[PATCH] Testsuite for inttypes methods.
Aditya Upadhyay
aadit0402 at gmail.com
Wed Sep 6 06:53:02 UTC 2017
testsuites/psxtests/psxinttypes01/Makefile.am | 22 +++++
testsuites/psxtests/psxinttypes01/init.c | 107 +++++++++++++++++++++
.../psxtests/psxinttypes01/psxinttypes01.scn | 11 +++
3 files changed, 140 insertions(+)
create mode 100644 testsuites/psxtests/psxinttypes01/Makefile.am
create mode 100644 testsuites/psxtests/psxinttypes01/init.c
create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
diff --git a/testsuites/psxtests/psxinttypes01/Makefile.am b/testsuites/psxtests/psxinttypes01/Makefile.am
new file mode 100644
index 0000000..90608d4
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes01
+psxinttypes01_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+#AM_CPPFLAGS = -I$(top_srcdir)/include
+#AM_CPPFLAGS = -I$(top_srcdir)/../support/include$(psxinttypes01_LDADD)
+LINK_OBJS = $(psxinttypes01_OBJECTS)
+LINK_LIBS = $(psxinttypes01_LDLIBS)
+psxinttypes01$(EXEEXT): $(psxinttypes01_OBJECTS) $(psxinttypes01_DEPENDENCIES)
+ @rm -f psxinttypes01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
index 0000000..43d49f6
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,107 @@
+ * This is the test for inttypes library. It covers these functions :
+ * imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/inttypes.h>
+#include <rtems/printer.h>
+#include <rtems/test.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
+#include <tmacros.h>
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "PSXINTTYPE 01";
+rtems_printer rtems_test_printer;
+ * RTEMS Startup Task
+rtems_task Init(
+ rtems_task_argument ignored
+ rtems_print_printer_printf(&rtems_test_printer);
+ rtems_test_begin();
+ char* endptr, *nptr;
+ uintmax_t j, k;
+ int base = 10;
+ wchar_t *nptr1, *endptr1;
+ intmax_t m, n;
+ nptr1 = L"10110134932";
+ nptr = "20690239864abc";
+ /* Test for wcstoimax */
+ m = wcstoimax(nptr1, &endptr1, base);
+ rtems_test_assert (m != 0);
+ rtems_test_assert (!(*endptr1));
+ printf( "wcstoimax = %jd\n", m );
+ /* test for strtoumax */
+ j = strtoumax (nptr, &endptr, base);
+ rtems_test_assert (j != 0);
+ rtems_test_assert (*endptr);
+ printf( "strtoumax = %ju ( base %d )\n", j, base );
+ printf( "Stopped scan at %s\n\n", endptr );
+ /*test for wcstoumax */
+ k = wcstoumax (nptr1, &endptr1, base);
+ rtems_test_assert (k != 0);
+ printf( "wcstoumax = %ju\n", k );
+ /*Test for imaxdiv */
+ imaxdiv_t retrival = imaxdiv ( 27, 4 );
+ printf( "imax div value = %jd\n", retrival.rem );
+ /*Test for imaxabs */
+ printf( "imaxabs_value = %jd\n", imaxabs (-1234));
+ /*Test for strtoimax */
+ n = strtoimax ("-123junk", &endptr, base);
+ rtems_test_assert (n != 0);
+ printf( "strtoimax value = %jd\n", n);
+ rtems_test_end();
+ exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000..79553be
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,11 @@
+*** BEGIN OF TEST PSXINTTYPES 01 ***
+wcstoimax = 10110134932
+strtoumax = 20690239864 ( base 10 )
+Stopped scan at abc
+wcstoumax = 10110134932
+imax div value = 3
+imaxabs_value = 1234
+strtoimax value = -123
+*** END OF TEST PSXINTTYPES 01 ***
2.7.4
