[PATCH 1/9] tests: Move rtems_test_printer definition
Sat Oct 28 08:36:18 UTC 2017
Hello Chris,
Can I go ahead? There is a lot more to do to get good test results without a console driver.
----- Chris Johns <chrisj at rtems.org> schrieb:
> Hi,
> This patch series looks good and thank you for making move. I had planned on
> moving to this point once I knew printk change gave me suitable test results on
> the zedboard.
> Does this mean the TEST_INIT defines can be removed? I can do this after I have
> tested this change.
> Chris
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
