[PATCH 1/4] cpukit: RISC-V - make riscv32 code work for riscv64
Hesham Almatary heshamelmatary at gmail.com
Sun Oct 29 05:59:35 UTC 2017
On Fri, Oct 27, 2017 at 8:49 PM, Hesham Almatary
<heshamelmatary at gmail.com> wrote:
> * Use #ifdefs for 32/64 bit code
> * Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
> * Move the code to a new shared riscv folder to be shared with riscv64
> * Symlink riscv -> riscv32
> * Symlink riscv -> riscv64
I am wondering if the main idea of sharing (speicifcally having sym
links) riscv code between riscv32 and riscv64 is fine.
> Update #3109
>  cpukit/score/cpu/riscv/Makefile.am                 |   26 +
>  cpukit/score/cpu/riscv/cpu.c                       |  124 ++
>  cpukit/score/cpu/riscv/riscv-context-initialize.c  |   67 +
>  cpukit/score/cpu/riscv/riscv-context-switch.S      |  136 ++
>  cpukit/score/cpu/riscv/riscv-context-validate.S    |  200 +++
>  .../cpu/riscv/riscv-context-volatile-clobber.S     |   50 +
>  cpukit/score/cpu/riscv/riscv-exception-default.c   |   39 +
>  .../score/cpu/riscv/riscv-exception-frame-print.c  |   45 +
>  cpukit/score/cpu/riscv/riscv-exception-handler.S   |  221 +++
>  cpukit/score/cpu/riscv/rtems/asm.h                 |  120 ++
>  cpukit/score/cpu/riscv/rtems/score/cpu.h           |  605 ++++++++
>  cpukit/score/cpu/riscv/rtems/score/cpu_asm.h       |   90 ++
>  cpukit/score/cpu/riscv/rtems/score/cpuatomic.h     |   31 +
>  cpukit/score/cpu/riscv/rtems/score/cpuimpl.h       |   51 +
>  cpukit/score/cpu/riscv/rtems/score/riscv-utility.h | 1526 ++++++++++++++++++++
>  cpukit/score/cpu/riscv/rtems/score/riscv.h         |   66 +
>  cpukit/score/cpu/riscv/rtems/score/types.h         |   70 +
>  cpukit/score/cpu/riscv32                           |    1 +
>  cpukit/score/cpu/riscv32/Makefile.am               |   26 -
>  cpukit/score/cpu/riscv32/cpu.c                     |  124 --
>  .../score/cpu/riscv32/riscv-context-initialize.c   |   67 -
>  cpukit/score/cpu/riscv32/riscv-context-switch.S    |  139 --
>  cpukit/score/cpu/riscv32/riscv-context-validate.S  |  201 ---
>  .../cpu/riscv32/riscv-context-volatile-clobber.S   |   50 -
>  cpukit/score/cpu/riscv32/riscv-exception-default.c |   39 -
>  .../cpu/riscv32/riscv-exception-frame-print.c      |   41 -
>  cpukit/score/cpu/riscv32/riscv-exception-handler.S |  220 ---
>  cpukit/score/cpu/riscv32/rtems/asm.h               |  120 --
>  cpukit/score/cpu/riscv32/rtems/score/cpu.h         |  585 --------
>  cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h     |   90 --
>  cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h   |   31 -
>  cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h     |   51 -
>  .../score/cpu/riscv32/rtems/score/riscv-utility.h  | 1526 --------------------
>  cpukit/score/cpu/riscv32/rtems/score/riscv.h       |   66 -
>  cpukit/score/cpu/riscv32/rtems/score/types.h       |   70 -
>  cpukit/score/cpu/riscv64                           |    1 +
>  36 files changed, 3469 insertions(+), 3446 deletions(-)
>  create mode 100644 cpukit/score/cpu/riscv/Makefile.am
>  create mode 100644 cpukit/score/cpu/riscv/cpu.c
>  create mode 100644 cpukit/score/cpu/riscv/riscv-context-initialize.c
>  create mode 100644 cpukit/score/cpu/riscv/riscv-context-switch.S
>  create mode 100644 cpukit/score/cpu/riscv/riscv-context-validate.S
>  create mode 100644 cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
>  create mode 100644 cpukit/score/cpu/riscv/riscv-exception-default.c
>  create mode 100644 cpukit/score/cpu/riscv/riscv-exception-frame-print.c
>  create mode 100644 cpukit/score/cpu/riscv/riscv-exception-handler.S
>  create mode 100644 cpukit/score/cpu/riscv/rtems/asm.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpu.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/riscv.h
>  create mode 100644 cpukit/score/cpu/riscv/rtems/score/types.h
>  create mode 120000 cpukit/score/cpu/riscv32
>  delete mode 100644 cpukit/score/cpu/riscv32/Makefile.am
>  delete mode 100644 cpukit/score/cpu/riscv32/cpu.c
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-initialize.c
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-switch.S
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-validate.S
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-default.c
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
>  delete mode 100644 cpukit/score/cpu/riscv32/riscv-exception-handler.S
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/asm.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpu.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/riscv.h
>  delete mode 100644 cpukit/score/cpu/riscv32/rtems/score/types.h
>  create mode 120000 cpukit/score/cpu/riscv64
> diff --git a/cpukit/score/cpu/riscv/Makefile.am b/cpukit/score/cpu/riscv/Makefile.am
> new file mode 100644
> index 0000000..1de5b2d
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/Makefile.am
> @@ -0,0 +1,26 @@
> +include $(top_srcdir)/automake/compile.am
> +include_rtemsdir = $(includedir)/rtems
> +include_rtems_HEADERS = rtems/asm.h
> +include_rtems_scoredir = $(includedir)/rtems/score
> +include_rtems_score_HEADERS = rtems/score/cpu.h
> +include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> +include_rtems_score_HEADERS += rtems/score/cpuimpl.h
> +include_rtems_score_HEADERS += rtems/score/cpu_asm.h
> +include_rtems_score_HEADERS += rtems/score/types.h
> +include_rtems_score_HEADERS += rtems/score/riscv.h
> +include_rtems_score_HEADERS += rtems/score/riscv-utility.h
> +noinst_LIBRARIES = libscorecpu.a
> +libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> +libscorecpu_a_SOURCES  = cpu.c
> +libscorecpu_a_SOURCES += riscv-exception-handler.S
> +libscorecpu_a_SOURCES += riscv-exception-default.c
> +libscorecpu_a_SOURCES += riscv-exception-frame-print.c
> +libscorecpu_a_SOURCES += riscv-context-switch.S
> +libscorecpu_a_SOURCES += riscv-context-initialize.c
> +libscorecpu_a_SOURCES += riscv-context-validate.S
> +libscorecpu_a_SOURCES += riscv-context-volatile-clobber.S
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/score/cpu/riscv/cpu.c b/cpukit/score/cpu/riscv/cpu.c
> index 0000000..8d2926e
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/cpu.c
> @@ -0,0 +1,124 @@
> + * RISC-V CPU Dependent Source
> + * Copyright (c) 2015 University of York.
> + * Hesham ALmatary <hesham at alumni.york.ac.uk>
> + * COPYRIGHT (c) 1989-1999.
> + * On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#include <rtems/system.h>
> +#include <rtems/score/isr.h>
> +#include <rtems/score/wkspace.h>
> +#include <rtems/score/cpu.h>
> +/* bsp_start_vector_table_begin is the start address of the vector table
> + * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
> + * and may differ from one BSP to another.
> +extern char bsp_start_vector_table_begin[];
> +void init(void);
> +void fini(void);
> +void _init()
> +void _fini()
> + * @brief Performs processor dependent initialization.
> +void _CPU_Initialize(void)
> +  /* Do nothing */
> +void _CPU_ISR_Set_level(unsigned long level)
> +  /* Do nothing */
> +unsigned long  _CPU_ISR_Get_level( void )
> +  /* Do nothing */
> +  return 0;
> +void _CPU_ISR_install_raw_handler(
> +  uint32_t   vector,
> +  proc_ptr    new_handler,
> +  proc_ptr   *old_handler
> +  /* Do nothing */
> +void _CPU_ISR_install_vector(
> +  unsigned long    vector,
> +  proc_ptr *table =
> +    (proc_ptr *) bsp_start_vector_table_begin;
> +  proc_ptr current_handler;
> +  ISR_Level level;
> +  _ISR_Local_disable( level );
> +  current_handler = table [vector];
> +  /* The current handler is now the old one */
> +  if (old_handler != NULL) {
> +    *old_handler = (proc_ptr) current_handler;
> +  /* Write only if necessary to avoid writes to a maybe read-only
> +   * memory */
> +  if (current_handler != new_handler) {
> +    table [vector] = new_handler;
> +  _ISR_Local_enable( level );
> +void _CPU_Install_interrupt_stack( void )
> +  /* Do nothing */
> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
> +  do {
> +  } while (1);
> +  return NULL;
> diff --git a/cpukit/score/cpu/riscv/riscv-context-initialize.c b/cpukit/score/cpu/riscv/riscv-context-initialize.c
> index 0000000..03fcc5c
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-context-initialize.c
> @@ -0,0 +1,67 @@
> + * Hesham Almatary <hesham at alumni.york.ac.uk>
> + * COPYRIGHT (c) 1989-2006.
> + * are met:
> + * SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <string.h>
> +#include <rtems/score/riscv-utility.h>
> +#include <rtems/score/interr.h>
> +void _CPU_Context_Initialize(
> +  Context_Control *context,
> +  void *stack_area_begin,
> +  size_t stack_area_size,
> +  unsigned long new_level,
> +  void (*entry_point)( void ),
> +  bool is_fp,
> +  void *tls_area
> +  uintptr_t stack = ((uintptr_t) stack_area_begin);
> +  /* Account for red-zone */
> +  uintptr_t stack_high = stack + stack_area_size - RISCV_GCC_RED_ZONE_SIZE;
> +  memset(context, 0, sizeof(*context));
> +  /* Stack Pointer - sp/x2 */
> +  context->x[2] = stack_high;
> +  /* Frame Pointer - fp/x8 */
> +  context->x[8] = stack_high;
> +  /* Return Address - ra/x1 */
> +  context->x[1] = (uintptr_t) entry_point;
> +  /* Enable interrupts and FP */
> +  context->mstatus = MSTATUS_FS | MSTATUS_MIE;
> diff --git a/cpukit/score/cpu/riscv/riscv-context-switch.S b/cpukit/score/cpu/riscv/riscv-context-switch.S
> index 0000000..0b1a72c
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-context-switch.S
> @@ -0,0 +1,136 @@
> + * riscv32 CPU Dependent Source
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +#include <rtems/asm.h>
> +.section .text, "ax"
> +.align 4
> +PUBLIC(_CPU_Context_switch)
> +PUBLIC(_CPU_Context_restore)
> +PUBLIC(_CPU_Context_restore_fp)
> +PUBLIC(_CPU_Context_save_fp)
> +PUBLIC(restore)
> +SYM(_CPU_Context_switch):
> +  /* Disable interrupts and store all registers */
> +  csrr t0, mstatus
> +  SREG t0, (32 * CPU_SIZEOF_POINTER)(a0)
> +  csrci mstatus, MSTATUS_MIE
> +  SREG x1, (1 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x2, (2 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x3, (3 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x4, (4 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x5, (5 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x6, (6 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x7, (7 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x8, (8 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x9, (9 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x10, (10 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x11, (11 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x12, (12 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x13, (13 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x14, (14 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x15, (15 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x16, (16 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x17, (17 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x18, (18 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x19, (19 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x20, (20 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x21, (21 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x22, (22 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x23, (23 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x24, (24 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x25, (25 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x26, (26 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x27, (27 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x28, (28 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x29, (28 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x30, (30 * CPU_SIZEOF_POINTER)(a0)
> +  SREG x31, (31 * CPU_SIZEOF_POINTER)(a0)
> +  SYM(restore):
> +  LREG x1, (1 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x2, (2 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x3, (3 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x4, (4 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x5, (5 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x6, (6 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x7, (7 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x8, (8 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x9, (9 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x10, (10 * CPU_SIZEOF_POINTER)(a1)
> +  /* Skip a1/x11 */
> +  LREG x12, (12 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x13, (13 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x14, (14 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x15, (15 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x16, (16 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x17, (17 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x18, (18 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x19, (19 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x20, (20 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x21, (21 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x22, (22 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x23, (23 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x24, (24 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x25, (25 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x26, (26 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x27, (27 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x28, (28 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x29, (29 * CPU_SIZEOF_POINTER)(a1)
> +  LREG x30, (30 * CPU_SIZEOF_POINTER)(a1)
> +  /* Load mstatus */
> +  LREG x31, (32 * CPU_SIZEOF_POINTER)(a1)
> +  csrw mstatus, x31
> +  LREG x11, (11 * CPU_SIZEOF_POINTER)(a1)
> +  ret
> +  SYM(_CPU_Context_restore):
> +  mv     a1, a0
> +  j      restore
> +  /* TODO no FP support for riscv32 yet */
> +  SYM(_CPU_Context_restore_fp):
> +  nop
> +  SYM(_CPU_Context_save_fp):
> +  nop
> diff --git a/cpukit/score/cpu/riscv/riscv-context-validate.S b/cpukit/score/cpu/riscv/riscv-context-validate.S
> index 0000000..f9918e3
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-context-validate.S
> @@ -0,0 +1,200 @@
> + * Copyrigh (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +.section       .text
> +PUBLIC(_CPU_Context_validate)
> +SYM(_CPU_Context_validate):
> +  /* RISC-V/RTEMS context has 36 registers of CPU_SIZEOF_POINTER size */
> +  addi sp, sp, -1 * 36 * CPU_SIZEOF_POINTER
> +  SREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
> +  /* Skip x2/sp */
> +  SREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x29, (28 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
> +  SREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
> +  /* Fill */
> +  /* t0 is used for temporary values */
> +  mv t0, x0
> +  /* x31 contains the stack pointer */
> +  mv x31, sp
> +  .macro fill_register reg
> +  addi t0, t0,  1
> +  mv   \reg, t0
> +  .endm
> +  fill_register        x1
> +  fill_register        x2
> +  fill_register        x3
> +  fill_register        x4
> +  fill_register        x5
> +  fill_register        x6
> +  fill_register        x7
> +  fill_register        x8
> +  fill_register        x9
> +  fill_register        x10
> +  fill_register        x11
> +  fill_register        x12
> +  fill_register        x13
> +  fill_register        x14
> +  fill_register        x15
> +  fill_register        x16
> +  fill_register        x17
> +  fill_register        x18
> +  fill_register        x19
> +  fill_register        x20
> +  fill_register        x21
> +  fill_register        x22
> +  fill_register        x23
> +  fill_register        x24
> +  fill_register        x25
> +  fill_register        x26
> +  fill_register        x27
> +  fill_register        x28
> +  fill_register        x29
> +  fill_register        x30
> +  fill_register        x31
> +  /* Check */
> +check:
> +  .macro check_register reg
> +  addi t0, t0, 1
> +  bne \reg, t0, restore
> +  .endm
> +  bne   x31, sp, restore
> +  mv t0, x0
> +  check_register       x1
> +  check_register       x2
> +  check_register       x3
> +  check_register       x4
> +  check_register       x5
> +  check_register       x6
> +  check_register       x7
> +  check_register       x8
> +  check_register       x9
> +  check_register       x10
> +  check_register       x11
> +  check_register       x12
> +  check_register       x13
> +  check_register       x14
> +  check_register       x15
> +  check_register       x16
> +  check_register       x17
> +  check_register       x18
> +  check_register       x19
> +  check_register       x20
> +  check_register       x21
> +  check_register       x22
> +  check_register       x23
> +  check_register       x24
> +  check_register       x25
> +  check_register       x26
> +  check_register       x27
> +  check_register       x28
> +  check_register       x29
> +  check_register       x30
> +  check_register       x31
> +  j check
> +  /* Restore */
> +restore:
> +  LREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
> +  /* Skip sp/x2 */
> +  LREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x29, (29 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
> +  LREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
> +  addi sp, sp, 36 * CPU_SIZEOF_POINTER
> +  ret
> diff --git a/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S b/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
> index 0000000..58ec25b
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-context-volatile-clobber.S
> @@ -0,0 +1,50 @@
> + * Copyright (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +.section .text
> +PUBLIC(_CPU_Context_volatile_clobber)
> +SYM(_CPU_Context_volatile_clobber):
> +  .macro clobber_register reg
> +  addi t0, t0, -1
> +  mv  \reg, t0
> +  .endm
> +  clobber_register  a0
> +  clobber_register  a1
> +  clobber_register  a2
> +  clobber_register  a3
> +  clobber_register  a4
> +  clobber_register  a5
> +  clobber_register  a6
> +  ret
> diff --git a/cpukit/score/cpu/riscv/riscv-exception-default.c b/cpukit/score/cpu/riscv/riscv-exception-default.c
> index 0000000..62d0dd3
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-exception-default.c
> @@ -0,0 +1,39 @@
> + * Copyright (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +#include <rtems/fatal.h>
> +#include <stdio.h>
> +void _RISCV_Exception_default(uint32_t vector, CPU_Exception_frame *frame);
> +  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
> diff --git a/cpukit/score/cpu/riscv/riscv-exception-frame-print.c b/cpukit/score/cpu/riscv/riscv-exception-frame-print.c
> index 0000000..4d90f58
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-exception-frame-print.c
> @@ -0,0 +1,45 @@
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +#include <rtems/bspIo.h>
> +#include <inttypes.h>
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> +  int i;
> +  for ( i = 0; i < 32; ++i ) {
> +#if __riscv_xlen == 32
> +    printk( "x%02i = 0x%032" PRIx32 "\n", i, frame->x[i]);
> +#else /* xlen == 64 */
> +    printk( "x%02i = 0x%032" PRIx64 "\n",i, frame->x[i]);
> +#endif
> diff --git a/cpukit/score/cpu/riscv/riscv-exception-handler.S b/cpukit/score/cpu/riscv/riscv-exception-handler.S
> index 0000000..8aba339
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/riscv-exception-handler.S
> @@ -0,0 +1,221 @@
> + * @file
> + * @ingroup ScoreCPU
> + * @brief RISC-V exception support implementation.
> + * are met:
> + * SUCH DAMAGE.
> +#endif
> +#include <rtems/score/percpu.h>
> +EXTERN(bsp_start_vector_table_begin)
> +EXTERN(_Thread_Dispatch)
> +PUBLIC(ISR_Handler)
> +.align 4
> +TYPE_FUNC(ISR_Handler)
> +SYM(ISR_Handler):
> +  /* Skip x2/sp */
> +  /* Exception level related registers */
> +  csrr a0, mstatus
> +  SREG a0, (32 * CPU_SIZEOF_POINTER)(sp)
> +  csrr a0, mcause
> +  SREG a0, (33 * CPU_SIZEOF_POINTER)(sp)
> +  csrr a1, mepc
> +  SREG a1, (34 * CPU_SIZEOF_POINTER)(sp)
> +  /* FIXME Only handle interrupts for now (MSB = 1) */
> +  andi a0, a0, 0xf
> +  /* Increment nesting level */
> +  la t0, ISR_NEST_LEVEL
> +  /* Disable multitasking */
> +  la t1, THREAD_DISPATCH_DISABLE_LEVEL
> +  lw t2, (t0)
> +  lw t3, (t1)
> +  addi t2, t2, 1
> +  addi t3, t3, 1
> +  sw t2, (t0)
> +  sw t3, (t1)
> +  /* Save interrupted task stack pointer */
> +  addi t4, sp, 36 * CPU_SIZEOF_POINTER
> +  SREG t4, (2 * CPU_SIZEOF_POINTER)(sp)
> +  /* Keep sp (Exception frame address) in s1 */
> +  mv   s1, sp
> +  /* Call the exception handler from vector table */
> +  /* First function arg for C handler is vector number,
> +   * and the second is a pointer to exception frame.
> +   * a0/mcause/vector number is already loaded above */
> +  mv a1, sp
> +  /* calculate the offset */
> +  la   t5, bsp_start_vector_table_begin
> +  slli t6, a0, 2
> +#else /* xlen = 64 */
> +  slli t6, a0, 3
> +#endif
> +  add  t5, t5, t6
> +  LREG t5, (t5)
> +  /* Do not switch stacks if we are in a nested interrupt. At
> +   * this point t2 should be holding ISR_NEST_LEVEL value.
> +  li   s0, 1
> +  bgtu t2, s0, jump_to_c_handler
> +  /* Switch to RTEMS dedicated interrupt stack */
> +  la     sp, INTERRUPT_STACK_HIGH
> +  LREG   sp, (sp)
> +jump_to_c_handler:
> +  jalr t5
> +  /* Switch back to the interrupted task stack */
> +  mv sp, s1
> +  /* Decrement nesting level */
> +  /* Enable multitasking */
> +  Lw t2, (t0)
> +  lw t3, (t1)
> +  addi t2, t2, -1
> +  addi t3, t3, -1
> +  sw t2, (t0)
> +  sw t3, (t1)
> +  /* Check if _ISR_Nest_level > 0 */
> +  bgtz t2, exception_frame_restore
> +  /* Check if _Thread_Dispatch_disable_level > 0 */
> +  bgtz t3, exception_frame_restore
> +  /* Check if dispatch needed */
> +  la   x31, DISPATCH_NEEDED
> +  lw x31, (x31)
> +  beqz x31, exception_frame_restore
> +  la x31, _Thread_Dispatch
> +  jalr x31
> +  SYM(exception_frame_restore):
> +  /* Skip sp/x2 */
> +  LREG x31, (32 * CPU_SIZEOF_POINTER)(sp)
> +  csrw mstatus, x31
> +  /* Load mepc */
> +  LREG x31, (34 * CPU_SIZEOF_POINTER)(sp)
> +  csrw mepc, x31
> +  /* Unwind exception frame */
> +  mret
> diff --git a/cpukit/score/cpu/riscv/rtems/asm.h b/cpukit/score/cpu/riscv/rtems/asm.h
> index 0000000..34b6474
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/asm.h
> @@ -0,0 +1,120 @@
> + * @file rtems/asm.h
> + *  This include file attempts to address the problems
> + *  caused by incompatible flavors of assemblers and
> + *  toolsets.  It primarily addresses variations in the
> + *  use of leading underscores on symbols and the requirement
> + *  that register names be preceded by a %.
> + *  NOTE: The spacing in the use of these macros
> + *        is critical to them working as advertised.
> + *  This file is based on similar code found in newlib available
> + *  from ftp.cygnus.com.  The file which was used had no copyright
> + *  notice.  This file is freely distributable as long as the source
> + *  of the file is noted.  This file is:
> + * COPYRIGHT (c) 1994-1997.
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef __RISCV_ASM_H
> +#define __RISCV_ASM_H
> + *  Indicate we are in an assembly file and get the basic CPU definitions.
> +#ifndef ASM
> +#define ASM
> +#endif
> +#include <rtems/score/cpuopts.h>
> +#include <rtems/score/riscv.h>
> + *  Recent versions of GNU cpp define variables which indicate the
> + *  need for underscores and percents.  If not using GNU cpp or
> + *  the version does not support this, then you will obviously
> + *  have to define these as appropriate.
> +#ifndef __USER_LABEL_PREFIX__
> +#define __USER_LABEL_PREFIX__ _
> +#endif
> +#ifndef __REGISTER_PREFIX__
> +#define __REGISTER_PREFIX__
> +#endif
> +/* ANSI concatenation macros.  */
> +#define CONCAT1(a, b) CONCAT2(a, b)
> +#define CONCAT2(a, b) a ## b
> +/* Use the right prefix for global labels.  */
> +#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> +/* Use the right prefix for registers.  */
> +#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> + *  define macros for all of the registers on this CPU
> + *  EXAMPLE:     #define d0 REG (d0)
> + *  Define macros to handle section beginning and ends.
> +#define BEGIN_CODE_DCL .text
> +#define END_CODE_DCL
> +#define BEGIN_DATA_DCL .data
> +#define END_DATA_DCL
> +#define BEGIN_CODE .text
> +#define END_CODE
> +#define BEGIN_DATA
> +#define END_DATA
> +#define BEGIN_BSS
> +#define END_BSS
> +#define END
> + *  Following must be tailor for a particular flavor of the C compiler.
> + *  They may need to put underscores in front of the symbols.
> +#define PUBLIC(sym)    .global SYM (sym)
> +#define EXTERN(sym)    .extern SYM (sym)
> +#define TYPE_FUNC(sym) .type SYM (sym), %function
> +#endif
> diff --git a/cpukit/score/cpu/riscv/rtems/score/cpu.h b/cpukit/score/cpu/riscv/rtems/score/cpu.h
> index 0000000..439b8c2
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/cpu.h
> @@ -0,0 +1,605 @@
> + * @file rtems/score/cpu.h
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef _RISCV_CPU_H
> +#define _RISCV_CPU_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <rtems/score/riscv.h> /* pick up machine definitions */
> +#include <rtems/score/types.h>
> +#ifndef ASM
> +#include <stdint.h>
> +#include <stdio.h> /* for printk */
> +#endif
> +#define CPU_INLINE_ENABLE_DISPATCH       FALSE
> +#define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
> +#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
> +#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
> +#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> +#define CPU_ISR_PASSES_FRAME_POINTER 1
> +#define CPU_HARDWARE_FP                  FALSE
> +#define CPU_SOFTWARE_FP                  FALSE
> +#define CPU_ALL_TASKS_ARE_FP             FALSE
> +#define CPU_IDLE_TASK_IS_FP              FALSE
> +#define CPU_USE_DEFERRED_FP_SWITCH       FALSE
> +#define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
> +#define CPU_STACK_GROWS_UP               FALSE
> +#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
> +#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES     FALSE
> +#define CPU_BIG_ENDIAN                           FALSE
> +#define CPU_LITTLE_ENDIAN                        TRUE
> +#define CPU_MODES_INTERRUPT_MASK   0x0000000000000001
> + *  Processor defined structures required for cpukit/score.
> +#ifndef ASM
> +typedef struct {
> +  /* riscv has 32 xlen-bit (where xlen can be 32 or 64) general purpose registers (x0-x31)*/
> +  unsigned long x[32];
> +  /* Special purpose registers */
> +  unsigned long mstatus;
> +  unsigned long mcause;
> +  unsigned long mepc;
> +#ifdef RTEMS_SMP
> +   * @brief On SMP configurations the thread context must contain a boolean
> +   * indicator to signal if this context is executing on a processor.
> +   * This field must be updated during a context switch.  The context switch
> +   * to the heir must wait until the heir context indicates that it is no
> +   * longer executing on a processor.  The context switch must also check if
> +   * a thread dispatch is necessary to honor updates of the heir thread for
> +   * this processor.  This indicator must be updated using an atomic test and
> +   * set operation to ensure that at most one processor uses the heir
> +   * context at the same time.
> +   * @code
> +   * void _CPU_Context_switch(
> +   *   Context_Control *executing,
> +   *   Context_Control *heir
> +   *   save( executing );
> +   *   executing->is_executing = false;
> +   *   memory_barrier();
> +   *   if ( test_and_set( &heir->is_executing ) ) {
> +   *     do {
> +   *       Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
> +   *       if ( cpu_self->dispatch_necessary ) {
> +   *         heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
> +   *     } while ( test_and_set( &heir->is_executing ) );
> +   *   restore( heir );
> +   * @endcode
> +  volatile bool is_executing;
> +#endif
> +} Context_Control;
> +#define _CPU_Context_Get_SP( _context ) \
> +  (_context)->x[2]
> +typedef struct {
> +  /** TODO FPU registers are listed here */
> +  double  some_float_register;
> +} Context_Control_fp;
> +typedef Context_Control CPU_Interrupt_frame;
> +#define CPU_CONTEXT_FP_SIZE  0
> +Context_Control_fp  _CPU_Null_fp_context;
> +#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> +#define CPU_STACK_MINIMUM_SIZE  4096
> +#else
> +#define CPU_STACK_MINIMUM_SIZE  4096 * 2
> +#endif
> +#define CPU_ALIGNMENT 8
> +#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> +#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
> +#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
> +#define CPU_STACK_ALIGNMENT        8
> +#define _CPU_Initialize_vectors()
> + *  Disable all interrupts for an RTEMS critical section.  The previous
> + *  level is returned in _level.
> +static inline unsigned long riscv_interrupt_disable( void )
> +  register unsigned long status = read_csr(mstatus);
> +  clear_csr(mstatus, MSTATUS_MIE);
> +  return status;
> +static inline void riscv_interrupt_enable(unsigned long level)
> +  write_csr(mstatus, level);
> +#define _CPU_ISR_Disable( _level ) \
> +    _level = riscv_interrupt_disable()
> +#define _CPU_ISR_Enable( _level )  \
> +  riscv_interrupt_enable( _level )
> +#define _CPU_ISR_Flash( _level ) \
> +  do{ \
> +      _CPU_ISR_Enable( _level ); \
> +      riscv_interrupt_disable(); \
> +    } while(0)
> +RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( unsigned long level )
> +  return ( level & MSTATUS_MIE ) != 0;
> +void _CPU_ISR_Set_level( unsigned long level );
> +unsigned long _CPU_ISR_Get_level( void );
> +/* end of ISR handler macros */
> +/* Context handler macros */
> +#define RISCV_GCC_RED_ZONE_SIZE 128
> +  bool is_fp,
> +  void *tls_area
> +#define _CPU_Context_Restart_self( _the_context ) \
> +   _CPU_Context_restore( (_the_context) )
> +#define _CPU_Context_Fp_start( _base, _offset ) \
> +   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
> +#define _CPU_Context_Initialize_fp( _destination ) \
> +   *(*(_destination)) = _CPU_Null_fp_context; \
> +extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
> +RTEMS_NO_RETURN;
> +/* end of Fatal Error manager macros */
> +#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> +#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> +#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> +#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> +    (_output) = 0;   /* do something to prevent warnings */ \
> +#endif
> +/* end of Bitfield handler macros */
> + *  This routine builds the mask which corresponds to the bit fields
> + *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
> + *  for that routine.
