[PATCH] RTEMS: Optimize pthread_once_t
Sebastian Huber
Tue Sep 19 13:09:12 UTC 2017
Reduce size of pthread_once_t and make it zero-initialized.
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
newlib/libc/sys/rtems/include/machine/_threads.h | 5 ++---
newlib/libc/sys/rtems/include/sys/_pthreadtypes.h | 8 ++++----
2 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/machine/_threads.h b/newlib/libc/sys/rtems/include/machine/_threads.h
index 24db21c0e..5faa78f46 100644
--- a/newlib/libc/sys/rtems/include/machine/_threads.h
+++ b/newlib/libc/sys/rtems/include/machine/_threads.h
@@ -41,12 +41,11 @@ typedef __uint32_t tss_t;
/* pthread_once_t */
typedef struct {
- int _is_initialized;
- int _init_executed;
+ unsigned char _flags;
} once_flag;
/* PTHREAD_ONCE_INIT */
-#define ONCE_FLAG_INIT { 1, 0 }
+#define ONCE_FLAG_INIT { 0 }
/* PTHREAD_DESTRUCTOR_ITERATIONS */
#define TSS_DTOR_ITERATIONS 4
diff --git a/newlib/libc/sys/rtems/include/sys/_pthreadtypes.h b/newlib/libc/sys/rtems/include/sys/_pthreadtypes.h
index bd66c689e..9db50fe44 100644
--- a/newlib/libc/sys/rtems/include/sys/_pthreadtypes.h
+++ b/newlib/libc/sys/rtems/include/sys/_pthreadtypes.h
@@ -169,11 +169,11 @@ typedef struct {
typedef __uint32_t pthread_key_t; /* thread-specific data keys */
typedef struct {
- int is_initialized; /* is this structure initialized? */
- int init_executed; /* has the initialization routine been run? */
-} pthread_once_t; /* dynamic package initialization */
+} pthread_once_t;
+#define _PTHREAD_ONCE_INIT { 0 }
-#define _PTHREAD_ONCE_INIT { 1, 0 } /* is initialized and not run */
#endif /* defined(_POSIX_THREADS) */
/* POSIX Barrier Types */
2.12.3
