Failures with rtems-bsp-builder
Tue Oct 31 23:06:25 UTC 2017
On 01/11/2017 09:53, Joel Sherrill wrote:
> I replied privately accidentally. The build logs contained nothing interesting
> although my build scripts did spot that the csb360 BSP does not build. That
> seems to one of the failures that your builder is having trouble reporting.
> I put the full logs on dispatch if you want to look.
> Also ends with an exception.
> 716 posix-debug v850/v850sim build:
>       configure: /home/joel/rtems-work/rtems/configure\
>       --target=v850-rtems4.12 --enable-rtemsbsp=v850sim\
>       --prefix=/home/joel/rtems-work/bsps --enable-debug --enable-posix
> Traceback (most recent call last):
>   File "./rtems-tools/tester/rtems-bsp-builder", line 40, in <module>
>     rt.check.run()
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1604,
> in run
>     run_args(sys.argv)
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1551,
> in run_args
>     b.build_profiles(profiles)
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1408,
> in build_profiles
>     self.run_jobs(self.profile_jobs(profiles))
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1361,
> in run_jobs
>     self._finished()
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1311,
> in _finished
>     self._warnings_report()
>   File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line 1288,
> in _warnings_report
>     f.write(self.results.warnings_errors.report())
> AttributeError: warnings_errors instance has no attribute 'report'
> 165198.96user 40795.30system 19:02:32elapsed 300%CPU (0avgtext+0avgdata
> 683248maxresident)k
> 66392inputs+1138172352outputs (1major+23612840922minor)pagefaults 0swaps
>                                                              17706,1       Bot
Thanks. I am seeing this as well and will fix it today.