> +#define _CPU_Priority_Mask( _bit_number ) \
> +    (1 << _bit_number)
> +#endif
> +#define _CPU_Priority_bits_index( _priority ) \
> +  (_priority)
> +#endif
> +#define CPU_MAXIMUM_PROCESSORS 32
> +#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
> +#define CPU_TIMESTAMP_USE_INT64 TRUE
> +#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
> +typedef struct {
> +  /* There is no CPU specific per-CPU state */
> +} CPU_Per_CPU_control;
> +#endif /* ASM */
> +#define CPU_SIZEOF_POINTER 4
> +/* 32-bit load/store instructions */
> +#define LREG lw
> +#define SREG sw
> +#define CPU_EXCEPTION_FRAME_SIZE 128
> +#define CPU_SIZEOF_POINTER 8
> +/* 64-bit load/store instructions */
> +#define LREG ld
> +#define SREG sd
> +#define CPU_EXCEPTION_FRAME_SIZE 256
> +#endif
> +#define CPU_PER_CPU_CONTROL_SIZE 0
> +#ifndef ASM
> +typedef uint16_t Priority_bit_map_Word;
> +typedef struct {
> +  unsigned long x[32];;
> +} CPU_Exception_frame;
> + * @brief Prints the exception frame via printk().
> + * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> +/* end of Priority handler macros */
> +/* functions */
> + *  _CPU_Initialize
> + *  This routine performs CPU dependent initialization.
> +  void
> + *  _CPU_ISR_install_raw_handler
> + *  This routine installs a "raw" interrupt handler directly into the
> + *  processor's vector table.
> +  uint32_t    vector,
> + *  _CPU_ISR_install_vector
> + *  This routine installs an interrupt vector.
> + *  NO_CPU Specific Information:
> + *  XXX document implementation including references if appropriate
> + *  _CPU_Install_interrupt_stack
> + *  This routine installs the hardware interrupt stack pointer.
> + *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
> + *         is TRUE.
> +void _CPU_Install_interrupt_stack( void );
> + *  _CPU_Thread_Idle_body
> + *  This routine is the CPU dependent IDLE thread body.
> + *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
> + *         is TRUE.
> +void *_CPU_Thread_Idle_body( uintptr_t ignored );
> + *  _CPU_Context_switch
> + *  This routine switches from the run context to the heir context.
> + *  RISCV Specific Information:
> + *  Please see the comments in the .c file for a description of how
> + *  this function works. There are several things to be aware of.
> +void _CPU_Context_switch(
> +  Context_Control  *run,
> +  Context_Control  *heir
> + *  _CPU_Context_restore
> + *  This routine is generally used only to restart self in an
> + *  efficient manner.  It may simply be a label in _CPU_Context_switch.
> + *  NOTE: May be unnecessary to reload some registers.
> +void _CPU_Context_restore(
> +  Context_Control *new_context
> +) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
> + *  _CPU_Context_save_fp
> + *  This routine saves the floating point context passed to it.
> +void _CPU_Context_save_fp(
> +  void **fp_context_ptr
> + *  _CPU_Context_restore_fp
> + *  This routine restores the floating point context passed to it.
> +void _CPU_Context_restore_fp(
> +/*  The following routine swaps the endian format of an unsigned int.
> + *  It must be static because it is referenced indirectly.
> + *  This version will work on any processor, but if there is a better
> + *  way for your CPU PLEASE use it.  The most common way to do this is to:
> + *     swap least significant two bytes with 16-bit rotate
> + *     swap upper and lower 16-bits
> + *     swap most significant two bytes with 16-bit rotate
> + *  Some CPUs have special instructions which swap a 32-bit quantity in
> + *  a single instruction (e.g. i486).  It is probably best to avoid
> + *  an "endian swapping control bit" in the CPU.  One good reason is
> + *  that interrupts would probably have to be disabled to insure that
> + *  an interrupt does not try to access the same "chunk" with the wrong
> + *  endian.  Another good reason is that on some CPUs, the endian bit
> + *  endianness for ALL fetches -- both code and data -- so the code
> + *  will be fetched incorrectly.
> +static inline uint32_t CPU_swap_u32(
> +  uint32_t value
> +  uint32_t   byte1, byte2, byte3, byte4, swapped;
> +  byte4 = (value >> 24) & 0xff;
> +  byte3 = (value >> 16) & 0xff;
> +  byte2 = (value >> 8)  & 0xff;
> +  byte1 =  value        & 0xff;
> +  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> +  return ( swapped );
> +#define CPU_swap_u16( value ) \
> +  (((value&0xff) << 8) | ((value >> 8)&0xff))
> +static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
> +  /* TODO */
> +static inline void _CPU_Context_validate( uintptr_t pattern )
> +  while (1) {
> +    /* TODO */
> +typedef uint32_t CPU_Counter_ticks;
> +CPU_Counter_ticks _CPU_Counter_read( void );
> +#ifdef RTEMS_SMP
> + * @brief Performs CPU specific SMP initialization in the context of the boot
> + * processor.
> + * This function is invoked on the boot processor during system
> + * initialization.  All interrupt stacks are allocated at this point in case
> + * the CPU port allocates the interrupt stacks.  This function is called
> + * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
> + * used.
> + * @return The count of physically or virtually available processors.
> + * Depending on the configuration the application may use not all processors.
> +uint32_t _CPU_SMP_Initialize( void );
> + * @brief Starts a processor specified by its index.
> + * initialization.
> + * This function will be called after _CPU_SMP_Initialize().
> + * @param[in] cpu_index The processor index.
> + * @retval true Successful operation.
> + * @retval false Unable to start this processor.
> +bool _CPU_SMP_Start_processor( uint32_t cpu_index );
> + * @brief Performs final steps of CPU specific SMP initialization in the
> + * context of the boot processor.
> + * initialization.
> + * This function will be called after all processors requested by the
> + * application have been started.
> + * @param[in] cpu_count The minimum value of the count of processors
> + * requested by the application configuration and the count of physically or
> + * virtually available processors.
> +void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
> + * @brief Returns the index of the current processor.
> + * An architecture specific method must be used to obtain the index of the
> + * current processor in the system.  The set of processor indices is the
> + * range of integers starting with zero up to the processor count minus one.
> +uint32_t _CPU_SMP_Get_current_processor( void );
> + * @brief Sends an inter-processor interrupt to the specified target
> + * processor.
> + * This operation is undefined for target processor indices out of range.
> + * @param[in] target_processor_index The target processor index.
> +void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
> + * @brief Broadcasts a processor event.
> + * Some architectures provide a low-level synchronization primitive for
> + * processors in a multi-processor environment.  Processors waiting for this
> + * event may go into a low-power state and stop generating system bus
> + * transactions.  This function must ensure that preceding store operations
> + * can be observed by other processors.
> + * @see _CPU_SMP_Processor_event_receive().
> +void _CPU_SMP_Processor_event_broadcast( void );
> + * @brief Receives a processor event.
> + * This function will wait for the processor event and may wait forever if no
> + * such event arrives.
> + * @see _CPU_SMP_Processor_event_broadcast().
> +static inline void _CPU_SMP_Processor_event_receive( void )
> +  __asm__ volatile ( "" : : : "memory" );
> + * @brief Gets the is executing indicator of the thread context.
> + * @param[in] context The context.
> +static inline bool _CPU_Context_Get_is_executing(
> +  const Context_Control *context
> +  return context->is_executing;
> + * @brief Sets the is executing indicator of the thread context.
> + * @param[in] is_executing The new value for the is executing indicator.
> +static inline void _CPU_Context_Set_is_executing(
> +  bool is_executing
> +  context->is_executing = is_executing;
> +#endif /* RTEMS_SMP */
> +#endif /* ASM */
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h b/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
> index 0000000..b5a56f3
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/cpu_asm.h
> @@ -0,0 +1,90 @@
> + * @file
> + * @brief riscv32 Assembly File
> + * Very loose template for an include file for the cpu_asm.? file
> + * if it is implemented as a ".S" file (preprocessed by cpp) instead
> + * of a ".s" file (preprocessed by gm4 or gasp).
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_CPU_ASM_H
> +#define _RTEMS_SCORE_CPU_ASM_H
> +/* pull in the generated offsets */
> +#include <rtems/score/offsets.h>
> + * Hardware General Registers
> +/* put something here */
> + * Hardware Floating Point Registers
> + * Hardware Control Registers
> + * Calling Convention
> + * Temporary registers
> + * Floating Point Registers - SW Conventions
> + * Temporary floating point registers
> +#endif
> +/* end of file */
> diff --git a/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
> index 0000000..8ee9606
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/cpuatomic.h
> @@ -0,0 +1,31 @@
> + * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
> +#define _RTEMS_SCORE_ATOMIC_CPU_H
> +#include <rtems/score/cpustdatomic.h>
> +#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
> diff --git a/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
> index 0000000..3904c84
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/cpuimpl.h
> @@ -0,0 +1,51 @@
> + * @file
> + * @brief CPU Port Implementation API
> + * Copyright (c) 2013 embedded brains GmbH
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_CPUIMPL_H
> +#define _RTEMS_SCORE_CPUIMPL_H
> +#ifndef ASM
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#ifdef __cplusplus
> +#endif
> +#endif /* ASM */
> +#endif /* _RTEMS_SCORE_CPUIMPL_H */
> diff --git a/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h b/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
> index 0000000..dc4836b
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/riscv-utility.h
> @@ -0,0 +1,1526 @@
> +/* Copyright (c) 2013, The Regents of the University of California (Regents).
> + * All Rights Reserved.
> + * modification, are permitted provided that the following conditions are met:
> + * 3. Neither the name of the Regents nor the
> + * names of its contributors may be used to endorse or promote products
> + * derived from this software without specific prior written
> + * permission.
> + * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
> + * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
> + * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
> + * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> + * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
> + * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> + * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
> + * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
> + * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
> +  * @file
> +  * @brief RISCV utility
> + * COPYRIGHT (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +/* This file is copied from riscv-tools/encoding.h with additions/modifications to work
> + * with RTEMS.
> +#ifndef _RTEMS_SCORE_RISCV_UTILITY_H
> +#define _RTEMS_SCORE_RISCV_UTILITY_H
> +#define MSTATUS_UIE         0x00000001
> +#define MSTATUS_SIE         0x00000002
> +#define MSTATUS_HIE         0x00000004
> +#define MSTATUS_MIE         0x00000008
> +#define MSTATUS_UPIE        0x00000010
> +#define MSTATUS_SPIE        0x00000020
> +#define MSTATUS_HPIE        0x00000040
> +#define MSTATUS_MPIE        0x00000080
> +#define MSTATUS_SPP         0x00000100
> +#define MSTATUS_HPP         0x00000600
> +#define MSTATUS_MPP         0x00001800
> +#define MSTATUS_FS          0x00006000
> +#define MSTATUS_XS          0x00018000
> +#define MSTATUS_MPRV        0x00020000
> +#define MSTATUS_SUM         0x00040000
> +#define MSTATUS_MXR         0x00080000
> +#define MSTATUS_TVM         0x00100000
> +#define MSTATUS_TW          0x00200000
> +#define MSTATUS_TSR         0x00400000
> +#define MSTATUS32_SD        0x80000000
> +#define MSTATUS64_SD        0x8000000000000000
> +#define SSTATUS_UIE         0x00000001
> +#define SSTATUS_SIE         0x00000002
> +#define SSTATUS_UPIE        0x00000010
> +#define SSTATUS_SPIE        0x00000020
> +#define SSTATUS_SPP         0x00000100
> +#define SSTATUS_FS          0x00006000
> +#define SSTATUS_XS          0x00018000
> +#define SSTATUS_SUM         0x00040000
> +#define SSTATUS_MXR         0x00080000
> +#define SSTATUS32_SD        0x80000000
> +#define SSTATUS64_SD        0x8000000000000000
> +#define DCSR_XDEBUGVER      (3U<<30)
> +#define DCSR_NDRESET        (1<<29)
> +#define DCSR_FULLRESET      (1<<28)
> +#define DCSR_EBREAKM        (1<<15)
> +#define DCSR_EBREAKH        (1<<14)
> +#define DCSR_EBREAKS        (1<<13)
> +#define DCSR_EBREAKU        (1<<12)
> +#define DCSR_STOPCYCLE      (1<<10)
> +#define DCSR_STOPTIME       (1<<9)
> +#define DCSR_CAUSE          (7<<6)
> +#define DCSR_DEBUGINT       (1<<5)
> +#define DCSR_HALT           (1<<3)
> +#define DCSR_STEP           (1<<2)
> +#define DCSR_PRV            (3<<0)
> +#define DCSR_CAUSE_NONE     0
> +#define DCSR_CAUSE_SWBP     1
> +#define DCSR_CAUSE_HWBP     2
> +#define DCSR_CAUSE_DEBUGINT 3
> +#define DCSR_CAUSE_STEP     4
> +#define DCSR_CAUSE_HALT     5
> +#define MCONTROL_TYPE(xlen)    (0xfULL<<((xlen)-4))
> +#define MCONTROL_DMODE(xlen)   (1ULL<<((xlen)-5))
> +#define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
> +#define MCONTROL_SELECT     (1<<19)
> +#define MCONTROL_TIMING     (1<<18)
> +#define MCONTROL_ACTION     (0x3f<<12)
> +#define MCONTROL_CHAIN      (1<<11)
> +#define MCONTROL_MATCH      (0xf<<7)
> +#define MCONTROL_M          (1<<6)
> +#define MCONTROL_H          (1<<5)
> +#define MCONTROL_S          (1<<4)
> +#define MCONTROL_U          (1<<3)
> +#define MCONTROL_EXECUTE    (1<<2)
> +#define MCONTROL_STORE      (1<<1)
> +#define MCONTROL_LOAD       (1<<0)
> +#define MCONTROL_TYPE_NONE      0
> +#define MCONTROL_TYPE_MATCH     2
> +#define MCONTROL_ACTION_DEBUG_EXCEPTION   0
> +#define MCONTROL_ACTION_DEBUG_MODE        1
> +#define MCONTROL_ACTION_TRACE_START       2
> +#define MCONTROL_ACTION_TRACE_STOP        3
> +#define MCONTROL_ACTION_TRACE_EMIT        4
> +#define MCONTROL_MATCH_EQUAL     0
> +#define MCONTROL_MATCH_NAPOT     1
> +#define MCONTROL_MATCH_GE        2
> +#define MCONTROL_MATCH_LT        3
> +#define MCONTROL_MATCH_MASK_LOW  4
> +#define MCONTROL_MATCH_MASK_HIGH 5
> +#define MIP_SSIP            (1 << IRQ_S_SOFT)
> +#define MIP_HSIP            (1 << IRQ_H_SOFT)
> +#define MIP_MSIP            (1 << IRQ_M_SOFT)
> +#define MIP_STIP            (1 << IRQ_S_TIMER)
> +#define MIP_HTIP            (1 << IRQ_H_TIMER)
> +#define MIP_MTIP            (1 << IRQ_M_TIMER)
> +#define MIP_SEIP            (1 << IRQ_S_EXT)
> +#define MIP_HEIP            (1 << IRQ_H_EXT)
> +#define MIP_MEIP            (1 << IRQ_M_EXT)
> +#define SIP_SSIP MIP_SSIP
> +#define SIP_STIP MIP_STIP
> +#define PRV_U 0
> +#define PRV_S 1
> +#define PRV_H 2
> +#define PRV_M 3
> +#define SPTBR32_MODE 0x80000000
> +#define SPTBR32_ASID 0x7FC00000
> +#define SPTBR32_PPN  0x003FFFFF
> +#define SPTBR64_MODE 0xF000000000000000
> +#define SPTBR64_ASID 0x0FFFF00000000000
> +#define SPTBR64_PPN  0x00000FFFFFFFFFFF
> +#define SPTBR_MODE_OFF  0
> +#define SPTBR_MODE_SV32 1
> +#define SPTBR_MODE_SV39 8
> +#define SPTBR_MODE_SV48 9
> +#define SPTBR_MODE_SV57 10
> +#define SPTBR_MODE_SV64 11
> +#define PMP_R     0x01
> +#define PMP_W     0x02
> +#define PMP_X     0x04
> +#define PMP_A     0x18
> +#define PMP_L     0x80
> +#define PMP_SHIFT 2
> +#define PMP_TOR   0x08
> +#define PMP_NA4   0x10
> +#define PMP_NAPOT 0x18
> +#define IRQ_S_SOFT   1
> +#define IRQ_H_SOFT   2
> +#define IRQ_M_SOFT   3
> +#define IRQ_S_TIMER  5
> +#define IRQ_H_TIMER  6
> +#define IRQ_M_TIMER  7
> +#define IRQ_S_EXT    9
> +#define IRQ_H_EXT    10
> +#define IRQ_M_EXT    11
> +#define IRQ_COP      12
> +#define IRQ_HOST     13
> +#define DEFAULT_RSTVEC     0x00001000
> +#define CLINT_BASE         0x02000000
> +#define CLINT_SIZE         0x000c0000
> +#define EXT_IO_BASE        0x40000000
> +#define DRAM_BASE          0x80000000
> +// page table entry (PTE) fields
> +#define PTE_V     0x001 // Valid
> +#define PTE_R     0x002 // Read
> +#define PTE_W     0x004 // Write
> +#define PTE_X     0x008 // Execute
> +#define PTE_U     0x010 // User
> +#define PTE_G     0x020 // Global
> +#define PTE_A     0x040 // Accessed
> +#define PTE_D     0x080 // Dirty
> +#define PTE_SOFT  0x300 // Reserved for Software
> +#define PTE_PPN_SHIFT 10
> +#define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
> +#ifdef __riscv
> +#if __riscv_xlen == 64
> +# define MSTATUS_SD MSTATUS64_SD
> +# define SSTATUS_SD SSTATUS64_SD
> +# define RISCV_PGLEVEL_BITS 9
> +# define SPTBR_MODE SPTBR64_MODE
> +#else
> +# define MSTATUS_SD MSTATUS32_SD
> +# define SSTATUS_SD SSTATUS32_SD
> +# define RISCV_PGLEVEL_BITS 10
> +# define SPTBR_MODE SPTBR32_MODE
> +#endif
> +#define RISCV_PGSHIFT 12
> +#define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
> +#ifndef __ASSEMBLER__
> +  * @brief Priv Mode registers definitions.
> +  * @see RISC-V priv-spec 1.10.
> +typedef enum {
> +  RISCV_USER_INTERRUPT = 0,
> +  RISCV_SUPERVISOR_SW_INTERRUPT = 1,
> +  RISCV_MACHINE_SW_INTERRUPT = 3,
> +  RISCV_USER_TIMER_INTERRUPT = 4,
> +  RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
> +  RISCV_MACHINE_TIMER_INTERRUPT = 7,
> +  RISCV_USER_EXTERNAL_INTERRUPT = 8,
> +  RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
> +  RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
> +} RISCV_Symbolic_interrupt_name;
> +#ifdef __GNUC__
> +#define read_csr(reg) ({ unsigned long __tmp; \
> +  asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
> +  __tmp; })
> +#define write_csr(reg, val) ({ \
> +  asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })
> +#define swap_csr(reg, val) ({ unsigned long __tmp; \
> +  asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \
> +  __tmp; })
> +#define set_csr(reg, bit) ({ unsigned long __tmp; \
> +  asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
> +  __tmp; })
> +#define clear_csr(reg, bit) ({ unsigned long __tmp; \
> +  asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
> +  __tmp; })
> +#define rdtime() read_csr(time)
> +#define rdcycle() read_csr(cycle)
> +#define rdinstret() read_csr(instret)
> +#endif
> +#endif
> +#endif
> +#endif
> +/* Automatically generated by parse-opcodes.  */
> +#ifndef RISCV_ENCODING_H
> +#define RISCV_ENCODING_H
> +#define MATCH_BEQ 0x63
> +#define MASK_BEQ  0x707f
> +#define MATCH_BNE 0x1063
> +#define MASK_BNE  0x707f
> +#define MATCH_BLT 0x4063
> +#define MASK_BLT  0x707f
> +#define MATCH_BGE 0x5063
> +#define MASK_BGE  0x707f
> +#define MATCH_BLTU 0x6063
> +#define MASK_BLTU  0x707f
> +#define MATCH_BGEU 0x7063
> +#define MASK_BGEU  0x707f
> +#define MATCH_JALR 0x67
> +#define MASK_JALR  0x707f
> +#define MATCH_JAL 0x6f
> +#define MASK_JAL  0x7f
> +#define MATCH_LUI 0x37
> +#define MASK_LUI  0x7f
> +#define MATCH_AUIPC 0x17
> +#define MASK_AUIPC  0x7f
> +#define MATCH_ADDI 0x13
> +#define MASK_ADDI  0x707f
> +#define MATCH_SLLI 0x1013
> +#define MASK_SLLI  0xfc00707f
> +#define MATCH_SLTI 0x2013
> +#define MASK_SLTI  0x707f
> +#define MATCH_SLTIU 0x3013
> +#define MASK_SLTIU  0x707f
> +#define MATCH_XORI 0x4013
> +#define MASK_XORI  0x707f
> +#define MATCH_SRLI 0x5013
> +#define MASK_SRLI  0xfc00707f
> +#define MATCH_SRAI 0x40005013
> +#define MASK_SRAI  0xfc00707f
> +#define MATCH_ORI 0x6013
> +#define MASK_ORI  0x707f
> +#define MATCH_ANDI 0x7013
> +#define MASK_ANDI  0x707f
> +#define MATCH_ADD 0x33
> +#define MASK_ADD  0xfe00707f
> +#define MATCH_SUB 0x40000033
> +#define MASK_SUB  0xfe00707f
> +#define MATCH_SLL 0x1033
> +#define MASK_SLL  0xfe00707f
> +#define MATCH_SLT 0x2033
> +#define MASK_SLT  0xfe00707f
> +#define MATCH_SLTU 0x3033
> +#define MASK_SLTU  0xfe00707f
> +#define MATCH_XOR 0x4033
> +#define MASK_XOR  0xfe00707f
> +#define MATCH_SRL 0x5033
> +#define MASK_SRL  0xfe00707f
> +#define MATCH_SRA 0x40005033
> +#define MASK_SRA  0xfe00707f
> +#define MATCH_OR 0x6033
> +#define MASK_OR  0xfe00707f
> +#define MATCH_AND 0x7033
> +#define MASK_AND  0xfe00707f
> +#define MATCH_ADDIW 0x1b
> +#define MASK_ADDIW  0x707f
> +#define MATCH_SLLIW 0x101b
> +#define MASK_SLLIW  0xfe00707f
> +#define MATCH_SRLIW 0x501b
> +#define MASK_SRLIW  0xfe00707f
> +#define MATCH_SRAIW 0x4000501b
> +#define MASK_SRAIW  0xfe00707f
> +#define MATCH_ADDW 0x3b
> +#define MASK_ADDW  0xfe00707f
> +#define MATCH_SUBW 0x4000003b
> +#define MASK_SUBW  0xfe00707f
> +#define MATCH_SLLW 0x103b
> +#define MASK_SLLW  0xfe00707f
> +#define MATCH_SRLW 0x503b
> +#define MASK_SRLW  0xfe00707f
> +#define MATCH_SRAW 0x4000503b
> +#define MASK_SRAW  0xfe00707f
> +#define MATCH_LB 0x3
> +#define MASK_LB  0x707f
> +#define MATCH_LH 0x1003
> +#define MASK_LH  0x707f
> +#define MATCH_LW 0x2003
> +#define MASK_LW  0x707f
> +#define MATCH_LD 0x3003
> +#define MASK_LD  0x707f
> +#define MATCH_LBU 0x4003
> +#define MASK_LBU  0x707f
> +#define MATCH_LHU 0x5003
> +#define MASK_LHU  0x707f
> +#define MATCH_LWU 0x6003
> +#define MASK_LWU  0x707f
> +#define MATCH_SB 0x23
> +#define MASK_SB  0x707f
> +#define MATCH_SH 0x1023
> +#define MASK_SH  0x707f
> +#define MATCH_SW 0x2023
> +#define MASK_SW  0x707f
> +#define MATCH_SD 0x3023
> +#define MASK_SD  0x707f
> +#define MATCH_FENCE 0xf
> +#define MASK_FENCE  0x707f
> +#define MATCH_FENCE_I 0x100f
> +#define MASK_FENCE_I  0x707f
> +#define MATCH_MUL 0x2000033
> +#define MASK_MUL  0xfe00707f
> +#define MATCH_MULH 0x2001033
> +#define MASK_MULH  0xfe00707f
> +#define MATCH_MULHSU 0x2002033
> +#define MASK_MULHSU  0xfe00707f
> +#define MATCH_MULHU 0x2003033
> +#define MASK_MULHU  0xfe00707f
> +#define MATCH_DIV 0x2004033
> +#define MASK_DIV  0xfe00707f
> +#define MATCH_DIVU 0x2005033
> +#define MASK_DIVU  0xfe00707f
> +#define MATCH_REM 0x2006033
> +#define MASK_REM  0xfe00707f
> +#define MATCH_REMU 0x2007033
> +#define MASK_REMU  0xfe00707f
> +#define MATCH_MULW 0x200003b
> +#define MASK_MULW  0xfe00707f
> +#define MATCH_DIVW 0x200403b
> +#define MASK_DIVW  0xfe00707f
> +#define MATCH_DIVUW 0x200503b
> +#define MASK_DIVUW  0xfe00707f
> +#define MATCH_REMW 0x200603b
> +#define MASK_REMW  0xfe00707f
> +#define MATCH_REMUW 0x200703b
> +#define MASK_REMUW  0xfe00707f
> +#define MATCH_AMOADD_W 0x202f
> +#define MASK_AMOADD_W  0xf800707f
> +#define MATCH_AMOXOR_W 0x2000202f
> +#define MASK_AMOXOR_W  0xf800707f
> +#define MATCH_AMOOR_W 0x4000202f
> +#define MASK_AMOOR_W  0xf800707f
> +#define MATCH_AMOAND_W 0x6000202f
> +#define MASK_AMOAND_W  0xf800707f
> +#define MATCH_AMOMIN_W 0x8000202f
> +#define MASK_AMOMIN_W  0xf800707f
> +#define MATCH_AMOMAX_W 0xa000202f
> +#define MASK_AMOMAX_W  0xf800707f
> +#define MATCH_AMOMINU_W 0xc000202f
> +#define MASK_AMOMINU_W  0xf800707f
> +#define MATCH_AMOMAXU_W 0xe000202f
> +#define MASK_AMOMAXU_W  0xf800707f
> +#define MATCH_AMOSWAP_W 0x800202f
> +#define MASK_AMOSWAP_W  0xf800707f
> +#define MATCH_LR_W 0x1000202f
> +#define MASK_LR_W  0xf9f0707f
> +#define MATCH_SC_W 0x1800202f
> +#define MASK_SC_W  0xf800707f
> +#define MATCH_AMOADD_D 0x302f
> +#define MASK_AMOADD_D  0xf800707f
> +#define MATCH_AMOXOR_D 0x2000302f
> +#define MASK_AMOXOR_D  0xf800707f
> +#define MATCH_AMOOR_D 0x4000302f
> +#define MASK_AMOOR_D  0xf800707f
> +#define MATCH_AMOAND_D 0x6000302f
> +#define MASK_AMOAND_D  0xf800707f
> +#define MATCH_AMOMIN_D 0x8000302f
> +#define MASK_AMOMIN_D  0xf800707f
> +#define MATCH_AMOMAX_D 0xa000302f
> +#define MASK_AMOMAX_D  0xf800707f
> +#define MATCH_AMOMINU_D 0xc000302f
> +#define MASK_AMOMINU_D  0xf800707f
> +#define MATCH_AMOMAXU_D 0xe000302f
> +#define MASK_AMOMAXU_D  0xf800707f
> +#define MATCH_AMOSWAP_D 0x800302f
> +#define MASK_AMOSWAP_D  0xf800707f
> +#define MATCH_LR_D 0x1000302f
> +#define MASK_LR_D  0xf9f0707f
> +#define MATCH_SC_D 0x1800302f
> +#define MASK_SC_D  0xf800707f
> +#define MATCH_ECALL 0x73
> +#define MASK_ECALL  0xffffffff
> +#define MATCH_EBREAK 0x100073
> +#define MASK_EBREAK  0xffffffff
> +#define MATCH_URET 0x200073
> +#define MASK_URET  0xffffffff
> +#define MATCH_SRET 0x10200073
> +#define MASK_SRET  0xffffffff
> +#define MATCH_MRET 0x30200073
> +#define MASK_MRET  0xffffffff
> +#define MATCH_DRET 0x7b200073
> +#define MASK_DRET  0xffffffff
> +#define MATCH_SFENCE_VMA 0x12000073
> +#define MASK_SFENCE_VMA  0xfe007fff
> +#define MATCH_WFI 0x10500073
> +#define MASK_WFI  0xffffffff
> +#define MATCH_CSRRW 0x1073
> +#define MASK_CSRRW  0x707f
> +#define MATCH_CSRRS 0x2073
> +#define MASK_CSRRS  0x707f
> +#define MATCH_CSRRC 0x3073
> +#define MASK_CSRRC  0x707f
> +#define MATCH_CSRRWI 0x5073
> +#define MASK_CSRRWI  0x707f
> +#define MATCH_CSRRSI 0x6073
> +#define MASK_CSRRSI  0x707f
> +#define MATCH_CSRRCI 0x7073
> +#define MASK_CSRRCI  0x707f
> +#define MATCH_FADD_S 0x53
> +#define MASK_FADD_S  0xfe00007f
> +#define MATCH_FSUB_S 0x8000053
> +#define MASK_FSUB_S  0xfe00007f
> +#define MATCH_FMUL_S 0x10000053
> +#define MASK_FMUL_S  0xfe00007f
> +#define MATCH_FDIV_S 0x18000053
> +#define MASK_FDIV_S  0xfe00007f
> +#define MATCH_FSGNJ_S 0x20000053
> +#define MASK_FSGNJ_S  0xfe00707f
> +#define MATCH_FSGNJN_S 0x20001053
> +#define MASK_FSGNJN_S  0xfe00707f
> +#define MATCH_FSGNJX_S 0x20002053
> +#define MASK_FSGNJX_S  0xfe00707f
> +#define MATCH_FMIN_S 0x28000053
> +#define MASK_FMIN_S  0xfe00707f
> +#define MATCH_FMAX_S 0x28001053
> +#define MASK_FMAX_S  0xfe00707f
> +#define MATCH_FSQRT_S 0x58000053
> +#define MASK_FSQRT_S  0xfff0007f
> +#define MATCH_FADD_D 0x2000053
> +#define MASK_FADD_D  0xfe00007f
> +#define MATCH_FSUB_D 0xa000053
> +#define MASK_FSUB_D  0xfe00007f
> +#define MATCH_FMUL_D 0x12000053
> +#define MASK_FMUL_D  0xfe00007f
> +#define MATCH_FDIV_D 0x1a000053
> +#define MASK_FDIV_D  0xfe00007f
> +#define MATCH_FSGNJ_D 0x22000053
> +#define MASK_FSGNJ_D  0xfe00707f
> +#define MATCH_FSGNJN_D 0x22001053
> +#define MASK_FSGNJN_D  0xfe00707f
> +#define MATCH_FSGNJX_D 0x22002053
> +#define MASK_FSGNJX_D  0xfe00707f
> +#define MATCH_FMIN_D 0x2a000053
> +#define MASK_FMIN_D  0xfe00707f
> +#define MATCH_FMAX_D 0x2a001053
> +#define MASK_FMAX_D  0xfe00707f
> +#define MATCH_FCVT_S_D 0x40100053
> +#define MASK_FCVT_S_D  0xfff0007f
> +#define MATCH_FCVT_D_S 0x42000053
> +#define MASK_FCVT_D_S  0xfff0007f
> +#define MATCH_FSQRT_D 0x5a000053
> +#define MASK_FSQRT_D  0xfff0007f
> +#define MATCH_FADD_Q 0x6000053
> +#define MASK_FADD_Q  0xfe00007f
> +#define MATCH_FSUB_Q 0xe000053
> +#define MASK_FSUB_Q  0xfe00007f
> +#define MATCH_FMUL_Q 0x16000053
> +#define MASK_FMUL_Q  0xfe00007f
> +#define MATCH_FDIV_Q 0x1e000053
> +#define MASK_FDIV_Q  0xfe00007f
> +#define MATCH_FSGNJ_Q 0x26000053
> +#define MASK_FSGNJ_Q  0xfe00707f
> +#define MATCH_FSGNJN_Q 0x26001053
> +#define MASK_FSGNJN_Q  0xfe00707f
> +#define MATCH_FSGNJX_Q 0x26002053
> +#define MASK_FSGNJX_Q  0xfe00707f
> +#define MATCH_FMIN_Q 0x2e000053
> +#define MASK_FMIN_Q  0xfe00707f
> +#define MATCH_FMAX_Q 0x2e001053
> +#define MASK_FMAX_Q  0xfe00707f
> +#define MATCH_FCVT_S_Q 0x40300053
> +#define MASK_FCVT_S_Q  0xfff0007f
> +#define MATCH_FCVT_Q_S 0x46000053
> +#define MASK_FCVT_Q_S  0xfff0007f
> +#define MATCH_FCVT_D_Q 0x42300053
> +#define MASK_FCVT_D_Q  0xfff0007f
> +#define MATCH_FCVT_Q_D 0x46100053
> +#define MASK_FCVT_Q_D  0xfff0007f
> +#define MATCH_FSQRT_Q 0x5e000053
> +#define MASK_FSQRT_Q  0xfff0007f
> +#define MATCH_FLE_S 0xa0000053
> +#define MASK_FLE_S  0xfe00707f
> +#define MATCH_FLT_S 0xa0001053
> +#define MASK_FLT_S  0xfe00707f
> +#define MATCH_FEQ_S 0xa0002053
> +#define MASK_FEQ_S  0xfe00707f
> +#define MATCH_FLE_D 0xa2000053
> +#define MASK_FLE_D  0xfe00707f
> +#define MATCH_FLT_D 0xa2001053
> +#define MASK_FLT_D  0xfe00707f
> +#define MATCH_FEQ_D 0xa2002053
> +#define MASK_FEQ_D  0xfe00707f
> +#define MATCH_FLE_Q 0xa6000053
> +#define MASK_FLE_Q  0xfe00707f
> +#define MATCH_FLT_Q 0xa6001053
> +#define MASK_FLT_Q  0xfe00707f
> +#define MATCH_FEQ_Q 0xa6002053
> +#define MASK_FEQ_Q  0xfe00707f
> +#define MATCH_FCVT_W_S 0xc0000053
> +#define MASK_FCVT_W_S  0xfff0007f
> +#define MATCH_FCVT_WU_S 0xc0100053
> +#define MASK_FCVT_WU_S  0xfff0007f
> +#define MATCH_FCVT_L_S 0xc0200053
> +#define MASK_FCVT_L_S  0xfff0007f
> +#define MATCH_FCVT_LU_S 0xc0300053
> +#define MASK_FCVT_LU_S  0xfff0007f
> +#define MATCH_FMV_X_W 0xe0000053
> +#define MASK_FMV_X_W  0xfff0707f
> +#define MATCH_FCLASS_S 0xe0001053
> +#define MASK_FCLASS_S  0xfff0707f
> +#define MATCH_FCVT_W_D 0xc2000053
> +#define MASK_FCVT_W_D  0xfff0007f
> +#define MATCH_FCVT_WU_D 0xc2100053
> +#define MASK_FCVT_WU_D  0xfff0007f
> +#define MATCH_FCVT_L_D 0xc2200053
> +#define MASK_FCVT_L_D  0xfff0007f
> +#define MATCH_FCVT_LU_D 0xc2300053
> +#define MASK_FCVT_LU_D  0xfff0007f
> +#define MATCH_FMV_X_D 0xe2000053
> +#define MASK_FMV_X_D  0xfff0707f
> +#define MATCH_FCLASS_D 0xe2001053
> +#define MASK_FCLASS_D  0xfff0707f
> +#define MATCH_FCVT_W_Q 0xc6000053
> +#define MASK_FCVT_W_Q  0xfff0007f
> +#define MATCH_FCVT_WU_Q 0xc6100053
> +#define MASK_FCVT_WU_Q  0xfff0007f
> +#define MATCH_FCVT_L_Q 0xc6200053
> +#define MASK_FCVT_L_Q  0xfff0007f
> +#define MATCH_FCVT_LU_Q 0xc6300053
> +#define MASK_FCVT_LU_Q  0xfff0007f
> +#define MATCH_FMV_X_Q 0xe6000053
> +#define MASK_FMV_X_Q  0xfff0707f
> +#define MATCH_FCLASS_Q 0xe6001053
> +#define MASK_FCLASS_Q  0xfff0707f
> +#define MATCH_FCVT_S_W 0xd0000053
> +#define MASK_FCVT_S_W  0xfff0007f
> +#define MATCH_FCVT_S_WU 0xd0100053
> +#define MASK_FCVT_S_WU  0xfff0007f
> +#define MATCH_FCVT_S_L 0xd0200053
> +#define MASK_FCVT_S_L  0xfff0007f
> +#define MATCH_FCVT_S_LU 0xd0300053
> +#define MASK_FCVT_S_LU  0xfff0007f
> +#define MATCH_FMV_W_X 0xf0000053
> +#define MASK_FMV_W_X  0xfff0707f
> +#define MATCH_FCVT_D_W 0xd2000053
> +#define MASK_FCVT_D_W  0xfff0007f
> +#define MATCH_FCVT_D_WU 0xd2100053
> +#define MASK_FCVT_D_WU  0xfff0007f
> +#define MATCH_FCVT_D_L 0xd2200053
> +#define MASK_FCVT_D_L  0xfff0007f
> +#define MATCH_FCVT_D_LU 0xd2300053
> +#define MASK_FCVT_D_LU  0xfff0007f
> +#define MATCH_FMV_D_X 0xf2000053
> +#define MASK_FMV_D_X  0xfff0707f
> +#define MATCH_FCVT_Q_W 0xd6000053
> +#define MASK_FCVT_Q_W  0xfff0007f
> +#define MATCH_FCVT_Q_WU 0xd6100053
> +#define MASK_FCVT_Q_WU  0xfff0007f
> +#define MATCH_FCVT_Q_L 0xd6200053
> +#define MASK_FCVT_Q_L  0xfff0007f
> +#define MATCH_FCVT_Q_LU 0xd6300053
> +#define MASK_FCVT_Q_LU  0xfff0007f
> +#define MATCH_FMV_Q_X 0xf6000053
> +#define MASK_FMV_Q_X  0xfff0707f
> +#define MATCH_FLW 0x2007
> +#define MASK_FLW  0x707f
> +#define MATCH_FLD 0x3007
> +#define MASK_FLD  0x707f
> +#define MATCH_FLQ 0x4007
> +#define MASK_FLQ  0x707f
> +#define MATCH_FSW 0x2027
> +#define MASK_FSW  0x707f
> +#define MATCH_FSD 0x3027
> +#define MASK_FSD  0x707f
> +#define MATCH_FSQ 0x4027
> +#define MASK_FSQ  0x707f
> +#define MATCH_FMADD_S 0x43
> +#define MASK_FMADD_S  0x600007f
> +#define MATCH_FMSUB_S 0x47
> +#define MASK_FMSUB_S  0x600007f
