[PATCH] score: Rename watchdog variants
Mon Oct 16 06:02:29 UTC 2017
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
 cpukit/posix/include/rtems/posix/pthreadimpl.h  |  2 +-
 cpukit/posix/src/alarm.c                        |  4 ++--
 cpukit/posix/src/pthread.c                      |  4 ++--
 cpukit/posix/src/pthreadsetschedparam.c         |  2 +-
 cpukit/posix/src/timerdelete.c                  |  2 +-
 cpukit/posix/src/timersettime.c                 |  4 ++--
 cpukit/posix/src/ualarm.c                       |  6 +++---
 cpukit/rtems/src/eventseize.c                   |  2 +-
 cpukit/rtems/src/ratemoncancel.c                |  2 +-
 cpukit/rtems/src/ratemonperiod.c                |  2 +-
 cpukit/rtems/src/ratemontimeout.c               |  2 +-
 cpukit/rtems/src/taskwakeafter.c                |  2 +-
 cpukit/rtems/src/taskwakewhen.c                 |  2 +-
 cpukit/rtems/src/timercreate.c                  |  6 +++---
 cpukit/rtems/src/timerreset.c                   |  2 +-
 cpukit/score/include/rtems/score/percpu.h       | 22 +++++++++++++---------
 cpukit/score/include/rtems/score/threadimpl.h   | 14 +++++++-------
 cpukit/score/include/rtems/score/watchdogimpl.h | 20 ++++++++++----------
 cpukit/score/src/coretodset.c                   |  2 +-
 cpukit/score/src/threadqenqueue.c               |  4 ++--
 cpukit/score/src/watchdogtick.c                 |  4 ++--
 testsuites/sptests/spintrcritical08/init.c      |  4 ++--
 testsuites/sptests/spintrcritical09/init.c      |  2 +-
 23 files changed, 60 insertions(+), 56 deletions(-)
diff --git a/cpukit/posix/include/rtems/posix/pthreadimpl.h b/cpukit/posix/include/rtems/posix/pthreadimpl.h
index 055043105b..ddc5bb252b 100644
--- a/cpukit/posix/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/posix/include/rtems/posix/pthreadimpl.h
@@ -56,7 +56,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Threads_Sporadic_timer_insert(
   the_thread->cpu_time_budget =
     _Timespec_To_ticks( &api->schedparam.sched_ss_init_budget );
-  _Watchdog_Per_CPU_insert_relative(
+  _Watchdog_Per_CPU_insert_monotonic(
     &api->Sporadic.Timer,
     _Per_CPU_Get(),
     _Timespec_To_ticks( &api->schedparam.sched_ss_repl_period )
diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
index dcc56431ea..fcf8c1569a 100644
--- a/cpukit/posix/src/alarm.c
+++ b/cpukit/posix/src/alarm.c
@@ -77,14 +77,14 @@ unsigned int alarm(
   now = cpu->Watchdog.ticks;
   remaining = (unsigned long) _Watchdog_Cancel(
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ],
+    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ],
     the_watchdog,
     now
   if ( ticks != 0 ) {
     _Watchdog_Insert(
       the_watchdog,
       now + ticks
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 107172a557..30b830cd85 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -69,7 +69,7 @@ void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog )
     _Priority_Node_set_inactive( &api->Sporadic.Low_priority );
-  _Watchdog_Per_CPU_remove_relative( &api->Sporadic.Timer );
+  _Watchdog_Per_CPU_remove_monotonic( &api->Sporadic.Timer );
   _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
   _Thread_Wait_release( the_thread, &queue_context );
@@ -165,7 +165,7 @@ static void _POSIX_Threads_Terminate_extension( Thread_Control *executing )
   _Thread_State_acquire( executing, &lock_context );
   if ( api->schedpolicy == SCHED_SPORADIC ) {
   _Thread_State_release( executing, &lock_context );
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 38bb0ad21e..3bd5bc4f3a 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -69,7 +69,7 @@ static int _POSIX_Set_sched_param(
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
   _Priority_Node_set_priority( &the_thread->Real_priority, core_normal_prio );
diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
index 5301a708c9..5c21e1e80d 100644
--- a/cpukit/posix/src/timerdelete.c
+++ b/cpukit/posix/src/timerdelete.c
@@ -56,7 +56,7 @@ int timer_delete(
     cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
     ptimer->state = POSIX_TIMER_STATE_FREE;
     _Watchdog_Remove(
       &ptimer->Timer
     _POSIX_Timer_Release( cpu, &lock_context );
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 1f98a7a08c..381e5002ce 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -42,7 +42,7 @@ static void _POSIX_Timer_Insert(
   _TOD_Get( &ptimer->time );
   _Watchdog_Insert(
     &ptimer->Timer,
     cpu->Watchdog.ticks + ticks
@@ -152,7 +152,7 @@ int timer_settime(
     /* Stop the timer */
     _Watchdog_Remove(
       &ptimer->Timer
diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
index 86fe1b05cc..1626153651 100644
--- a/cpukit/posix/src/ualarm.c
+++ b/cpukit/posix/src/ualarm.c
@@ -55,7 +55,7 @@ static void _POSIX_signals_Ualarm_TSR( Watchdog_Control *the_watchdog )
    * If the reset interval is non-zero, reschedule ourselves.
