Self-contained POSIX synchronization objects for RTEMS 4.12?
Joel Sherrill
joel at rtems.org
Fri Sep 15 14:14:33 UTC 2017
On Fri, Sep 15, 2017 at 7:56 AM, Sebastian Huber <
> Hello,
> the next Newlib snapshot will introduce a 64-bit time_t which makes this
> tool chain ABI incompatible to all previous versions and forces a
> re-compilation of all object files (RTEMS, libraries, applications). This
> would be a good opportunity to also introduce the self-contained POSIX
> synchronization objects:
> https://devel.rtems.org/ticket/3112
> https://devel.rtems.org/ticket/3113
> https://devel.rtems.org/ticket/3114
> https://devel.rtems.org/ticket/3115
> https://devel.rtems.org/ticket/3116
> What do you think about this? Anyway we should make the RTEMS 4.12 branch
> with the next Newlib snapshot.
4.12 should have 64 bit time_t no questions about it.
I am ok with the self-contained POSIX objects going in.
But in general, we just need to work the open 4.12 tickets. There is
still a pile to work through or defer.
--joel
> Address : Dornierstr. 4
> <https://maps.google.com/?q=Dornierstr.+4&entry=gmail&source=g>, D-82178
> Puchheim, Germany
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170915/be876354/attachment-0001.html>
