[PATCH 02/16] psxclockrealtime01: New test
Mon Oct 23 13:53:33 UTC 2017
Update #3182.
 testsuites/psxtests/Makefile.am                    |   1 +
 testsuites/psxtests/configure.ac                   |   1 +
 testsuites/psxtests/psxclockrealtime01/Makefile.am |  19 +
 testsuites/psxtests/psxclockrealtime01/init.c      | 602 +++++++++++++++++++++
 .../psxclockrealtime01/psxclockrealtime01.doc      |  20 +
 .../psxclockrealtime01/psxclockrealtime01.scn      |  57 ++
 6 files changed, 700 insertions(+)
 create mode 100644 testsuites/psxtests/psxclockrealtime01/Makefile.am
 create mode 100644 testsuites/psxtests/psxclockrealtime01/init.c
 create mode 100644 testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
 create mode 100644 testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index cccdb39118..2a74470d60 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -36,6 +36,7 @@ endif
 _SUBDIRS += psxclock
 if HAS_POSIX
 _SUBDIRS += psxclock01
+_SUBDIRS += psxclockrealtime01
 _SUBDIRS += psxconcurrency01
 _SUBDIRS += psxcond01
 _SUBDIRS += psxcond02
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 96a0149302..7243bfdbb5 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -140,6 +140,7 @@ psxcleanup01/Makefile
 psxcleanup02/Makefile
 psxclock/Makefile
 psxclock01/Makefile
+psxclockrealtime01/Makefile
 psxconcurrency01/Makefile
 psxcond01/Makefile
 psxcond02/Makefile
diff --git a/testsuites/psxtests/psxclockrealtime01/Makefile.am b/testsuites/psxtests/psxclockrealtime01/Makefile.am
new file mode 100644
index 0000000000..d0b1a76dbe
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = psxclockrealtime01
+psxclockrealtime01_SOURCES = init.c
+dist_rtems_tests_DATA = psxclockrealtime01.scn psxclockrealtime01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxclockrealtime01_OBJECTS)
+LINK_LIBS = $(psxclockrealtime01_LDLIBS)
+psxclockrealtime01$(EXEEXT): $(psxclockrealtime01_OBJECTS) $(psxclockrealtime01_DEPENDENCIES)
+	@rm -f psxclockrealtime01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxclockrealtime01/init.c b/testsuites/psxtests/psxclockrealtime01/init.c
index 0000000000..3404ee5919
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/init.c
@@ -0,0 +1,602 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+ * This test program runs also on GNU/Linux.  Use
+ * cc init.c -pthread -Wall -Wextra -lrt && sudo ./a.out
+ * to run it.  It must run probably as root for the clock_settime().
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <sys/stat.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <inttypes.h>
+#include <limits.h>
+#include <mqueue.h>
+#include <pthread.h>
+#include <semaphore.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <string.h>
+#include <time.h>
+#include <unistd.h>
+#ifdef __rtems__
+#include "tmacros.h"
+#else /* __rtems__ */
+#include <assert.h>
+#define rtems_test_assert(x) assert(x)
+#endif /* __rtems__ */
+static void assert_eno(const char *hint, int eno, int expected_eno)
+  const char *warn;
+  if (eno != expected_eno) {
+    warn = "WARNING: ";
+  } else {
+    warn = "";
+  printf(
+    "%s%s: actual '%s', expected '%s'\n",
+    warn,
+    hint,
+    strerror(eno),
+    strerror(expected_eno)
+#ifdef __rtems__
+  rtems_test_assert(eno == expected_eno);
+static void assert_rv(const char *hint, int rv, int expected_eno)
+  int eno;
+  if (rv != 0) {
+    eno = errno;
+  } else {
+    eno = 0;
+  assert_eno(hint, eno, expected_eno);
+typedef struct {
+  char data;
+} test_msg;
+#define MSG_COUNT 1
+#define MSG_SIZE sizeof(test_msg)
+typedef struct {
+  int value;
+  pthread_mutex_t mtx;
+  pthread_cond_t cnd;
+} event;
+typedef enum {
+  ACTION_NONE,
+  ACTION_MTX_LOCK,
+  ACTION_CND_WAIT,
+  ACTION_RW_RDLOCK,
+  ACTION_RW_WRLOCK,
