_supplicant/main.c',
> +            'contrib/wpa/wpa_supplicant/notify.c',
> +            'contrib/wpa/wpa_supplicant/offchannel.c',
> +            'contrib/wpa/wpa_supplicant/scan.c',
> +            'contrib/wpa/wpa_supplicant/wmm_ac.c',
> +            'contrib/wpa/wpa_supplicant/wpa_supplicant.c',
> +            'contrib/wpa/wpa_supplicant/wpas_glue.c',
> +            'contrib/wpa/wpa_supplicant/wps_supplicant.c',
> +            'contrib/wpa/src/ap/ap_drv_ops.c',
> +            'contrib/wpa/src/ap/hs20.c',
> +            'contrib/wpa/src/ap/ieee802_11_shared.c',
> +            'contrib/wpa/src/utils/base64.c',
> +            'contrib/wpa/src/utils/common.c',
> +            'contrib/wpa/src/utils/eloop.c',
> +            'contrib/wpa/src/utils/os_unix.c',
> +            'contrib/wpa/src/utils/uuid.c',
> +            'contrib/wpa/src/utils/wpa_debug.c',
> +            'contrib/wpa/src/utils/wpabuf.c',
> +            'contrib/wpa/src/common/gas.c',
> +            'contrib/wpa/src/common/hw_features_common.c',
> +            'contrib/wpa/src/common/ieee802_11_common.c',
> +            'contrib/wpa/src/common/wpa_common.c',
> +            'contrib/wpa/src/drivers/driver_bsd.c',
> +            'contrib/wpa/src/drivers/driver_common.c',
> +            'contrib/wpa/src/drivers/driver_ndis.c',
> +            'contrib/wpa/src/drivers/driver_wired.c',
> +            'contrib/wpa/src/drivers/drivers.c',
> +            'contrib/wpa/src/wps/http_client.c',
> +            'contrib/wpa/src/wps/http_server.c',
> +            'contrib/wpa/src/wps/httpread.c',
> +            'contrib/wpa/src/wps/upnp_xml.c',
> +            'contrib/wpa/src/wps/wps.c',
> +            'contrib/wpa/src/wps/wps_attr_build.c',
> +            'contrib/wpa/src/wps/wps_attr_parse.c',
> +            'contrib/wpa/src/wps/wps_attr_process.c',
> +            'contrib/wpa/src/wps/wps_common.c',
> +            'contrib/wpa/src/wps/wps_dev_attr.c',
> +            'contrib/wpa/src/wps/wps_enrollee.c',
> +            'contrib/wpa/src/wps/wps_registrar.c',
> +            'contrib/wpa/src/wps/wps_upnp.c',
> +            'contrib/wpa/src/wps/wps_upnp_ap.c',
> +            'contrib/wpa/src/wps/wps_upnp_event.c',
> +            'contrib/wpa/src/wps/wps_upnp_ssdp.c',
> +            'contrib/wpa/src/wps/wps_upnp_web.c',
> +            'contrib/wpa/src/l2_packet/l2_packet_freebsd.c',
> +            'contrib/wpa/src/rsn_supp/peerkey.c',
> +            'contrib/wpa/src/rsn_supp/pmksa_cache.c',
> +            'contrib/wpa/src/rsn_supp/preauth.c',
> +            'contrib/wpa/src/rsn_supp/wpa.c',
> +            'contrib/wpa/src/rsn_supp/wpa_ft.c',
> +            'contrib/wpa/src/rsn_supp/wpa_ie.c',
> +            'contrib/wpa/src/eapol_supp/eapol_supp_sm.c',
> +            'contrib/wpa/src/eap_peer/eap.c',
> +            'contrib/wpa/src/eap_peer/eap_methods.c',
> +            'contrib/wpa/src/eap_peer/eap_mschapv2.c',
> +            'contrib/wpa/src/eap_peer/mschapv2.c',
> +            'contrib/wpa/src/eap_peer/eap_md5.c',
> +            'contrib/wpa/src/eap_peer/eap_tls.c',
> +            'contrib/wpa/src/eap_peer/eap_peap.c',
> +            'contrib/wpa/src/eap_peer/eap_ttls.c',
> +            'contrib/wpa/src/eap_peer/eap_gtc.c',
> +            'contrib/wpa/src/eap_peer/eap_otp.c',
> +            'contrib/wpa/src/eap_peer/eap_leap.c',
> +            'contrib/wpa/src/eap_peer/eap_psk.c',
> +            'contrib/wpa/src/eap_peer/eap_tls_common.c',
