[PATCH 3/3] posix: Simplify _POSIX_Threads_Create_extension()
Tue Oct 17 10:11:55 UTC 2017
Move unblocked signals initialization to pthread_create().
Update #2514.
 cpukit/posix/src/pthread.c       | 17 -----------------
 cpukit/posix/src/pthreadcreate.c |  4 ++++
 2 files changed, 4 insertions(+), 17 deletions(-)
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 8bd44ca03a..ba394b4924 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -122,26 +122,9 @@ static bool _POSIX_Threads_Create_extension(
   POSIX_API_Control *api;
-  POSIX_API_Control *executing_api;
   api = created->API_Extensions[ THREAD_API_POSIX ];
-   *  If the thread is not a posix thread, then all posix signals are blocked
-   *  by default.
-   *  The check for class == 1 is debug.  Should never really happen.
-  RTEMS_STATIC_ASSERT( SIGNAL_EMPTY_MASK == 0, signals_pending );
-  if ( _Objects_Get_API( created->Object.id ) == OBJECTS_POSIX_API
-       #if defined(RTEMS_DEBUG)
-         && _Objects_Get_class( created->Object.id ) == 1
-       #endif
-    executing_api = _Thread_Get_executing()->API_Extensions[ THREAD_API_POSIX ];
-    api->signals_unblocked = executing_api->signals_unblocked;
   api->Sporadic.thread = created;
   _Watchdog_Preinitialize( &api->Sporadic.Timer, _Per_CPU_Get_by_index( 0 ) );
   _Watchdog_Initialize( &api->Sporadic.Timer, _POSIX_Threads_Sporadic_timer );
diff --git a/cpukit/posix/src/pthreadcreate.c b/cpukit/posix/src/pthreadcreate.c
index 0de566f7c2..2315b7f5ee 100644
--- a/cpukit/posix/src/pthreadcreate.c
+++ b/cpukit/posix/src/pthreadcreate.c
@@ -74,6 +74,7 @@ int pthread_create(
   Thread_Control                     *executing;
   const Scheduler_Control            *scheduler;
+  const POSIX_API_Control            *executing_api;
   int                                 schedpolicy = SCHED_RR;
   struct sched_param                  schedparam;
   Objects_Name                        name;
@@ -237,6 +238,9 @@ int pthread_create(
    *  finish initializing the per API structure
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
+  executing_api = executing->API_Extensions[ THREAD_API_POSIX ];
+  api->signals_unblocked = executing_api->signals_unblocked;
   api->created_with_explicit_scheduler =
     ( the_attr->inheritsched == PTHREAD_EXPLICIT_SCHED );
2.12.3