+  ACTION_SEM_WAIT,
+  ACTION_MQ_SEND,
+  ACTION_MQ_RECV,
+  ACTION_CLOCK_NANOSLEEP,
+  ACTION_TERMINATE
+} test_action;
+typedef enum {
+  MODE_TIMEOUT_FINITE,
+  MODE_TIMEOUT_NEGATIVE_SEC,
+  MODE_TIMEOUT_NEGATIVE_NSEC,
+  MODE_TIMEOUT_NEGATIVE_SEC_NSEC,
+  MODE_TIMEOUT_HUGE_NSEC,
+#ifdef __rtems__
+  MODE_TIMEOUT_NULL,
+  MODE_TIMEOUT_PRACTICALLY_INFINITE,
+  MODE_COUNT
+} test_mode;
+typedef struct {
+  test_mode mode;
+  pthread_t worker;
+  event action;
+  event done;
+  pthread_mutex_t mtx2;
+  pthread_rwlock_t rw;
+  sem_t sem;
+  mqd_t mq;
+  int counter[ACTION_TERMINATE + 1];
+} test_context;
+static test_context test_instance;
+static void event_init(event *e)
+  int eno;
+  eno = pthread_mutex_init(&e->mtx, NULL);
+  rtems_test_assert(eno == 0);
+  eno = pthread_cond_init(&e->cnd, NULL);
+static void event_destroy(event *e)
+  int eno;
+  eno = pthread_mutex_destroy(&e->mtx);
+  eno = pthread_cond_destroy(&e->cnd);
+static void event_post(event *e, int value)
+  int eno;
+  eno = pthread_mutex_lock(&e->mtx);
+  e->value = value;
+  eno = pthread_cond_signal(&e->cnd);
+  eno = pthread_mutex_unlock(&e->mtx);
+static int event_get(event *e)
+  int eno;
+  int value;
+  while (true) {
+    value = e->value;
+    if (value != 0) {
+      e->value = 0;
+      break;
+    eno = pthread_cond_wait(&e->cnd, &e->mtx);
+  return value;
+static void *worker(void *arg)
+  test_context *ctx;
+  test_action action;
+  test_mode mode;
+  int eno;
+  int unused;
+  ctx = arg;
+  mode = ctx->mode;
+  eno = pthread_setcancelstate(PTHREAD_CANCEL_ENABLE, &unused);
+  eno = pthread_setcanceltype(PTHREAD_CANCEL_ASYNCHRONOUS, &unused);
+  while ((action = event_get(&ctx->action)) != ACTION_TERMINATE) {
+    int rv;
+    struct timespec to_storage;
+    const struct timespec *to;
+    int expected_eno;
+    test_msg msg;
+    unsigned prio;
+    switch (mode) {
+      case MODE_TIMEOUT_FINITE:
+        rv = clock_gettime(CLOCK_REALTIME, &to_storage);
+        rtems_test_assert(rv == 0);
+        to_storage.tv_sec += 3600;
+        to = &to_storage;
+        expected_eno = ETIMEDOUT;
+        break;
+      case MODE_TIMEOUT_NEGATIVE_SEC:
+        to_storage.tv_sec = -1;
+        to_storage.tv_nsec = 1;
+        to = &to_storage;
+        break;
+      case MODE_TIMEOUT_NEGATIVE_NSEC:
+        to_storage.tv_sec = 1;
+        to_storage.tv_nsec = -1;
+        to = &to_storage;
+        expected_eno = EINVAL;
+        break;
+      case MODE_TIMEOUT_NEGATIVE_SEC_NSEC:
+        to = &to_storage;
+        break;
+      case MODE_TIMEOUT_HUGE_NSEC:
+        to_storage.tv_nsec = LONG_MAX;
+        to = &to_storage;
+        break;
+#ifdef __rtems__
+      case MODE_TIMEOUT_NULL:
+        to = NULL;
+        break;
+      case MODE_TIMEOUT_PRACTICALLY_INFINITE:
+        to_storage.tv_sec = INT64_MAX;
+        to_storage.tv_nsec = 999999999;
+        to = &to_storage;
+        expected_eno = -1;
+        break;
+      default:
+        rtems_test_assert(0);
+        break;
+    switch (action) {
+      case ACTION_MTX_LOCK:
+        eno = pthread_mutex_timedlock(&ctx->mtx, to);
+        assert_eno("pthread_mutex_timedlock", eno, expected_eno);
+        break;
+      case ACTION_CND_WAIT:
+        eno = pthread_mutex_lock(&ctx->mtx2);
+        eno = pthread_cond_timedwait(&ctx->cnd, &ctx->mtx2, to);
+        assert_eno("pthread_cond_timedwait", eno, expected_eno);
+        eno = pthread_mutex_unlock(&ctx->mtx2);
+        break;
+      case ACTION_RW_RDLOCK:
+        eno = pthread_rwlock_timedrdlock(&ctx->rw, to);
+        assert_eno("pthread_rwlock_timedrdlock", eno, expected_eno);
+        break;
+      case ACTION_RW_WRLOCK:
+        eno = pthread_rwlock_timedwrlock(&ctx->rw, to);