> +#define MATCH_FNMSUB_S 0x4b
> +#define MASK_FNMSUB_S  0x600007f
> +#define MATCH_FNMADD_S 0x4f
> +#define MASK_FNMADD_S  0x600007f
> +#define MATCH_FMADD_D 0x2000043
> +#define MASK_FMADD_D  0x600007f
> +#define MATCH_FMSUB_D 0x2000047
> +#define MASK_FMSUB_D  0x600007f
> +#define MATCH_FNMSUB_D 0x200004b
> +#define MASK_FNMSUB_D  0x600007f
> +#define MATCH_FNMADD_D 0x200004f
> +#define MASK_FNMADD_D  0x600007f
> +#define MATCH_FMADD_Q 0x6000043
> +#define MASK_FMADD_Q  0x600007f
> +#define MATCH_FMSUB_Q 0x6000047
> +#define MASK_FMSUB_Q  0x600007f
> +#define MATCH_FNMSUB_Q 0x600004b
> +#define MASK_FNMSUB_Q  0x600007f
> +#define MATCH_FNMADD_Q 0x600004f
> +#define MASK_FNMADD_Q  0x600007f
> +#define MATCH_C_NOP 0x1
> +#define MASK_C_NOP  0xffff
> +#define MATCH_C_ADDI16SP 0x6101
> +#define MASK_C_ADDI16SP  0xef83
> +#define MATCH_C_JR 0x8002
> +#define MASK_C_JR  0xf07f
> +#define MATCH_C_JALR 0x9002
> +#define MASK_C_JALR  0xf07f
> +#define MATCH_C_EBREAK 0x9002
> +#define MASK_C_EBREAK  0xffff
> +#define MATCH_C_LD 0x6000
> +#define MASK_C_LD  0xe003
> +#define MATCH_C_SD 0xe000
> +#define MASK_C_SD  0xe003
> +#define MATCH_C_ADDIW 0x2001
> +#define MASK_C_ADDIW  0xe003
> +#define MATCH_C_LDSP 0x6002
> +#define MASK_C_LDSP  0xe003
> +#define MATCH_C_SDSP 0xe002
> +#define MASK_C_SDSP  0xe003
> +#define MATCH_C_ADDI4SPN 0x0
> +#define MASK_C_ADDI4SPN  0xe003
> +#define MATCH_C_FLD 0x2000
> +#define MASK_C_FLD  0xe003
> +#define MATCH_C_LW 0x4000
> +#define MASK_C_LW  0xe003
> +#define MATCH_C_FLW 0x6000
> +#define MASK_C_FLW  0xe003
> +#define MATCH_C_FSD 0xa000
> +#define MASK_C_FSD  0xe003
> +#define MATCH_C_SW 0xc000
> +#define MASK_C_SW  0xe003
> +#define MATCH_C_FSW 0xe000
> +#define MASK_C_FSW  0xe003
> +#define MATCH_C_ADDI 0x1
> +#define MASK_C_ADDI  0xe003
> +#define MATCH_C_JAL 0x2001
> +#define MASK_C_JAL  0xe003
> +#define MATCH_C_LI 0x4001
> +#define MASK_C_LI  0xe003
> +#define MATCH_C_LUI 0x6001
> +#define MASK_C_LUI  0xe003
> +#define MATCH_C_SRLI 0x8001
> +#define MASK_C_SRLI  0xec03
> +#define MATCH_C_SRAI 0x8401
> +#define MASK_C_SRAI  0xec03
> +#define MATCH_C_ANDI 0x8801
> +#define MASK_C_ANDI  0xec03
> +#define MATCH_C_SUB 0x8c01
> +#define MASK_C_SUB  0xfc63
> +#define MATCH_C_XOR 0x8c21
> +#define MASK_C_XOR  0xfc63
> +#define MATCH_C_OR 0x8c41
> +#define MASK_C_OR  0xfc63
> +#define MATCH_C_AND 0x8c61
> +#define MASK_C_AND  0xfc63
> +#define MATCH_C_SUBW 0x9c01
> +#define MASK_C_SUBW  0xfc63
> +#define MATCH_C_ADDW 0x9c21
> +#define MASK_C_ADDW  0xfc63
> +#define MATCH_C_J 0xa001
> +#define MASK_C_J  0xe003
> +#define MATCH_C_BEQZ 0xc001
> +#define MASK_C_BEQZ  0xe003
> +#define MATCH_C_BNEZ 0xe001
> +#define MASK_C_BNEZ  0xe003
> +#define MATCH_C_SLLI 0x2
> +#define MASK_C_SLLI  0xe003
> +#define MATCH_C_FLDSP 0x2002
> +#define MASK_C_FLDSP  0xe003
> +#define MATCH_C_LWSP 0x4002
> +#define MASK_C_LWSP  0xe003
> +#define MATCH_C_FLWSP 0x6002
> +#define MASK_C_FLWSP  0xe003
> +#define MATCH_C_MV 0x8002
> +#define MASK_C_MV  0xf003
> +#define MATCH_C_ADD 0x9002
> +#define MASK_C_ADD  0xf003
> +#define MATCH_C_FSDSP 0xa002
> +#define MASK_C_FSDSP  0xe003
> +#define MATCH_C_SWSP 0xc002
> +#define MASK_C_SWSP  0xe003
> +#define MATCH_C_FSWSP 0xe002
> +#define MASK_C_FSWSP  0xe003
> +#define MATCH_CUSTOM0 0xb
> +#define MASK_CUSTOM0  0x707f
> +#define MATCH_CUSTOM0_RS1 0x200b
> +#define MASK_CUSTOM0_RS1  0x707f
> +#define MATCH_CUSTOM0_RS1_RS2 0x300b
> +#define MASK_CUSTOM0_RS1_RS2  0x707f
> +#define MATCH_CUSTOM0_RD 0x400b
> +#define MASK_CUSTOM0_RD  0x707f
> +#define MATCH_CUSTOM0_RD_RS1 0x600b
> +#define MASK_CUSTOM0_RD_RS1  0x707f
> +#define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
> +#define MASK_CUSTOM0_RD_RS1_RS2  0x707f
> +#define MATCH_CUSTOM1 0x2b
> +#define MASK_CUSTOM1  0x707f
> +#define MATCH_CUSTOM1_RS1 0x202b
> +#define MASK_CUSTOM1_RS1  0x707f
> +#define MATCH_CUSTOM1_RS1_RS2 0x302b
> +#define MASK_CUSTOM1_RS1_RS2  0x707f
> +#define MATCH_CUSTOM1_RD 0x402b
> +#define MASK_CUSTOM1_RD  0x707f
> +#define MATCH_CUSTOM1_RD_RS1 0x602b
> +#define MASK_CUSTOM1_RD_RS1  0x707f
> +#define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
> +#define MASK_CUSTOM1_RD_RS1_RS2  0x707f
> +#define MATCH_CUSTOM2 0x5b
> +#define MASK_CUSTOM2  0x707f
> +#define MATCH_CUSTOM2_RS1 0x205b
> +#define MASK_CUSTOM2_RS1  0x707f
> +#define MATCH_CUSTOM2_RS1_RS2 0x305b
> +#define MASK_CUSTOM2_RS1_RS2  0x707f
> +#define MATCH_CUSTOM2_RD 0x405b
> +#define MASK_CUSTOM2_RD  0x707f
> +#define MATCH_CUSTOM2_RD_RS1 0x605b
> +#define MASK_CUSTOM2_RD_RS1  0x707f
> +#define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
> +#define MASK_CUSTOM2_RD_RS1_RS2  0x707f
> +#define MATCH_CUSTOM3 0x7b
> +#define MASK_CUSTOM3  0x707f
> +#define MATCH_CUSTOM3_RS1 0x207b
> +#define MASK_CUSTOM3_RS1  0x707f
> +#define MATCH_CUSTOM3_RS1_RS2 0x307b
> +#define MASK_CUSTOM3_RS1_RS2  0x707f
> +#define MATCH_CUSTOM3_RD 0x407b
> +#define MASK_CUSTOM3_RD  0x707f
> +#define MATCH_CUSTOM3_RD_RS1 0x607b
> +#define MASK_CUSTOM3_RD_RS1  0x707f
> +#define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
> +#define MASK_CUSTOM3_RD_RS1_RS2  0x707f
> +#define CSR_FFLAGS 0x1
> +#define CSR_FRM 0x2
> +#define CSR_FCSR 0x3
> +#define CSR_CYCLE 0xc00
> +#define CSR_TIME 0xc01
> +#define CSR_INSTRET 0xc02
> +#define CSR_HPMCOUNTER3 0xc03
> +#define CSR_HPMCOUNTER4 0xc04
> +#define CSR_HPMCOUNTER5 0xc05
> +#define CSR_HPMCOUNTER6 0xc06
> +#define CSR_HPMCOUNTER7 0xc07
> +#define CSR_HPMCOUNTER8 0xc08
> +#define CSR_HPMCOUNTER9 0xc09
> +#define CSR_HPMCOUNTER10 0xc0a
> +#define CSR_HPMCOUNTER11 0xc0b
> +#define CSR_HPMCOUNTER12 0xc0c
> +#define CSR_HPMCOUNTER13 0xc0d
> +#define CSR_HPMCOUNTER14 0xc0e
> +#define CSR_HPMCOUNTER15 0xc0f
> +#define CSR_HPMCOUNTER16 0xc10
> +#define CSR_HPMCOUNTER17 0xc11
> +#define CSR_HPMCOUNTER18 0xc12
> +#define CSR_HPMCOUNTER19 0xc13
> +#define CSR_HPMCOUNTER20 0xc14
> +#define CSR_HPMCOUNTER21 0xc15
> +#define CSR_HPMCOUNTER22 0xc16
> +#define CSR_HPMCOUNTER23 0xc17
> +#define CSR_HPMCOUNTER24 0xc18
> +#define CSR_HPMCOUNTER25 0xc19
> +#define CSR_HPMCOUNTER26 0xc1a
> +#define CSR_HPMCOUNTER27 0xc1b
> +#define CSR_HPMCOUNTER28 0xc1c
> +#define CSR_HPMCOUNTER29 0xc1d
> +#define CSR_HPMCOUNTER30 0xc1e
> +#define CSR_HPMCOUNTER31 0xc1f
> +#define CSR_SSTATUS 0x100
> +#define CSR_SIE 0x104
> +#define CSR_STVEC 0x105
> +#define CSR_SCOUNTEREN 0x106
> +#define CSR_SSCRATCH 0x140
> +#define CSR_SEPC 0x141
> +#define CSR_SCAUSE 0x142
> +#define CSR_SBADADDR 0x143
> +#define CSR_SIP 0x144
> +#define CSR_SPTBR 0x180
> +#define CSR_MSTATUS 0x300
> +#define CSR_MISA 0x301
> +#define CSR_MEDELEG 0x302
> +#define CSR_MIDELEG 0x303
> +#define CSR_MIE 0x304
> +#define CSR_MTVEC 0x305
> +#define CSR_MCOUNTEREN 0x306
> +#define CSR_MSCRATCH 0x340
> +#define CSR_MEPC 0x341
> +#define CSR_MCAUSE 0x342
> +#define CSR_MBADADDR 0x343
> +#define CSR_MIP 0x344
> +#define CSR_PMPCFG0 0x3a0
> +#define CSR_PMPCFG1 0x3a1
> +#define CSR_PMPCFG2 0x3a2
> +#define CSR_PMPCFG3 0x3a3
> +#define CSR_PMPADDR0 0x3b0
> +#define CSR_PMPADDR1 0x3b1
> +#define CSR_PMPADDR2 0x3b2
> +#define CSR_PMPADDR3 0x3b3
> +#define CSR_PMPADDR4 0x3b4
> +#define CSR_PMPADDR5 0x3b5
> +#define CSR_PMPADDR6 0x3b6
> +#define CSR_PMPADDR7 0x3b7
> +#define CSR_PMPADDR8 0x3b8
> +#define CSR_PMPADDR9 0x3b9
> +#define CSR_PMPADDR10 0x3ba
> +#define CSR_PMPADDR11 0x3bb
> +#define CSR_PMPADDR12 0x3bc
> +#define CSR_PMPADDR13 0x3bd
> +#define CSR_PMPADDR14 0x3be
> +#define CSR_PMPADDR15 0x3bf
> +#define CSR_TSELECT 0x7a0
> +#define CSR_TDATA1 0x7a1
> +#define CSR_TDATA2 0x7a2
> +#define CSR_TDATA3 0x7a3
> +#define CSR_DCSR 0x7b0
> +#define CSR_DPC 0x7b1
> +#define CSR_DSCRATCH 0x7b2
> +#define CSR_MCYCLE 0xb00
> +#define CSR_MINSTRET 0xb02
> +#define CSR_MHPMCOUNTER3 0xb03
> +#define CSR_MHPMCOUNTER4 0xb04
> +#define CSR_MHPMCOUNTER5 0xb05
> +#define CSR_MHPMCOUNTER6 0xb06
> +#define CSR_MHPMCOUNTER7 0xb07
> +#define CSR_MHPMCOUNTER8 0xb08
> +#define CSR_MHPMCOUNTER9 0xb09
> +#define CSR_MHPMCOUNTER10 0xb0a
> +#define CSR_MHPMCOUNTER11 0xb0b
> +#define CSR_MHPMCOUNTER12 0xb0c
> +#define CSR_MHPMCOUNTER13 0xb0d
> +#define CSR_MHPMCOUNTER14 0xb0e
> +#define CSR_MHPMCOUNTER15 0xb0f
> +#define CSR_MHPMCOUNTER16 0xb10
> +#define CSR_MHPMCOUNTER17 0xb11
> +#define CSR_MHPMCOUNTER18 0xb12
> +#define CSR_MHPMCOUNTER19 0xb13
> +#define CSR_MHPMCOUNTER20 0xb14
> +#define CSR_MHPMCOUNTER21 0xb15
> +#define CSR_MHPMCOUNTER22 0xb16
> +#define CSR_MHPMCOUNTER23 0xb17
> +#define CSR_MHPMCOUNTER24 0xb18
> +#define CSR_MHPMCOUNTER25 0xb19
> +#define CSR_MHPMCOUNTER26 0xb1a
> +#define CSR_MHPMCOUNTER27 0xb1b
> +#define CSR_MHPMCOUNTER28 0xb1c
> +#define CSR_MHPMCOUNTER29 0xb1d
> +#define CSR_MHPMCOUNTER30 0xb1e
> +#define CSR_MHPMCOUNTER31 0xb1f
> +#define CSR_MHPMEVENT3 0x323
> +#define CSR_MHPMEVENT4 0x324
> +#define CSR_MHPMEVENT5 0x325
> +#define CSR_MHPMEVENT6 0x326
> +#define CSR_MHPMEVENT7 0x327
> +#define CSR_MHPMEVENT8 0x328
> +#define CSR_MHPMEVENT9 0x329
> +#define CSR_MHPMEVENT10 0x32a
> +#define CSR_MHPMEVENT11 0x32b
> +#define CSR_MHPMEVENT12 0x32c
> +#define CSR_MHPMEVENT13 0x32d
> +#define CSR_MHPMEVENT14 0x32e
> +#define CSR_MHPMEVENT15 0x32f
> +#define CSR_MHPMEVENT16 0x330
> +#define CSR_MHPMEVENT17 0x331
> +#define CSR_MHPMEVENT18 0x332
> +#define CSR_MHPMEVENT19 0x333
> +#define CSR_MHPMEVENT20 0x334
> +#define CSR_MHPMEVENT21 0x335
> +#define CSR_MHPMEVENT22 0x336
> +#define CSR_MHPMEVENT23 0x337
> +#define CSR_MHPMEVENT24 0x338
> +#define CSR_MHPMEVENT25 0x339
> +#define CSR_MHPMEVENT26 0x33a
> +#define CSR_MHPMEVENT27 0x33b
> +#define CSR_MHPMEVENT28 0x33c
> +#define CSR_MHPMEVENT29 0x33d
> +#define CSR_MHPMEVENT30 0x33e
> +#define CSR_MHPMEVENT31 0x33f
> +#define CSR_MVENDORID 0xf11
> +#define CSR_MARCHID 0xf12
> +#define CSR_MIMPID 0xf13
> +#define CSR_MHARTID 0xf14
> +#define CSR_CYCLEH 0xc80
> +#define CSR_TIMEH 0xc81
> +#define CSR_INSTRETH 0xc82
> +#define CSR_HPMCOUNTER3H 0xc83
> +#define CSR_HPMCOUNTER4H 0xc84
> +#define CSR_HPMCOUNTER5H 0xc85
> +#define CSR_HPMCOUNTER6H 0xc86
> +#define CSR_HPMCOUNTER7H 0xc87
> +#define CSR_HPMCOUNTER8H 0xc88
> +#define CSR_HPMCOUNTER9H 0xc89
> +#define CSR_HPMCOUNTER10H 0xc8a
> +#define CSR_HPMCOUNTER11H 0xc8b
> +#define CSR_HPMCOUNTER12H 0xc8c
> +#define CSR_HPMCOUNTER13H 0xc8d
> +#define CSR_HPMCOUNTER14H 0xc8e
> +#define CSR_HPMCOUNTER15H 0xc8f
> +#define CSR_HPMCOUNTER16H 0xc90
> +#define CSR_HPMCOUNTER17H 0xc91
> +#define CSR_HPMCOUNTER18H 0xc92
> +#define CSR_HPMCOUNTER19H 0xc93
> +#define CSR_HPMCOUNTER20H 0xc94
> +#define CSR_HPMCOUNTER21H 0xc95
> +#define CSR_HPMCOUNTER22H 0xc96
> +#define CSR_HPMCOUNTER23H 0xc97
> +#define CSR_HPMCOUNTER24H 0xc98
> +#define CSR_HPMCOUNTER25H 0xc99
> +#define CSR_HPMCOUNTER26H 0xc9a
> +#define CSR_HPMCOUNTER27H 0xc9b
> +#define CSR_HPMCOUNTER28H 0xc9c
> +#define CSR_HPMCOUNTER29H 0xc9d
> +#define CSR_HPMCOUNTER30H 0xc9e
> +#define CSR_HPMCOUNTER31H 0xc9f
> +#define CSR_MCYCLEH 0xb80
> +#define CSR_MINSTRETH 0xb82
> +#define CSR_MHPMCOUNTER3H 0xb83
> +#define CSR_MHPMCOUNTER4H 0xb84
> +#define CSR_MHPMCOUNTER5H 0xb85
> +#define CSR_MHPMCOUNTER6H 0xb86
> +#define CSR_MHPMCOUNTER7H 0xb87
> +#define CSR_MHPMCOUNTER8H 0xb88
> +#define CSR_MHPMCOUNTER9H 0xb89
> +#define CSR_MHPMCOUNTER10H 0xb8a
> +#define CSR_MHPMCOUNTER11H 0xb8b
> +#define CSR_MHPMCOUNTER12H 0xb8c
> +#define CSR_MHPMCOUNTER13H 0xb8d
> +#define CSR_MHPMCOUNTER14H 0xb8e
> +#define CSR_MHPMCOUNTER15H 0xb8f
> +#define CSR_MHPMCOUNTER16H 0xb90
> +#define CSR_MHPMCOUNTER17H 0xb91
> +#define CSR_MHPMCOUNTER18H 0xb92
> +#define CSR_MHPMCOUNTER19H 0xb93
> +#define CSR_MHPMCOUNTER20H 0xb94
> +#define CSR_MHPMCOUNTER21H 0xb95
> +#define CSR_MHPMCOUNTER22H 0xb96
> +#define CSR_MHPMCOUNTER23H 0xb97
> +#define CSR_MHPMCOUNTER24H 0xb98
> +#define CSR_MHPMCOUNTER25H 0xb99
> +#define CSR_MHPMCOUNTER26H 0xb9a
> +#define CSR_MHPMCOUNTER27H 0xb9b
> +#define CSR_MHPMCOUNTER28H 0xb9c
> +#define CSR_MHPMCOUNTER29H 0xb9d
> +#define CSR_MHPMCOUNTER30H 0xb9e
> +#define CSR_MHPMCOUNTER31H 0xb9f
> +#define CAUSE_MISALIGNED_FETCH 0x0
> +#define CAUSE_FETCH_ACCESS 0x1
> +#define CAUSE_ILLEGAL_INSTRUCTION 0x2
> +#define CAUSE_BREAKPOINT 0x3
> +#define CAUSE_MISALIGNED_LOAD 0x4
> +#define CAUSE_LOAD_ACCESS 0x5
> +#define CAUSE_MISALIGNED_STORE 0x6
> +#define CAUSE_STORE_ACCESS 0x7
> +#define CAUSE_USER_ECALL 0x8
> +#define CAUSE_SUPERVISOR_ECALL 0x9
> +#define CAUSE_HYPERVISOR_ECALL 0xa
> +#define CAUSE_MACHINE_ECALL 0xb
> +#define CAUSE_FETCH_PAGE_FAULT 0xc
> +#define CAUSE_LOAD_PAGE_FAULT 0xd
> +#define CAUSE_STORE_PAGE_FAULT 0xf
> +#endif
> +#ifdef DECLARE_INSN
> +DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
> +DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
> +DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
> +DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
> +DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
> +DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
> +DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
> +DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
> +DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
> +DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
> +DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
> +DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
> +DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
> +DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
> +DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
> +DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
> +DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
> +DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
> +DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
> +DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
> +DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
> +DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
> +DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
> +DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
> +DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
> +DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
> +DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
> +DECLARE_INSN( or , MATCH_OR, MASK_OR)
> +DECLARE_INSN( and , MATCH_AND, MASK_AND)
> +DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
> +DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
> +DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
> +DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
> +DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
> +DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
> +DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
> +DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
> +DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
> +DECLARE_INSN(lb, MATCH_LB, MASK_LB)
> +DECLARE_INSN(lh, MATCH_LH, MASK_LH)
> +DECLARE_INSN(lw, MATCH_LW, MASK_LW)
> +DECLARE_INSN(ld, MATCH_LD, MASK_LD)
> +DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
> +DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
> +DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
> +DECLARE_INSN(sb, MATCH_SB, MASK_SB)
> +DECLARE_INSN(sh, MATCH_SH, MASK_SH)
> +DECLARE_INSN(sw, MATCH_SW, MASK_SW)
> +DECLARE_INSN(sd, MATCH_SD, MASK_SD)
> +DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
> +DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
> +DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
> +DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
> +DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
> +DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
> +DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
> +DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
> +DECLARE_INSN(rem, MATCH_REM, MASK_REM)
> +DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
> +DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
> +DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
> +DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
> +DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
> +DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
> +DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
> +DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
> +DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
> +DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
> +DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
> +DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
> +DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
> +DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
> +DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
> +DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
> +DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
> +DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
> +DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
> +DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
> +DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
> +DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
> +DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
> +DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
> +DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
> +DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
> +DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
> +DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
> +DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
> +DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
> +DECLARE_INSN(uret, MATCH_URET, MASK_URET)
> +DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
> +DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
> +DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
> +DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
> +DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
> +DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
> +DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
> +DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
> +DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
> +DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
> +DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
> +DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
> +DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
> +DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
> +DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
> +DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
> +DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
> +DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
> +DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
> +DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
> +DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
> +DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
> +DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
> +DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
> +DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
> +DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
> +DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
> +DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
> +DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
> +DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
> +DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
> +DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
> +DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
> +DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
> +DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
> +DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
> +DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
> +DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
> +DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
> +DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
> +DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
> +DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
> +DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
> +DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
> +DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
> +DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
> +DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
> +DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
> +DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
> +DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
> +DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
> +DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
> +DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
> +DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
> +DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
> +DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
> +DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
> +DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
> +DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
> +DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
> +DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
> +DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
> +DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
> +DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
> +DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
> +DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
> +DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
> +DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
> +DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
> +DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
> +DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
> +DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
> +DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
> +DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
> +DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
> +DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
> +DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
> +DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
> +DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
> +DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
> +DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
> +DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
> +DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
> +DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
> +DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
> +DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
> +DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
> +DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
> +DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
> +DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
> +DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
> +DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
> +DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
> +DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
> +DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
> +DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
> +DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
> +DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
> +DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
> +DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
> +DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
> +DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
> +DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
> +DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
> +DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
> +DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
> +DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
> +DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
> +DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
> +DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
> +DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
> +DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
> +DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
> +DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
> +DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
> +DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
> +DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
> +DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
> +DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
> +DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
> +DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
> +DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
> +DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
> +DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
> +DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
> +DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
> +DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
> +DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
> +DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
> +DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
> +DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
> +DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
> +DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
> +DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
> +DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
> +DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
> +DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
> +DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
> +DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
> +DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
> +DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
> +DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
> +DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
> +DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
> +DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
> +DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
> +DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
> +DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
> +DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
> +DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
> +DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
> +DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
> +DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
> +DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
> +DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
> +DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
> +DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
> +DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
> +DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
> +DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
> +DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
> +DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
> +DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
> +DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
> +DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
> +DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
> +DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
> +DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
> +DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
> +DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
> +DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
> +DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
> +DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
> +#endif
> +#ifdef DECLARE_CSR
> +DECLARE_CSR(fflags, CSR_FFLAGS)
> +DECLARE_CSR(frm, CSR_FRM)
> +DECLARE_CSR(fcsr, CSR_FCSR)
> +DECLARE_CSR(cycle, CSR_CYCLE)
> +DECLARE_CSR(time, CSR_TIME)
> +DECLARE_CSR(instret, CSR_INSTRET)
> +DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
> +DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
> +DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
> +DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
> +DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
> +DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
> +DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
> +DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
> +DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
> +DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
> +DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
> +DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
> +DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
> +DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
> +DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
> +DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
> +DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
> +DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
> +DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
> +DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
> +DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
> +DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
> +DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
> +DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
> +DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
> +DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
> +DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
> +DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
> +DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
> +DECLARE_CSR(sstatus, CSR_SSTATUS)
> +DECLARE_CSR(sie, CSR_SIE)
> +DECLARE_CSR(stvec, CSR_STVEC)
> +DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
> +DECLARE_CSR(sscratch, CSR_SSCRATCH)
> +DECLARE_CSR(sepc, CSR_SEPC)
> +DECLARE_CSR(scause, CSR_SCAUSE)
> +DECLARE_CSR(sbadaddr, CSR_SBADADDR)
> +DECLARE_CSR(sip, CSR_SIP)
> +DECLARE_CSR(sptbr, CSR_SPTBR)
> +DECLARE_CSR(mstatus, CSR_MSTATUS)
> +DECLARE_CSR(misa, CSR_MISA)
> +DECLARE_CSR(medeleg, CSR_MEDELEG)
> +DECLARE_CSR(mideleg, CSR_MIDELEG)
> +DECLARE_CSR(mie, CSR_MIE)
> +DECLARE_CSR(mtvec, CSR_MTVEC)
> +DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
> +DECLARE_CSR(mscratch, CSR_MSCRATCH)
> +DECLARE_CSR(mepc, CSR_MEPC)
> +DECLARE_CSR(mcause, CSR_MCAUSE)
> +DECLARE_CSR(mbadaddr, CSR_MBADADDR)
> +DECLARE_CSR(mip, CSR_MIP)
> +DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
> +DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
> +DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
> +DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
> +DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
> +DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
> +DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
> +DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
> +DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
> +DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
> +DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
> +DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
> +DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
> +DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
> +DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
> +DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
