[PATCH 04/16] score: Add _Watchdog_Ticks_per_second
Mon Oct 23 13:53:35 UTC 2017
This value is frequently used.  Avoid the function call overhead and the
integer division at run-time.
Update #3117.
Update #3182.
 cpukit/rtems/Makefile.am                    |  1 -
 cpukit/rtems/include/rtems/rtems/clock.h    |  5 ++++-
 cpukit/rtems/src/clockgettickspersecond.c   | 29 -----------------------------
 cpukit/sapi/include/confdefs.h              |  4 ++++
 cpukit/score/include/rtems/score/watchdog.h |  8 ++++++++
 testsuites/sptests/spwatchdog/init.c        |  6 ++++++
 6 files changed, 22 insertions(+), 31 deletions(-)
 delete mode 100644 cpukit/rtems/src/clockgettickspersecond.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index da6e302e2e..c8ff4f4aa5 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -140,7 +140,6 @@ librtems_a_SOURCES += src/barrierwait.c
 ## CLOCK_C_FILES
 librtems_a_SOURCES += src/clockgetsecondssinceepoch.c
-librtems_a_SOURCES += src/clockgettickspersecond.c
 librtems_a_SOURCES += src/clockgettod.c
 librtems_a_SOURCES += src/clockgettodtimeval.c
 librtems_a_SOURCES += src/clockgetuptime.c
diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
index b1ae8845a6..542785d50b 100644
--- a/cpukit/rtems/include/rtems/rtems/clock.h
+++ b/cpukit/rtems/include/rtems/rtems/clock.h
@@ -196,7 +196,10 @@ RTEMS_INLINE_ROUTINE bool rtems_clock_tick_before(
  *         fail since RTEMS is always configured to know the number of
  *         ticks per second.
-rtems_interval rtems_clock_get_ticks_per_second(void);
+RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_get_ticks_per_second( void )
+  return _Watchdog_Ticks_per_second;
  * @brief Set the Current TOD
diff --git a/cpukit/rtems/src/clockgettickspersecond.c b/cpukit/rtems/src/clockgettickspersecond.c
deleted file mode 100644
index f49c91cbd3..0000000000
--- a/cpukit/rtems/src/clockgettickspersecond.c
+++ /dev/null
@@ -1,29 +0,0 @@
- *  @file
- *  @brief Obtain Ticks Per Seconds
- *  @ingroup ClassicClock
- *  COPYRIGHT (c) 1989-2008.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/rtems/clock.h>
-#include <rtems/score/todimpl.h>
-#include <rtems/config.h>
-  return TOD_MICROSECONDS_PER_SECOND /
-    rtems_configuration_get_microseconds_per_tick();
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index a64170bdff..3dfcf9b2d5 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2287,6 +2287,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
             RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
   #endif
+  #define _CONFIGURE_TICKS_PER_SECOND (1000000 / CONFIGURE_MICROSECONDS_PER_TICK)
   /** The configures the number of clock ticks per timeslice. */
   #ifndef CONFIGURE_TICKS_PER_TIMESLICE
     #define CONFIGURE_TICKS_PER_TIMESLICE        50
@@ -3102,6 +3104,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   const size_t _Thread_Control_add_on_count =
     RTEMS_ARRAY_SIZE( _Thread_Control_add_ons );
+  const uint32_t _Watchdog_Ticks_per_second = _CONFIGURE_TICKS_PER_SECOND;
    * This is the Classic API Configuration Table.
diff --git a/cpukit/score/include/rtems/score/watchdog.h b/cpukit/score/include/rtems/score/watchdog.h
index 11a5974c26..bbe2a93b26 100644
--- a/cpukit/score/include/rtems/score/watchdog.h
+++ b/cpukit/score/include/rtems/score/watchdog.h
@@ -158,6 +158,14 @@ struct Watchdog_Control {
 extern volatile Watchdog_Interval _Watchdog_Ticks_since_boot;
+ * @brief The watchdog ticks per second.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uint32_t _Watchdog_Ticks_per_second;
 #ifdef __cplusplus
diff --git a/testsuites/sptests/spwatchdog/init.c b/testsuites/sptests/spwatchdog/init.c
index 3b08fb57e5..3ce7917166 100644
--- a/testsuites/sptests/spwatchdog/init.c
+++ b/testsuites/sptests/spwatchdog/init.c
@@ -55,6 +55,11 @@ static void test_watchdog_static_init( void )
   rtems_test_assert( memcmp( &a, &b, sizeof( a ) ) == 0 );
+static void test_watchdog_config( void )
+  rtems_test_assert( _Watchdog_Ticks_per_second == 100 );
 static bool test_watchdog_is_inactive( test_watchdog *watchdog )
   return _Watchdog_Get_state( &watchdog->Base ) == WATCHDOG_INACTIVE;
@@ -225,6 +230,7 @@ rtems_task Init(
   test_watchdog_operations();
   test_watchdog_static_init();
+  test_watchdog_config();
   build_time( &time, 12, 31, 1988, 9, 0, 0, 0 );
2.12.3