+        assert_eno("pthread_rwlock_timedwrlock", eno, expected_eno);
+        break;
+      case ACTION_SEM_WAIT:
+        errno = 0;
+        rv = sem_timedwait(&ctx->sem, to);
+        assert_rv("sem_timedwait", rv, expected_eno);
+        break;
+      case ACTION_MQ_SEND:
+        msg.data = 13;
+        rv = mq_send(ctx->mq, &msg.data, sizeof(msg), 7);
+        msg.data = 31;
+        errno = 0;
+        rv = mq_timedsend(ctx->mq, &msg.data, sizeof(msg), 5, to);
+        assert_rv("mq_timedsend", rv, expected_eno);
+        break;
+      case ACTION_MQ_RECV:
+        msg.data = 0;
+        prio = 0;
+        rv = mq_receive(ctx->mq, &msg.data, sizeof(msg), &prio);
+        rtems_test_assert(rv == 1);
+        rtems_test_assert(msg.data == 13);
+        rtems_test_assert(prio == 7);
+        msg.data = 0;
+        prio = 0;
+        errno = 0;
+        rv = mq_timedreceive(ctx->mq, &msg.data, sizeof(msg), &prio, to);
+        assert_rv("mq_timedreceive", rv, expected_eno);
+        rtems_test_assert(msg.data == 0);
+        rtems_test_assert(prio == 0);
+        break;
+      case ACTION_CLOCK_NANOSLEEP:
+        rv = clock_nanosleep(CLOCK_REALTIME, TIMER_ABSTIME, to, NULL);
+        if (expected_eno == ETIMEDOUT) {
+          assert_rv("clock_nanosleep", rv, 0);
+        } else {
+          assert_rv("clock_nanosleep", rv, expected_eno);
+        break;
+      default:
+        break;
+    ++ctx->counter[action];
+    event_post(&ctx->done, 1);
+  return ctx;
+static void delay(void)
+  int rv;
+  rv = usleep(100000);
+static void run(
+  test_context *ctx,
+  const char *test,
+  test_mode mode,
+  void (*f)(void)
+  int eno;
+  void *status;
+  printf("*** %s ***\n", test);
+  ctx->mode = mode;
+  eno = pthread_create(&ctx->worker, NULL, worker, ctx);
+  for (action = ACTION_MTX_LOCK; action < ACTION_TERMINATE; ++action) {
+    event_post(&ctx->action, action);
+    delay();
+    (*f)();
+    event_get(&ctx->done);
+  event_post(&ctx->action, ACTION_TERMINATE);
+  status = NULL;
+  eno = pthread_join(ctx->worker, &status);
+  rtems_test_assert(status == ctx);
+static void timeout_finite(void)
+  struct timespec now;
+  int rv;
+  rv = clock_gettime(CLOCK_REALTIME, &now);
+  now.tv_sec += 7200;
+  rv = clock_settime(CLOCK_REALTIME, &now);
+static void test_timeout_finite(test_context *ctx)
+  run(ctx, "timeout finite", MODE_TIMEOUT_FINITE, timeout_finite);
+static void do_nothing(void)
+  /* Do nothing */
+static void test_timeout_negative_sec(test_context *ctx)
+  run(ctx, "timeout negative sec", MODE_TIMEOUT_NEGATIVE_SEC, do_nothing);
+static void test_timeout_negative_nsec(test_context *ctx)
+  run(ctx, "timout negative nsec", MODE_TIMEOUT_NEGATIVE_NSEC, do_nothing);
+static void test_timeout_negative_sec_nsec(test_context *ctx)
+  run(
+    ctx,
+    "timout negative sec and nsec",
+    do_nothing
+static void test_timeout_huge_nsec(test_context *ctx)
+  run(ctx, "timout huge nsec", MODE_TIMEOUT_HUGE_NSEC, do_nothing);
+#ifdef __rtems__
+static void test_timeout_null(test_context *ctx)
+  run(ctx, "timeout NULL", MODE_TIMEOUT_NULL, do_nothing);
+static void test_timeout_practically_infinite(test_context *ctx)
+  int eno;
+  puts("*** timeout practically infinite ***");
+  ctx->mode = MODE_TIMEOUT_PRACTICALLY_INFINITE;
+    void *status;
+    delay();
+    eno = pthread_cancel(ctx->worker);
+    status = NULL;
+    rtems_test_assert(status == PTHREAD_CANCELED);
+static void test(test_context *ctx)
+  int eno;
+  int rv;
+  mode_t mode;
+  struct mq_attr ma;
+  event_init(&ctx->action);
+  event_init(&ctx->done);
+  eno = pthread_mutex_init(&ctx->mtx, NULL);
+  eno = pthread_mutex_lock(&ctx->mtx);
+  eno = pthread_mutex_init(&ctx->mtx2, NULL);
+  eno = pthread_cond_init(&ctx->cnd, NULL);
