[PATCH 17/18] libio: Unify readv() and writev()
Wed Sep 13 13:39:50 UTC 2017
Update #3082.
 cpukit/libcsupport/include/rtems/libio_.h | 22 ++++++++++++++++------
 cpukit/libcsupport/src/readv.c            | 27 +++++++++++++++++----------
 cpukit/libcsupport/src/writev.c           | 27 +++++++++++++++++----------
 3 files changed, 50 insertions(+), 26 deletions(-)
diff --git a/cpukit/libcsupport/include/rtems/libio_.h b/cpukit/libcsupport/include/rtems/libio_.h
index f29d6fa93d..0207a5c004 100644
--- a/cpukit/libcsupport/include/rtems/libio_.h
+++ b/cpukit/libcsupport/include/rtems/libio_.h
@@ -903,12 +903,19 @@ static inline bool rtems_filesystem_is_parent_directory(
   return tokenlen == 2 && token [0] == '.' && token [1] == '.';
-static inline ssize_t rtems_libio_iovec_eval(
-  int fd,
+typedef ssize_t ( *rtems_libio_iovec_adapter )(
+  rtems_libio_t      *iop,
   const struct iovec *iov,
-  int iovcnt,
-  uint32_t flags,
-  rtems_libio_t **iopp
+  int                 iovcnt,
+  ssize_t             total
+static inline ssize_t rtems_libio_iovec_eval(
+  int                        fd,
+  const struct iovec        *iov,
+  int                        iovcnt,
+  uint32_t                   flags,
+  rtems_libio_iovec_adapter  adapter
   ssize_t        total;
@@ -948,7 +955,10 @@ static inline ssize_t rtems_libio_iovec_eval(
   LIBIO_GET_IOP_WITH_ACCESS( fd, iop, flags, EBADF );
-  *iopp = iop;
+  if ( total > 0 ) {
+    total = ( *adapter )( iop, iov, iovcnt, total );
   return total;
diff --git a/cpukit/libcsupport/src/readv.c b/cpukit/libcsupport/src/readv.c
index 8c901cabe7..6d4f1b3cf1 100644
--- a/cpukit/libcsupport/src/readv.c
+++ b/cpukit/libcsupport/src/readv.c
@@ -22,6 +22,16 @@
 #include <rtems/libio_.h>
+static ssize_t readv_adapter(
+  int                 iovcnt,
+  ssize_t             total
+  return ( *iop->pathinfo.handlers->readv_h )( iop, iov, iovcnt, total );
  *  readv() - POSIX 1003.1 - Read a Vector
@@ -35,14 +45,11 @@ ssize_t readv(
   int                 iovcnt
-  ssize_t        total;
-  rtems_libio_t *iop;
-  total = rtems_libio_iovec_eval( fd, iov, iovcnt, LIBIO_FLAGS_READ, &iop );
-  if ( total > 0 ) {
-    total = ( *iop->pathinfo.handlers->readv_h )( iop, iov, iovcnt, total );
-  return total;
+  return rtems_libio_iovec_eval(
+    fd,
+    iov,
+    iovcnt,
+    LIBIO_FLAGS_READ,
+    readv_adapter
diff --git a/cpukit/libcsupport/src/writev.c b/cpukit/libcsupport/src/writev.c
index c5663293d2..ad3d8dcd75 100644
--- a/cpukit/libcsupport/src/writev.c
+++ b/cpukit/libcsupport/src/writev.c
@@ -21,20 +21,27 @@
+static ssize_t writev_adapter(
+  int                 iovcnt,
+  ssize_t             total
+  return ( *iop->pathinfo.handlers->writev_h )( iop, iov, iovcnt, total );
 ssize_t writev(
   int                 fd,
   int                 iovcnt
-  ssize_t        total;
-  total = rtems_libio_iovec_eval( fd, iov, iovcnt, LIBIO_FLAGS_WRITE, &iop );
-    total = ( *iop->pathinfo.handlers->writev_h )( iop, iov, iovcnt, total );
-  return total;
+    fd,
+    iov,
+    iovcnt,
+    LIBIO_FLAGS_WRITE,
+    writev_adapter
2.12.3
