[PATCH v2] RTEMS: Remove internal timecounter API
Sebastian Huber
Wed Oct 25 05:38:14 UTC 2017
Change copyright. Original BSD content moved to
<machine/_kernel_time.h>.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
newlib/libc/sys/rtems/include/machine/_time.h | 33 ++++-----------------------
1 file changed, 4 insertions(+), 29 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/machine/_time.h b/newlib/libc/sys/rtems/include/machine/_time.h
index dd69bd665..13fa14afa 100644
--- a/newlib/libc/sys/rtems/include/machine/_time.h
+++ b/newlib/libc/sys/rtems/include/machine/_time.h
@@ -1,6 +1,6 @@
- * Copyright (c) 1982, 1986, 1993
- * The Regents of the University of California. All rights reserved.
+ * Copyright (c) 2016 embedded brains GmbH
+ * All rights reserved.
* modification, are permitted provided that the following conditions
@@ -10,14 +10,11 @@
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
- * 4. Neither the name of the University nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
@@ -25,34 +22,12 @@
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
* SUCH DAMAGE.
- * @(#)time.h 8.5 (Berkeley) 5/4/95
- * $FreeBSD$
#ifndef _SYS_TIME_H_
#error "must be included via <sys/time.h>"
#endif /* !_SYS_TIME_H_ */
-__BEGIN_DECLS
-extern volatile time_t _Timecounter_Time_second;
-extern volatile time_t _Timecounter_Time_uptime;
-extern struct bintime _Timecounter_Boottimebin;
-void _Timecounter_Binuptime(struct bintime *);
-void _Timecounter_Nanouptime(struct timespec *);
-void _Timecounter_Microuptime(struct timeval *);
-void _Timecounter_Bintime(struct bintime *);
-void _Timecounter_Nanotime(struct timespec *);
-void _Timecounter_Microtime(struct timeval *);
-void _Timecounter_Getbinuptime(struct bintime *);
-void _Timecounter_Getnanouptime(struct timespec *);
-void _Timecounter_Getmicrouptime(struct timeval *);
-void _Timecounter_Getbintime(struct bintime *);
-void _Timecounter_Getnanotime(struct timespec *);
-void _Timecounter_Getmicrotime(struct timeval *);
-__END_DECLS
#ifdef _KERNEL
/* Header file provided outside of Newlib */
#include <machine/_kernel_time.h>
2.12.3
