[PATCH 4/4] bsp: Add new riscv_generic bsp v3
Fri Oct 27 07:09:22 UTC 2017
On 27/10/17 01:45, Hesham Almatary wrote:
> +static void riscv_generic_clock_at_tick(void)
> +  REG(MTIME_MM) = 0;
> +  REG(MTIMECMP_MM) = TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT;
> +  cpu_counter_ticks += TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT * 10000;
Instead of setting the MM to 0, can't you increment the CMP_MM at each
clock tick? This would make MM to a free running counter for easier
timecounter and CPU counter support.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