> +DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
> +DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
> +DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
> +DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
> +DECLARE_CSR(tselect, CSR_TSELECT)
> +DECLARE_CSR(tdata1, CSR_TDATA1)
> +DECLARE_CSR(tdata2, CSR_TDATA2)
> +DECLARE_CSR(tdata3, CSR_TDATA3)
> +DECLARE_CSR(dcsr, CSR_DCSR)
> +DECLARE_CSR(dpc, CSR_DPC)
> +DECLARE_CSR(dscratch, CSR_DSCRATCH)
> +DECLARE_CSR(mcycle, CSR_MCYCLE)
> +DECLARE_CSR(minstret, CSR_MINSTRET)
> +DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
> +DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
> +DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
> +DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
> +DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
> +DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
> +DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
> +DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
> +DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
> +DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
> +DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
> +DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
> +DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
> +DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
> +DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
> +DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
> +DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
> +DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
> +DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
> +DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
> +DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
> +DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
> +DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
> +DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
> +DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
> +DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
> +DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
> +DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
> +DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
> +DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
> +DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
> +DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
> +DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
> +DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
> +DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
> +DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
> +DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
> +DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
> +DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
> +DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
> +DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
> +DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
> +DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
> +DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
> +DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
> +DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
> +DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
> +DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
> +DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
> +DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
> +DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
> +DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
> +DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
> +DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
> +DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
> +DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
> +DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
> +DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
> +DECLARE_CSR(mvendorid, CSR_MVENDORID)
> +DECLARE_CSR(marchid, CSR_MARCHID)
> +DECLARE_CSR(mimpid, CSR_MIMPID)
> +DECLARE_CSR(mhartid, CSR_MHARTID)
> +DECLARE_CSR(cycleh, CSR_CYCLEH)
> +DECLARE_CSR(timeh, CSR_TIMEH)
> +DECLARE_CSR(instreth, CSR_INSTRETH)
> +DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
> +DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
> +DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
> +DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
> +DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
> +DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
> +DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
> +DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
> +DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
> +DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
> +DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
> +DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
> +DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
> +DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
> +DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
> +DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
> +DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
> +DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
> +DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
> +DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
> +DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
> +DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
> +DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
> +DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
> +DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
> +DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
> +DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
> +DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
> +DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
> +DECLARE_CSR(mcycleh, CSR_MCYCLEH)
> +DECLARE_CSR(minstreth, CSR_MINSTRETH)
> +DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
> +DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
> +DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
> +DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
> +DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
> +DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
> +DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
> +DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
> +DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
> +DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
> +DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
> +DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
> +DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
> +DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
> +DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
> +DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
> +DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
> +DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
> +DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
> +DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
> +DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
> +DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
> +DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
> +DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
> +DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
> +DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
> +DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
> +DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
> +DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
> +#endif
> +#ifdef DECLARE_CAUSE
> +DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
> +DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
> +DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
> +DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
> +DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
> +DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
> +DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
> +DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
> +DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
> +DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
> +DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
> +DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
> +DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
> +DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
> +DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
> +#endif
> diff --git a/cpukit/score/cpu/riscv/rtems/score/riscv.h b/cpukit/score/cpu/riscv/rtems/score/riscv.h
> new file mode 100644
> index 0000000..6e7f137
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/riscv.h
> @@ -0,0 +1,66 @@
> + * @file rtems/score/riscv.h
> + *  This file contains information pertaining to the riscv32 processor.
> + *  COPYRIGHT (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
> + *  Based on code with the following copyright...
> + *  COPYRIGHT (c) 1989-1999, 2010.
> + *  On-Line Applications Research Corporation (OAR).
> + * Redistribution and use in source and binary forms, with or without
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_RISCV_H
> +#define _RTEMS_SCORE_RISCV_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + *  This file contains the information required to build
> + *  RTEMS for a particular member of the RISCV family.
> + *  It does this by setting variables to indicate which
> + *  implementation dependent features are present in a particular
> + *  member of the family.
> + *  This is a good place to list all the known CPU models
> + *  that this port supports and which RTEMS CPU model they correspond
> + *  to.
> +*  Define the name of the CPU family and specific model.
> +#define CPU_NAME "RISCV"
> +#define CPU_MODEL_NAME "RISCV"
> +#ifdef __cplusplus
> +#endif
> +#endif /* _RTEMS_SCORE_RISCV_H */
> diff --git a/cpukit/score/cpu/riscv/rtems/score/types.h b/cpukit/score/cpu/riscv/rtems/score/types.h
> index 0000000..d1440fb
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv/rtems/score/types.h
> @@ -0,0 +1,70 @@
> + * @file
> + * @brief RISC-V Architecture Types API
> + *  This include file contains type definitions pertaining to the
> + *  RISC-V processor family.
> + * are met:
> + * SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_TYPES_H
> +#define _RTEMS_SCORE_TYPES_H
> +#include <rtems/score/basedefs.h>
> +#ifndef ASM
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup ScoreCPU
> + *  This section defines the basic types for this processor.
> +/** Type that can store a 32-bit integer or a pointer. */
> +typedef uintptr_t CPU_Uint32ptr;
> +typedef uint16_t Priority_bit_map_Word;
> +typedef void riscv_isr;
> +typedef void ( *riscv_isr_entry )( void );
> +#ifdef __cplusplus
> +#endif
> +#endif  /* !ASM */
> +#endif
> diff --git a/cpukit/score/cpu/riscv32 b/cpukit/score/cpu/riscv32
> new file mode 120000
> index 0000000..4847a64
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv32
> @@ -0,0 +1 @@
> +riscv
> \ No newline at end of file
> diff --git a/cpukit/score/cpu/riscv32/Makefile.am b/cpukit/score/cpu/riscv32/Makefile.am
> deleted file mode 100644
> index 1de5b2d..0000000
> --- a/cpukit/score/cpu/riscv32/Makefile.am
> +++ /dev/null
> @@ -1,26 +0,0 @@
> -include $(top_srcdir)/automake/compile.am
> -include_rtemsdir = $(includedir)/rtems
> -include_rtems_HEADERS = rtems/asm.h
> -include_rtems_scoredir = $(includedir)/rtems/score
> -include_rtems_score_HEADERS = rtems/score/cpu.h
> -include_rtems_score_HEADERS += rtems/score/cpuatomic.h
> -include_rtems_score_HEADERS += rtems/score/cpuimpl.h
> -include_rtems_score_HEADERS += rtems/score/cpu_asm.h
> -include_rtems_score_HEADERS += rtems/score/types.h
> -include_rtems_score_HEADERS += rtems/score/riscv.h
> -include_rtems_score_HEADERS += rtems/score/riscv-utility.h
> -noinst_LIBRARIES = libscorecpu.a
> -libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> -libscorecpu_a_SOURCES  = cpu.c
> -libscorecpu_a_SOURCES += riscv-exception-handler.S
> -libscorecpu_a_SOURCES += riscv-exception-default.c
> -libscorecpu_a_SOURCES += riscv-exception-frame-print.c
> -libscorecpu_a_SOURCES += riscv-context-switch.S
> -libscorecpu_a_SOURCES += riscv-context-initialize.c
> -libscorecpu_a_SOURCES += riscv-context-validate.S
> -libscorecpu_a_SOURCES += riscv-context-volatile-clobber.S
> -include $(srcdir)/preinstall.am
> -include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/score/cpu/riscv32/cpu.c b/cpukit/score/cpu/riscv32/cpu.c
> index 7061d10..0000000
> --- a/cpukit/score/cpu/riscv32/cpu.c
> +++ /dev/null
> @@ -1,124 +0,0 @@
> - * riscv32 CPU Dependent Source
> - * Copyright (c) 2015 University of York.
> - * Hesham ALmatary <hesham at alumni.york.ac.uk>
> - * COPYRIGHT (c) 1989-1999.
> - * On-Line Applications Research Corporation (OAR).
> - * Redistribution and use in source and binary forms, with or without
> - * modification, are permitted provided that the following conditions
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - *    notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - *    notice, this list of conditions and the following disclaimer in the
> - *    documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> - * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> - * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> - * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> - * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> - * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> - * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> - * SUCH DAMAGE.
> -#include <rtems/system.h>
> -#include <rtems/score/isr.h>
> -#include <rtems/score/wkspace.h>
> -#include <rtems/score/cpu.h>
> -/* bsp_start_vector_table_begin is the start address of the vector table
> - * containing addresses to ISR Handlers. It's defined at the BSP linkcmds
> - * and may differ from one BSP to another.
> -extern char bsp_start_vector_table_begin[];
> -void init(void);
> -void fini(void);
> -void _init()
> -void _fini()
> - * @brief Performs processor dependent initialization.
> -void _CPU_Initialize(void)
> -  /* Do nothing */
> -void _CPU_ISR_Set_level(uint32_t level)
> -  /* Do nothing */
> -uint32_t  _CPU_ISR_Get_level( void )
> -  /* Do nothing */
> -  return 0;
> -void _CPU_ISR_install_raw_handler(
> -  uint32_t   vector,
> -  proc_ptr    new_handler,
> -  proc_ptr   *old_handler
> -  /* Do nothing */
> -void _CPU_ISR_install_vector(
> -  uint32_t    vector,
> -  proc_ptr *table =
> -    (proc_ptr *) bsp_start_vector_table_begin;
> -  proc_ptr current_handler;
> -  ISR_Level level;
> -  _ISR_Local_disable( level );
> -  current_handler = table [vector];
> -  /* The current handler is now the old one */
> -  if (old_handler != NULL) {
> -    *old_handler = (proc_ptr) current_handler;
> -  /* Write only if necessary to avoid writes to a maybe read-only
> -   * memory */
> -  if (current_handler != new_handler) {
> -    table [vector] = new_handler;
> -  _ISR_Local_enable( level );
> -void _CPU_Install_interrupt_stack( void )
> -  /* Do nothing */
> -void *_CPU_Thread_Idle_body( uintptr_t ignored )
> -  do {
> -  } while (1);
> -  return NULL;
> diff --git a/cpukit/score/cpu/riscv32/riscv-context-initialize.c b/cpukit/score/cpu/riscv32/riscv-context-initialize.c
> index f4c3361..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-context-initialize.c
> +++ /dev/null
> @@ -1,67 +0,0 @@
> - * Hesham Almatary <hesham at alumni.york.ac.uk>
> - * COPYRIGHT (c) 1989-2006.
> - * are met:
> - * SUCH DAMAGE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include <string.h>
> -#include <rtems/score/riscv-utility.h>
> -#include <rtems/score/interr.h>
> -void _CPU_Context_Initialize(
> -  Context_Control *context,
> -  void *stack_area_begin,
> -  size_t stack_area_size,
> -  uint32_t new_level,
> -  void (*entry_point)( void ),
> -  bool is_fp,
> -  void *tls_area
> -  uintptr_t stack = ((uintptr_t) stack_area_begin);
> -  /* Account for red-zone */
> -  uintptr_t stack_high = stack + stack_area_size - RISCV_GCC_RED_ZONE_SIZE;
> -  memset(context, 0, sizeof(*context));
> -  /* Stack Pointer - sp/x2 */
> -  context->x[2] = stack_high;
> -  /* Frame Pointer - fp/x8 */
> -  context->x[8] = stack_high;
> -  /* Return Address - ra/x1 */
> -  context->x[1] = (uintptr_t) entry_point;
> -  /* Enable interrupts and FP */
> -  context->mstatus = MSTATUS_FS | MSTATUS_MIE;
> diff --git a/cpukit/score/cpu/riscv32/riscv-context-switch.S b/cpukit/score/cpu/riscv32/riscv-context-switch.S
> index acb7fba..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-context-switch.S
> +++ /dev/null
> @@ -1,139 +0,0 @@
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -#include <rtems/asm.h>
> -.section .text, "ax"
> -.align 4
> -# define LREG lw
> -# define SREG sw
> -PUBLIC(_CPU_Context_switch)
> -PUBLIC(_CPU_Context_restore)
> -PUBLIC(_CPU_Context_restore_fp)
> -PUBLIC(_CPU_Context_save_fp)
> -PUBLIC(restore)
> -SYM(_CPU_Context_switch):
> -  /* Disable interrupts and store all registers */
> -  csrr t0, mstatus
> -  SREG t0, (32 * CPU_SIZEOF_POINTER)(a0)
> -  csrci mstatus, MSTATUS_MIE
> -  SREG x1, (1 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x2, (2 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x3, (3 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x4, (4 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x5, (5 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x6, (6 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x7, (7 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x8, (8 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x9, (9 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x10, (10 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x11, (11 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x12, (12 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x13, (13 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x14, (14 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x15, (15 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x16, (16 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x17, (17 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x18, (18 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x19, (19 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x20, (20 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x21, (21 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x22, (22 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x23, (23 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x24, (24 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x25, (25 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x26, (26 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x27, (27 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x28, (28 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x29, (28 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x30, (30 * CPU_SIZEOF_POINTER)(a0)
> -  SREG x31, (31 * CPU_SIZEOF_POINTER)(a0)
> -  SYM(restore):
> -  LREG x1, (1 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x2, (2 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x3, (3 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x4, (4 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x5, (5 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x6, (6 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x7, (7 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x8, (8 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x9, (9 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x10, (10 * CPU_SIZEOF_POINTER)(a1)
> -  /* Skip a1/x11 */
> -  LREG x12, (12 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x13, (13 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x14, (14 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x15, (15 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x16, (16 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x17, (17 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x18, (18 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x19, (19 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x20, (20 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x21, (21 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x22, (22 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x23, (23 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x24, (24 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x25, (25 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x26, (26 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x27, (27 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x28, (28 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x29, (29 * CPU_SIZEOF_POINTER)(a1)
> -  LREG x30, (30 * CPU_SIZEOF_POINTER)(a1)
> -  /* Load mstatus */
> -  LREG x31, (32 * CPU_SIZEOF_POINTER)(a1)
> -  csrw mstatus, x31
> -  LREG x11, (11 * CPU_SIZEOF_POINTER)(a1)
> -  ret
> -  SYM(_CPU_Context_restore):
> -  mv     a1, a0
> -  j      restore
> -  /* TODO no FP support for riscv32 yet */
> -  SYM(_CPU_Context_restore_fp):
> -  nop
> -  SYM(_CPU_Context_save_fp):
> -  nop
> diff --git a/cpukit/score/cpu/riscv32/riscv-context-validate.S b/cpukit/score/cpu/riscv32/riscv-context-validate.S
> index 8e9a5d3..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-context-validate.S
> +++ /dev/null
> @@ -1,201 +0,0 @@
> - * Copyrigh (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -.section       .text
> -#define SREG sw
> -#define LREG lw
> -PUBLIC(_CPU_Context_validate)
> -SYM(_CPU_Context_validate):
> -  addi sp, sp, -144
> -  SREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
> -  /* Skip x2/sp */
> -  SREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x29, (28 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
> -  SREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
> -  /* Fill */
> -  /* t0 is used for temporary values */
> -  mv t0, x0
> -  /* x31 contains the stack pointer */
> -  mv x31, sp
> -  .macro fill_register reg
> -  addi t0, t0,  1
> -  mv   \reg, t0
> -  .endm
> -  fill_register        x1
> -  fill_register        x2
> -  fill_register        x3
> -  fill_register        x4
> -  fill_register        x5
> -  fill_register        x6
> -  fill_register        x7
> -  fill_register        x8
> -  fill_register        x9
> -  fill_register        x10
> -  fill_register        x11
> -  fill_register        x12
> -  fill_register        x13
> -  fill_register        x14
> -  fill_register        x15
> -  fill_register        x16
> -  fill_register        x17
> -  fill_register        x18
> -  fill_register        x19
> -  fill_register        x20
> -  fill_register        x21
> -  fill_register        x22
> -  fill_register        x23
> -  fill_register        x24
> -  fill_register        x25
> -  fill_register        x26
> -  fill_register        x27
> -  fill_register        x28
> -  fill_register        x29
> -  fill_register        x30
> -  fill_register        x31
> -  /* Check */
> -check:
> -  .macro check_register reg
> -  addi t0, t0, 1
> -  bne \reg, t0, restore
> -  .endm
> -  bne   x31, sp, restore
> -  mv t0, x0
> -  check_register       x1
> -  check_register       x2
> -  check_register       x3
> -  check_register       x4
> -  check_register       x5
> -  check_register       x6
> -  check_register       x7
> -  check_register       x8
> -  check_register       x9
> -  check_register       x10
> -  check_register       x11
> -  check_register       x12
> -  check_register       x13
> -  check_register       x14
> -  check_register       x15
> -  check_register       x16
> -  check_register       x17
> -  check_register       x18
> -  check_register       x19
> -  check_register       x20
> -  check_register       x21
> -  check_register       x22
> -  check_register       x23
> -  check_register       x24
> -  check_register       x25
> -  check_register       x26
> -  check_register       x27
> -  check_register       x28
> -  check_register       x29
> -  check_register       x30
> -  check_register       x31
> -  j check
> -  /* Restore */
> -restore:
> -  LREG x1, (1 * CPU_SIZEOF_POINTER)(sp)
> -  /* Skip sp/x2 */
> -  LREG x3, (3 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x4, (4 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x5, (5 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x6, (6 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x7, (7 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x8, (8 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x9, (9 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x10, (10 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x11, (11 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x12, (12 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x13, (13 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x14, (14 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x15, (15 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x16, (16 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x17, (17 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x18, (18 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x19, (19 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x20, (20 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x21, (21 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x22, (22 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x23, (23 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x24, (24 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x25, (25 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x26, (26 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x27, (27 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x28, (28 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x29, (29 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x30, (30 * CPU_SIZEOF_POINTER)(sp)
> -  LREG x31, (31 * CPU_SIZEOF_POINTER)(sp)
> -  addi sp, sp, 144
> -  ret
> diff --git a/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S b/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
> index 58ec25b..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-context-volatile-clobber.S
> +++ /dev/null
> @@ -1,50 +0,0 @@
> - * Copyright (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -.section .text
> -PUBLIC(_CPU_Context_volatile_clobber)
> -SYM(_CPU_Context_volatile_clobber):
> -  .macro clobber_register reg
> -  addi t0, t0, -1
> -  mv  \reg, t0
> -  .endm
> -  clobber_register  a0
> -  clobber_register  a1
> -  clobber_register  a2
> -  clobber_register  a3
> -  clobber_register  a4
> -  clobber_register  a5
> -  clobber_register  a6
> -  ret
> diff --git a/cpukit/score/cpu/riscv32/riscv-exception-default.c b/cpukit/score/cpu/riscv32/riscv-exception-default.c
> index 62d0dd3..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-exception-default.c
> +++ /dev/null
> @@ -1,39 +0,0 @@
> - * Copyright (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -#include <rtems/fatal.h>
> -#include <stdio.h>
> -void _RISCV_Exception_default(uint32_t vector, CPU_Exception_frame *frame);
> -  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
> diff --git a/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c b/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
> index 377616c..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-exception-frame-print.c
> +++ /dev/null
> @@ -1,41 +0,0 @@
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -#include <rtems/bspIo.h>
> -#include <inttypes.h>
> -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> -  int i;
> -  for ( i = 0; i < 32; ++i ) {
> -    printk( "x%02i = 0x%016" PRIx32 "\n", i, frame->x[i]);
> diff --git a/cpukit/score/cpu/riscv32/riscv-exception-handler.S b/cpukit/score/cpu/riscv32/riscv-exception-handler.S
> index 69bab1f..0000000
> --- a/cpukit/score/cpu/riscv32/riscv-exception-handler.S
> +++ /dev/null
> @@ -1,220 +0,0 @@
> - * @file
> - * @ingroup ScoreCPU
> - * @brief riscv32 exception support implementation.
> - * are met:
> - * SUCH DAMAGE.
> -#endif
> -#include <rtems/score/percpu.h>
> -# define LREG lw
> -# define SREG sw
> -EXTERN(bsp_start_vector_table_begin)
> -EXTERN(_Thread_Dispatch)
> -PUBLIC(ISR_Handler)
> -.align 4
> -TYPE_FUNC(ISR_Handler)
> -SYM(ISR_Handler):
> -  addi sp, sp, -144
> -  /* Skip x2/sp */
> -  /* Exception level related registers */
> -  csrr a0, mstatus
> -  SREG a0, (32 * CPU_SIZEOF_POINTER)(sp)
> -  csrr a0, mcause
> -  SREG a0, (33 * CPU_SIZEOF_POINTER)(sp)
> -  csrr a1, mepc
> -  SREG a1, (34 * CPU_SIZEOF_POINTER)(sp)
> -  /* FIXME Only handle interrupts for now (MSB = 1) */
> -  andi a0, a0, 0xf
> -  /* Increment nesting level */
> -  la t0, ISR_NEST_LEVEL
> -  /* Disable multitasking */
> -  la t1, THREAD_DISPATCH_DISABLE_LEVEL
> -  LREG t2, (t0)
> -  LREG t3, (t1)
> -  addi t2, t2, 1
> -  addi t3, t3, 1
> -  SREG t2, (t0)
> -  SREG t3, (t1)
> -  /* Save interrupted task stack pointer */
> -  addi t4, sp, 144
> -  SREG t4, (2 * CPU_SIZEOF_POINTER)(sp)
> -  /* Keep sp (Exception frame address) in s1 */
> -  mv   s1, sp
> -  /* Call the exception handler from vector table */
> -  /* First function arg for C handler is vector number,
> -   * and the second is a pointer to exception frame.
> -   * a0/mcause/vector number is already loaded above */
> -  mv a1, sp
> -  /* calculate the offset */
> -  la   t5, bsp_start_vector_table_begin
> -  slli t6, a0, 2
> -  add  t5, t5, t6
> -  LREG t5, (t5)
> -  /* Do not switch stacks if we are in a nested interrupt. At
> -   * this point t2 should be holding ISR_NEST_LEVEL value.
> -  li   s0, 1
> -  bgtu t2, s0, jump_to_c_handler
> -  /* Switch to RTEMS dedicated interrupt stack */
> -  la     sp, INTERRUPT_STACK_HIGH
> -  LREG   sp, (sp)
> -jump_to_c_handler:
> -  jalr t5
> -  /* Switch back to the interrupted task stack */
> -  mv sp, s1
> -  /* Decrement nesting level */
> -  /* Enable multitasking */
> -  LREG t2, (t0)
> -  LREG t3, (t1)
> -  addi t2, t2, -1
> -  addi t3, t3, -1
> -  SREG t2, (t0)
> -  SREG t3, (t1)
> -  /* Check if _ISR_Nest_level > 0 */
> -  bgtz t2, exception_frame_restore
> -  /* Check if _Thread_Dispatch_disable_level > 0 */
> -  bgtz t3, exception_frame_restore
> -  /* Check if dispatch needed */
> -  la   x31, DISPATCH_NEEDED
> -  LREG x31, (x31)
> -  beqz x31, exception_frame_restore
> -  la x31, _Thread_Dispatch
> -  jalr x31
> -  SYM(exception_frame_restore):
> -  /* Skip sp/x2 */
> -  LREG x31, (32 * CPU_SIZEOF_POINTER)(sp)
> -  csrw mstatus, x31
> -  /* Load mepc */
> -  LREG x31, (34 * CPU_SIZEOF_POINTER)(sp)
> -  csrw mepc, x31
> -  /* Unwind exception frame */
> -  addi sp, sp, 144
> -  mret
> diff --git a/cpukit/score/cpu/riscv32/rtems/asm.h b/cpukit/score/cpu/riscv32/rtems/asm.h
> index 34b6474..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/asm.h
> +++ /dev/null
> @@ -1,120 +0,0 @@
> - * @file rtems/asm.h
> - *  This include file attempts to address the problems
> - *  caused by incompatible flavors of assemblers and
> - *  toolsets.  It primarily addresses variations in the
> - *  use of leading underscores on symbols and the requirement
> - *  that register names be preceded by a %.