   if ( _POSIX_signals_Ualarm_interval != 0 ) {
       the_watchdog,
       _Per_CPU_Get(),
@@ -107,7 +107,7 @@ useconds_t ualarm(
   remaining = (useconds_t) _Watchdog_Cancel(
     the_watchdog,
     now
@@ -118,7 +118,7 @@ useconds_t ualarm(
     cpu = _Per_CPU_Get();
     _Watchdog_Set_CPU( the_watchdog, cpu );
     _Watchdog_Insert(
       the_watchdog,
       now + ticks_initial
diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
index 696481c2f5..76f9356800 100644
--- a/cpukit/rtems/src/eventseize.c
+++ b/cpukit/rtems/src/eventseize.c
@@ -81,7 +81,7 @@ rtems_status_code _Event_Seize(
   _Thread_Wait_release_default( executing, lock_context );
   if ( ticks ) {
-    _Thread_Timer_insert_relative(
+    _Thread_Timer_insert_monotonic(
       executing,
       cpu_self,
       _Thread_Timeout,
diff --git a/cpukit/rtems/src/ratemoncancel.c b/cpukit/rtems/src/ratemoncancel.c
index cb95f54408..0a88310d09 100644
--- a/cpukit/rtems/src/ratemoncancel.c
+++ b/cpukit/rtems/src/ratemoncancel.c
@@ -32,7 +32,7 @@ void _Rate_monotonic_Cancel(
   _Rate_monotonic_Acquire_critical( the_period, lock_context );
-  _Watchdog_Per_CPU_remove_relative( &the_period->Timer );
+  _Watchdog_Per_CPU_remove_monotonic( &the_period->Timer );
   the_period->state = RATE_MONOTONIC_INACTIVE;
   _Scheduler_Cancel_job(
     the_period->owner,
diff --git a/cpukit/rtems/src/ratemonperiod.c b/cpukit/rtems/src/ratemonperiod.c
index efcd121584..511e46c21b 100644
--- a/cpukit/rtems/src/ratemonperiod.c
+++ b/cpukit/rtems/src/ratemonperiod.c
@@ -101,7 +101,7 @@ static void _Rate_monotonic_Release_job(
   cpu_self = _Thread_Dispatch_disable_critical( lock_context );
-  deadline = _Watchdog_Per_CPU_insert_relative(
+  deadline = _Watchdog_Per_CPU_insert_monotonic(
     &the_period->Timer,
     cpu_self,
     next_length
diff --git a/cpukit/rtems/src/ratemontimeout.c b/cpukit/rtems/src/ratemontimeout.c
index 5a838fd916..b920c48789 100644
--- a/cpukit/rtems/src/ratemontimeout.c
+++ b/cpukit/rtems/src/ratemontimeout.c
@@ -36,7 +36,7 @@ static void _Rate_monotonic_Renew_deadline(
   the_period->state = RATE_MONOTONIC_EXPIRED;
     &the_period->Timer,
     _Per_CPU_Get(),
     the_period->next_length
diff --git a/cpukit/rtems/src/taskwakeafter.c b/cpukit/rtems/src/taskwakeafter.c
index faf4a835cd..43bf612f61 100644
--- a/cpukit/rtems/src/taskwakeafter.c
+++ b/cpukit/rtems/src/taskwakeafter.c
@@ -41,7 +41,7 @@ rtems_status_code rtems_task_wake_after(
     } else {
       _Thread_Set_state( executing, STATES_WAITING_FOR_TIME );
       _Thread_Wait_flags_set( executing, THREAD_WAIT_STATE_BLOCKED );
         executing,
         cpu_self,
         _Thread_Timeout,
diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
index 5d6d45afcf..ac92ea875e 100644
--- a/cpukit/rtems/src/taskwakewhen.c
+++ b/cpukit/rtems/src/taskwakewhen.c
@@ -52,7 +52,7 @@ rtems_status_code rtems_task_wake_when(
