[PATCH 13/18] libio: Add rtems_libio_iop_is_readable()
Wed Sep 13 13:39:46 UTC 2017
Update #3082.
 c/src/lib/libbsp/shared/console.c        |  4 ++--
 cpukit/libcsupport/include/rtems/libio.h | 10 ++++++++++
 cpukit/libnetworking/lib/ftpfs.c         |  2 +-
 3 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/shared/console.c b/c/src/lib/libbsp/shared/console.c
index fbeec253e6..6d287c8726 100644
--- a/c/src/lib/libbsp/shared/console.c
+++ b/c/src/lib/libbsp/shared/console.c
@@ -255,7 +255,7 @@ rtems_device_driver console_open(
-  if ( (args->iop->flags&LIBIO_FLAGS_READ) &&
+  if (rtems_libio_iop_is_readable(args->iop) &&
       cptr->pDeviceFlow &&
       cptr->pDeviceFlow->deviceStartRemoteTx) {
     cptr->pDeviceFlow->deviceStartRemoteTx(minor);
@@ -288,7 +288,7 @@ rtems_device_driver console_close(
    * Stop only if it's the last one opened.
   if ( (current_tty->refcount == 1) ) {
           cptr->pDeviceFlow->deviceStopRemoteTx) {
       cptr->pDeviceFlow->deviceStopRemoteTx(minor);
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 702ec352b9..7d85fb7af3 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1390,6 +1390,16 @@ static inline bool rtems_libio_iop_is_no_delay( const rtems_libio_t *iop )
+ * @brief Returns true if this is a readable iop, otherwise returns false.
+ * @param[in] iop The iop.
+static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
+  return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_READ ) != 0;
  * @name External I/O Handlers
diff --git a/cpukit/libnetworking/lib/ftpfs.c b/cpukit/libnetworking/lib/ftpfs.c
index 912ec82b39..deccddfa89 100644
--- a/cpukit/libnetworking/lib/ftpfs.c
+++ b/cpukit/libnetworking/lib/ftpfs.c
@@ -1037,7 +1037,7 @@ static int rtems_ftpfs_open(
   /* Check for either read-only or write-only flags */
   if (
     (iop->flags & LIBIO_FLAGS_WRITE) != 0
-      && (iop->flags & LIBIO_FLAGS_READ) != 0
+      && rtems_libio_iop_is_readable(iop)
     eno = ENOTSUP;
2.12.3