> - *  NOTE: The spacing in the use of these macros
> - *        is critical to them working as advertised.
> - *  This file is based on similar code found in newlib available
> - *  from ftp.cygnus.com.  The file which was used had no copyright
> - *  notice.  This file is freely distributable as long as the source
> - *  of the file is noted.  This file is:
> - * COPYRIGHT (c) 1994-1997.
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef __RISCV_ASM_H
> -#define __RISCV_ASM_H
> - *  Indicate we are in an assembly file and get the basic CPU definitions.
> -#ifndef ASM
> -#define ASM
> -#endif
> -#include <rtems/score/cpuopts.h>
> -#include <rtems/score/riscv.h>
> - *  Recent versions of GNU cpp define variables which indicate the
> - *  need for underscores and percents.  If not using GNU cpp or
> - *  the version does not support this, then you will obviously
> - *  have to define these as appropriate.
> -#ifndef __USER_LABEL_PREFIX__
> -#define __USER_LABEL_PREFIX__ _
> -#endif
> -#ifndef __REGISTER_PREFIX__
> -#define __REGISTER_PREFIX__
> -#endif
> -/* ANSI concatenation macros.  */
> -#define CONCAT1(a, b) CONCAT2(a, b)
> -#define CONCAT2(a, b) a ## b
> -/* Use the right prefix for global labels.  */
> -#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> -/* Use the right prefix for registers.  */
> -#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> - *  define macros for all of the registers on this CPU
> - *  EXAMPLE:     #define d0 REG (d0)
> - *  Define macros to handle section beginning and ends.
> -#define BEGIN_CODE_DCL .text
> -#define END_CODE_DCL
> -#define BEGIN_DATA_DCL .data
> -#define END_DATA_DCL
> -#define BEGIN_CODE .text
> -#define END_CODE
> -#define BEGIN_DATA
> -#define END_DATA
> -#define BEGIN_BSS
> -#define END_BSS
> -#define END
> - *  Following must be tailor for a particular flavor of the C compiler.
> - *  They may need to put underscores in front of the symbols.
> -#define PUBLIC(sym)    .global SYM (sym)
> -#define EXTERN(sym)    .extern SYM (sym)
> -#define TYPE_FUNC(sym) .type SYM (sym), %function
> -#endif
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu.h b/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> index f77db55..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/cpu.h
> +++ /dev/null
> @@ -1,585 +0,0 @@
> - * @file rtems/score/cpu.h
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef _RISCV_CPU_H
> -#define _RISCV_CPU_H
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -#include <rtems/score/riscv.h> /* pick up machine definitions */
> -#include <rtems/score/types.h>
> -#ifndef ASM
> -#include <stdint.h>
> -#include <stdio.h> /* for printk */
> -#endif
> -#define CPU_INLINE_ENABLE_DISPATCH       FALSE
> -#define CPU_UNROLL_ENQUEUE_PRIORITY      TRUE
> -#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
> -#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
> -#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> -#define CPU_ISR_PASSES_FRAME_POINTER 1
> -#define CPU_HARDWARE_FP                  FALSE
> -#define CPU_SOFTWARE_FP                  FALSE
> -#define CPU_ALL_TASKS_ARE_FP             FALSE
> -#define CPU_IDLE_TASK_IS_FP              FALSE
> -#define CPU_USE_DEFERRED_FP_SWITCH       FALSE
> -#define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
> -#define CPU_STACK_GROWS_UP               FALSE
> -#define CPU_STRUCTURE_ALIGNMENT __attribute__ ((aligned (64)))
> -#define CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES     FALSE
> -#define CPU_BIG_ENDIAN                           FALSE
> -#define CPU_LITTLE_ENDIAN                        TRUE
> -#define CPU_MODES_INTERRUPT_MASK   0x00000001
> - *  Processor defined structures required for cpukit/score.
> -#ifndef ASM
> -typedef struct {
> -  /* riscv32 has 32 32-bit general purpose registers (x0-x31). */
> -  uint32_t  x[32];
> -  /* Special purpose registers */
> -  uint32_t  mstatus;
> -  uint32_t  mcause;
> -  uint32_t  mepc;
> -#ifdef RTEMS_SMP
> -   * @brief On SMP configurations the thread context must contain a boolean
> -   * indicator to signal if this context is executing on a processor.
> -   * This field must be updated during a context switch.  The context switch
> -   * to the heir must wait until the heir context indicates that it is no
> -   * longer executing on a processor.  The context switch must also check if
> -   * a thread dispatch is necessary to honor updates of the heir thread for
> -   * this processor.  This indicator must be updated using an atomic test and
> -   * set operation to ensure that at most one processor uses the heir
> -   * context at the same time.
> -   * @code
> -   * void _CPU_Context_switch(
> -   *   Context_Control *executing,
> -   *   Context_Control *heir
> -   *   save( executing );
> -   *   executing->is_executing = false;
> -   *   memory_barrier();
> -   *   if ( test_and_set( &heir->is_executing ) ) {
> -   *     do {
> -   *       Per_CPU_Control *cpu_self = _Per_CPU_Get_snapshot();
> -   *       if ( cpu_self->dispatch_necessary ) {
> -   *         heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
> -   *     } while ( test_and_set( &heir->is_executing ) );
> -   *   restore( heir );
> -   * @endcode
> -  volatile bool is_executing;
> -#endif
> -} Context_Control;
> -#define _CPU_Context_Get_SP( _context ) \
> -  (_context)->x[2]
> -typedef struct {
> -  /** TODO FPU registers are listed here */
> -  double  some_float_register;
> -} Context_Control_fp;
> -typedef Context_Control CPU_Interrupt_frame;
> -#define CPU_CONTEXT_FP_SIZE  0
> -Context_Control_fp  _CPU_Null_fp_context;
> -#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> -#define CPU_STACK_MINIMUM_SIZE  4096
> -#define CPU_ALIGNMENT 8
> -#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> -#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
> -#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
> -#define CPU_STACK_ALIGNMENT        8
> -#define _CPU_Initialize_vectors()
> - *  Disable all interrupts for an RTEMS critical section.  The previous
> - *  level is returned in _level.
> -static inline uint32_t riscv_interrupt_disable( void )
> -  register uint32_t status = read_csr(mstatus);
> -  clear_csr(mstatus, MSTATUS_MIE);
> -  return status;
> -static inline void riscv_interrupt_enable(uint32_t level)
> -  write_csr(mstatus, level);
> -#define _CPU_ISR_Disable( _level ) \
> -    _level = riscv_interrupt_disable()
> -#define _CPU_ISR_Enable( _level )  \
> -  riscv_interrupt_enable( _level )
> -#define _CPU_ISR_Flash( _level ) \
> -  do{ \
> -      _CPU_ISR_Enable( _level ); \
> -      riscv_interrupt_disable(); \
> -    } while(0)
> -RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
> -  return ( level & MSTATUS_MIE ) != 0;
> -void _CPU_ISR_Set_level( uint32_t level );
> -uint32_t _CPU_ISR_Get_level( void );
> -/* end of ISR handler macros */
> -/* Context handler macros */
> -#define RISCV_GCC_RED_ZONE_SIZE 128
> -  bool is_fp,
> -  void *tls_area
> -#define _CPU_Context_Restart_self( _the_context ) \
> -   _CPU_Context_restore( (_the_context) )
> -#define _CPU_Context_Fp_start( _base, _offset ) \
> -   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
> -#define _CPU_Context_Initialize_fp( _destination ) \
> -   *(*(_destination)) = _CPU_Null_fp_context; \
> -extern void _CPU_Fatal_halt(uint32_t source, uint32_t error)
> -RTEMS_NO_RETURN;
> -/* end of Fatal Error manager macros */
> -#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> -#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> -#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> -#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> -    (_output) = 0;   /* do something to prevent warnings */ \
> -#endif
> -/* end of Bitfield handler macros */
> - *  This routine builds the mask which corresponds to the bit fields
> - *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
> - *  for that routine.
> -#define _CPU_Priority_Mask( _bit_number ) \
> -    (1 << _bit_number)
> -#endif
> -#define _CPU_Priority_bits_index( _priority ) \
> -  (_priority)
> -#endif
> -#define CPU_MAXIMUM_PROCESSORS 32
> -#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC FALSE
> -#define CPU_TIMESTAMP_USE_INT64 TRUE
> -#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
> -typedef struct {
> -  /* There is no CPU specific per-CPU state */
> -} CPU_Per_CPU_control;
> -#endif /* ASM */
> -#define CPU_SIZEOF_POINTER 4
> -#define CPU_EXCEPTION_FRAME_SIZE 128
> -#define CPU_PER_CPU_CONTROL_SIZE 0
> -#ifndef ASM
> -typedef uint16_t Priority_bit_map_Word;
> -typedef struct {
> -  uint32_t x[32];;
> -} CPU_Exception_frame;
> - * @brief Prints the exception frame via printk().
> - * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
> -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> -/* end of Priority handler macros */
> -/* functions */
> - *  _CPU_Initialize
> - *  This routine performs CPU dependent initialization.
> -  void
> - *  _CPU_ISR_install_raw_handler
> - *  This routine installs a "raw" interrupt handler directly into the
> - *  processor's vector table.
> -  uint32_t    vector,
> - *  _CPU_ISR_install_vector
> - *  This routine installs an interrupt vector.
> - *  NO_CPU Specific Information:
> - *  XXX document implementation including references if appropriate
> -  uint32_t    vector,
> - *  _CPU_Install_interrupt_stack
> - *  This routine installs the hardware interrupt stack pointer.
> - *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
> - *         is TRUE.
> -void _CPU_Install_interrupt_stack( void );
> - *  _CPU_Thread_Idle_body
> - *  This routine is the CPU dependent IDLE thread body.
> - *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
> - *         is TRUE.
> -void *_CPU_Thread_Idle_body( uintptr_t ignored );
> - *  _CPU_Context_switch
> - *  This routine switches from the run context to the heir context.
> - *  RISCV Specific Information:
> - *  Please see the comments in the .c file for a description of how
> - *  this function works. There are several things to be aware of.
> -void _CPU_Context_switch(
> -  Context_Control  *run,
> -  Context_Control  *heir
> - *  _CPU_Context_restore
> - *  This routine is generally used only to restart self in an
> - *  efficient manner.  It may simply be a label in _CPU_Context_switch.
> - *  NOTE: May be unnecessary to reload some registers.
> -void _CPU_Context_restore(
> -  Context_Control *new_context
> -) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
> - *  _CPU_Context_save_fp
> - *  This routine saves the floating point context passed to it.
> -void _CPU_Context_save_fp(
> -  void **fp_context_ptr
> - *  _CPU_Context_restore_fp
> - *  This routine restores the floating point context passed to it.
> -void _CPU_Context_restore_fp(
> -/*  The following routine swaps the endian format of an unsigned int.
> - *  It must be static because it is referenced indirectly.
> - *  This version will work on any processor, but if there is a better
> - *  way for your CPU PLEASE use it.  The most common way to do this is to:
> - *     swap least significant two bytes with 16-bit rotate
> - *     swap upper and lower 16-bits
> - *     swap most significant two bytes with 16-bit rotate
> - *  Some CPUs have special instructions which swap a 32-bit quantity in
> - *  a single instruction (e.g. i486).  It is probably best to avoid
> - *  an "endian swapping control bit" in the CPU.  One good reason is
> - *  that interrupts would probably have to be disabled to insure that
> - *  an interrupt does not try to access the same "chunk" with the wrong
> - *  endian.  Another good reason is that on some CPUs, the endian bit
> - *  endianness for ALL fetches -- both code and data -- so the code
> - *  will be fetched incorrectly.
> -static inline unsigned int CPU_swap_u32(
> -  unsigned int value
> -  uint32_t   byte1, byte2, byte3, byte4, swapped;
> -  byte4 = (value >> 24) & 0xff;
> -  byte3 = (value >> 16) & 0xff;
> -  byte2 = (value >> 8)  & 0xff;
> -  byte1 =  value        & 0xff;
> -  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> -  return ( swapped );
> -#define CPU_swap_u16( value ) \
> -  (((value&0xff) << 8) | ((value >> 8)&0xff))
> -static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
> -  /* TODO */
> -static inline void _CPU_Context_validate( uintptr_t pattern )
> -  while (1) {
> -    /* TODO */
> -typedef uint32_t CPU_Counter_ticks;
> -CPU_Counter_ticks _CPU_Counter_read( void );
> -#ifdef RTEMS_SMP
> - * @brief Performs CPU specific SMP initialization in the context of the boot
> - * processor.
> - * This function is invoked on the boot processor during system
> - * initialization.  All interrupt stacks are allocated at this point in case
> - * the CPU port allocates the interrupt stacks.  This function is called
> - * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
> - * used.
> - * @return The count of physically or virtually available processors.
> - * Depending on the configuration the application may use not all processors.
> -uint32_t _CPU_SMP_Initialize( void );
> - * @brief Starts a processor specified by its index.
> - * initialization.
> - * This function will be called after _CPU_SMP_Initialize().
> - * @param[in] cpu_index The processor index.
> - * @retval true Successful operation.
> - * @retval false Unable to start this processor.
> -bool _CPU_SMP_Start_processor( uint32_t cpu_index );
> - * @brief Performs final steps of CPU specific SMP initialization in the
> - * context of the boot processor.
> - * initialization.
> - * This function will be called after all processors requested by the
> - * application have been started.
> - * @param[in] cpu_count The minimum value of the count of processors
> - * requested by the application configuration and the count of physically or
> - * virtually available processors.
> -void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
> - * @brief Returns the index of the current processor.
> - * An architecture specific method must be used to obtain the index of the
> - * current processor in the system.  The set of processor indices is the
> - * range of integers starting with zero up to the processor count minus one.
> -uint32_t _CPU_SMP_Get_current_processor( void );
> - * @brief Sends an inter-processor interrupt to the specified target
> - * processor.
> - * This operation is undefined for target processor indices out of range.
> - * @param[in] target_processor_index The target processor index.
> -void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
> - * @brief Broadcasts a processor event.
> - * Some architectures provide a low-level synchronization primitive for
> - * processors in a multi-processor environment.  Processors waiting for this
> - * event may go into a low-power state and stop generating system bus
> - * transactions.  This function must ensure that preceding store operations
> - * can be observed by other processors.
> - * @see _CPU_SMP_Processor_event_receive().
> -void _CPU_SMP_Processor_event_broadcast( void );
> - * @brief Receives a processor event.
> - * This function will wait for the processor event and may wait forever if no
> - * such event arrives.
> - * @see _CPU_SMP_Processor_event_broadcast().
> -static inline void _CPU_SMP_Processor_event_receive( void )
> -  __asm__ volatile ( "" : : : "memory" );
> - * @brief Gets the is executing indicator of the thread context.
> - * @param[in] context The context.
> -static inline bool _CPU_Context_Get_is_executing(
> -  const Context_Control *context
> -  return context->is_executing;
> - * @brief Sets the is executing indicator of the thread context.
> - * @param[in] is_executing The new value for the is executing indicator.
> -static inline void _CPU_Context_Set_is_executing(
> -  bool is_executing
> -  context->is_executing = is_executing;
> -#endif /* RTEMS_SMP */
> -#endif /* ASM */
> -#ifdef __cplusplus
> -#endif
> -#endif
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h b/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
> index b5a56f3..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/cpu_asm.h
> +++ /dev/null
> @@ -1,90 +0,0 @@
> - * @file
> - * @brief riscv32 Assembly File
> - * Very loose template for an include file for the cpu_asm.? file
> - * if it is implemented as a ".S" file (preprocessed by cpp) instead
> - * of a ".s" file (preprocessed by gm4 or gasp).
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef _RTEMS_SCORE_CPU_ASM_H
> -#define _RTEMS_SCORE_CPU_ASM_H
> -/* pull in the generated offsets */
> -#include <rtems/score/offsets.h>
> - * Hardware General Registers
> -/* put something here */
> - * Hardware Floating Point Registers
> - * Hardware Control Registers
> - * Calling Convention
> - * Temporary registers
> - * Floating Point Registers - SW Conventions
> - * Temporary floating point registers
> -#endif
> -/* end of file */
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h b/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
> index 8ee9606..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/cpuatomic.h
> +++ /dev/null
> @@ -1,31 +0,0 @@
> - * COPYRIGHT (c) 2012-2013 Deng Hengyi.
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
> -#define _RTEMS_SCORE_ATOMIC_CPU_H
> -#include <rtems/score/cpustdatomic.h>
> -#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h b/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
> index 3904c84..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/cpuimpl.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> - * @file
> - * @brief CPU Port Implementation API
> - * Copyright (c) 2013 embedded brains GmbH
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef _RTEMS_SCORE_CPUIMPL_H
> -#define _RTEMS_SCORE_CPUIMPL_H
> -#ifndef ASM
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -#ifdef __cplusplus
> -#endif
> -#endif /* ASM */
> -#endif /* _RTEMS_SCORE_CPUIMPL_H */
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h b/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> index dc4836b..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/riscv-utility.h
> +++ /dev/null
> @@ -1,1526 +0,0 @@
> -/* Copyright (c) 2013, The Regents of the University of California (Regents).
> - * All Rights Reserved.
> - * modification, are permitted provided that the following conditions are met:
> - * 3. Neither the name of the Regents nor the
> - * names of its contributors may be used to endorse or promote products
> - * derived from this software without specific prior written
> - * permission.
> - * IN NO EVENT SHALL REGENTS BE LIABLE TO ANY PARTY FOR DIRECT,
> - * INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, INCLUDING LOST
> - * PROFITS, ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
> - * REGENTS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> - * REGENTS SPECIFICALLY DISCLAIMS ANY WARRANTIES, INCLUDING, BUT NOT
> - * LIMITED TO,THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> - * PURPOSE. THE SOFTWARE AND ACCOMPANYING DOCUMENTATION, IF ANY, PROVIDED
> - * HEREUNDER IS PROVIDED "AS IS". REGENTS HAS NO OBLIGATION TO PROVIDE
> - * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
> -  * @file
> -  * @brief RISCV utility
> - * COPYRIGHT (c) 2015 Hesham Almatary <hesham at alumni.york.ac.uk>
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -/* This file is copied from riscv-tools/encoding.h with additions/modifications to work
> - * with RTEMS.
> -#ifndef _RTEMS_SCORE_RISCV_UTILITY_H
> -#define _RTEMS_SCORE_RISCV_UTILITY_H
> -#define MSTATUS_UIE         0x00000001
> -#define MSTATUS_SIE         0x00000002
> -#define MSTATUS_HIE         0x00000004
> -#define MSTATUS_MIE         0x00000008
> -#define MSTATUS_UPIE        0x00000010
> -#define MSTATUS_SPIE        0x00000020
> -#define MSTATUS_HPIE        0x00000040
> -#define MSTATUS_MPIE        0x00000080
> -#define MSTATUS_SPP         0x00000100
> -#define MSTATUS_HPP         0x00000600
> -#define MSTATUS_MPP         0x00001800
> -#define MSTATUS_FS          0x00006000
> -#define MSTATUS_XS          0x00018000
> -#define MSTATUS_MPRV        0x00020000
> -#define MSTATUS_SUM         0x00040000
> -#define MSTATUS_MXR         0x00080000
> -#define MSTATUS_TVM         0x00100000
> -#define MSTATUS_TW          0x00200000
> -#define MSTATUS_TSR         0x00400000
> -#define MSTATUS32_SD        0x80000000
> -#define MSTATUS64_SD        0x8000000000000000
> -#define SSTATUS_UIE         0x00000001
> -#define SSTATUS_SIE         0x00000002
> -#define SSTATUS_UPIE        0x00000010
> -#define SSTATUS_SPIE        0x00000020
> -#define SSTATUS_SPP         0x00000100
> -#define SSTATUS_FS          0x00006000
> -#define SSTATUS_XS          0x00018000
> -#define SSTATUS_SUM         0x00040000
> -#define SSTATUS_MXR         0x00080000
> -#define SSTATUS32_SD        0x80000000
> -#define SSTATUS64_SD        0x8000000000000000
> -#define DCSR_XDEBUGVER      (3U<<30)
> -#define DCSR_NDRESET        (1<<29)
> -#define DCSR_FULLRESET      (1<<28)
> -#define DCSR_EBREAKM        (1<<15)
> -#define DCSR_EBREAKH        (1<<14)
> -#define DCSR_EBREAKS        (1<<13)
> -#define DCSR_EBREAKU        (1<<12)
> -#define DCSR_STOPCYCLE      (1<<10)
> -#define DCSR_STOPTIME       (1<<9)
> -#define DCSR_CAUSE          (7<<6)
> -#define DCSR_DEBUGINT       (1<<5)
> -#define DCSR_HALT           (1<<3)
> -#define DCSR_STEP           (1<<2)
> -#define DCSR_PRV            (3<<0)
> -#define DCSR_CAUSE_NONE     0
> -#define DCSR_CAUSE_SWBP     1
> -#define DCSR_CAUSE_HWBP     2
> -#define DCSR_CAUSE_DEBUGINT 3
> -#define DCSR_CAUSE_STEP     4
> -#define DCSR_CAUSE_HALT     5
> -#define MCONTROL_TYPE(xlen)    (0xfULL<<((xlen)-4))
> -#define MCONTROL_DMODE(xlen)   (1ULL<<((xlen)-5))
> -#define MCONTROL_MASKMAX(xlen) (0x3fULL<<((xlen)-11))
> -#define MCONTROL_SELECT     (1<<19)
> -#define MCONTROL_TIMING     (1<<18)
> -#define MCONTROL_ACTION     (0x3f<<12)
> -#define MCONTROL_CHAIN      (1<<11)
> -#define MCONTROL_MATCH      (0xf<<7)
> -#define MCONTROL_M          (1<<6)
> -#define MCONTROL_H          (1<<5)
> -#define MCONTROL_S          (1<<4)
> -#define MCONTROL_U          (1<<3)
> -#define MCONTROL_EXECUTE    (1<<2)
> -#define MCONTROL_STORE      (1<<1)
> -#define MCONTROL_LOAD       (1<<0)
> -#define MCONTROL_TYPE_NONE      0
> -#define MCONTROL_TYPE_MATCH     2
> -#define MCONTROL_ACTION_DEBUG_EXCEPTION   0
> -#define MCONTROL_ACTION_DEBUG_MODE        1
> -#define MCONTROL_ACTION_TRACE_START       2
> -#define MCONTROL_ACTION_TRACE_STOP        3
> -#define MCONTROL_ACTION_TRACE_EMIT        4
> -#define MCONTROL_MATCH_EQUAL     0
> -#define MCONTROL_MATCH_NAPOT     1
> -#define MCONTROL_MATCH_GE        2
> -#define MCONTROL_MATCH_LT        3
> -#define MCONTROL_MATCH_MASK_LOW  4
> -#define MCONTROL_MATCH_MASK_HIGH 5
> -#define MIP_SSIP            (1 << IRQ_S_SOFT)
> -#define MIP_HSIP            (1 << IRQ_H_SOFT)
> -#define MIP_MSIP            (1 << IRQ_M_SOFT)
> -#define MIP_STIP            (1 << IRQ_S_TIMER)
> -#define MIP_HTIP            (1 << IRQ_H_TIMER)
> -#define MIP_MTIP            (1 << IRQ_M_TIMER)
> -#define MIP_SEIP            (1 << IRQ_S_EXT)
> -#define MIP_HEIP            (1 << IRQ_H_EXT)
> -#define MIP_MEIP            (1 << IRQ_M_EXT)
> -#define SIP_SSIP MIP_SSIP
> -#define SIP_STIP MIP_STIP
> -#define PRV_U 0
> -#define PRV_S 1
> -#define PRV_H 2
> -#define PRV_M 3
> -#define SPTBR32_MODE 0x80000000
> -#define SPTBR32_ASID 0x7FC00000
> -#define SPTBR32_PPN  0x003FFFFF
> -#define SPTBR64_MODE 0xF000000000000000
> -#define SPTBR64_ASID 0x0FFFF00000000000
> -#define SPTBR64_PPN  0x00000FFFFFFFFFFF
> -#define SPTBR_MODE_OFF  0
> -#define SPTBR_MODE_SV32 1
> -#define SPTBR_MODE_SV39 8
> -#define SPTBR_MODE_SV48 9
> -#define SPTBR_MODE_SV57 10
> -#define SPTBR_MODE_SV64 11
> -#define PMP_R     0x01
> -#define PMP_W     0x02
> -#define PMP_X     0x04
> -#define PMP_A     0x18
> -#define PMP_L     0x80
> -#define PMP_SHIFT 2
> -#define PMP_TOR   0x08
> -#define PMP_NA4   0x10
> -#define PMP_NAPOT 0x18
> -#define IRQ_S_SOFT   1
> -#define IRQ_H_SOFT   2
> -#define IRQ_M_SOFT   3
> -#define IRQ_S_TIMER  5
> -#define IRQ_H_TIMER  6
> -#define IRQ_M_TIMER  7
> -#define IRQ_S_EXT    9
> -#define IRQ_H_EXT    10
> -#define IRQ_M_EXT    11
> -#define IRQ_COP      12
> -#define IRQ_HOST     13
> -#define DEFAULT_RSTVEC     0x00001000
> -#define CLINT_BASE         0x02000000
> -#define CLINT_SIZE         0x000c0000
> -#define EXT_IO_BASE        0x40000000
> -#define DRAM_BASE          0x80000000
> -// page table entry (PTE) fields
> -#define PTE_V     0x001 // Valid
> -#define PTE_R     0x002 // Read
> -#define PTE_W     0x004 // Write
> -#define PTE_X     0x008 // Execute
> -#define PTE_U     0x010 // User
> -#define PTE_G     0x020 // Global
> -#define PTE_A     0x040 // Accessed
> -#define PTE_D     0x080 // Dirty
> -#define PTE_SOFT  0x300 // Reserved for Software
> -#define PTE_PPN_SHIFT 10
> -#define PTE_TABLE(PTE) (((PTE) & (PTE_V | PTE_R | PTE_W | PTE_X)) == PTE_V)
> -#ifdef __riscv
> -#if __riscv_xlen == 64
> -# define MSTATUS_SD MSTATUS64_SD
> -# define SSTATUS_SD SSTATUS64_SD
> -# define RISCV_PGLEVEL_BITS 9
> -# define SPTBR_MODE SPTBR64_MODE
> -#else
> -# define MSTATUS_SD MSTATUS32_SD
> -# define SSTATUS_SD SSTATUS32_SD
> -# define RISCV_PGLEVEL_BITS 10
> -# define SPTBR_MODE SPTBR32_MODE
> -#endif
> -#define RISCV_PGSHIFT 12
> -#define RISCV_PGSIZE (1 << RISCV_PGSHIFT)
> -#ifndef __ASSEMBLER__
> -  * @brief Priv Mode registers definitions.
> -  * @see RISC-V priv-spec 1.10.