+  eno = pthread_rwlock_init(&ctx->rw, NULL);
+  eno = pthread_rwlock_wrlock(&ctx->rw);
+  rv = sem_init(&ctx->sem, 0, 0);
+  mode = S_IRWXU | S_IRWXG | S_IRWXO;
+  memset(&ma, 0, sizeof(ma));
+  ma.mq_maxmsg = MSG_COUNT;
+  ma.mq_msgsize = MSG_SIZE;
+  ctx->mq = mq_open("/mq", O_CREAT | O_RDWR, mode, &ma);
+  rtems_test_assert(ctx->mq != (mqd_t) -1);
+  test_timeout_finite(ctx);
+  test_timeout_negative_sec(ctx);
+  test_timeout_negative_nsec(ctx);
+  test_timeout_negative_sec_nsec(ctx);
+  test_timeout_huge_nsec(ctx);
+#ifdef __rtems__
+  test_timeout_null(ctx);
+  test_timeout_practically_infinite(ctx);
+  event_destroy(&ctx->action);
+  event_destroy(&ctx->done);
+  eno = pthread_mutex_unlock(&ctx->mtx);
+  eno = pthread_mutex_destroy(&ctx->mtx);
+  eno = pthread_mutex_destroy(&ctx->mtx2);
+#ifdef __rtems__
+  rtems_test_assert(eno == 0 || eno == EBUSY);
+  eno = pthread_cond_destroy(&ctx->cnd);
+  eno = pthread_rwlock_unlock(&ctx->rw);
+  eno = pthread_rwlock_destroy(&ctx->rw);
+  rv = sem_destroy(&ctx->sem);
+  rv = mq_close(ctx->mq);
+  rv = mq_unlink("/mq");
+    rtems_test_assert(ctx->counter[action] == MODE_COUNT - 1);
+#ifdef __rtems__
+const char rtems_test_name[] = "PSXCLOCKREALTIME 1";
+static void *POSIX_Init(void *arg)
+  TEST_BEGIN();
+  test(&test_instance);
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+int main(void)
+  return 0;
diff --git a/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
index 0000000000..68e273d428
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
@@ -0,0 +1,20 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclockrealtime01
+directives:
+  - pthread_mutex_timedlock()
+  - pthread_cond_timedwait()
+  - pthread_rwlock_timedrdlock()
+  - pthread_rwlock_timedwrlock()
+  - sem_timedwait()
+  - mq_timedsend()
+  - mq_timedreceive()
+  - clock_nanosleep()
+concepts:
+  - Test some invalid and extreme timeout values.
+  - Ensure that absolute CLOCK_REALTIME timeouts expire due to external clock
+    changes.
diff --git a/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
index 0000000000..33e9ff5269
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
@@ -0,0 +1,57 @@
+*** BEGIN OF TEST PSXCLOCKREALTIME 1 ***
+*** timeout finite ***
+pthread_mutex_timedlock: actual 'Connection timed out', expected 'Connection timed out'
+pthread_cond_timedwait: actual 'Connection timed out', expected 'Connection timed out'
+pthread_rwlock_timedrdlock: actual 'Connection timed out', expected 'Connection timed out'
+pthread_rwlock_timedwrlock: actual 'Connection timed out', expected 'Connection timed out'
+sem_timedwait: actual 'Connection timed out', expected 'Connection timed out'
+mq_timedsend: actual 'Connection timed out', expected 'Connection timed out'
+mq_timedreceive: actual 'Connection timed out', expected 'Connection timed out'
+clock_nanosleep: actual 'Success', expected 'Success'
+*** timeout negative sec ***
+*** timout negative nsec ***
+pthread_mutex_timedlock: actual 'Invalid argument', expected 'Invalid argument'
+pthread_cond_timedwait: actual 'Invalid argument', expected 'Invalid argument'
+pthread_rwlock_timedrdlock: actual 'Invalid argument', expected 'Invalid argument'
+pthread_rwlock_timedwrlock: actual 'Invalid argument', expected 'Invalid argument'
+sem_timedwait: actual 'Invalid argument', expected 'Invalid argument'
+mq_timedsend: actual 'Invalid argument', expected 'Invalid argument'
+mq_timedreceive: actual 'Invalid argument', expected 'Invalid argument'
+clock_nanosleep: actual 'Invalid argument', expected 'Invalid argument'
+*** timout negative sec and nsec ***
+*** timout huge nsec ***
+*** timeout NULL ***
+*** timeout practically infinite ***
+*** END OF TEST PSXCLOCKREALTIME 1 ***
2.12.3
