Failures with rtems-bsp-builder
Tue Oct 31 22:53:20 UTC 2017
I replied privately accidentally. The build logs contained nothing
interesting
although my build scripts did spot that the csb360 BSP does not build. That
seems to one of the failures that your builder is having trouble reporting.
I put the full logs on dispatch if you want to look.
Also ends with an exception.
716 posix-debug v850/v850sim build:
      configure: /home/joel/rtems-work/rtems/configure\
      --target=v850-rtems4.12 --enable-rtemsbsp=v850sim\
      --prefix=/home/joel/rtems-work/bsps --enable-debug --enable-posix
Traceback (most recent call last):
  File "./rtems-tools/tester/rtems-bsp-builder", line 40, in <module>
    rt.check.run()
  File "/data/home/joel/rtems-work/rtems-tools/tester/rt/check.py", line
1604, in run
    run_args(sys.argv)
1551, in run_args
    b.build_profiles(profiles)
1408, in build_profiles
    self.run_jobs(self.profile_jobs(profiles))
1361, in run_jobs
    self._finished()
1311, in _finished
    self._warnings_report()
1288, in _warnings_report
    f.write(self.results.warnings_errors.report())
AttributeError: warnings_errors instance has no attribute 'report'
165198.96user 40795.30system 19:02:32elapsed 300%CPU (0avgtext+0avgdata
683248maxresident)k
66392inputs+1138172352outputs (1major+23612840922minor)pagefaults 0swaps
                                                             17706,1
 Bot
On Tue, Oct 31, 2017 at 4:58 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 31/10/2017 22:57, Joel Sherrill wrote:
> > I am seeing failures in the main output but nothing more detailed. I
> tried the
> > configurations I thought were failing by hand but they work.
> > Any ideas? Anyone else seeing this?
> Command line?
> Anything in the log file?
> > [   1/1565] arm/altcycv_devkit (debug)
>  Configuring
> > run: %s: arm/altcycv_devkit.debug\
> That is weird, there must be an extra '%' in the format string or Python
> will
> have told me off.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171031/f5bfdbe8/attachment-0002.html>
