IOP changes impact on IPV4 Stack
Joel Sherrill
joel at rtems.org
Fri Sep 15 13:12:10 UTC 2017
I haven't poured through the batch of email this morning. Are the changes
in this set?
Is there anywhere else this applies? Shared memory uses fds.
On Sep 15, 2017 8:02 AM, "Sebastian Huber" <
> Hello Joel,
> On 15/09/17 01:41, Joel Sherrill wrote:
>> Hi Sebastian
>> The IPV4 stack allocates IOPs and maps fds to sockets
>> in its implementation of system calls. Are these impacted
>> by the recent changes?
>> If so, you need to make sure to fix the handful of files
>> impacted.
> thanks for the reminder. Yes, I had to adjust a couple of things in the
> old and new network stack.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170915/8dfa9d4c/attachment.html>
