BSD Howto Document name change?
Mon Sep 18 23:00:12 UTC 2017
On 19/09/2017 08:26, Joel Sherrill wrote:
> On Mon, Sep 18, 2017 at 4:57 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     Hi,
>     The BSP Howto's current name is:
>      RTEMS BSP and Device Driver Development Guide
>     This is long and causes problems in the PDF:
>      https://docs.rtems.org/branches/master/bsp-howto.pdf
>     <https://docs.rtems.org/branches/master/bsp-howto.pdf>
>     Most pages after page 4 show the problem.
>     Could the name be changed to something like:
>      RTEMS BSP and Driver Guide
> Sure.
Great.
> But I have problems with the POSIX 1003.1 Compliance Guide. ::)
> The PDF is named posix1003-1.pdf which looks enormously close
> to the name of what the standard itself would look like as a PDF.
> Any suggestion?
The file name and the document's internal name are different. The file name can
be anything, for example rtems-posix1003-gc.pdf or some variation. What is the
internal name (see conf.py in the docs directory)?