> +            'contrib/wpa/src/eap_common/eap_common.c',
> +            'contrib/wpa/src/eap_common/eap_peap_common.c',
> +            'contrib/wpa/src/eap_common/eap_psk_common.c',
> +            'contrib/wpa/src/eap_common/chap.c',
> +            'contrib/wpa/src/crypto/crypto_openssl.c',
> +            'contrib/wpa/src/crypto/random.c',
> +            'contrib/wpa/src/crypto/aes-omac1.c',
> +            'contrib/wpa/src/crypto/sha256-prf.c',
> +            'contrib/wpa/src/crypto/sha256-internal.c',
> +            'contrib/wpa/src/crypto/sha1.c',
> +            'contrib/wpa/src/crypto/sha1-prf.c',
> +            'contrib/wpa/src/crypto/aes-unwrap.c',
> +            'contrib/wpa/src/crypto/rc4.c',
> +            'contrib/wpa/src/crypto/sha1-pbkdf2.c',
> +            'contrib/wpa/src/crypto/tls_internal.c',
> +            'contrib/wpa/src/crypto/ms_funcs.c',
> +            'contrib/wpa/src/crypto/aes-eax.c',
> +            'contrib/wpa/src/crypto/aes-ctr.c',
> +            'contrib/wpa/src/crypto/aes-encblock.c',
> +            'usr.sbin/wpa/wpa_supplicant/Packet32.c',
> +        mm.generator['source'](['-D__FreeBSD__=1',
> +                                '-DCONFIG_BACKEND_FILE=1',
> +                                '-DCONFIG_DEBUG_SYSLOG=1',
> +                                '-DCONFIG_DRIVER_BSD=1',
> +                                '-DCONFIG_DRIVER_NDIS=1',
> +                                '-DCONFIG_DRIVER_WIRED=1',
> +                                '-DCONFIG_GAS=1',
> +                                '-DCONFIG_HS20=1',
> +                                '-DCONFIG_IEEE80211R=1',
> +                                '-DCONFIG_INTERWORKING=1',
> +                                '-DCONFIG_PEERKEY=1',
> +                                '-DCONFIG_PRIVSEP=1',
> +                                '-DCONFIG_SMARTCARD=1',
> +                                '-DCONFIG_TERMINATE_ONLASTIF=1',
> +                                '-DCONFIG_TLS=openssl',
> +                                '-DCONFIG_WPS=1',
> +                                '-DCONFIG_WPS2=1',
> +                                '-DCONFIG_WPS_UPNP=1',
> +                                '-DPKCS12_FUNCS=1',
> +                                '-DCONFIG_SHA256=1',
> +                                '-DCONFIG_CTRL_IFACE=1',
> +                                '-DCONFIG_CTRL_IFACE_UNIX=1',
> +                                '-DIEEE8021X_EAPOL=1',
> +                                '-DEAP_MD5=1',
> +                                '-DEAP_GTC=1',
> +                                '-DEAP_LEAP=1',
> +                                '-DEAP_MSCHAPv2=1',
> +                                '-DEAP_OTP=1',
> +                                '-DEAP_PEAP=1',
> +                                '-DEAP_PSK=1',
> +                                '-DEAP_TLS=1',
> +                                '-DEAP_TTLS=1'],
> +                               ['freebsd/contrib/wpa/src',
> +                                'freebsd/contrib/wpa/src/utils',
> +                                'freebsd/contrib/wpa/src/eap_peer',
> +                                'freebsd/usr.sbin/wpa/wpa_supplicant',
> +                                'freebsd/crypto/openssl/crypto'])
> +    mod.addRTEMSSourceFiles(
> +            'rtems/rtems-bsd-shell-wpa_supplicant.c',
> +            'rtems/rtems-wpa_supplicant_mutex.c',
> +        mm.generator['source']()
> +    return mod