> -typedef enum {
> -  RISCV_USER_INTERRUPT = 0,
> -  RISCV_SUPERVISOR_SW_INTERRUPT = 1,
> -  RISCV_MACHINE_SW_INTERRUPT = 3,
> -  RISCV_USER_TIMER_INTERRUPT = 4,
> -  RISCV_SUPERVISOR_TIMER_INTERRUPT = 4,
> -  RISCV_MACHINE_TIMER_INTERRUPT = 7,
> -  RISCV_USER_EXTERNAL_INTERRUPT = 8,
> -  RISCV_SUPERVISOR_EXTERNAL_INTERRUPT = 9,
> -  RISCV_MACHINE_EXTERNAL_INTERRUPT = 11
> -} RISCV_Symbolic_interrupt_name;
> -#ifdef __GNUC__
> -#define read_csr(reg) ({ unsigned long __tmp; \
> -  asm volatile ("csrr %0, " #reg : "=r"(__tmp)); \
> -  __tmp; })
> -#define write_csr(reg, val) ({ \
> -  asm volatile ("csrw " #reg ", %0" :: "rK"(val)); })
> -#define swap_csr(reg, val) ({ unsigned long __tmp; \
> -  asm volatile ("csrrw %0, " #reg ", %1" : "=r"(__tmp) : "rK"(val)); \
> -  __tmp; })
> -#define set_csr(reg, bit) ({ unsigned long __tmp; \
> -  asm volatile ("csrrs %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
> -  __tmp; })
> -#define clear_csr(reg, bit) ({ unsigned long __tmp; \
> -  asm volatile ("csrrc %0, " #reg ", %1" : "=r"(__tmp) : "rK"(bit)); \
> -  __tmp; })
> -#define rdtime() read_csr(time)
> -#define rdcycle() read_csr(cycle)
> -#define rdinstret() read_csr(instret)
> -#endif
> -#endif
> -#endif
> -#endif
> -/* Automatically generated by parse-opcodes.  */
> -#ifndef RISCV_ENCODING_H
> -#define RISCV_ENCODING_H
> -#define MATCH_BEQ 0x63
> -#define MASK_BEQ  0x707f
> -#define MATCH_BNE 0x1063
> -#define MASK_BNE  0x707f
> -#define MATCH_BLT 0x4063
> -#define MASK_BLT  0x707f
> -#define MATCH_BGE 0x5063
> -#define MASK_BGE  0x707f
> -#define MATCH_BLTU 0x6063
> -#define MASK_BLTU  0x707f
> -#define MATCH_BGEU 0x7063
> -#define MASK_BGEU  0x707f
> -#define MATCH_JALR 0x67
> -#define MASK_JALR  0x707f
> -#define MATCH_JAL 0x6f
> -#define MASK_JAL  0x7f
> -#define MATCH_LUI 0x37
> -#define MASK_LUI  0x7f
> -#define MATCH_AUIPC 0x17
> -#define MASK_AUIPC  0x7f
> -#define MATCH_ADDI 0x13
> -#define MASK_ADDI  0x707f
> -#define MATCH_SLLI 0x1013
> -#define MASK_SLLI  0xfc00707f
> -#define MATCH_SLTI 0x2013
> -#define MASK_SLTI  0x707f
> -#define MATCH_SLTIU 0x3013
> -#define MASK_SLTIU  0x707f
> -#define MATCH_XORI 0x4013
> -#define MASK_XORI  0x707f
> -#define MATCH_SRLI 0x5013
> -#define MASK_SRLI  0xfc00707f
> -#define MATCH_SRAI 0x40005013
> -#define MASK_SRAI  0xfc00707f
> -#define MATCH_ORI 0x6013
> -#define MASK_ORI  0x707f
> -#define MATCH_ANDI 0x7013
> -#define MASK_ANDI  0x707f
> -#define MATCH_ADD 0x33
> -#define MASK_ADD  0xfe00707f
> -#define MATCH_SUB 0x40000033
> -#define MASK_SUB  0xfe00707f
> -#define MATCH_SLL 0x1033
> -#define MASK_SLL  0xfe00707f
> -#define MATCH_SLT 0x2033
> -#define MASK_SLT  0xfe00707f
> -#define MATCH_SLTU 0x3033
> -#define MASK_SLTU  0xfe00707f
> -#define MATCH_XOR 0x4033
> -#define MASK_XOR  0xfe00707f
> -#define MATCH_SRL 0x5033
> -#define MASK_SRL  0xfe00707f
> -#define MATCH_SRA 0x40005033
> -#define MASK_SRA  0xfe00707f
> -#define MATCH_OR 0x6033
> -#define MASK_OR  0xfe00707f
> -#define MATCH_AND 0x7033
> -#define MASK_AND  0xfe00707f
> -#define MATCH_ADDIW 0x1b
> -#define MASK_ADDIW  0x707f
> -#define MATCH_SLLIW 0x101b
> -#define MASK_SLLIW  0xfe00707f
> -#define MATCH_SRLIW 0x501b
> -#define MASK_SRLIW  0xfe00707f
> -#define MATCH_SRAIW 0x4000501b
> -#define MASK_SRAIW  0xfe00707f
> -#define MATCH_ADDW 0x3b
> -#define MASK_ADDW  0xfe00707f
> -#define MATCH_SUBW 0x4000003b
> -#define MASK_SUBW  0xfe00707f
> -#define MATCH_SLLW 0x103b
> -#define MASK_SLLW  0xfe00707f
> -#define MATCH_SRLW 0x503b
> -#define MASK_SRLW  0xfe00707f
> -#define MATCH_SRAW 0x4000503b
> -#define MASK_SRAW  0xfe00707f
> -#define MATCH_LB 0x3
> -#define MASK_LB  0x707f
> -#define MATCH_LH 0x1003
> -#define MASK_LH  0x707f
> -#define MATCH_LW 0x2003
> -#define MASK_LW  0x707f
> -#define MATCH_LD 0x3003
> -#define MASK_LD  0x707f
> -#define MATCH_LBU 0x4003
> -#define MASK_LBU  0x707f
> -#define MATCH_LHU 0x5003
> -#define MASK_LHU  0x707f
> -#define MATCH_LWU 0x6003
> -#define MASK_LWU  0x707f
> -#define MATCH_SB 0x23
> -#define MASK_SB  0x707f
> -#define MATCH_SH 0x1023
> -#define MASK_SH  0x707f
> -#define MATCH_SW 0x2023
> -#define MASK_SW  0x707f
> -#define MATCH_SD 0x3023
> -#define MASK_SD  0x707f
> -#define MATCH_FENCE 0xf
> -#define MASK_FENCE  0x707f
> -#define MATCH_FENCE_I 0x100f
> -#define MASK_FENCE_I  0x707f
> -#define MATCH_MUL 0x2000033
> -#define MASK_MUL  0xfe00707f
> -#define MATCH_MULH 0x2001033
> -#define MASK_MULH  0xfe00707f
> -#define MATCH_MULHSU 0x2002033
> -#define MASK_MULHSU  0xfe00707f
> -#define MATCH_MULHU 0x2003033
> -#define MASK_MULHU  0xfe00707f
> -#define MATCH_DIV 0x2004033
> -#define MASK_DIV  0xfe00707f
> -#define MATCH_DIVU 0x2005033
> -#define MASK_DIVU  0xfe00707f
> -#define MATCH_REM 0x2006033
> -#define MASK_REM  0xfe00707f
> -#define MATCH_REMU 0x2007033
> -#define MASK_REMU  0xfe00707f
> -#define MATCH_MULW 0x200003b
> -#define MASK_MULW  0xfe00707f
> -#define MATCH_DIVW 0x200403b
> -#define MASK_DIVW  0xfe00707f
> -#define MATCH_DIVUW 0x200503b
> -#define MASK_DIVUW  0xfe00707f
> -#define MATCH_REMW 0x200603b
> -#define MASK_REMW  0xfe00707f
> -#define MATCH_REMUW 0x200703b
> -#define MASK_REMUW  0xfe00707f
> -#define MATCH_AMOADD_W 0x202f
> -#define MASK_AMOADD_W  0xf800707f
> -#define MATCH_AMOXOR_W 0x2000202f
> -#define MASK_AMOXOR_W  0xf800707f
> -#define MATCH_AMOOR_W 0x4000202f
> -#define MASK_AMOOR_W  0xf800707f
> -#define MATCH_AMOAND_W 0x6000202f
> -#define MASK_AMOAND_W  0xf800707f
> -#define MATCH_AMOMIN_W 0x8000202f
> -#define MASK_AMOMIN_W  0xf800707f
> -#define MATCH_AMOMAX_W 0xa000202f
> -#define MASK_AMOMAX_W  0xf800707f
> -#define MATCH_AMOMINU_W 0xc000202f
> -#define MASK_AMOMINU_W  0xf800707f
> -#define MATCH_AMOMAXU_W 0xe000202f
> -#define MASK_AMOMAXU_W  0xf800707f
> -#define MATCH_AMOSWAP_W 0x800202f
> -#define MASK_AMOSWAP_W  0xf800707f
> -#define MATCH_LR_W 0x1000202f
> -#define MASK_LR_W  0xf9f0707f
> -#define MATCH_SC_W 0x1800202f
> -#define MASK_SC_W  0xf800707f
> -#define MATCH_AMOADD_D 0x302f
> -#define MASK_AMOADD_D  0xf800707f
> -#define MATCH_AMOXOR_D 0x2000302f
> -#define MASK_AMOXOR_D  0xf800707f
> -#define MATCH_AMOOR_D 0x4000302f
> -#define MASK_AMOOR_D  0xf800707f
> -#define MATCH_AMOAND_D 0x6000302f
> -#define MASK_AMOAND_D  0xf800707f
> -#define MATCH_AMOMIN_D 0x8000302f
> -#define MASK_AMOMIN_D  0xf800707f
> -#define MATCH_AMOMAX_D 0xa000302f
> -#define MASK_AMOMAX_D  0xf800707f
> -#define MATCH_AMOMINU_D 0xc000302f
> -#define MASK_AMOMINU_D  0xf800707f
> -#define MATCH_AMOMAXU_D 0xe000302f
> -#define MASK_AMOMAXU_D  0xf800707f
> -#define MATCH_AMOSWAP_D 0x800302f
> -#define MASK_AMOSWAP_D  0xf800707f
> -#define MATCH_LR_D 0x1000302f
> -#define MASK_LR_D  0xf9f0707f
> -#define MATCH_SC_D 0x1800302f
> -#define MASK_SC_D  0xf800707f
> -#define MATCH_ECALL 0x73
> -#define MASK_ECALL  0xffffffff
> -#define MATCH_EBREAK 0x100073
> -#define MASK_EBREAK  0xffffffff
> -#define MATCH_URET 0x200073
> -#define MASK_URET  0xffffffff
> -#define MATCH_SRET 0x10200073
> -#define MASK_SRET  0xffffffff
> -#define MATCH_MRET 0x30200073
> -#define MASK_MRET  0xffffffff
> -#define MATCH_DRET 0x7b200073
> -#define MASK_DRET  0xffffffff
> -#define MATCH_SFENCE_VMA 0x12000073
> -#define MASK_SFENCE_VMA  0xfe007fff
> -#define MATCH_WFI 0x10500073
> -#define MASK_WFI  0xffffffff
> -#define MATCH_CSRRW 0x1073
> -#define MASK_CSRRW  0x707f
> -#define MATCH_CSRRS 0x2073
> -#define MASK_CSRRS  0x707f
> -#define MATCH_CSRRC 0x3073
> -#define MASK_CSRRC  0x707f
> -#define MATCH_CSRRWI 0x5073
> -#define MASK_CSRRWI  0x707f
> -#define MATCH_CSRRSI 0x6073
> -#define MASK_CSRRSI  0x707f
> -#define MATCH_CSRRCI 0x7073
> -#define MASK_CSRRCI  0x707f
> -#define MATCH_FADD_S 0x53
> -#define MASK_FADD_S  0xfe00007f
> -#define MATCH_FSUB_S 0x8000053
> -#define MASK_FSUB_S  0xfe00007f
> -#define MATCH_FMUL_S 0x10000053
> -#define MASK_FMUL_S  0xfe00007f
> -#define MATCH_FDIV_S 0x18000053
> -#define MASK_FDIV_S  0xfe00007f
> -#define MATCH_FSGNJ_S 0x20000053
> -#define MASK_FSGNJ_S  0xfe00707f
> -#define MATCH_FSGNJN_S 0x20001053
> -#define MASK_FSGNJN_S  0xfe00707f
> -#define MATCH_FSGNJX_S 0x20002053
> -#define MASK_FSGNJX_S  0xfe00707f
> -#define MATCH_FMIN_S 0x28000053
> -#define MASK_FMIN_S  0xfe00707f
> -#define MATCH_FMAX_S 0x28001053
> -#define MASK_FMAX_S  0xfe00707f
> -#define MATCH_FSQRT_S 0x58000053
> -#define MASK_FSQRT_S  0xfff0007f
> -#define MATCH_FADD_D 0x2000053
> -#define MASK_FADD_D  0xfe00007f
> -#define MATCH_FSUB_D 0xa000053
> -#define MASK_FSUB_D  0xfe00007f
> -#define MATCH_FMUL_D 0x12000053
> -#define MASK_FMUL_D  0xfe00007f
> -#define MATCH_FDIV_D 0x1a000053
> -#define MASK_FDIV_D  0xfe00007f
> -#define MATCH_FSGNJ_D 0x22000053
> -#define MASK_FSGNJ_D  0xfe00707f
> -#define MATCH_FSGNJN_D 0x22001053
> -#define MASK_FSGNJN_D  0xfe00707f
> -#define MATCH_FSGNJX_D 0x22002053
> -#define MASK_FSGNJX_D  0xfe00707f
> -#define MATCH_FMIN_D 0x2a000053
> -#define MASK_FMIN_D  0xfe00707f
> -#define MATCH_FMAX_D 0x2a001053
> -#define MASK_FMAX_D  0xfe00707f
> -#define MATCH_FCVT_S_D 0x40100053
> -#define MASK_FCVT_S_D  0xfff0007f
> -#define MATCH_FCVT_D_S 0x42000053
> -#define MASK_FCVT_D_S  0xfff0007f
> -#define MATCH_FSQRT_D 0x5a000053
> -#define MASK_FSQRT_D  0xfff0007f
> -#define MATCH_FADD_Q 0x6000053
> -#define MASK_FADD_Q  0xfe00007f
> -#define MATCH_FSUB_Q 0xe000053
> -#define MASK_FSUB_Q  0xfe00007f
> -#define MATCH_FMUL_Q 0x16000053
> -#define MASK_FMUL_Q  0xfe00007f
> -#define MATCH_FDIV_Q 0x1e000053
> -#define MASK_FDIV_Q  0xfe00007f
> -#define MATCH_FSGNJ_Q 0x26000053
> -#define MASK_FSGNJ_Q  0xfe00707f
> -#define MATCH_FSGNJN_Q 0x26001053
> -#define MASK_FSGNJN_Q  0xfe00707f
> -#define MATCH_FSGNJX_Q 0x26002053
> -#define MASK_FSGNJX_Q  0xfe00707f
> -#define MATCH_FMIN_Q 0x2e000053
> -#define MASK_FMIN_Q  0xfe00707f
> -#define MATCH_FMAX_Q 0x2e001053
> -#define MASK_FMAX_Q  0xfe00707f
> -#define MATCH_FCVT_S_Q 0x40300053
> -#define MASK_FCVT_S_Q  0xfff0007f
> -#define MATCH_FCVT_Q_S 0x46000053
> -#define MASK_FCVT_Q_S  0xfff0007f
> -#define MATCH_FCVT_D_Q 0x42300053
> -#define MASK_FCVT_D_Q  0xfff0007f
> -#define MATCH_FCVT_Q_D 0x46100053
> -#define MASK_FCVT_Q_D  0xfff0007f
> -#define MATCH_FSQRT_Q 0x5e000053
> -#define MASK_FSQRT_Q  0xfff0007f
> -#define MATCH_FLE_S 0xa0000053
> -#define MASK_FLE_S  0xfe00707f
> -#define MATCH_FLT_S 0xa0001053
> -#define MASK_FLT_S  0xfe00707f
> -#define MATCH_FEQ_S 0xa0002053
> -#define MASK_FEQ_S  0xfe00707f
> -#define MATCH_FLE_D 0xa2000053
> -#define MASK_FLE_D  0xfe00707f
> -#define MATCH_FLT_D 0xa2001053
> -#define MASK_FLT_D  0xfe00707f
> -#define MATCH_FEQ_D 0xa2002053
> -#define MASK_FEQ_D  0xfe00707f
> -#define MATCH_FLE_Q 0xa6000053
> -#define MASK_FLE_Q  0xfe00707f
> -#define MATCH_FLT_Q 0xa6001053
> -#define MASK_FLT_Q  0xfe00707f
> -#define MATCH_FEQ_Q 0xa6002053
> -#define MASK_FEQ_Q  0xfe00707f
> -#define MATCH_FCVT_W_S 0xc0000053
> -#define MASK_FCVT_W_S  0xfff0007f
> -#define MATCH_FCVT_WU_S 0xc0100053
> -#define MASK_FCVT_WU_S  0xfff0007f
> -#define MATCH_FCVT_L_S 0xc0200053
> -#define MASK_FCVT_L_S  0xfff0007f
> -#define MATCH_FCVT_LU_S 0xc0300053
> -#define MASK_FCVT_LU_S  0xfff0007f
> -#define MATCH_FMV_X_W 0xe0000053
> -#define MASK_FMV_X_W  0xfff0707f
> -#define MATCH_FCLASS_S 0xe0001053
> -#define MASK_FCLASS_S  0xfff0707f
> -#define MATCH_FCVT_W_D 0xc2000053
> -#define MASK_FCVT_W_D  0xfff0007f
> -#define MATCH_FCVT_WU_D 0xc2100053
> -#define MASK_FCVT_WU_D  0xfff0007f
> -#define MATCH_FCVT_L_D 0xc2200053
> -#define MASK_FCVT_L_D  0xfff0007f
> -#define MATCH_FCVT_LU_D 0xc2300053
> -#define MASK_FCVT_LU_D  0xfff0007f
> -#define MATCH_FMV_X_D 0xe2000053
> -#define MASK_FMV_X_D  0xfff0707f
> -#define MATCH_FCLASS_D 0xe2001053
> -#define MASK_FCLASS_D  0xfff0707f
> -#define MATCH_FCVT_W_Q 0xc6000053
> -#define MASK_FCVT_W_Q  0xfff0007f
> -#define MATCH_FCVT_WU_Q 0xc6100053
> -#define MASK_FCVT_WU_Q  0xfff0007f
> -#define MATCH_FCVT_L_Q 0xc6200053
> -#define MASK_FCVT_L_Q  0xfff0007f
> -#define MATCH_FCVT_LU_Q 0xc6300053
> -#define MASK_FCVT_LU_Q  0xfff0007f
> -#define MATCH_FMV_X_Q 0xe6000053
> -#define MASK_FMV_X_Q  0xfff0707f
> -#define MATCH_FCLASS_Q 0xe6001053
> -#define MASK_FCLASS_Q  0xfff0707f
> -#define MATCH_FCVT_S_W 0xd0000053
> -#define MASK_FCVT_S_W  0xfff0007f
> -#define MATCH_FCVT_S_WU 0xd0100053
> -#define MASK_FCVT_S_WU  0xfff0007f
> -#define MATCH_FCVT_S_L 0xd0200053
> -#define MASK_FCVT_S_L  0xfff0007f
> -#define MATCH_FCVT_S_LU 0xd0300053
> -#define MASK_FCVT_S_LU  0xfff0007f
> -#define MATCH_FMV_W_X 0xf0000053
> -#define MASK_FMV_W_X  0xfff0707f
> -#define MATCH_FCVT_D_W 0xd2000053
> -#define MASK_FCVT_D_W  0xfff0007f
> -#define MATCH_FCVT_D_WU 0xd2100053
> -#define MASK_FCVT_D_WU  0xfff0007f
> -#define MATCH_FCVT_D_L 0xd2200053
> -#define MASK_FCVT_D_L  0xfff0007f
> -#define MATCH_FCVT_D_LU 0xd2300053
> -#define MASK_FCVT_D_LU  0xfff0007f
> -#define MATCH_FMV_D_X 0xf2000053
> -#define MASK_FMV_D_X  0xfff0707f
> -#define MATCH_FCVT_Q_W 0xd6000053
> -#define MASK_FCVT_Q_W  0xfff0007f
> -#define MATCH_FCVT_Q_WU 0xd6100053
> -#define MASK_FCVT_Q_WU  0xfff0007f
> -#define MATCH_FCVT_Q_L 0xd6200053
> -#define MASK_FCVT_Q_L  0xfff0007f
> -#define MATCH_FCVT_Q_LU 0xd6300053
> -#define MASK_FCVT_Q_LU  0xfff0007f
> -#define MATCH_FMV_Q_X 0xf6000053
> -#define MASK_FMV_Q_X  0xfff0707f
> -#define MATCH_FLW 0x2007
> -#define MASK_FLW  0x707f
> -#define MATCH_FLD 0x3007
> -#define MASK_FLD  0x707f
> -#define MATCH_FLQ 0x4007
> -#define MASK_FLQ  0x707f
> -#define MATCH_FSW 0x2027
> -#define MASK_FSW  0x707f
> -#define MATCH_FSD 0x3027
> -#define MASK_FSD  0x707f
> -#define MATCH_FSQ 0x4027
> -#define MASK_FSQ  0x707f
> -#define MATCH_FMADD_S 0x43
> -#define MASK_FMADD_S  0x600007f
> -#define MATCH_FMSUB_S 0x47
> -#define MASK_FMSUB_S  0x600007f
> -#define MATCH_FNMSUB_S 0x4b
> -#define MASK_FNMSUB_S  0x600007f
> -#define MATCH_FNMADD_S 0x4f
> -#define MASK_FNMADD_S  0x600007f
> -#define MATCH_FMADD_D 0x2000043
> -#define MASK_FMADD_D  0x600007f
> -#define MATCH_FMSUB_D 0x2000047
> -#define MASK_FMSUB_D  0x600007f
> -#define MATCH_FNMSUB_D 0x200004b
> -#define MASK_FNMSUB_D  0x600007f
> -#define MATCH_FNMADD_D 0x200004f
> -#define MASK_FNMADD_D  0x600007f
> -#define MATCH_FMADD_Q 0x6000043
> -#define MASK_FMADD_Q  0x600007f
> -#define MATCH_FMSUB_Q 0x6000047
> -#define MASK_FMSUB_Q  0x600007f
> -#define MATCH_FNMSUB_Q 0x600004b
> -#define MASK_FNMSUB_Q  0x600007f
> -#define MATCH_FNMADD_Q 0x600004f
> -#define MASK_FNMADD_Q  0x600007f
> -#define MATCH_C_NOP 0x1
> -#define MASK_C_NOP  0xffff
> -#define MATCH_C_ADDI16SP 0x6101
> -#define MASK_C_ADDI16SP  0xef83
> -#define MATCH_C_JR 0x8002
> -#define MASK_C_JR  0xf07f
> -#define MATCH_C_JALR 0x9002
> -#define MASK_C_JALR  0xf07f
> -#define MATCH_C_EBREAK 0x9002
> -#define MASK_C_EBREAK  0xffff
> -#define MATCH_C_LD 0x6000
> -#define MASK_C_LD  0xe003
> -#define MATCH_C_SD 0xe000
> -#define MASK_C_SD  0xe003
> -#define MATCH_C_ADDIW 0x2001
> -#define MASK_C_ADDIW  0xe003
> -#define MATCH_C_LDSP 0x6002
> -#define MASK_C_LDSP  0xe003
> -#define MATCH_C_SDSP 0xe002
> -#define MASK_C_SDSP  0xe003
> -#define MATCH_C_ADDI4SPN 0x0
> -#define MASK_C_ADDI4SPN  0xe003
> -#define MATCH_C_FLD 0x2000
> -#define MASK_C_FLD  0xe003
> -#define MATCH_C_LW 0x4000
> -#define MASK_C_LW  0xe003
> -#define MATCH_C_FLW 0x6000
> -#define MASK_C_FLW  0xe003
> -#define MATCH_C_FSD 0xa000
> -#define MASK_C_FSD  0xe003
> -#define MATCH_C_SW 0xc000
> -#define MASK_C_SW  0xe003
> -#define MATCH_C_FSW 0xe000
> -#define MASK_C_FSW  0xe003
> -#define MATCH_C_ADDI 0x1
> -#define MASK_C_ADDI  0xe003
> -#define MATCH_C_JAL 0x2001
> -#define MASK_C_JAL  0xe003
> -#define MATCH_C_LI 0x4001
> -#define MASK_C_LI  0xe003
> -#define MATCH_C_LUI 0x6001
> -#define MASK_C_LUI  0xe003
> -#define MATCH_C_SRLI 0x8001
> -#define MASK_C_SRLI  0xec03
> -#define MATCH_C_SRAI 0x8401
> -#define MASK_C_SRAI  0xec03
> -#define MATCH_C_ANDI 0x8801
> -#define MASK_C_ANDI  0xec03
> -#define MATCH_C_SUB 0x8c01
> -#define MASK_C_SUB  0xfc63
> -#define MATCH_C_XOR 0x8c21
> -#define MASK_C_XOR  0xfc63
> -#define MATCH_C_OR 0x8c41
> -#define MASK_C_OR  0xfc63
> -#define MATCH_C_AND 0x8c61
> -#define MASK_C_AND  0xfc63
> -#define MATCH_C_SUBW 0x9c01
> -#define MASK_C_SUBW  0xfc63
> -#define MATCH_C_ADDW 0x9c21
> -#define MASK_C_ADDW  0xfc63
> -#define MATCH_C_J 0xa001
> -#define MASK_C_J  0xe003
> -#define MATCH_C_BEQZ 0xc001
> -#define MASK_C_BEQZ  0xe003
> -#define MATCH_C_BNEZ 0xe001
> -#define MASK_C_BNEZ  0xe003
> -#define MATCH_C_SLLI 0x2
> -#define MASK_C_SLLI  0xe003
> -#define MATCH_C_FLDSP 0x2002
> -#define MASK_C_FLDSP  0xe003
> -#define MATCH_C_LWSP 0x4002
> -#define MASK_C_LWSP  0xe003
> -#define MATCH_C_FLWSP 0x6002
> -#define MASK_C_FLWSP  0xe003
> -#define MATCH_C_MV 0x8002
> -#define MASK_C_MV  0xf003
> -#define MATCH_C_ADD 0x9002
> -#define MASK_C_ADD  0xf003
> -#define MATCH_C_FSDSP 0xa002
> -#define MASK_C_FSDSP  0xe003
> -#define MATCH_C_SWSP 0xc002
> -#define MASK_C_SWSP  0xe003
> -#define MATCH_C_FSWSP 0xe002
> -#define MASK_C_FSWSP  0xe003
> -#define MATCH_CUSTOM0 0xb
> -#define MASK_CUSTOM0  0x707f
> -#define MATCH_CUSTOM0_RS1 0x200b
> -#define MASK_CUSTOM0_RS1  0x707f
> -#define MATCH_CUSTOM0_RS1_RS2 0x300b
> -#define MASK_CUSTOM0_RS1_RS2  0x707f
> -#define MATCH_CUSTOM0_RD 0x400b
> -#define MASK_CUSTOM0_RD  0x707f
> -#define MATCH_CUSTOM0_RD_RS1 0x600b
> -#define MASK_CUSTOM0_RD_RS1  0x707f
> -#define MATCH_CUSTOM0_RD_RS1_RS2 0x700b
> -#define MASK_CUSTOM0_RD_RS1_RS2  0x707f
> -#define MATCH_CUSTOM1 0x2b
> -#define MASK_CUSTOM1  0x707f
> -#define MATCH_CUSTOM1_RS1 0x202b
> -#define MASK_CUSTOM1_RS1  0x707f
> -#define MATCH_CUSTOM1_RS1_RS2 0x302b
> -#define MASK_CUSTOM1_RS1_RS2  0x707f
> -#define MATCH_CUSTOM1_RD 0x402b
> -#define MASK_CUSTOM1_RD  0x707f
> -#define MATCH_CUSTOM1_RD_RS1 0x602b