     executing = _Thread_Executing;
-    _Thread_Timer_insert_absolute(
+    _Thread_Timer_insert_realtime(
       executing,
       cpu_self,
       _Thread_Timeout,
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index fc6d43e6dc..444b07cfa5 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -29,7 +29,7 @@
 RTEMS_STATIC_ASSERT(
-  PER_CPU_WATCHDOG_ABSOLUTE == TIMER_CLASS_BIT_TIME_OF_DAY,
+  PER_CPU_WATCHDOG_REALTIME == TIMER_CLASS_BIT_TIME_OF_DAY,
@@ -72,13 +72,13 @@ rtems_status_code _Timer_Fire(
     if ( _Timer_Is_interval_class( the_class ) ) {
       _Watchdog_Insert(
         &the_timer->Ticker,
         cpu->Watchdog.ticks + interval
     } else {
       _Watchdog_Insert(
-        &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_ABSOLUTE ],
+        &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ],
         &the_timer->Ticker,
         _Watchdog_Ticks_from_seconds( interval )
diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
index a4090152b3..3718fffa66 100644
--- a/cpukit/rtems/src/timerreset.c
+++ b/cpukit/rtems/src/timerreset.c
@@ -37,7 +37,7 @@ rtems_status_code rtems_timer_reset(
     if ( _Timer_Is_interval_class( the_timer->the_class ) ) {
       _Timer_Cancel( cpu, the_timer );
       _Watchdog_Insert(
         &the_timer->Ticker,
         cpu->Watchdog.ticks + the_timer->initial
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 97cb2bea15..00528b5ce3 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -248,20 +248,23 @@ typedef struct {
 typedef enum {
-   * @brief Index for relative per-CPU watchdog header.
+   * @brief Index for monotonic clock per-CPU watchdog header.
-   * The reference time point for this header is current ticks value
-   * during insert.  Time is measured in clock ticks.
+   * The reference time point for the monotonic clock is the system start.  The
+   * clock resolution is one system clock tick.  It is used for the system
+   * clock tick based time services and the POSIX services using
+   * CLOCK_MONOTONIC.
-  PER_CPU_WATCHDOG_RELATIVE,
+  PER_CPU_WATCHDOG_MONOTONIC,
-   * @brief Index for absolute per-CPU watchdog header.
+   * @brief Index for realtime clock per-CPU watchdog header.
-   * The reference time point for this header is the POSIX Epoch.  Time is
-   * measured in nanoseconds since POSIX Epoch.
+   * The reference time point for the realtime clock is the POSIX Epoch.  The
+   * clock resolution is one nanosecond.  It is used for the time of day
+   * services and the POSIX services using CLOCK_REALTIME.
-  PER_CPU_WATCHDOG_ABSOLUTE,
+  PER_CPU_WATCHDOG_REALTIME,
    * @brief Count of per-CPU watchdog headers.
@@ -395,7 +398,8 @@ typedef struct Per_CPU_Control {
     ISR_LOCK_MEMBER( Lock )
-     * @brief Watchdog ticks on this processor used for relative watchdogs.
+     * @brief Watchdog ticks on this processor used for monotonic clock
+     * watchdogs.