>  # in_chksum Module
>  def in_cksum(mm):
> @@ -4237,6 +4522,7 @@ def sources(mm):
>      mm.addModule(contrib_expat(mm))
>      mm.addModule(contrib_libpcap(mm))
>      mm.addModule(usr_sbin_tcpdump(mm))
> +    mm.addModule(usr_sbin_wpa_supplicant(mm))
>      mm.addModule(crypto_openssl(mm))
>      mm.addModule(tests(mm))
> diff --git a/libbsd_waf.py b/libbsd_waf.py
> index c466930..63a0f48 100644
> --- a/libbsd_waf.py
> +++ b/libbsd_waf.py
> @@ -64,6 +64,7 @@ def build(bld):
>      includes += ["rtemsbsd/include"]
>      includes += ["freebsd/sys"]
>      includes += ["freebsd/sys/contrib/pf"]
> +    includes += ["freebsd/crypto"]
>      includes += ["freebsd/sys/net"]
>      includes += ["freebsd/include"]
>      includes += ["freebsd/lib"]
> @@ -1403,7 +1404,111 @@ def build(bld):
>                  source = objs07_source)
>      libbsd_use += ["objs07"]
> -    objs08_source = ['freebsd/contrib/tcpdump/addrtoname.c',
> +    objs08_source = ['freebsd/contrib/wpa/src/ap/ap_drv_ops.c',
> +                     'freebsd/contrib/wpa/src/ap/hs20.c',
> +                     'freebsd/contrib/wpa/src/ap/ieee802_11_shared.c',
> +                     'freebsd/contrib/wpa/src/common/gas.c',
> +                     'freebsd/contrib/wpa/src/common/hw_features_common.c',
> +                     'freebsd/contrib/wpa/src/common/ieee802_11_common.c',
> +                     'freebsd/contrib/wpa/src/common/wpa_common.c',
> +                     'freebsd/contrib/wpa/src/crypto/aes-ctr.c',
> +                     'freebsd/contrib/wpa/src/crypto/aes-eax.c',
> +                     'freebsd/contrib/wpa/src/crypto/aes-encblock.c',
> +                     'freebsd/contrib/wpa/src/crypto/aes-omac1.c',
> +                     'freebsd/contrib/wpa/src/crypto/aes-unwrap.c',
> +                     'freebsd/contrib/wpa/src/crypto/crypto_openssl.c',
> +                     'freebsd/contrib/wpa/src/crypto/ms_funcs.c',
> +                     'freebsd/contrib/wpa/src/crypto/random.c',
> +                     'freebsd/contrib/wpa/src/crypto/rc4.c',
> +                     'freebsd/contrib/wpa/src/crypto/sha1-pbkdf2.c',
> +                     'freebsd/contrib/wpa/src/crypto/sha1-prf.c',
> +                     'freebsd/contrib/wpa/src/crypto/sha1.c',
> +                     'freebsd/contrib/wpa/src/crypto/sha256-internal.c',
> +                     'freebsd/contrib/wpa/src/crypto/sha256-prf.c',
> +                     'freebsd/contrib/wpa/src/crypto/tls_internal.c',
> +                     'freebsd/contrib/wpa/src/drivers/driver_bsd.c',
> +                     'freebsd/contrib/wpa/src/drivers/driver_common.c',
> +                     'freebsd/contrib/wpa/src/drivers/driver_ndis.c',
> +                     'freebsd/contrib/wpa/src/drivers/driver_wired.c',
> +                     'freebsd/contrib/wpa/src/drivers/drivers.c',
> +                     'freebsd/contrib/wpa/src/eap_common/chap.c',
> +                     'freebsd/contrib/wpa/src/eap_common/eap_common.c',
> +                     'freebsd/contrib/wpa/src/eap_common/eap_peap_common.c',
> +                     'freebsd/contrib/wpa/src/eap_common/eap_psk_common.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_gtc.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_leap.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_md5.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_methods.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_mschapv2.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_otp.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_peap.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_psk.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_tls.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_tls_common.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/eap_ttls.c',