> -#define MASK_CUSTOM1_RD_RS1  0x707f
> -#define MATCH_CUSTOM1_RD_RS1_RS2 0x702b
> -#define MASK_CUSTOM1_RD_RS1_RS2  0x707f
> -#define MATCH_CUSTOM2 0x5b
> -#define MASK_CUSTOM2  0x707f
> -#define MATCH_CUSTOM2_RS1 0x205b
> -#define MASK_CUSTOM2_RS1  0x707f
> -#define MATCH_CUSTOM2_RS1_RS2 0x305b
> -#define MASK_CUSTOM2_RS1_RS2  0x707f
> -#define MATCH_CUSTOM2_RD 0x405b
> -#define MASK_CUSTOM2_RD  0x707f
> -#define MATCH_CUSTOM2_RD_RS1 0x605b
> -#define MASK_CUSTOM2_RD_RS1  0x707f
> -#define MATCH_CUSTOM2_RD_RS1_RS2 0x705b
> -#define MASK_CUSTOM2_RD_RS1_RS2  0x707f
> -#define MATCH_CUSTOM3 0x7b
> -#define MASK_CUSTOM3  0x707f
> -#define MATCH_CUSTOM3_RS1 0x207b
> -#define MASK_CUSTOM3_RS1  0x707f
> -#define MATCH_CUSTOM3_RS1_RS2 0x307b
> -#define MASK_CUSTOM3_RS1_RS2  0x707f
> -#define MATCH_CUSTOM3_RD 0x407b
> -#define MASK_CUSTOM3_RD  0x707f
> -#define MATCH_CUSTOM3_RD_RS1 0x607b
> -#define MASK_CUSTOM3_RD_RS1  0x707f
> -#define MATCH_CUSTOM3_RD_RS1_RS2 0x707b
> -#define MASK_CUSTOM3_RD_RS1_RS2  0x707f
> -#define CSR_FFLAGS 0x1
> -#define CSR_FRM 0x2
> -#define CSR_FCSR 0x3
> -#define CSR_CYCLE 0xc00
> -#define CSR_TIME 0xc01
> -#define CSR_INSTRET 0xc02
> -#define CSR_HPMCOUNTER3 0xc03
> -#define CSR_HPMCOUNTER4 0xc04
> -#define CSR_HPMCOUNTER5 0xc05
> -#define CSR_HPMCOUNTER6 0xc06
> -#define CSR_HPMCOUNTER7 0xc07
> -#define CSR_HPMCOUNTER8 0xc08
> -#define CSR_HPMCOUNTER9 0xc09
> -#define CSR_HPMCOUNTER10 0xc0a
> -#define CSR_HPMCOUNTER11 0xc0b
> -#define CSR_HPMCOUNTER12 0xc0c
> -#define CSR_HPMCOUNTER13 0xc0d
> -#define CSR_HPMCOUNTER14 0xc0e
> -#define CSR_HPMCOUNTER15 0xc0f
> -#define CSR_HPMCOUNTER16 0xc10
> -#define CSR_HPMCOUNTER17 0xc11
> -#define CSR_HPMCOUNTER18 0xc12
> -#define CSR_HPMCOUNTER19 0xc13
> -#define CSR_HPMCOUNTER20 0xc14
> -#define CSR_HPMCOUNTER21 0xc15
> -#define CSR_HPMCOUNTER22 0xc16
> -#define CSR_HPMCOUNTER23 0xc17
> -#define CSR_HPMCOUNTER24 0xc18
> -#define CSR_HPMCOUNTER25 0xc19
> -#define CSR_HPMCOUNTER26 0xc1a
> -#define CSR_HPMCOUNTER27 0xc1b
> -#define CSR_HPMCOUNTER28 0xc1c
> -#define CSR_HPMCOUNTER29 0xc1d
> -#define CSR_HPMCOUNTER30 0xc1e
> -#define CSR_HPMCOUNTER31 0xc1f
> -#define CSR_SSTATUS 0x100
> -#define CSR_SIE 0x104
> -#define CSR_STVEC 0x105
> -#define CSR_SCOUNTEREN 0x106
> -#define CSR_SSCRATCH 0x140
> -#define CSR_SEPC 0x141
> -#define CSR_SCAUSE 0x142
> -#define CSR_SBADADDR 0x143
> -#define CSR_SIP 0x144
> -#define CSR_SPTBR 0x180
> -#define CSR_MSTATUS 0x300
> -#define CSR_MISA 0x301
> -#define CSR_MEDELEG 0x302
> -#define CSR_MIDELEG 0x303
> -#define CSR_MIE 0x304
> -#define CSR_MTVEC 0x305
> -#define CSR_MCOUNTEREN 0x306
> -#define CSR_MSCRATCH 0x340
> -#define CSR_MEPC 0x341
> -#define CSR_MCAUSE 0x342
> -#define CSR_MBADADDR 0x343
> -#define CSR_MIP 0x344
> -#define CSR_PMPCFG0 0x3a0
> -#define CSR_PMPCFG1 0x3a1
> -#define CSR_PMPCFG2 0x3a2
> -#define CSR_PMPCFG3 0x3a3
> -#define CSR_PMPADDR0 0x3b0
> -#define CSR_PMPADDR1 0x3b1
> -#define CSR_PMPADDR2 0x3b2
> -#define CSR_PMPADDR3 0x3b3
> -#define CSR_PMPADDR4 0x3b4
> -#define CSR_PMPADDR5 0x3b5
> -#define CSR_PMPADDR6 0x3b6
> -#define CSR_PMPADDR7 0x3b7
> -#define CSR_PMPADDR8 0x3b8
> -#define CSR_PMPADDR9 0x3b9
> -#define CSR_PMPADDR10 0x3ba
> -#define CSR_PMPADDR11 0x3bb
> -#define CSR_PMPADDR12 0x3bc
> -#define CSR_PMPADDR13 0x3bd
> -#define CSR_PMPADDR14 0x3be
> -#define CSR_PMPADDR15 0x3bf
> -#define CSR_TSELECT 0x7a0
> -#define CSR_TDATA1 0x7a1
> -#define CSR_TDATA2 0x7a2
> -#define CSR_TDATA3 0x7a3
> -#define CSR_DCSR 0x7b0
> -#define CSR_DPC 0x7b1
> -#define CSR_DSCRATCH 0x7b2
> -#define CSR_MCYCLE 0xb00
> -#define CSR_MINSTRET 0xb02
> -#define CSR_MHPMCOUNTER3 0xb03
> -#define CSR_MHPMCOUNTER4 0xb04
> -#define CSR_MHPMCOUNTER5 0xb05
> -#define CSR_MHPMCOUNTER6 0xb06
> -#define CSR_MHPMCOUNTER7 0xb07
> -#define CSR_MHPMCOUNTER8 0xb08
> -#define CSR_MHPMCOUNTER9 0xb09
> -#define CSR_MHPMCOUNTER10 0xb0a
> -#define CSR_MHPMCOUNTER11 0xb0b
> -#define CSR_MHPMCOUNTER12 0xb0c
> -#define CSR_MHPMCOUNTER13 0xb0d
> -#define CSR_MHPMCOUNTER14 0xb0e
> -#define CSR_MHPMCOUNTER15 0xb0f
> -#define CSR_MHPMCOUNTER16 0xb10
> -#define CSR_MHPMCOUNTER17 0xb11
> -#define CSR_MHPMCOUNTER18 0xb12
> -#define CSR_MHPMCOUNTER19 0xb13
> -#define CSR_MHPMCOUNTER20 0xb14
> -#define CSR_MHPMCOUNTER21 0xb15
> -#define CSR_MHPMCOUNTER22 0xb16
> -#define CSR_MHPMCOUNTER23 0xb17
> -#define CSR_MHPMCOUNTER24 0xb18
> -#define CSR_MHPMCOUNTER25 0xb19
> -#define CSR_MHPMCOUNTER26 0xb1a
> -#define CSR_MHPMCOUNTER27 0xb1b
> -#define CSR_MHPMCOUNTER28 0xb1c
> -#define CSR_MHPMCOUNTER29 0xb1d
> -#define CSR_MHPMCOUNTER30 0xb1e
> -#define CSR_MHPMCOUNTER31 0xb1f
> -#define CSR_MHPMEVENT3 0x323
> -#define CSR_MHPMEVENT4 0x324
> -#define CSR_MHPMEVENT5 0x325
> -#define CSR_MHPMEVENT6 0x326
> -#define CSR_MHPMEVENT7 0x327
> -#define CSR_MHPMEVENT8 0x328
> -#define CSR_MHPMEVENT9 0x329
> -#define CSR_MHPMEVENT10 0x32a
> -#define CSR_MHPMEVENT11 0x32b
> -#define CSR_MHPMEVENT12 0x32c
> -#define CSR_MHPMEVENT13 0x32d
> -#define CSR_MHPMEVENT14 0x32e
> -#define CSR_MHPMEVENT15 0x32f
> -#define CSR_MHPMEVENT16 0x330
> -#define CSR_MHPMEVENT17 0x331
> -#define CSR_MHPMEVENT18 0x332
> -#define CSR_MHPMEVENT19 0x333
> -#define CSR_MHPMEVENT20 0x334
> -#define CSR_MHPMEVENT21 0x335
> -#define CSR_MHPMEVENT22 0x336
> -#define CSR_MHPMEVENT23 0x337
> -#define CSR_MHPMEVENT24 0x338
> -#define CSR_MHPMEVENT25 0x339
> -#define CSR_MHPMEVENT26 0x33a
> -#define CSR_MHPMEVENT27 0x33b
> -#define CSR_MHPMEVENT28 0x33c
> -#define CSR_MHPMEVENT29 0x33d
> -#define CSR_MHPMEVENT30 0x33e
> -#define CSR_MHPMEVENT31 0x33f
> -#define CSR_MVENDORID 0xf11
> -#define CSR_MARCHID 0xf12
> -#define CSR_MIMPID 0xf13
> -#define CSR_MHARTID 0xf14
> -#define CSR_CYCLEH 0xc80
> -#define CSR_TIMEH 0xc81
> -#define CSR_INSTRETH 0xc82
> -#define CSR_HPMCOUNTER3H 0xc83
> -#define CSR_HPMCOUNTER4H 0xc84
> -#define CSR_HPMCOUNTER5H 0xc85
> -#define CSR_HPMCOUNTER6H 0xc86
> -#define CSR_HPMCOUNTER7H 0xc87
> -#define CSR_HPMCOUNTER8H 0xc88
> -#define CSR_HPMCOUNTER9H 0xc89
> -#define CSR_HPMCOUNTER10H 0xc8a
> -#define CSR_HPMCOUNTER11H 0xc8b
> -#define CSR_HPMCOUNTER12H 0xc8c
> -#define CSR_HPMCOUNTER13H 0xc8d
> -#define CSR_HPMCOUNTER14H 0xc8e
> -#define CSR_HPMCOUNTER15H 0xc8f
> -#define CSR_HPMCOUNTER16H 0xc90
> -#define CSR_HPMCOUNTER17H 0xc91
> -#define CSR_HPMCOUNTER18H 0xc92
> -#define CSR_HPMCOUNTER19H 0xc93
> -#define CSR_HPMCOUNTER20H 0xc94
> -#define CSR_HPMCOUNTER21H 0xc95
> -#define CSR_HPMCOUNTER22H 0xc96
> -#define CSR_HPMCOUNTER23H 0xc97
> -#define CSR_HPMCOUNTER24H 0xc98
> -#define CSR_HPMCOUNTER25H 0xc99
> -#define CSR_HPMCOUNTER26H 0xc9a
> -#define CSR_HPMCOUNTER27H 0xc9b
> -#define CSR_HPMCOUNTER28H 0xc9c
> -#define CSR_HPMCOUNTER29H 0xc9d
> -#define CSR_HPMCOUNTER30H 0xc9e
> -#define CSR_HPMCOUNTER31H 0xc9f
> -#define CSR_MCYCLEH 0xb80
> -#define CSR_MINSTRETH 0xb82
> -#define CSR_MHPMCOUNTER3H 0xb83
> -#define CSR_MHPMCOUNTER4H 0xb84
> -#define CSR_MHPMCOUNTER5H 0xb85
> -#define CSR_MHPMCOUNTER6H 0xb86
> -#define CSR_MHPMCOUNTER7H 0xb87
> -#define CSR_MHPMCOUNTER8H 0xb88
> -#define CSR_MHPMCOUNTER9H 0xb89
> -#define CSR_MHPMCOUNTER10H 0xb8a
> -#define CSR_MHPMCOUNTER11H 0xb8b
> -#define CSR_MHPMCOUNTER12H 0xb8c
> -#define CSR_MHPMCOUNTER13H 0xb8d
> -#define CSR_MHPMCOUNTER14H 0xb8e
> -#define CSR_MHPMCOUNTER15H 0xb8f
> -#define CSR_MHPMCOUNTER16H 0xb90
> -#define CSR_MHPMCOUNTER17H 0xb91
> -#define CSR_MHPMCOUNTER18H 0xb92
> -#define CSR_MHPMCOUNTER19H 0xb93
> -#define CSR_MHPMCOUNTER20H 0xb94
> -#define CSR_MHPMCOUNTER21H 0xb95
> -#define CSR_MHPMCOUNTER22H 0xb96
> -#define CSR_MHPMCOUNTER23H 0xb97
> -#define CSR_MHPMCOUNTER24H 0xb98
> -#define CSR_MHPMCOUNTER25H 0xb99
> -#define CSR_MHPMCOUNTER26H 0xb9a
> -#define CSR_MHPMCOUNTER27H 0xb9b
> -#define CSR_MHPMCOUNTER28H 0xb9c
> -#define CSR_MHPMCOUNTER29H 0xb9d
> -#define CSR_MHPMCOUNTER30H 0xb9e
> -#define CSR_MHPMCOUNTER31H 0xb9f
> -#define CAUSE_MISALIGNED_FETCH 0x0
> -#define CAUSE_FETCH_ACCESS 0x1
> -#define CAUSE_ILLEGAL_INSTRUCTION 0x2
> -#define CAUSE_BREAKPOINT 0x3
> -#define CAUSE_MISALIGNED_LOAD 0x4
> -#define CAUSE_LOAD_ACCESS 0x5
> -#define CAUSE_MISALIGNED_STORE 0x6
> -#define CAUSE_STORE_ACCESS 0x7
> -#define CAUSE_USER_ECALL 0x8
> -#define CAUSE_SUPERVISOR_ECALL 0x9
> -#define CAUSE_HYPERVISOR_ECALL 0xa
> -#define CAUSE_MACHINE_ECALL 0xb
> -#define CAUSE_FETCH_PAGE_FAULT 0xc
> -#define CAUSE_LOAD_PAGE_FAULT 0xd
> -#define CAUSE_STORE_PAGE_FAULT 0xf
> -#endif
> -#ifdef DECLARE_INSN
> -DECLARE_INSN(beq, MATCH_BEQ, MASK_BEQ)
> -DECLARE_INSN(bne, MATCH_BNE, MASK_BNE)
> -DECLARE_INSN(blt, MATCH_BLT, MASK_BLT)
> -DECLARE_INSN(bge, MATCH_BGE, MASK_BGE)
> -DECLARE_INSN(bltu, MATCH_BLTU, MASK_BLTU)
> -DECLARE_INSN(bgeu, MATCH_BGEU, MASK_BGEU)
> -DECLARE_INSN(jalr, MATCH_JALR, MASK_JALR)
> -DECLARE_INSN(jal, MATCH_JAL, MASK_JAL)
> -DECLARE_INSN(lui, MATCH_LUI, MASK_LUI)
> -DECLARE_INSN(auipc, MATCH_AUIPC, MASK_AUIPC)
> -DECLARE_INSN(addi, MATCH_ADDI, MASK_ADDI)
> -DECLARE_INSN(slli, MATCH_SLLI, MASK_SLLI)
> -DECLARE_INSN(slti, MATCH_SLTI, MASK_SLTI)
> -DECLARE_INSN(sltiu, MATCH_SLTIU, MASK_SLTIU)
> -DECLARE_INSN(xori, MATCH_XORI, MASK_XORI)
> -DECLARE_INSN(srli, MATCH_SRLI, MASK_SRLI)
> -DECLARE_INSN(srai, MATCH_SRAI, MASK_SRAI)
> -DECLARE_INSN(ori, MATCH_ORI, MASK_ORI)
> -DECLARE_INSN(andi, MATCH_ANDI, MASK_ANDI)
> -DECLARE_INSN(add, MATCH_ADD, MASK_ADD)
> -DECLARE_INSN(sub, MATCH_SUB, MASK_SUB)
> -DECLARE_INSN(sll, MATCH_SLL, MASK_SLL)
> -DECLARE_INSN(slt, MATCH_SLT, MASK_SLT)
> -DECLARE_INSN(sltu, MATCH_SLTU, MASK_SLTU)
> -DECLARE_INSN(xor, MATCH_XOR, MASK_XOR)
> -DECLARE_INSN(srl, MATCH_SRL, MASK_SRL)
> -DECLARE_INSN(sra, MATCH_SRA, MASK_SRA)
> -DECLARE_INSN( or , MATCH_OR, MASK_OR)
> -DECLARE_INSN( and , MATCH_AND, MASK_AND)
> -DECLARE_INSN(addiw, MATCH_ADDIW, MASK_ADDIW)
> -DECLARE_INSN(slliw, MATCH_SLLIW, MASK_SLLIW)
> -DECLARE_INSN(srliw, MATCH_SRLIW, MASK_SRLIW)
> -DECLARE_INSN(sraiw, MATCH_SRAIW, MASK_SRAIW)
> -DECLARE_INSN(addw, MATCH_ADDW, MASK_ADDW)
> -DECLARE_INSN(subw, MATCH_SUBW, MASK_SUBW)
> -DECLARE_INSN(sllw, MATCH_SLLW, MASK_SLLW)
> -DECLARE_INSN(srlw, MATCH_SRLW, MASK_SRLW)
> -DECLARE_INSN(sraw, MATCH_SRAW, MASK_SRAW)
> -DECLARE_INSN(lb, MATCH_LB, MASK_LB)
> -DECLARE_INSN(lh, MATCH_LH, MASK_LH)
> -DECLARE_INSN(lw, MATCH_LW, MASK_LW)
> -DECLARE_INSN(ld, MATCH_LD, MASK_LD)
> -DECLARE_INSN(lbu, MATCH_LBU, MASK_LBU)
> -DECLARE_INSN(lhu, MATCH_LHU, MASK_LHU)
> -DECLARE_INSN(lwu, MATCH_LWU, MASK_LWU)
> -DECLARE_INSN(sb, MATCH_SB, MASK_SB)
> -DECLARE_INSN(sh, MATCH_SH, MASK_SH)
> -DECLARE_INSN(sw, MATCH_SW, MASK_SW)
> -DECLARE_INSN(sd, MATCH_SD, MASK_SD)
> -DECLARE_INSN(fence, MATCH_FENCE, MASK_FENCE)
> -DECLARE_INSN(fence_i, MATCH_FENCE_I, MASK_FENCE_I)
> -DECLARE_INSN(mul, MATCH_MUL, MASK_MUL)
> -DECLARE_INSN(mulh, MATCH_MULH, MASK_MULH)
> -DECLARE_INSN(mulhsu, MATCH_MULHSU, MASK_MULHSU)
> -DECLARE_INSN(mulhu, MATCH_MULHU, MASK_MULHU)
> -DECLARE_INSN(div, MATCH_DIV, MASK_DIV)
> -DECLARE_INSN(divu, MATCH_DIVU, MASK_DIVU)
> -DECLARE_INSN(rem, MATCH_REM, MASK_REM)
> -DECLARE_INSN(remu, MATCH_REMU, MASK_REMU)
> -DECLARE_INSN(mulw, MATCH_MULW, MASK_MULW)
> -DECLARE_INSN(divw, MATCH_DIVW, MASK_DIVW)
> -DECLARE_INSN(divuw, MATCH_DIVUW, MASK_DIVUW)
> -DECLARE_INSN(remw, MATCH_REMW, MASK_REMW)
> -DECLARE_INSN(remuw, MATCH_REMUW, MASK_REMUW)
> -DECLARE_INSN(amoadd_w, MATCH_AMOADD_W, MASK_AMOADD_W)
> -DECLARE_INSN(amoxor_w, MATCH_AMOXOR_W, MASK_AMOXOR_W)
> -DECLARE_INSN(amoor_w, MATCH_AMOOR_W, MASK_AMOOR_W)
> -DECLARE_INSN(amoand_w, MATCH_AMOAND_W, MASK_AMOAND_W)
> -DECLARE_INSN(amomin_w, MATCH_AMOMIN_W, MASK_AMOMIN_W)
> -DECLARE_INSN(amomax_w, MATCH_AMOMAX_W, MASK_AMOMAX_W)
> -DECLARE_INSN(amominu_w, MATCH_AMOMINU_W, MASK_AMOMINU_W)
> -DECLARE_INSN(amomaxu_w, MATCH_AMOMAXU_W, MASK_AMOMAXU_W)
> -DECLARE_INSN(amoswap_w, MATCH_AMOSWAP_W, MASK_AMOSWAP_W)
> -DECLARE_INSN(lr_w, MATCH_LR_W, MASK_LR_W)
> -DECLARE_INSN(sc_w, MATCH_SC_W, MASK_SC_W)
> -DECLARE_INSN(amoadd_d, MATCH_AMOADD_D, MASK_AMOADD_D)
> -DECLARE_INSN(amoxor_d, MATCH_AMOXOR_D, MASK_AMOXOR_D)
> -DECLARE_INSN(amoor_d, MATCH_AMOOR_D, MASK_AMOOR_D)
> -DECLARE_INSN(amoand_d, MATCH_AMOAND_D, MASK_AMOAND_D)
> -DECLARE_INSN(amomin_d, MATCH_AMOMIN_D, MASK_AMOMIN_D)
> -DECLARE_INSN(amomax_d, MATCH_AMOMAX_D, MASK_AMOMAX_D)
> -DECLARE_INSN(amominu_d, MATCH_AMOMINU_D, MASK_AMOMINU_D)
> -DECLARE_INSN(amomaxu_d, MATCH_AMOMAXU_D, MASK_AMOMAXU_D)
> -DECLARE_INSN(amoswap_d, MATCH_AMOSWAP_D, MASK_AMOSWAP_D)
> -DECLARE_INSN(lr_d, MATCH_LR_D, MASK_LR_D)
> -DECLARE_INSN(sc_d, MATCH_SC_D, MASK_SC_D)
> -DECLARE_INSN(ecall, MATCH_ECALL, MASK_ECALL)
> -DECLARE_INSN(ebreak, MATCH_EBREAK, MASK_EBREAK)
> -DECLARE_INSN(uret, MATCH_URET, MASK_URET)
> -DECLARE_INSN(sret, MATCH_SRET, MASK_SRET)
> -DECLARE_INSN(mret, MATCH_MRET, MASK_MRET)
> -DECLARE_INSN(dret, MATCH_DRET, MASK_DRET)
> -DECLARE_INSN(sfence_vma, MATCH_SFENCE_VMA, MASK_SFENCE_VMA)
> -DECLARE_INSN(wfi, MATCH_WFI, MASK_WFI)
> -DECLARE_INSN(csrrw, MATCH_CSRRW, MASK_CSRRW)
> -DECLARE_INSN(csrrs, MATCH_CSRRS, MASK_CSRRS)
> -DECLARE_INSN(csrrc, MATCH_CSRRC, MASK_CSRRC)
> -DECLARE_INSN(csrrwi, MATCH_CSRRWI, MASK_CSRRWI)
> -DECLARE_INSN(csrrsi, MATCH_CSRRSI, MASK_CSRRSI)
> -DECLARE_INSN(csrrci, MATCH_CSRRCI, MASK_CSRRCI)
> -DECLARE_INSN(fadd_s, MATCH_FADD_S, MASK_FADD_S)
> -DECLARE_INSN(fsub_s, MATCH_FSUB_S, MASK_FSUB_S)
> -DECLARE_INSN(fmul_s, MATCH_FMUL_S, MASK_FMUL_S)
> -DECLARE_INSN(fdiv_s, MATCH_FDIV_S, MASK_FDIV_S)
> -DECLARE_INSN(fsgnj_s, MATCH_FSGNJ_S, MASK_FSGNJ_S)
> -DECLARE_INSN(fsgnjn_s, MATCH_FSGNJN_S, MASK_FSGNJN_S)
> -DECLARE_INSN(fsgnjx_s, MATCH_FSGNJX_S, MASK_FSGNJX_S)
> -DECLARE_INSN(fmin_s, MATCH_FMIN_S, MASK_FMIN_S)
> -DECLARE_INSN(fmax_s, MATCH_FMAX_S, MASK_FMAX_S)
> -DECLARE_INSN(fsqrt_s, MATCH_FSQRT_S, MASK_FSQRT_S)
> -DECLARE_INSN(fadd_d, MATCH_FADD_D, MASK_FADD_D)
> -DECLARE_INSN(fsub_d, MATCH_FSUB_D, MASK_FSUB_D)
> -DECLARE_INSN(fmul_d, MATCH_FMUL_D, MASK_FMUL_D)
> -DECLARE_INSN(fdiv_d, MATCH_FDIV_D, MASK_FDIV_D)
> -DECLARE_INSN(fsgnj_d, MATCH_FSGNJ_D, MASK_FSGNJ_D)
> -DECLARE_INSN(fsgnjn_d, MATCH_FSGNJN_D, MASK_FSGNJN_D)
> -DECLARE_INSN(fsgnjx_d, MATCH_FSGNJX_D, MASK_FSGNJX_D)
> -DECLARE_INSN(fmin_d, MATCH_FMIN_D, MASK_FMIN_D)
> -DECLARE_INSN(fmax_d, MATCH_FMAX_D, MASK_FMAX_D)
> -DECLARE_INSN(fcvt_s_d, MATCH_FCVT_S_D, MASK_FCVT_S_D)
> -DECLARE_INSN(fcvt_d_s, MATCH_FCVT_D_S, MASK_FCVT_D_S)
> -DECLARE_INSN(fsqrt_d, MATCH_FSQRT_D, MASK_FSQRT_D)
> -DECLARE_INSN(fadd_q, MATCH_FADD_Q, MASK_FADD_Q)
> -DECLARE_INSN(fsub_q, MATCH_FSUB_Q, MASK_FSUB_Q)
> -DECLARE_INSN(fmul_q, MATCH_FMUL_Q, MASK_FMUL_Q)
> -DECLARE_INSN(fdiv_q, MATCH_FDIV_Q, MASK_FDIV_Q)
> -DECLARE_INSN(fsgnj_q, MATCH_FSGNJ_Q, MASK_FSGNJ_Q)
> -DECLARE_INSN(fsgnjn_q, MATCH_FSGNJN_Q, MASK_FSGNJN_Q)
> -DECLARE_INSN(fsgnjx_q, MATCH_FSGNJX_Q, MASK_FSGNJX_Q)
> -DECLARE_INSN(fmin_q, MATCH_FMIN_Q, MASK_FMIN_Q)
> -DECLARE_INSN(fmax_q, MATCH_FMAX_Q, MASK_FMAX_Q)
> -DECLARE_INSN(fcvt_s_q, MATCH_FCVT_S_Q, MASK_FCVT_S_Q)
> -DECLARE_INSN(fcvt_q_s, MATCH_FCVT_Q_S, MASK_FCVT_Q_S)
> -DECLARE_INSN(fcvt_d_q, MATCH_FCVT_D_Q, MASK_FCVT_D_Q)
> -DECLARE_INSN(fcvt_q_d, MATCH_FCVT_Q_D, MASK_FCVT_Q_D)
> -DECLARE_INSN(fsqrt_q, MATCH_FSQRT_Q, MASK_FSQRT_Q)
> -DECLARE_INSN(fle_s, MATCH_FLE_S, MASK_FLE_S)
> -DECLARE_INSN(flt_s, MATCH_FLT_S, MASK_FLT_S)
> -DECLARE_INSN(feq_s, MATCH_FEQ_S, MASK_FEQ_S)
> -DECLARE_INSN(fle_d, MATCH_FLE_D, MASK_FLE_D)
> -DECLARE_INSN(flt_d, MATCH_FLT_D, MASK_FLT_D)
> -DECLARE_INSN(feq_d, MATCH_FEQ_D, MASK_FEQ_D)
> -DECLARE_INSN(fle_q, MATCH_FLE_Q, MASK_FLE_Q)
> -DECLARE_INSN(flt_q, MATCH_FLT_Q, MASK_FLT_Q)
> -DECLARE_INSN(feq_q, MATCH_FEQ_Q, MASK_FEQ_Q)
> -DECLARE_INSN(fcvt_w_s, MATCH_FCVT_W_S, MASK_FCVT_W_S)
> -DECLARE_INSN(fcvt_wu_s, MATCH_FCVT_WU_S, MASK_FCVT_WU_S)
> -DECLARE_INSN(fcvt_l_s, MATCH_FCVT_L_S, MASK_FCVT_L_S)
> -DECLARE_INSN(fcvt_lu_s, MATCH_FCVT_LU_S, MASK_FCVT_LU_S)
> -DECLARE_INSN(fmv_x_w, MATCH_FMV_X_W, MASK_FMV_X_W)
> -DECLARE_INSN(fclass_s, MATCH_FCLASS_S, MASK_FCLASS_S)
> -DECLARE_INSN(fcvt_w_d, MATCH_FCVT_W_D, MASK_FCVT_W_D)
> -DECLARE_INSN(fcvt_wu_d, MATCH_FCVT_WU_D, MASK_FCVT_WU_D)
> -DECLARE_INSN(fcvt_l_d, MATCH_FCVT_L_D, MASK_FCVT_L_D)
> -DECLARE_INSN(fcvt_lu_d, MATCH_FCVT_LU_D, MASK_FCVT_LU_D)
> -DECLARE_INSN(fmv_x_d, MATCH_FMV_X_D, MASK_FMV_X_D)
> -DECLARE_INSN(fclass_d, MATCH_FCLASS_D, MASK_FCLASS_D)
> -DECLARE_INSN(fcvt_w_q, MATCH_FCVT_W_Q, MASK_FCVT_W_Q)
> -DECLARE_INSN(fcvt_wu_q, MATCH_FCVT_WU_Q, MASK_FCVT_WU_Q)
> -DECLARE_INSN(fcvt_l_q, MATCH_FCVT_L_Q, MASK_FCVT_L_Q)
> -DECLARE_INSN(fcvt_lu_q, MATCH_FCVT_LU_Q, MASK_FCVT_LU_Q)
> -DECLARE_INSN(fmv_x_q, MATCH_FMV_X_Q, MASK_FMV_X_Q)
> -DECLARE_INSN(fclass_q, MATCH_FCLASS_Q, MASK_FCLASS_Q)
> -DECLARE_INSN(fcvt_s_w, MATCH_FCVT_S_W, MASK_FCVT_S_W)
> -DECLARE_INSN(fcvt_s_wu, MATCH_FCVT_S_WU, MASK_FCVT_S_WU)
> -DECLARE_INSN(fcvt_s_l, MATCH_FCVT_S_L, MASK_FCVT_S_L)
> -DECLARE_INSN(fcvt_s_lu, MATCH_FCVT_S_LU, MASK_FCVT_S_LU)
> -DECLARE_INSN(fmv_w_x, MATCH_FMV_W_X, MASK_FMV_W_X)
> -DECLARE_INSN(fcvt_d_w, MATCH_FCVT_D_W, MASK_FCVT_D_W)
> -DECLARE_INSN(fcvt_d_wu, MATCH_FCVT_D_WU, MASK_FCVT_D_WU)
> -DECLARE_INSN(fcvt_d_l, MATCH_FCVT_D_L, MASK_FCVT_D_L)
> -DECLARE_INSN(fcvt_d_lu, MATCH_FCVT_D_LU, MASK_FCVT_D_LU)
> -DECLARE_INSN(fmv_d_x, MATCH_FMV_D_X, MASK_FMV_D_X)
> -DECLARE_INSN(fcvt_q_w, MATCH_FCVT_Q_W, MASK_FCVT_Q_W)
> -DECLARE_INSN(fcvt_q_wu, MATCH_FCVT_Q_WU, MASK_FCVT_Q_WU)
> -DECLARE_INSN(fcvt_q_l, MATCH_FCVT_Q_L, MASK_FCVT_Q_L)
> -DECLARE_INSN(fcvt_q_lu, MATCH_FCVT_Q_LU, MASK_FCVT_Q_LU)
> -DECLARE_INSN(fmv_q_x, MATCH_FMV_Q_X, MASK_FMV_Q_X)
> -DECLARE_INSN(flw, MATCH_FLW, MASK_FLW)
> -DECLARE_INSN(fld, MATCH_FLD, MASK_FLD)
> -DECLARE_INSN(flq, MATCH_FLQ, MASK_FLQ)
> -DECLARE_INSN(fsw, MATCH_FSW, MASK_FSW)
> -DECLARE_INSN(fsd, MATCH_FSD, MASK_FSD)
> -DECLARE_INSN(fsq, MATCH_FSQ, MASK_FSQ)
> -DECLARE_INSN(fmadd_s, MATCH_FMADD_S, MASK_FMADD_S)
> -DECLARE_INSN(fmsub_s, MATCH_FMSUB_S, MASK_FMSUB_S)