     uint64_t ticks;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 60c7759e09..67de07e5a2 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1853,11 +1853,11 @@ RTEMS_INLINE_ROUTINE void _Thread_Timer_initialize(
   _ISR_lock_Initialize( &timer->Lock, "Thread Timer" );
-  timer->header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ];
+  timer->header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
   _Watchdog_Preinitialize( &timer->Watchdog, cpu );
-RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_relative(
+RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_monotonic(
   Thread_Control                 *the_thread,
   Per_CPU_Control                *cpu,
   Watchdog_Service_routine_entry  routine,
@@ -1869,14 +1869,14 @@ RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_relative(
   _ISR_lock_ISR_disable_and_acquire( &the_thread->Timer.Lock, &lock_context );
   the_thread->Timer.header =
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ];
+    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
   the_thread->Timer.Watchdog.routine = routine;
-  _Watchdog_Per_CPU_insert_relative( &the_thread->Timer.Watchdog, cpu, ticks );
+  _Watchdog_Per_CPU_insert_monotonic( &the_thread->Timer.Watchdog, cpu, ticks );
   _ISR_lock_Release_and_ISR_enable( &the_thread->Timer.Lock, &lock_context );
-RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_absolute(
+RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_realtime(
@@ -1888,9 +1888,9 @@ RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_absolute(
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_ABSOLUTE ];
+    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
-  _Watchdog_Per_CPU_insert_absolute( &the_thread->Timer.Watchdog, cpu, expire );
+  _Watchdog_Per_CPU_insert_realtime( &the_thread->Timer.Watchdog, cpu, expire );
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index f6ad05cd8a..e248bcc061 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -351,7 +351,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_release_critical(
   _ISR_lock_Release( &cpu->Watchdog.Lock, lock_context );
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_relative(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_monotonic(
   Watchdog_Control  *the_watchdog,
   Watchdog_Interval  ticks
@@ -361,7 +361,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_relative(
   Watchdog_Header  *header;
   uint64_t          expire;
-  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ];
+  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
@@ -372,7 +372,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_relative(
   return expire;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_absolute(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_realtime(
   uint64_t          expire
@@ -381,7 +381,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_absolute(
   ISR_lock_Context  lock_context;
-  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_ABSOLUTE ];
+  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
@@ -407,7 +407,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove(
   _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_relative(
+RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_monotonic(
@@ -417,11 +417,11 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_relative(
     the_watchdog,
     cpu,
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_absolute(
+RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_realtime(
@@ -431,11 +431,11 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_absolute(
     the_watchdog,
     cpu,
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_tickle_absolute(
+RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_tickle_realtime(
   uint64_t         now
@@ -444,7 +444,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_tickle_absolute(
   _ISR_lock_ISR_disable_and_acquire( &cpu->Watchdog.Lock, &lock_context );
   _Watchdog_Tickle(
     now,
     &lock_context
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index 80b0b762bd..beda8c69b8 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -43,7 +43,7 @@ void _TOD_Set(
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
     Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
-    _Watchdog_Per_CPU_tickle_absolute( cpu, tod_as_ticks );
+    _Watchdog_Per_CPU_tickle_realtime( cpu, tod_as_ticks );
   _TOD.is_set = true;
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 1f5a9c1660..df1bea02cb 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -385,7 +385,7 @@ static void _Thread_queue_Timeout(
     case WATCHDOG_RELATIVE:
       /* A relative timeout of 0 is a special case indefinite (no) timeout */
       if ( queue_context->timeout != 0 ) {
           the_thread,
           cpu_self,
           _Thread_Timeout,
@@ -394,7 +394,7 @@ static void _Thread_queue_Timeout(
       break;
     case WATCHDOG_ABSOLUTE:
         the_thread,
         cpu_self,
         _Thread_Timeout,
diff --git a/cpukit/score/src/watchdogtick.c b/cpukit/score/src/watchdogtick.c
index ab7eadcf1d..e1c5a30f8a 100644
--- a/cpukit/score/src/watchdogtick.c
+++ b/cpukit/score/src/watchdogtick.c
@@ -76,14 +76,14 @@ void _Watchdog_Tick( Per_CPU_Control *cpu )
   cpu->Watchdog.ticks = ticks;
   _Watchdog_Tickle(
     ticks,
     &lock_context
   _Timecounter_Getnanotime( &now );
     cpu,
     _Watchdog_Ticks_from_timespec( &now )
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 8d17feb365..1a7ed2d2e5 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -45,7 +45,7 @@ static rtems_timer_service_routine test_release_from_isr(
   Per_CPU_Control *cpu = _Per_CPU_Get();
-  Watchdog_Header *header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ];
+  Watchdog_Header *header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
   Watchdog_Control *watchdog = (Watchdog_Control *) header->first;
   if (
@@ -55,7 +55,7 @@ static rtems_timer_service_routine test_release_from_isr(
     Thread_Wait_flags flags = _Thread_Wait_flags_get( thread );
-    _Watchdog_Per_CPU_remove_relative( watchdog );
+    _Watchdog_Per_CPU_remove_monotonic( watchdog );
     rtems_test_assert( getState() == RATE_MONOTONIC_ACTIVE );
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index 44eccc7821..87c1c1aab3 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -39,7 +39,7 @@ static rtems_timer_service_routine test_release_from_isr(
   Per_CPU_Control *cpu_self = _Per_CPU_Get();
-  Watchdog_Header *header = &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_RELATIVE ];
+  Watchdog_Header *header = &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
   if (
2.12.3
