gdb 8.0.1 released
Jiri Gaisler jiri at gaisler.se
Fri Sep 8 13:48:22 UTC 2017
On 09/08/2017 03:41 PM, Sebastian Huber wrote:
> On 08/09/17 15:37, Jiri Gaisler wrote:
>> On 09/08/2017 02:12 PM, Sebastian Huber wrote:
>>> On 08/09/17 13:53, Sebastian Huber wrote:
>>>> Hello,
>>>> Jiri was so kind to update the SIS patches today. I moved the GDB
>>>> 7.12 targets to use GDB 8.0.1.
>>>> I test currently a build on FreeBSD.
>>> The build fails now on FreeBSD 11:
>>> https://devel.rtems.org/ticket/3123
>> Which version of FreeBSD do you use?
>> I compiled gdb-8.0 and 8.0.1 + sis patches on FreeBSD 11.1  without
>> problems:
>> [jiri at freebsd /usr/home/jiri/src/gdb/b801]$ uname -a
>> FreeBSD freebsd 11.1-RELEASE-p1 FreeBSD 11.1-RELEASE-p1 #0: Wed Aug  9
>> 11:55:48 UTC 2017
>> root at amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC   amd64
> [user at FreeBSDBuild ~]$ uname -a
> FreeBSD FreeBSDBuild 11.0-RELEASE-p1 FreeBSD 11.0-RELEASE-p1 #0
> r306420: Thu Sep 29 01:43:23 UTC 2016
> root at releng2.nyi.freebsd.org:/usr/obj/usr/src/sys/GENERIC  amd64
> Seems I have to update to 11.1.
I also noticed that compilation only works if I use gmake in a bash
shell. The standard make and shell breaks the build ...
