[PATCH] Return invalid mode for !preempt and interrupt disable modes when SMP
Joel Sherrill
joel at rtems.org
Thu Oct 12 18:45:57 UTC 2017
This impacts rtems_task_mode() and rtems_task_create().
Closes #3000.
c-user/directive_status_codes.rst | 4 ++++
c-user/task_manager.rst | 8 ++++++++
2 files changed, 12 insertions(+)
diff --git a/c-user/directive_status_codes.rst b/c-user/directive_status_codes.rst
index 420a0a0..a08ad1d 100644
--- a/c-user/directive_status_codes.rst
+++ b/c-user/directive_status_codes.rst
@@ -75,6 +75,10 @@ The directives are:
- RTEMS inconsistency detected
* - ``RTEMS_NO_MEMORY``
- could not get enough memory
+ * - ``RTEMS_IO_ERROR``
+ - a driver error occurred
+ * - ``RTEMS_INVALID_MODE``
+ - attempted to set a task mode that is unavailable in SMP configurations
.. raw:: latex
diff --git a/c-user/task_manager.rst b/c-user/task_manager.rst
index 426a91f..e52ab74 100644
--- a/c-user/task_manager.rst
+++ b/c-user/task_manager.rst
@@ -618,6 +618,10 @@ DIRECTIVE STATUS CODES:
- ``id`` is NULL
* - ``RTEMS_INVALID_NAME``
- invalid task name
+ - non-preemption mode not available in SMP configurations
+ - interrupt disable portion of mode not available in SMP configurations
* - ``RTEMS_INVALID_PRIORITY``
- invalid task priority
* - ``RTEMS_MP_NOT_CONFIGURED``
@@ -1256,6 +1260,10 @@ DIRECTIVE STATUS CODES:
* - ``RTEMS_SUCCESSFUL``
- task mode set successfully
* - ``RTEMS_INVALID_ADDRESS``
- ``previous_mode_set`` is NULL
1.8.3.1
