[PATCH] *** Covoar Windows Build Failure. ***
Cillian O'Donnell cpodonnell8 at gmail.com
Wed Sep 13 15:45:29 UTC 2017
*** The build is successfull if I run ./waf -v however the build fails on
a normal ./waf command as it can't link to -lelf
 4-mingw32/bin/ld.exe: cannot find -lelf
Has anyone seen this behaviour before were it only builds in verbose mode?***
Cillian O'Donnell (1):
  covoar: Add function defs to fix Windows build errors.
 tester/covoar/DesiredSymbols.cc | 2 +-
 tester/covoar/ReportsBase.cc    | 4 ++--
 tester/covoar/TraceConverter.cc | 4 ++++
 tester/covoar/covoar.cc         | 4 ++++
 4 files changed, 11 insertions(+), 3 deletions(-)
2.10.1