> +                     'freebsd/contrib/wpa/src/eap_peer/mschapv2.c',
> +                     'freebsd/contrib/wpa/src/eapol_supp/eapol_supp_sm.c',
> +                     'freebsd/contrib/wpa/src/l2_packet/l2_packet_freebsd.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/peerkey.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/pmksa_cache.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/preauth.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/wpa.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/wpa_ft.c',
> +                     'freebsd/contrib/wpa/src/rsn_supp/wpa_ie.c',
> +                     'freebsd/contrib/wpa/src/utils/base64.c',
> +                     'freebsd/contrib/wpa/src/utils/common.c',
> +                     'freebsd/contrib/wpa/src/utils/eloop.c',
> +                     'freebsd/contrib/wpa/src/utils/os_unix.c',
> +                     'freebsd/contrib/wpa/src/utils/uuid.c',
> +                     'freebsd/contrib/wpa/src/utils/wpa_debug.c',
> +                     'freebsd/contrib/wpa/src/utils/wpabuf.c',
> +                     'freebsd/contrib/wpa/src/wps/http_client.c',
> +                     'freebsd/contrib/wpa/src/wps/http_server.c',
> +                     'freebsd/contrib/wpa/src/wps/httpread.c',
> +                     'freebsd/contrib/wpa/src/wps/upnp_xml.c',
> +                     'freebsd/contrib/wpa/src/wps/wps.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_attr_build.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_attr_parse.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_attr_process.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_common.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_dev_attr.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_enrollee.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_registrar.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_upnp.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_upnp_ap.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_upnp_event.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_upnp_ssdp.c',
> +                     'freebsd/contrib/wpa/src/wps/wps_upnp_web.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/blacklist.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/bss.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/config.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/config_file.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/ctrl_iface.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/ctrl_iface_unix.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/eap_register.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/events.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/gas_query.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/hs20_supplicant.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/interworking.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/main.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/notify.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/offchannel.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/scan.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/wmm_ac.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/wpa_supplicant.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/wpas_glue.c',
