[PATCH 07/16] score: Rename _Watchdog_Ticks_from_*()
Mon Oct 23 13:53:38 UTC 2017
Rename _Watchdog_Ticks_from_*() to _Watchdog_Realtime_from_*().
This highlights that these routines are used for the CLOCK_REALTIME
watchdogs (in contrast to CLOCK_MONOTONIC).
Update #3117.
Update #3182.
 cpukit/posix/src/nanosleep.c                    | 4 ++--
 cpukit/rtems/src/taskwakewhen.c                 | 2 +-
 cpukit/rtems/src/timercreate.c                  | 2 +-
 cpukit/score/include/rtems/score/watchdogimpl.h | 6 +++---
 cpukit/score/src/coretodset.c                   | 2 +-
 cpukit/score/src/watchdogtick.c                 | 2 +-
 6 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 13f4536f6e..b2c169373a 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -152,7 +152,7 @@ int nanosleep(
   if ( err != 0 )
     return -1;
   _Timespec_Add_to( &now, rqtp );
-  ticks = _Watchdog_Ticks_from_timespec( &now );
+  ticks = _Watchdog_Realtime_from_timespec( &now );
   err = nanosleep_helper( CLOCK_REALTIME,
       ticks,
       &now,
@@ -209,7 +209,7 @@ int clock_nanosleep(
   _Timespec_Add_to( &timeout, rqtp );
   if ( clock_id == CLOCK_REALTIME ) {
-    ticks = _Watchdog_Ticks_from_timespec( &timeout );
+    ticks = _Watchdog_Realtime_from_timespec( &timeout );
         clock_id,
         ticks,
diff --git a/cpukit/rtems/src/taskwakewhen.c b/cpukit/rtems/src/taskwakewhen.c
index ac92ea875e..228dd98052 100644
--- a/cpukit/rtems/src/taskwakewhen.c
+++ b/cpukit/rtems/src/taskwakewhen.c
@@ -56,7 +56,7 @@ rtems_status_code rtems_task_wake_when(
       executing,
       cpu_self,
       _Thread_Timeout,
-      _Watchdog_Ticks_from_seconds( seconds )
+      _Watchdog_Realtime_from_seconds( seconds )
   _Thread_Dispatch_enable( cpu_self );
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index 444b07cfa5..42492c2f67 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -80,7 +80,7 @@ rtems_status_code _Timer_Fire(
       _Watchdog_Insert(
         &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ],
         &the_timer->Ticker,
-        _Watchdog_Ticks_from_seconds( interval )
+        _Watchdog_Realtime_from_seconds( interval )
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 89a7e7d602..f1693a3a14 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -293,7 +293,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Next_first(
 #define WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Realtime_from_seconds(
   uint32_t seconds
@@ -304,7 +304,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds(
   return ticks;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Realtime_from_timespec(
   const struct timespec *ts
@@ -324,7 +324,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
   return ticks;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_sbintime(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Realtime_from_sbintime(
   sbintime_t sbt
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index beda8c69b8..1223f5c7aa 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -37,7 +37,7 @@ void _TOD_Set(
   timespec2bintime( tod, &tod_as_bintime );
   _Timecounter_Set_clock( &tod_as_bintime, lock_context );
-  tod_as_ticks = _Watchdog_Ticks_from_timespec( tod );
+  tod_as_ticks = _Watchdog_Realtime_from_timespec( tod );
   cpu_count = _SMP_Get_processor_count();
   for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
diff --git a/cpukit/score/src/watchdogtick.c b/cpukit/score/src/watchdogtick.c
index e1c5a30f8a..3384ea60f3 100644
--- a/cpukit/score/src/watchdogtick.c
+++ b/cpukit/score/src/watchdogtick.c
@@ -85,7 +85,7 @@ void _Watchdog_Tick( Per_CPU_Control *cpu )
   _Timecounter_Getnanotime( &now );
   _Watchdog_Per_CPU_tickle_realtime(
     cpu,
-    _Watchdog_Ticks_from_timespec( &now )
+    _Watchdog_Realtime_from_timespec( &now )
   _Scheduler_Tick( cpu );
2.12.3