> -DECLARE_INSN(fnmsub_s, MATCH_FNMSUB_S, MASK_FNMSUB_S)
> -DECLARE_INSN(fnmadd_s, MATCH_FNMADD_S, MASK_FNMADD_S)
> -DECLARE_INSN(fmadd_d, MATCH_FMADD_D, MASK_FMADD_D)
> -DECLARE_INSN(fmsub_d, MATCH_FMSUB_D, MASK_FMSUB_D)
> -DECLARE_INSN(fnmsub_d, MATCH_FNMSUB_D, MASK_FNMSUB_D)
> -DECLARE_INSN(fnmadd_d, MATCH_FNMADD_D, MASK_FNMADD_D)
> -DECLARE_INSN(fmadd_q, MATCH_FMADD_Q, MASK_FMADD_Q)
> -DECLARE_INSN(fmsub_q, MATCH_FMSUB_Q, MASK_FMSUB_Q)
> -DECLARE_INSN(fnmsub_q, MATCH_FNMSUB_Q, MASK_FNMSUB_Q)
> -DECLARE_INSN(fnmadd_q, MATCH_FNMADD_Q, MASK_FNMADD_Q)
> -DECLARE_INSN(c_nop, MATCH_C_NOP, MASK_C_NOP)
> -DECLARE_INSN(c_addi16sp, MATCH_C_ADDI16SP, MASK_C_ADDI16SP)
> -DECLARE_INSN(c_jr, MATCH_C_JR, MASK_C_JR)
> -DECLARE_INSN(c_jalr, MATCH_C_JALR, MASK_C_JALR)
> -DECLARE_INSN(c_ebreak, MATCH_C_EBREAK, MASK_C_EBREAK)
> -DECLARE_INSN(c_ld, MATCH_C_LD, MASK_C_LD)
> -DECLARE_INSN(c_sd, MATCH_C_SD, MASK_C_SD)
> -DECLARE_INSN(c_addiw, MATCH_C_ADDIW, MASK_C_ADDIW)
> -DECLARE_INSN(c_ldsp, MATCH_C_LDSP, MASK_C_LDSP)
> -DECLARE_INSN(c_sdsp, MATCH_C_SDSP, MASK_C_SDSP)
> -DECLARE_INSN(c_addi4spn, MATCH_C_ADDI4SPN, MASK_C_ADDI4SPN)
> -DECLARE_INSN(c_fld, MATCH_C_FLD, MASK_C_FLD)
> -DECLARE_INSN(c_lw, MATCH_C_LW, MASK_C_LW)
> -DECLARE_INSN(c_flw, MATCH_C_FLW, MASK_C_FLW)
> -DECLARE_INSN(c_fsd, MATCH_C_FSD, MASK_C_FSD)
> -DECLARE_INSN(c_sw, MATCH_C_SW, MASK_C_SW)
> -DECLARE_INSN(c_fsw, MATCH_C_FSW, MASK_C_FSW)
> -DECLARE_INSN(c_addi, MATCH_C_ADDI, MASK_C_ADDI)
> -DECLARE_INSN(c_jal, MATCH_C_JAL, MASK_C_JAL)
> -DECLARE_INSN(c_li, MATCH_C_LI, MASK_C_LI)
> -DECLARE_INSN(c_lui, MATCH_C_LUI, MASK_C_LUI)
> -DECLARE_INSN(c_srli, MATCH_C_SRLI, MASK_C_SRLI)
> -DECLARE_INSN(c_srai, MATCH_C_SRAI, MASK_C_SRAI)
> -DECLARE_INSN(c_andi, MATCH_C_ANDI, MASK_C_ANDI)
> -DECLARE_INSN(c_sub, MATCH_C_SUB, MASK_C_SUB)
> -DECLARE_INSN(c_xor, MATCH_C_XOR, MASK_C_XOR)
> -DECLARE_INSN(c_or, MATCH_C_OR, MASK_C_OR)
> -DECLARE_INSN(c_and, MATCH_C_AND, MASK_C_AND)
> -DECLARE_INSN(c_subw, MATCH_C_SUBW, MASK_C_SUBW)
> -DECLARE_INSN(c_addw, MATCH_C_ADDW, MASK_C_ADDW)
> -DECLARE_INSN(c_j, MATCH_C_J, MASK_C_J)
> -DECLARE_INSN(c_beqz, MATCH_C_BEQZ, MASK_C_BEQZ)
> -DECLARE_INSN(c_bnez, MATCH_C_BNEZ, MASK_C_BNEZ)
> -DECLARE_INSN(c_slli, MATCH_C_SLLI, MASK_C_SLLI)
> -DECLARE_INSN(c_fldsp, MATCH_C_FLDSP, MASK_C_FLDSP)
> -DECLARE_INSN(c_lwsp, MATCH_C_LWSP, MASK_C_LWSP)
> -DECLARE_INSN(c_flwsp, MATCH_C_FLWSP, MASK_C_FLWSP)
> -DECLARE_INSN(c_mv, MATCH_C_MV, MASK_C_MV)
> -DECLARE_INSN(c_add, MATCH_C_ADD, MASK_C_ADD)
> -DECLARE_INSN(c_fsdsp, MATCH_C_FSDSP, MASK_C_FSDSP)
> -DECLARE_INSN(c_swsp, MATCH_C_SWSP, MASK_C_SWSP)
> -DECLARE_INSN(c_fswsp, MATCH_C_FSWSP, MASK_C_FSWSP)
> -DECLARE_INSN(custom0, MATCH_CUSTOM0, MASK_CUSTOM0)
> -DECLARE_INSN(custom0_rs1, MATCH_CUSTOM0_RS1, MASK_CUSTOM0_RS1)
> -DECLARE_INSN(custom0_rs1_rs2, MATCH_CUSTOM0_RS1_RS2, MASK_CUSTOM0_RS1_RS2)
> -DECLARE_INSN(custom0_rd, MATCH_CUSTOM0_RD, MASK_CUSTOM0_RD)
> -DECLARE_INSN(custom0_rd_rs1, MATCH_CUSTOM0_RD_RS1, MASK_CUSTOM0_RD_RS1)
> -DECLARE_INSN(custom0_rd_rs1_rs2, MATCH_CUSTOM0_RD_RS1_RS2, MASK_CUSTOM0_RD_RS1_RS2)
> -DECLARE_INSN(custom1, MATCH_CUSTOM1, MASK_CUSTOM1)
> -DECLARE_INSN(custom1_rs1, MATCH_CUSTOM1_RS1, MASK_CUSTOM1_RS1)
> -DECLARE_INSN(custom1_rs1_rs2, MATCH_CUSTOM1_RS1_RS2, MASK_CUSTOM1_RS1_RS2)
> -DECLARE_INSN(custom1_rd, MATCH_CUSTOM1_RD, MASK_CUSTOM1_RD)
> -DECLARE_INSN(custom1_rd_rs1, MATCH_CUSTOM1_RD_RS1, MASK_CUSTOM1_RD_RS1)
> -DECLARE_INSN(custom1_rd_rs1_rs2, MATCH_CUSTOM1_RD_RS1_RS2, MASK_CUSTOM1_RD_RS1_RS2)
> -DECLARE_INSN(custom2, MATCH_CUSTOM2, MASK_CUSTOM2)
> -DECLARE_INSN(custom2_rs1, MATCH_CUSTOM2_RS1, MASK_CUSTOM2_RS1)
> -DECLARE_INSN(custom2_rs1_rs2, MATCH_CUSTOM2_RS1_RS2, MASK_CUSTOM2_RS1_RS2)
> -DECLARE_INSN(custom2_rd, MATCH_CUSTOM2_RD, MASK_CUSTOM2_RD)
> -DECLARE_INSN(custom2_rd_rs1, MATCH_CUSTOM2_RD_RS1, MASK_CUSTOM2_RD_RS1)
> -DECLARE_INSN(custom2_rd_rs1_rs2, MATCH_CUSTOM2_RD_RS1_RS2, MASK_CUSTOM2_RD_RS1_RS2)
> -DECLARE_INSN(custom3, MATCH_CUSTOM3, MASK_CUSTOM3)
> -DECLARE_INSN(custom3_rs1, MATCH_CUSTOM3_RS1, MASK_CUSTOM3_RS1)
> -DECLARE_INSN(custom3_rs1_rs2, MATCH_CUSTOM3_RS1_RS2, MASK_CUSTOM3_RS1_RS2)
> -DECLARE_INSN(custom3_rd, MATCH_CUSTOM3_RD, MASK_CUSTOM3_RD)
> -DECLARE_INSN(custom3_rd_rs1, MATCH_CUSTOM3_RD_RS1, MASK_CUSTOM3_RD_RS1)
> -DECLARE_INSN(custom3_rd_rs1_rs2, MATCH_CUSTOM3_RD_RS1_RS2, MASK_CUSTOM3_RD_RS1_RS2)
> -#endif
> -#ifdef DECLARE_CSR
> -DECLARE_CSR(fflags, CSR_FFLAGS)
> -DECLARE_CSR(frm, CSR_FRM)
> -DECLARE_CSR(fcsr, CSR_FCSR)
> -DECLARE_CSR(cycle, CSR_CYCLE)
> -DECLARE_CSR(time, CSR_TIME)
> -DECLARE_CSR(instret, CSR_INSTRET)
> -DECLARE_CSR(hpmcounter3, CSR_HPMCOUNTER3)
> -DECLARE_CSR(hpmcounter4, CSR_HPMCOUNTER4)
> -DECLARE_CSR(hpmcounter5, CSR_HPMCOUNTER5)
> -DECLARE_CSR(hpmcounter6, CSR_HPMCOUNTER6)
> -DECLARE_CSR(hpmcounter7, CSR_HPMCOUNTER7)
> -DECLARE_CSR(hpmcounter8, CSR_HPMCOUNTER8)
> -DECLARE_CSR(hpmcounter9, CSR_HPMCOUNTER9)
> -DECLARE_CSR(hpmcounter10, CSR_HPMCOUNTER10)
> -DECLARE_CSR(hpmcounter11, CSR_HPMCOUNTER11)
> -DECLARE_CSR(hpmcounter12, CSR_HPMCOUNTER12)
> -DECLARE_CSR(hpmcounter13, CSR_HPMCOUNTER13)
> -DECLARE_CSR(hpmcounter14, CSR_HPMCOUNTER14)
> -DECLARE_CSR(hpmcounter15, CSR_HPMCOUNTER15)
> -DECLARE_CSR(hpmcounter16, CSR_HPMCOUNTER16)
> -DECLARE_CSR(hpmcounter17, CSR_HPMCOUNTER17)
> -DECLARE_CSR(hpmcounter18, CSR_HPMCOUNTER18)
> -DECLARE_CSR(hpmcounter19, CSR_HPMCOUNTER19)
> -DECLARE_CSR(hpmcounter20, CSR_HPMCOUNTER20)
> -DECLARE_CSR(hpmcounter21, CSR_HPMCOUNTER21)
> -DECLARE_CSR(hpmcounter22, CSR_HPMCOUNTER22)
> -DECLARE_CSR(hpmcounter23, CSR_HPMCOUNTER23)
> -DECLARE_CSR(hpmcounter24, CSR_HPMCOUNTER24)
> -DECLARE_CSR(hpmcounter25, CSR_HPMCOUNTER25)
> -DECLARE_CSR(hpmcounter26, CSR_HPMCOUNTER26)
> -DECLARE_CSR(hpmcounter27, CSR_HPMCOUNTER27)
> -DECLARE_CSR(hpmcounter28, CSR_HPMCOUNTER28)
> -DECLARE_CSR(hpmcounter29, CSR_HPMCOUNTER29)
> -DECLARE_CSR(hpmcounter30, CSR_HPMCOUNTER30)
> -DECLARE_CSR(hpmcounter31, CSR_HPMCOUNTER31)
> -DECLARE_CSR(sstatus, CSR_SSTATUS)
> -DECLARE_CSR(sie, CSR_SIE)
> -DECLARE_CSR(stvec, CSR_STVEC)
> -DECLARE_CSR(scounteren, CSR_SCOUNTEREN)
> -DECLARE_CSR(sscratch, CSR_SSCRATCH)
> -DECLARE_CSR(sepc, CSR_SEPC)
> -DECLARE_CSR(scause, CSR_SCAUSE)
> -DECLARE_CSR(sbadaddr, CSR_SBADADDR)
> -DECLARE_CSR(sip, CSR_SIP)
> -DECLARE_CSR(sptbr, CSR_SPTBR)
> -DECLARE_CSR(mstatus, CSR_MSTATUS)
> -DECLARE_CSR(misa, CSR_MISA)
> -DECLARE_CSR(medeleg, CSR_MEDELEG)
> -DECLARE_CSR(mideleg, CSR_MIDELEG)
> -DECLARE_CSR(mie, CSR_MIE)
> -DECLARE_CSR(mtvec, CSR_MTVEC)
> -DECLARE_CSR(mcounteren, CSR_MCOUNTEREN)
> -DECLARE_CSR(mscratch, CSR_MSCRATCH)
> -DECLARE_CSR(mepc, CSR_MEPC)
> -DECLARE_CSR(mcause, CSR_MCAUSE)
> -DECLARE_CSR(mbadaddr, CSR_MBADADDR)
> -DECLARE_CSR(mip, CSR_MIP)
> -DECLARE_CSR(pmpcfg0, CSR_PMPCFG0)
> -DECLARE_CSR(pmpcfg1, CSR_PMPCFG1)
> -DECLARE_CSR(pmpcfg2, CSR_PMPCFG2)
> -DECLARE_CSR(pmpcfg3, CSR_PMPCFG3)
> -DECLARE_CSR(pmpaddr0, CSR_PMPADDR0)
> -DECLARE_CSR(pmpaddr1, CSR_PMPADDR1)
> -DECLARE_CSR(pmpaddr2, CSR_PMPADDR2)
> -DECLARE_CSR(pmpaddr3, CSR_PMPADDR3)
> -DECLARE_CSR(pmpaddr4, CSR_PMPADDR4)
> -DECLARE_CSR(pmpaddr5, CSR_PMPADDR5)
> -DECLARE_CSR(pmpaddr6, CSR_PMPADDR6)
> -DECLARE_CSR(pmpaddr7, CSR_PMPADDR7)
> -DECLARE_CSR(pmpaddr8, CSR_PMPADDR8)
> -DECLARE_CSR(pmpaddr9, CSR_PMPADDR9)
> -DECLARE_CSR(pmpaddr10, CSR_PMPADDR10)
> -DECLARE_CSR(pmpaddr11, CSR_PMPADDR11)
> -DECLARE_CSR(pmpaddr12, CSR_PMPADDR12)
> -DECLARE_CSR(pmpaddr13, CSR_PMPADDR13)
> -DECLARE_CSR(pmpaddr14, CSR_PMPADDR14)
> -DECLARE_CSR(pmpaddr15, CSR_PMPADDR15)
> -DECLARE_CSR(tselect, CSR_TSELECT)
> -DECLARE_CSR(tdata1, CSR_TDATA1)
> -DECLARE_CSR(tdata2, CSR_TDATA2)
> -DECLARE_CSR(tdata3, CSR_TDATA3)
> -DECLARE_CSR(dcsr, CSR_DCSR)
> -DECLARE_CSR(dpc, CSR_DPC)
> -DECLARE_CSR(dscratch, CSR_DSCRATCH)
> -DECLARE_CSR(mcycle, CSR_MCYCLE)
> -DECLARE_CSR(minstret, CSR_MINSTRET)
> -DECLARE_CSR(mhpmcounter3, CSR_MHPMCOUNTER3)
> -DECLARE_CSR(mhpmcounter4, CSR_MHPMCOUNTER4)
> -DECLARE_CSR(mhpmcounter5, CSR_MHPMCOUNTER5)
> -DECLARE_CSR(mhpmcounter6, CSR_MHPMCOUNTER6)
> -DECLARE_CSR(mhpmcounter7, CSR_MHPMCOUNTER7)
> -DECLARE_CSR(mhpmcounter8, CSR_MHPMCOUNTER8)
> -DECLARE_CSR(mhpmcounter9, CSR_MHPMCOUNTER9)
> -DECLARE_CSR(mhpmcounter10, CSR_MHPMCOUNTER10)
> -DECLARE_CSR(mhpmcounter11, CSR_MHPMCOUNTER11)
> -DECLARE_CSR(mhpmcounter12, CSR_MHPMCOUNTER12)
> -DECLARE_CSR(mhpmcounter13, CSR_MHPMCOUNTER13)
> -DECLARE_CSR(mhpmcounter14, CSR_MHPMCOUNTER14)
> -DECLARE_CSR(mhpmcounter15, CSR_MHPMCOUNTER15)
> -DECLARE_CSR(mhpmcounter16, CSR_MHPMCOUNTER16)
> -DECLARE_CSR(mhpmcounter17, CSR_MHPMCOUNTER17)
> -DECLARE_CSR(mhpmcounter18, CSR_MHPMCOUNTER18)
> -DECLARE_CSR(mhpmcounter19, CSR_MHPMCOUNTER19)
> -DECLARE_CSR(mhpmcounter20, CSR_MHPMCOUNTER20)
> -DECLARE_CSR(mhpmcounter21, CSR_MHPMCOUNTER21)
> -DECLARE_CSR(mhpmcounter22, CSR_MHPMCOUNTER22)
> -DECLARE_CSR(mhpmcounter23, CSR_MHPMCOUNTER23)
> -DECLARE_CSR(mhpmcounter24, CSR_MHPMCOUNTER24)
> -DECLARE_CSR(mhpmcounter25, CSR_MHPMCOUNTER25)
> -DECLARE_CSR(mhpmcounter26, CSR_MHPMCOUNTER26)
> -DECLARE_CSR(mhpmcounter27, CSR_MHPMCOUNTER27)
> -DECLARE_CSR(mhpmcounter28, CSR_MHPMCOUNTER28)
> -DECLARE_CSR(mhpmcounter29, CSR_MHPMCOUNTER29)
> -DECLARE_CSR(mhpmcounter30, CSR_MHPMCOUNTER30)
> -DECLARE_CSR(mhpmcounter31, CSR_MHPMCOUNTER31)
> -DECLARE_CSR(mhpmevent3, CSR_MHPMEVENT3)
> -DECLARE_CSR(mhpmevent4, CSR_MHPMEVENT4)
> -DECLARE_CSR(mhpmevent5, CSR_MHPMEVENT5)
> -DECLARE_CSR(mhpmevent6, CSR_MHPMEVENT6)
> -DECLARE_CSR(mhpmevent7, CSR_MHPMEVENT7)
> -DECLARE_CSR(mhpmevent8, CSR_MHPMEVENT8)
> -DECLARE_CSR(mhpmevent9, CSR_MHPMEVENT9)
> -DECLARE_CSR(mhpmevent10, CSR_MHPMEVENT10)
> -DECLARE_CSR(mhpmevent11, CSR_MHPMEVENT11)
> -DECLARE_CSR(mhpmevent12, CSR_MHPMEVENT12)
> -DECLARE_CSR(mhpmevent13, CSR_MHPMEVENT13)
> -DECLARE_CSR(mhpmevent14, CSR_MHPMEVENT14)
> -DECLARE_CSR(mhpmevent15, CSR_MHPMEVENT15)
> -DECLARE_CSR(mhpmevent16, CSR_MHPMEVENT16)
> -DECLARE_CSR(mhpmevent17, CSR_MHPMEVENT17)
> -DECLARE_CSR(mhpmevent18, CSR_MHPMEVENT18)
> -DECLARE_CSR(mhpmevent19, CSR_MHPMEVENT19)
> -DECLARE_CSR(mhpmevent20, CSR_MHPMEVENT20)
> -DECLARE_CSR(mhpmevent21, CSR_MHPMEVENT21)
> -DECLARE_CSR(mhpmevent22, CSR_MHPMEVENT22)
> -DECLARE_CSR(mhpmevent23, CSR_MHPMEVENT23)
> -DECLARE_CSR(mhpmevent24, CSR_MHPMEVENT24)
> -DECLARE_CSR(mhpmevent25, CSR_MHPMEVENT25)
> -DECLARE_CSR(mhpmevent26, CSR_MHPMEVENT26)
> -DECLARE_CSR(mhpmevent27, CSR_MHPMEVENT27)
> -DECLARE_CSR(mhpmevent28, CSR_MHPMEVENT28)
> -DECLARE_CSR(mhpmevent29, CSR_MHPMEVENT29)
> -DECLARE_CSR(mhpmevent30, CSR_MHPMEVENT30)
> -DECLARE_CSR(mhpmevent31, CSR_MHPMEVENT31)
> -DECLARE_CSR(mvendorid, CSR_MVENDORID)
> -DECLARE_CSR(marchid, CSR_MARCHID)
> -DECLARE_CSR(mimpid, CSR_MIMPID)
> -DECLARE_CSR(mhartid, CSR_MHARTID)
> -DECLARE_CSR(cycleh, CSR_CYCLEH)
> -DECLARE_CSR(timeh, CSR_TIMEH)
> -DECLARE_CSR(instreth, CSR_INSTRETH)
> -DECLARE_CSR(hpmcounter3h, CSR_HPMCOUNTER3H)
> -DECLARE_CSR(hpmcounter4h, CSR_HPMCOUNTER4H)
> -DECLARE_CSR(hpmcounter5h, CSR_HPMCOUNTER5H)
> -DECLARE_CSR(hpmcounter6h, CSR_HPMCOUNTER6H)
> -DECLARE_CSR(hpmcounter7h, CSR_HPMCOUNTER7H)
> -DECLARE_CSR(hpmcounter8h, CSR_HPMCOUNTER8H)
> -DECLARE_CSR(hpmcounter9h, CSR_HPMCOUNTER9H)
> -DECLARE_CSR(hpmcounter10h, CSR_HPMCOUNTER10H)
> -DECLARE_CSR(hpmcounter11h, CSR_HPMCOUNTER11H)
> -DECLARE_CSR(hpmcounter12h, CSR_HPMCOUNTER12H)
> -DECLARE_CSR(hpmcounter13h, CSR_HPMCOUNTER13H)
> -DECLARE_CSR(hpmcounter14h, CSR_HPMCOUNTER14H)
> -DECLARE_CSR(hpmcounter15h, CSR_HPMCOUNTER15H)
> -DECLARE_CSR(hpmcounter16h, CSR_HPMCOUNTER16H)
> -DECLARE_CSR(hpmcounter17h, CSR_HPMCOUNTER17H)
> -DECLARE_CSR(hpmcounter18h, CSR_HPMCOUNTER18H)
> -DECLARE_CSR(hpmcounter19h, CSR_HPMCOUNTER19H)
> -DECLARE_CSR(hpmcounter20h, CSR_HPMCOUNTER20H)
> -DECLARE_CSR(hpmcounter21h, CSR_HPMCOUNTER21H)
> -DECLARE_CSR(hpmcounter22h, CSR_HPMCOUNTER22H)
> -DECLARE_CSR(hpmcounter23h, CSR_HPMCOUNTER23H)
> -DECLARE_CSR(hpmcounter24h, CSR_HPMCOUNTER24H)
> -DECLARE_CSR(hpmcounter25h, CSR_HPMCOUNTER25H)
> -DECLARE_CSR(hpmcounter26h, CSR_HPMCOUNTER26H)
> -DECLARE_CSR(hpmcounter27h, CSR_HPMCOUNTER27H)
> -DECLARE_CSR(hpmcounter28h, CSR_HPMCOUNTER28H)
> -DECLARE_CSR(hpmcounter29h, CSR_HPMCOUNTER29H)
> -DECLARE_CSR(hpmcounter30h, CSR_HPMCOUNTER30H)
> -DECLARE_CSR(hpmcounter31h, CSR_HPMCOUNTER31H)
> -DECLARE_CSR(mcycleh, CSR_MCYCLEH)
> -DECLARE_CSR(minstreth, CSR_MINSTRETH)
> -DECLARE_CSR(mhpmcounter3h, CSR_MHPMCOUNTER3H)
> -DECLARE_CSR(mhpmcounter4h, CSR_MHPMCOUNTER4H)
> -DECLARE_CSR(mhpmcounter5h, CSR_MHPMCOUNTER5H)
> -DECLARE_CSR(mhpmcounter6h, CSR_MHPMCOUNTER6H)
> -DECLARE_CSR(mhpmcounter7h, CSR_MHPMCOUNTER7H)
> -DECLARE_CSR(mhpmcounter8h, CSR_MHPMCOUNTER8H)
> -DECLARE_CSR(mhpmcounter9h, CSR_MHPMCOUNTER9H)
> -DECLARE_CSR(mhpmcounter10h, CSR_MHPMCOUNTER10H)
> -DECLARE_CSR(mhpmcounter11h, CSR_MHPMCOUNTER11H)
> -DECLARE_CSR(mhpmcounter12h, CSR_MHPMCOUNTER12H)
> -DECLARE_CSR(mhpmcounter13h, CSR_MHPMCOUNTER13H)
> -DECLARE_CSR(mhpmcounter14h, CSR_MHPMCOUNTER14H)
> -DECLARE_CSR(mhpmcounter15h, CSR_MHPMCOUNTER15H)
> -DECLARE_CSR(mhpmcounter16h, CSR_MHPMCOUNTER16H)
> -DECLARE_CSR(mhpmcounter17h, CSR_MHPMCOUNTER17H)
> -DECLARE_CSR(mhpmcounter18h, CSR_MHPMCOUNTER18H)
> -DECLARE_CSR(mhpmcounter19h, CSR_MHPMCOUNTER19H)
> -DECLARE_CSR(mhpmcounter20h, CSR_MHPMCOUNTER20H)
> -DECLARE_CSR(mhpmcounter21h, CSR_MHPMCOUNTER21H)
> -DECLARE_CSR(mhpmcounter22h, CSR_MHPMCOUNTER22H)
> -DECLARE_CSR(mhpmcounter23h, CSR_MHPMCOUNTER23H)
> -DECLARE_CSR(mhpmcounter24h, CSR_MHPMCOUNTER24H)
> -DECLARE_CSR(mhpmcounter25h, CSR_MHPMCOUNTER25H)
> -DECLARE_CSR(mhpmcounter26h, CSR_MHPMCOUNTER26H)
> -DECLARE_CSR(mhpmcounter27h, CSR_MHPMCOUNTER27H)
> -DECLARE_CSR(mhpmcounter28h, CSR_MHPMCOUNTER28H)
> -DECLARE_CSR(mhpmcounter29h, CSR_MHPMCOUNTER29H)
> -DECLARE_CSR(mhpmcounter30h, CSR_MHPMCOUNTER30H)
> -DECLARE_CSR(mhpmcounter31h, CSR_MHPMCOUNTER31H)
> -#endif
> -#ifdef DECLARE_CAUSE
> -DECLARE_CAUSE("misaligned fetch", CAUSE_MISALIGNED_FETCH)
> -DECLARE_CAUSE("fetch access", CAUSE_FETCH_ACCESS)
> -DECLARE_CAUSE("illegal instruction", CAUSE_ILLEGAL_INSTRUCTION)
> -DECLARE_CAUSE("breakpoint", CAUSE_BREAKPOINT)
> -DECLARE_CAUSE("misaligned load", CAUSE_MISALIGNED_LOAD)
> -DECLARE_CAUSE("load access", CAUSE_LOAD_ACCESS)
> -DECLARE_CAUSE("misaligned store", CAUSE_MISALIGNED_STORE)
> -DECLARE_CAUSE("store access", CAUSE_STORE_ACCESS)
> -DECLARE_CAUSE("user_ecall", CAUSE_USER_ECALL)
> -DECLARE_CAUSE("supervisor_ecall", CAUSE_SUPERVISOR_ECALL)
> -DECLARE_CAUSE("hypervisor_ecall", CAUSE_HYPERVISOR_ECALL)
> -DECLARE_CAUSE("machine_ecall", CAUSE_MACHINE_ECALL)
> -DECLARE_CAUSE("fetch page fault", CAUSE_FETCH_PAGE_FAULT)
> -DECLARE_CAUSE("load page fault", CAUSE_LOAD_PAGE_FAULT)
> -DECLARE_CAUSE("store page fault", CAUSE_STORE_PAGE_FAULT)
> -#endif
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/riscv.h b/cpukit/score/cpu/riscv32/rtems/score/riscv.h
> deleted file mode 100644
> index 6e7f137..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/riscv.h
> +++ /dev/null
> @@ -1,66 +0,0 @@
> - * @file rtems/score/riscv.h
> - *  This file contains information pertaining to the riscv32 processor.
> - *  COPYRIGHT (c) 2014 Hesham Almatary <heshamelmatary at gmail.com>
> - *  Based on code with the following copyright...
> - *  COPYRIGHT (c) 1989-1999, 2010.
> - *  On-Line Applications Research Corporation (OAR).
> - * Redistribution and use in source and binary forms, with or without
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - *    notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - *    notice, this list of conditions and the following disclaimer in the
> - *    documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> - * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> - * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> - * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> - * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> - * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> - * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> - * SUCH DAMAGE.
> -#ifndef _RTEMS_SCORE_RISCV_H
> -#define _RTEMS_SCORE_RISCV_H
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - *  This file contains the information required to build
> - *  RTEMS for a particular member of the RISCV family.
> - *  It does this by setting variables to indicate which
> - *  implementation dependent features are present in a particular
> - *  member of the family.
> - *  This is a good place to list all the known CPU models
> - *  that this port supports and which RTEMS CPU model they correspond
> - *  to.
> -*  Define the name of the CPU family and specific model.
> -#define CPU_NAME "RISCV"
> -#define CPU_MODEL_NAME "RISCV"
> -#ifdef __cplusplus
> -#endif
> -#endif /* _RTEMS_SCORE_RISCV_H */
> diff --git a/cpukit/score/cpu/riscv32/rtems/score/types.h b/cpukit/score/cpu/riscv32/rtems/score/types.h
> index fe23b4f..0000000
> --- a/cpukit/score/cpu/riscv32/rtems/score/types.h
> +++ /dev/null
> @@ -1,70 +0,0 @@
> - * @file
> - * @brief riscv32 Architecture Types API
> - *  This include file contains type definitions pertaining to the
> - *  RISC-V processor family.
> - * are met:
> - * SUCH DAMAGE.
> -#ifndef _RTEMS_SCORE_TYPES_H
> -#define _RTEMS_SCORE_TYPES_H
> -#include <rtems/score/basedefs.h>
> -#ifndef ASM
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - * @addtogroup ScoreCPU
> - *  This section defines the basic types for this processor.
> -/** Type that can store a 32-bit integer or a pointer. */
> -typedef uintptr_t CPU_Uint32ptr;
> -typedef uint16_t Priority_bit_map_Word;
> -typedef void riscv_isr;
> -typedef void ( *riscv_isr_entry )( void );
> -#ifdef __cplusplus
> -#endif
> -#endif  /* !ASM */
> -#endif
> diff --git a/cpukit/score/cpu/riscv64 b/cpukit/score/cpu/riscv64
> new file mode 120000
> index 0000000..4847a64
> --- /dev/null
> +++ b/cpukit/score/cpu/riscv64
> @@ -0,0 +1 @@
> +riscv
> \ No newline at end of file
> 2.7.4
Hesham