> +                     'freebsd/contrib/wpa/wpa_supplicant/wps_supplicant.c',
> +                     'freebsd/usr.sbin/wpa/wpa_supplicant/Packet32.c']
> +    bld.objects(target = "objs08",
> +                features = "c",
> +                cflags = cflags,
> +                includes = ['freebsd/contrib/wpa/src', 'freebsd/contrib/wpa/src/eap_peer', 'freebsd/contrib/wpa/src/utils', 'freebsd/crypto/openssl/crypto', 'freebsd/usr.sbin/wpa/wpa_supplicant'] + includes,
> +                defines = defines + ['CONFIG_BACKEND_FILE=1', 'CONFIG_CTRL_IFACE=1', 'CONFIG_CTRL_IFACE_UNIX=1', 'CONFIG_DEBUG_SYSLOG=1', 'CONFIG_DRIVER_BSD=1', 'CONFIG_DRIVER_NDIS=1', 'CONFIG_DRIVER_WIRED=1', 'CONFIG_GAS=1', 'CONFIG_HS20=1', 'CONFIG_IEEE80211R=1', 'CONFIG_INTERWORKING=1', 'CONFIG_PEERKEY=1', 'CONFIG_PRIVSEP=1', 'CONFIG_SHA256=1', 'CONFIG_SMARTCARD=1', 'CONFIG_TERMINATE_ONLASTIF=1', 'CONFIG_TLS=openssl', 'CONFIG_WPS2=1', 'CONFIG_WPS=1', 'CONFIG_WPS_UPNP=1', 'EAP_GTC=1', 'EAP_LEAP=1', 'EAP_MD5=1', 'EAP_MSCHAPv2=1', 'EAP_OTP=1', 'EAP_PEAP=1', 'EAP_PSK=1', 'EAP_TLS=1', 'EAP_TTLS=1', 'IEEE8021X_EAPOL=1', 'PKCS12_FUNCS=1', '__FreeBSD__=1'],
> +                source = objs08_source)
> +    libbsd_use += ["objs08"]
> +    objs09_source = ['freebsd/contrib/tcpdump/addrtoname.c',
>                       'freebsd/contrib/tcpdump/addrtostr.c',
>                       'freebsd/contrib/tcpdump/af.c',
>                       'freebsd/contrib/tcpdump/ascii_strcasecmp.c',
> @@ -1570,13 +1675,13 @@ def build(bld):
>                       'freebsd/contrib/tcpdump/smbutil.c',
>                       'freebsd/contrib/tcpdump/tcpdump.c',
>                       'freebsd/contrib/tcpdump/util-print.c']
> -    bld.objects(target = "objs08",
> +    bld.objects(target = "objs09",
>                  features = "c",
>                  cflags = cflags,
>                  includes = ['freebsd/contrib/tcpdump', 'freebsd/usr.sbin/tcpdump/tcpdump'] + includes,
>                  defines = defines + ['HAVE_CONFIG_H=1', 'HAVE_NET_PFVAR_H=1', 'INET6', '_U_=__attribute__((unused))', '__FreeBSD__=1'],
> -                source = objs08_source)
> -    libbsd_use += ["objs08"]
> +                source = objs09_source)
> +    libbsd_use += ["objs09"]
>      source = ['freebsd/sys/arm/lpc/if_lpe.c',
>                'freebsd/sys/arm/lpc/lpc_pwr.c',
> @@ -2205,6 +2310,7 @@ def build(bld):
>                'rtemsbsd/rtems/rtems-bsd-shell-tcpdump.c',
>                'rtemsbsd/rtems/rtems-bsd-shell-vmstat.c',
>                'rtemsbsd/rtems/rtems-bsd-shell-wlanstats.c',
> +              'rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c',
>                'rtemsbsd/rtems/rtems-bsd-syscall-api.c',
>                'rtemsbsd/rtems/rtems-kernel-assert.c',
>                'rtemsbsd/rtems/rtems-kernel-autoconf.c',
> @@ -2246,6 +2352,7 @@ def build(bld):
>                'rtemsbsd/rtems/rtems-program-socket.c',
>                'rtemsbsd/rtems/rtems-program.c',
>                'rtemsbsd/rtems/rtems-routes.c',
> +              'rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c',
>                'rtemsbsd/rtems/syslog.c',
>                'rtemsbsd/sys/dev/atsam/if_atsam.c',
