RTEMS milestones 4.13 and 5.0?
Joel Sherrill
joel at rtems.org
Sun Oct 15 00:13:23 UTC 2017
On Oct 12, 2017 11:37 PM, "Sebastian Huber" <
On 12/10/17 16:24, Chris Johns wrote:
> On 11/10/17 11:30 pm, Sebastian Huber wrote:
>> milestones 4.13 and 5.0 don't fit the new version scheme:
>> https://devel.rtems.org/wiki/Developer/Release#RTEMSRelease5
>> SeriesAndHigherNumbering
>> I suggest to rename the 5.0 milestone to 5.1 and move all 4.13 tickets to
>> 5.1.
>> A change to the major revision number requires a major change.
In the new version scheme the major number changes with every release.
The reality is
> 4.12 should be 5.0. The release and what it contains has grown
> considerable and
> we are currently attempting to converge on stability across all hosts and
> architectures before we branch. Looking at 4.12 now it appears to me to be
> a
> good 5.0 candidate so should this happen or is it too late?
> We have planned the move to 5.0 to be a build system change. The work to
> make
> this important and needed change is not small and I cannot do it without
> funding
> and I do not have any for this work. Moving to 5.0 after 4.12 without
> something
> major may result in a long wait while planned 5.0 changes are implemented.
> As a
> result we will have smaller things hanging on the development branch that
> should
> be released as we have with 4.12 now. We added 4.13 as a way to keep us
> keep
> moving with releases while we figure out now to make the build system
> change. I
> do not like having 4.13 but I do not see another path. Jumping to 5.0 is a
> solution.
Using 5.1 for the next release is probably less confusing for users since a
lot of stuff changed (current master would be 5.0.0, release is 5.1.0,
branch version after release is 5.1.1). Someone would have to do this
number change.
Historically we bumped the first digit on major architectural or feature
changes. IMO 4.11 should have been 5.0 due to addition of SMP. Now that it
is very optimized and we feel it is ready for production use, I think
bumping to 5.x is the right thing to do.
Sebastian Huber, embedd
<https://maps.google.com/?q=Huber,+embedd&entry=gmail&source=g>ed brains
GmbH
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171014/d11542e3/attachment.html>