>                'rtemsbsd/sys/dev/atsam/if_atsam_media.c',
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index 082363a..f0ce1bd 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -61,6 +61,8 @@ SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
>  SYSINIT_MODULE_REFERENCE(wlan_sta);
>  SYSINIT_MODULE_REFERENCE(wlan_amrr);
>  SYSINIT_MODULE_REFERENCE(wlan_wep);
> +SYSINIT_MODULE_REFERENCE(wlan_tkip);
> +SYSINIT_MODULE_REFERENCE(wlan_ccmp);
>  SYSINIT_REFERENCE(rtwn_rtl8188eufw);
>  RTEMS_BSD_DRIVER_USB;
> diff --git a/rtemsbsd/include/machine/rtems-bsd-commands.h b/rtemsbsd/include/machine/rtems-bsd-commands.h
> index 9e9ed1c..03a09bc 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-commands.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-commands.h
> @@ -62,6 +62,8 @@ int rtems_bsd_command_route(int argc, char **argv);
>  int rtems_bsd_command_dhcpcd(int argc, char **argv);
> +int rtems_bsd_command_wpa_supplicant(int argc, char **argv);
>  int rtems_bsd_command_tcpdump(int argc, char **argv);
>  int rtems_bsd_command_sysctl(int argc, char **argv);
> diff --git a/rtemsbsd/include/machine/rtems-wpa_supplicant-mutex.h b/rtemsbsd/include/machine/rtems-wpa_supplicant-mutex.h
> new file mode 100644
> index 0000000..1abb177
> --- /dev/null
> +++ b/rtemsbsd/include/machine/rtems-wpa_supplicant-mutex.h
> @@ -0,0 +1,41 @@
> + * @file
> + * @ingroup rtems_bsd_machine
> + * @brief TODO.
> + * Copyright (c) 2017 Sichen Zhao.  All rights reserved.
> + *  <zsc19940506 at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_BSD_MACHINE_RTEMS_WPA_SUPPLICANT_MUTEX_H_
> +#define _RTEMS_BSD_MACHINE_RTEMS_WPA_SUPPLICANT_MUTEX_H_
> +extern struct mtx wpa_supplicant_mtx;
> +#endif /* _RTEMS_BSD_MACHINE_RTEMS_WPA_SUPPLICANT_MUTEX_H_ */
> diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
> index 515b265..046c859 100644
> --- a/rtemsbsd/include/rtems/netcmds-config.h
> +++ b/rtemsbsd/include/rtems/netcmds-config.h
> @@ -39,6 +39,8 @@ extern rtems_shell_cmd_t rtems_shell_HOSTNAME_Command;
>  extern rtems_shell_cmd_t rtems_shell_TCPDUMP_Command;
> +extern rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_Command;
>  extern rtems_shell_cmd_t rtems_shell_SYSCTL_Command;
>  extern rtems_shell_cmd_t rtems_shell_VMSTAT_Command;
> diff --git a/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c
> index 0000000..32ebb86
> --- /dev/null
> +++ b/rtemsbsd/rtems/rtems-bsd-shell-wpa_supplicant.c
> @@ -0,0 +1,36 @@
> + * are met:
> + * SUCH DAMAGE.
> +#include <rtems/netcmds-config.h>
> +rtems_shell_cmd_t rtems_shell_WPA_SUPPLICANT_Command = {
> +  .name = "wpa_supplicant",
> +  .usage = "wpa_supplicant [args]",
> +  .topic = "net",
> +  .command = rtems_bsd_command_wpa_supplicant
> diff --git a/rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c b/rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c
> index 0000000..737fd04
> --- /dev/null
> +++ b/rtemsbsd/rtems/rtems-wpa_supplicant_mutex.c
> @@ -0,0 +1,47 @@
> + * @file
> + * @ingroup rtems_bsd_rtems
> + * @brief TODO.
> + * Copyright (c) 2017, Sichen Zhao.  All rights reserved.
> + * are met:
> + * SUCH DAMAGE.
> +#include <machine/rtems-bsd-kernel-space.h>
> +#include <machine/rtems-bsd-thread.h>
> +#include <sys/types.h>
> +#include <sys/kernel.h>
> +#include <sys/lock.h>
> +#include <machine/rtems-wpa_supplicant-mutex.h>
> +struct mtx wpa_supplicant_mtx;
> +MTX_SYSINIT(wpa_supplicant_program, &wpa_supplicant_mtx, "WPA program", MTX_DEF);
